[mapguide-commits] r5174 - trunk/MgDev/Common/Renderers
svn_mapguide at osgeo.org
Tue Sep 21 14:31:58 EDT 2010
Author: traianstanev
Date: 2010-09-21 18:31:58 +0000 (Tue, 21 Sep 2010)
New Revision: 5174
trunk/MgDev/Common/Renderers/FontManager.cpp
trunk/MgDev/Common/Renderers/FontManager.h
Fixes to my previous submission -- hopefully fix for the Linux build, and also set the sm_init variable to true after initialization. Turned out I was merging more than the expected changes to the code...
Modified: trunk/MgDev/Common/Renderers/FontManager.cpp
--- trunk/MgDev/Common/Renderers/FontManager.cpp 2010-09-21 18:04:09 UTC (rev 5173)
+++ trunk/MgDev/Common/Renderers/FontManager.cpp 2010-09-21 18:31:58 UTC (rev 5174)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2008 by Autodesk, Inc.
+// Copyright (C) 2004-2010 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -125,6 +125,8 @@
sm_manager.init_font_list();
+ sm_init = true;
return &sm_manager;
@@ -258,7 +260,9 @@
//are we searching for a specific font
if (!searchString.empty())
- wstring lowerFileName = ToLower(FindFileData.cFileName);
+ wstring wFilename;
+ UnicodeString::MultiByteToWideChar(entryName.c_str(), wFilename);
+ wstring lowerFileName = ToLower(wFilename);
if (!wcsstr(lowerFileName.c_str(), searchString.c_str()))
continue;
Modified: trunk/MgDev/Common/Renderers/FontManager.h
--- trunk/MgDev/Common/Renderers/FontManager.h 2010-09-21 18:04:09 UTC (rev 5173)
+++ trunk/MgDev/Common/Renderers/FontManager.h 2010-09-21 18:31:58 UTC (rev 5174)
@@ -1,5 +1,5 @@
More information about the mapguide-commits
