[mapguide-commits] r5186 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Thu Sep 23 23:43:12 EDT 2010
Author: waltweltonlair
Date: 2010-09-24 03:43:12 +0000 (Fri, 24 Sep 2010)
New Revision: 5186
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumDatum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumEllipsoid.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h
trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysUnitInformation.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.cpp
trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
trunk/MgDev/Common/CoordinateSystem/MentorDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h
trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
trunk/MgDev/Common/CoordinateSystem/MentorUtil.h
trunk/MgDev/Common/CoordinateSystem/namestruct.cpp
trunk/MgDev/Common/CoordinateSystem/namestruct.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
Some source files are missing blank lines at the end, which results in annoying warnings when building under Linux. Fix this.
Also removed silly "End of file" tags from end of files. Who needs tags like this to know where to find the end of a file?
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -3409,5 +3409,3 @@
size_t size=sizeof(m_csprm.csdef)+sizeof(UINT8);
return static_cast<UINT32>(size);
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -694,5 +694,3 @@
return SAFE_ADDREF(m_pCatalog.p);
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -372,4 +372,4 @@
return new T(this->catalog); //the callee has to incr. the ref counter, if it needs the catalog object
-#endif //BUILD_DICTIONARY_BASE
\ No newline at end of file
+#endif //BUILD_DICTIONARY_BASE
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -362,5 +362,3 @@
return pNew.Detach();
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -328,6 +328,3 @@
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -424,6 +424,3 @@
//And we're done! Return success.
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumDatum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumDatum.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumDatum.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -67,5 +67,3 @@
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumEllipsoid.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumEllipsoid.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumEllipsoid.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -67,5 +67,3 @@
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -267,5 +267,3 @@
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -1184,5 +1184,3 @@
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -122,4 +122,4 @@
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateX,double,this->geocentricTransformParams->translateX)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateY,double,this->geocentricTransformParams->translateY)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateZ,double,this->geocentricTransformParams->translateZ)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticAnalyticalTransformDefParams,TranslateZ,double,this->geocentricTransformParams->translateZ)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -81,4 +81,4 @@
} //namespace CSLibrary
-#endif //_CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
+#endif //_CCOORDSYSGEODETICANALYTICALTRANSFORMDEFPARAMS_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -185,4 +185,4 @@
ENSURE_NOT_NULL(target, L"CCoordinateSystemGeodeticInterpolationTransformDefParams.CopyTo");
memcpy(target, this->gridFileParams, sizeof(csGridFileXformParams));
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -59,4 +59,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
+#endif //_CCOORDINATESYSTEMGEODETICINTERPOLATIONTRANSFORMDEFPARAMS_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -130,4 +130,4 @@
DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientPhi,double,this->mulRegParams->coeffPhi,104)
DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientLambda,double,this->mulRegParams->coeffLambda,104)
-DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientHeight,double,this->mulRegParams->coeffHeight,104)
+DEFINE_GET_SET_NUMERIC_IDX(CCoordinateSystemGeodeticMultipleRegressionTransformDefParams,CoefficientHeight,double,this->mulRegParams->coeffHeight,104)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticMultipleRegressionTransformDefParams.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -98,4 +98,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
+#endif //_CCOORDINATESYSTEMGEODETICMULTIPLEREGRESSIONTRANSFORMDEFPARAMS_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -88,4 +88,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICPATH_H_
+#endif //_CCOORDINATESYSTEMGEODETICPATH_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -219,4 +219,4 @@
return this->m_pDictionary->GetCatalog();
-#include "CoordSysDictionaryBase.cpp"
+#include "CoordSysDictionaryBase.cpp"
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -103,4 +103,4 @@
DEFINE_GET_SET_STRING(CCoordinateSystemGeodeticPathElement,TransformName,this->pathElement->geodeticXformName)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPathElement,IsInversed,bool,this->pathElement->direction)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPathElement,IsInversed,bool,this->pathElement->direction)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPathElement.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -48,4 +48,4 @@
-#endif //_COORDSYSGEODETICPATHELEMENT_H_
+#endif //_COORDSYSGEODETICPATHELEMENT_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -351,4 +351,4 @@
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,MaxIterations,INT32,this->transformDefinition->maxIterations)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ConvergenceValue,double,this->transformDefinition->cnvrgValue)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,ErrorValue,double,this->transformDefinition->errorValue)
-DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,Accuracy,double,this->transformDefinition->accuracy)
+DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,Accuracy,double,this->transformDefinition->accuracy)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -104,4 +104,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
+#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEF_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -218,4 +218,4 @@
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefDictionary.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -78,4 +78,4 @@
} // namespace CSLibrary
-#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
+#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFDICTIONARY_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -35,4 +35,3 @@
return this->isProtected;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDefParams.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -37,4 +37,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
+#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMDEFPARAMS_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformGridFile.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -55,4 +55,4 @@
-#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
+#endif //_CCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILE_H
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGridGeneric.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -229,5 +229,3 @@
delete this;
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMacro.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -98,4 +98,4 @@
target[index] = propertyValue;\
-#endif //_MG_COORDSYSMACRO_H_
+#endif //_MG_COORDSYSMACRO_H_
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -1489,4 +1489,3 @@
return canDoPoles;
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -573,5 +573,3 @@
return str;
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysUnitInformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysUnitInformation.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysUnitInformation.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -312,5 +312,3 @@
assert(0);
return L"";
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysUtil.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -700,4 +700,3 @@
throw new MgNotImplementedException(L"GetAvailableMemory", __LINE__, __WFILE__, NULL, L"", NULL);
#endif
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/CriticalSection.h
--- trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/CriticalSection.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -134,4 +134,4 @@
bool m_bEntered;
-#endif
+#endif //CRITICALSECTION_H_
Modified: trunk/MgDev/Common/CoordinateSystem/MentorDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/MentorDictionary.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/MentorDictionary.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -191,5 +191,3 @@
MG_CATCH_AND_THROW(kpMethodName)
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h
--- trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/MentorDictionary.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -359,5 +359,3 @@
#endif //MG_MENTORDICTIONARY_H
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp
--- trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/MentorUtil.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -1680,5 +1680,3 @@
MG_THROW()
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/MentorUtil.h
--- trunk/MgDev/Common/CoordinateSystem/MentorUtil.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/MentorUtil.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -369,6 +369,3 @@
//refer to the class MgCoordinateSystemProjectionParameterType for the values
#endif //MG_MENTORUTIL_H
-//End of file.
Modified: trunk/MgDev/Common/CoordinateSystem/namestruct.cpp
--- trunk/MgDev/Common/CoordinateSystem/namestruct.cpp 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/namestruct.cpp 2010-09-24 03:43:12 UTC (rev 5186)
@@ -120,4 +120,4 @@
TNameStruct::Name() const
return this->name;
Modified: trunk/MgDev/Common/CoordinateSystem/namestruct.h
--- trunk/MgDev/Common/CoordinateSystem/namestruct.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/CoordinateSystem/namestruct.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -129,6 +129,3 @@
typedef std::list<CCategoryName> CCategoryNameList;
#endif //MG_NAMESTRUCT_H
-//End of file.
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -52,4 +52,4 @@
-#endif
+#endif //_MGCOORDINATESYSTEMGEODETICPATHELEMENT_H_
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h 2010-09-24 03:35:43 UTC (rev 5185)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h 2010-09-24 03:43:12 UTC (rev 5186)
@@ -41,4 +41,4 @@
-#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
+#endif //_MGCOORDINATESYSTEMGEODETICTRANSFORMGRIDFILEFORMAT_H_
More information about the mapguide-commits
