[mapguide-commits] r5187 - in trunk/MgDev/Common: CoordinateSystem
Geometry Geometry/Buffer Geometry/Parse
MapGuideCommon/Services MapGuideCommon/System MdfModel
MdfParser PlatformBase/MapLayer PlatformBase/Services
Renderers Stylization
svn_mapguide at osgeo.org
Fri Sep 24 01:09:45 EDT 2010
Author: waltweltonlair
Date: 2010-09-24 05:09:44 +0000 (Fri, 24 Sep 2010)
New Revision: 5187
trunk/MgDev/Common/CoordinateSystem/ArbitraryCoordsys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp
trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp
trunk/MgDev/Common/Geometry/Buffer/MgBuffer.h
trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp
trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp
trunk/MgDev/Common/Geometry/CoordinateCollection.h
trunk/MgDev/Common/Geometry/Parse/StringUtility.cpp
trunk/MgDev/Common/MapGuideCommon/Services/FeatureInformation.h
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp
trunk/MgDev/Common/MdfModel/AreaRule.cpp
trunk/MgDev/Common/MdfModel/AreaSymbolization2D.cpp
trunk/MgDev/Common/MdfModel/CompositeRule.cpp
trunk/MgDev/Common/MdfModel/Label.cpp
trunk/MgDev/Common/MdfModel/LineSymbolization2D.cpp
trunk/MgDev/Common/MdfModel/LineUsage.cpp
trunk/MgDev/Common/MdfModel/MarkSymbol.cpp
trunk/MgDev/Common/MdfModel/MdfOwnerCollection.h
trunk/MgDev/Common/MdfModel/Override.cpp
trunk/MgDev/Common/MdfModel/PointRule.cpp
trunk/MgDev/Common/MdfModel/PointSymbolization2D.cpp
trunk/MgDev/Common/MdfModel/Rule.cpp
trunk/MgDev/Common/MdfModel/SimpleSymbol.cpp
trunk/MgDev/Common/MdfModel/SimpleSymbolDefinition.cpp
trunk/MgDev/Common/MdfModel/SymbolInstance.cpp
trunk/MgDev/Common/MdfModel/Text.cpp
trunk/MgDev/Common/MdfModel/VectorScaleRange.cpp
trunk/MgDev/Common/MdfParser/FSDSAX2Parser.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
trunk/MgDev/Common/PlatformBase/Services/FeatureAggregateOptions.h
trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
trunk/MgDev/Common/PlatformBase/Services/GeometryProperty.cpp
trunk/MgDev/Common/Renderers/DWFRenderer.cpp
trunk/MgDev/Common/Renderers/EMapRenderer.cpp
trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
trunk/MgDev/Common/Renderers/GDRenderer.cpp
trunk/MgDev/Common/Renderers/KmlRenderer.cpp
trunk/MgDev/Common/Renderers/RS_ByteData.cpp
trunk/MgDev/Common/Stylization/Band.cpp
trunk/MgDev/Common/Stylization/BandData.cpp
trunk/MgDev/Common/Stylization/DataValueStack.h
trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
trunk/MgDev/Common/Stylization/GridData.cpp
trunk/MgDev/Common/Stylization/GridThemeParser.cpp
trunk/MgDev/Common/Stylization/LabelRenderer.cpp
trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
trunk/MgDev/Common/Stylization/RS_FontEngine.cpp
trunk/MgDev/Common/Stylization/RasterAdapter.cpp
trunk/MgDev/Common/Stylization/RichTextEngine.cpp
trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
trunk/MgDev/Common/Stylization/atom.h
trunk/MgDev/Common/Stylization/atom_element_style.cpp
trunk/MgDev/Common/Stylization/mtext_parser.cpp
Minor cleanup...
Change code like the following:
if (pointer)
delete pointer;
to just:
delete pointer;
Calling delete with null is safe.
Modified: trunk/MgDev/Common/CoordinateSystem/ArbitraryCoordsys.cpp
--- trunk/MgDev/Common/CoordinateSystem/ArbitraryCoordsys.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/CoordinateSystem/ArbitraryCoordsys.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -529,7 +529,7 @@
- if(szComponent) delete [] szComponent;
+ delete [] szComponent;
return bOK;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDatum.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -254,7 +254,7 @@
strncpy(m_DtDef.key_nm, pStr, cs_KEYNM_MAX);
//Free the converted string
- delete [] pStr;
+ delete[] pStr;
//And we're done!
MG_CATCH_AND_THROW(L"MgCoordinateSystemDatum.SetDtCode")
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumInteger32.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -57,11 +57,9 @@
throw new MgNullArgumentException(L"MgCoordinateSystemEnumInteger32.SetList", __LINE__, __WFILE__, NULL, L"", NULL);
- if (m_pnValues)
- delete [] m_pnValues;
- m_pnValues = NULL;
+ delete [] m_pnValues;
+ m_pnValues = NULL;
m_ulPos = 0;
m_ulSize = 0;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -315,18 +315,9 @@
//the dictionary we will fail because it is protected
//in the dictionary file
pCsFromDict->SetProtectMode(false);
- if (pswCsName)
- delete[] pswCsName;
- if (pswDtName)
- delete[] pswDtName;
- if (pswElName)
- delete[] pswElName;
+ delete[] pswCsName;
+ delete[] pswDtName;
+ delete[] pswElName;
delete[] pszWkt;
@@ -343,19 +334,11 @@
//text information parameters
pEFromDict->Release();
- if (pswCsName)
- if (pswDtName)
- if (pswElName)
//creates the coordsys defintion
//don't ask the function to load the datum from the catalog, we'll set it later
pCsDef=BuildInterfaceFromCsDef(csDef, NULL);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformation.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -386,8 +386,7 @@
MG_CATCH(L"CCoordinateSystemGeodeticTransformation.SetupFromTransformationDef")
- if (NULL != transformName)
- delete[] transformName;
+ delete[] transformName;
MG_THROW()
Modified: trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp
--- trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Buffer/GreatCircleBufferUtil.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -174,10 +174,7 @@
void GreatCircleBufferUtil::InitPolyObject()
- if (m_pfBufferVerts != NULL)
- delete [] m_pfBufferVerts;
+ delete [] m_pfBufferVerts;
// allocate the buffer used by CreateConvexOffsetChains() - note that the
// buffer is given an "overrun" area at the end - this helps simplify the
Modified: trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp
--- trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Buffer/MgBuffer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -254,12 +254,9 @@
else
delete bufferPolygon;
- if (bufferUtil != NULL)
- delete bufferUtil;
+ delete bufferUtil;
+ delete borderWalker;
- if (borderWalker)
- delete borderWalker;
return;
@@ -311,12 +308,9 @@
else
- if (borderWalker)
return;
@@ -378,12 +372,9 @@
else
- if (borderWalker)
return;
@@ -461,11 +452,8 @@
else
- if (borderWalker)
return;
@@ -542,12 +530,9 @@
else
- if (borderWalker)
if (topoError)
throw new PlaneSweepException(PlaneSweepException::TopologicalError);
@@ -627,11 +612,8 @@
else
- if (borderWalker)
return;
@@ -719,11 +701,8 @@
else
- if (borderWalker)
return;
Modified: trunk/MgDev/Common/Geometry/Buffer/MgBuffer.h
--- trunk/MgDev/Common/Geometry/Buffer/MgBuffer.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Buffer/MgBuffer.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -44,10 +44,8 @@
~BufferParams()
- if (progressCallback != NULL)
- delete progressCallback;
- if (transform != NULL)
- delete transform;
+ delete progressCallback;
+ delete transform;
ProgressCallback* progressCallback;
Modified: trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp
--- trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Buffer/bufrutil.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -110,10 +110,7 @@
BufferUtility::~BufferUtility()
} // end: destructor
@@ -188,10 +185,7 @@
void BufferUtility::InitPointLine()
// allocate a buffer used to generate point/line segment buffers
@@ -222,10 +216,7 @@
void BufferUtility::InitPolyObject()
Modified: trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp
--- trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -332,10 +332,6 @@
void PlaneSweep::DoPlaneSweep(ProgressCallback &callback,
OrientedPolyPolygon &outputPolygon)
// check if there is anything to do
if (m_nEdgesAdded == 0)
@@ -353,7 +349,6 @@
if (callback.IsCanceled())
return;
// initialize pointers to data structures
EventIntervalArray *eventIntArray = NULL;
@@ -495,12 +490,6 @@
callback.AdvanceOneSubInterval();
// clean up data structures that are no longer required, and the
// progress interval for the sweep part
@@ -541,21 +530,12 @@
MG_THROW()
delete intersectList;
// extract the output poly-polygon from the graph of WingedEdges
if (!callback.IsCanceled())
try
GetOutputPolygon(callback, outputPolygon);
@@ -566,14 +546,8 @@
callback.EndProgressInterval();
throw(ex);
// end the progress interval started above
@@ -680,7 +654,8 @@
void PlaneSweep::AddEdge(OpsDoublePoint *vertices[2])
- if (*vertices[0] != *vertices[1]) {
+ if (*vertices[0] != *vertices[1])
WingedEdge *wEdge = m_wingedEdgeAlloc->Allocate(vertices);
m_tupleArray->AddSweepTuples(m_sweepEdgeAlloc->Allocate(wEdge));
m_nEdgesAdded++;
@@ -735,7 +710,8 @@
double ordinate;
SweepEdge *edge2 = xOrdTree->Below(edge);
- while (edge2 != NULL) {
+ while (edge2 != NULL)
ordinate = edge2->Ordinate(x);
if (y != ordinate)
break;
@@ -746,7 +722,8 @@
// walk up the X-Order looking for intersecting edges
edge2 = xOrdTree->Above(edge);
if (y != ordinate)
break;
@@ -795,12 +772,10 @@
OpsDoublePoint *intersectPt = edge1->MinVert();
if ( !intersectList->Add(*intersectPt, edge1->GetWingedEdge(),
edge2->GetWingedEdge()))
return;
// if the edges have the same slope, and the start point of edge1 is not
// the end point of edge2 then the two edges overlap - add the appropriate
// edge endpoint to the intersection list
@@ -1279,10 +1254,6 @@
void PlaneSweep::GetOutputPolygon(ProgressCallback &callback,
// open boundary traversal trace file if necessary (debug mode only)
#if defined _DEBUG
@@ -1318,13 +1289,6 @@
(float)wEdge->m_vert[1]->x, (float)wEdge->m_vert[1]->y);
MgDumpFFGF::closeFile(ffgfFile);
#endif
for (int i = 0; i < totalEdges; i++) {
@@ -1394,12 +1358,6 @@
#endif
// if no points in the output polygon and no cancelation was signalled,
// then some sort of topological error must have occurred - throw a Plane-
// SweepException to indicate the error
@@ -1477,9 +1435,6 @@
::fprintf(boundaryTraversalTraceFile, "id: %d - already visited\n", wEdge->m_id);
#endif
abandonBoundary = TRUE;
break;
@@ -1509,7 +1464,6 @@
} while ( wEdge != startEdge || side != startSide);
// if no interior edges were encountered, then close the boundary and
// call internal AcceptBoundary() method to determine whether or not to
// accept the boundary
@@ -1674,11 +1628,13 @@
void PlaneSweep::ResizeBoundaryArray()
- if (m_nBoundaryVertices + 1 > m_boundaryArraySize) {
+ if (m_nBoundaryVertices + 1 > m_boundaryArraySize)
size_t newSize = m_boundaryArraySize + BoundaryArraySize;
OpsFloatPoint *tmp = new OpsFloatPoint[newSize];
- if (m_nBoundaryVertices > 0) {
+ if (m_nBoundaryVertices > 0)
size_t nBytesToCopy = m_nBoundaryVertices * sizeof(OpsFloatPoint);
::memcpy(tmp, m_boundaryVertices, nBytesToCopy);
@@ -1915,7 +1871,6 @@
if (yCross[0] == HUGE_VAL || yCross[1] == HUGE_VAL)
return FALSE;
Modified: trunk/MgDev/Common/Geometry/CoordinateCollection.h
--- trunk/MgDev/Common/Geometry/CoordinateCollection.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/CoordinateCollection.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -316,7 +316,10 @@
virtual void ToAwkt(REFSTRING awktStr, REFSTRING coordDim, bool is2dOnly);
protected:
- void Dispose() { delete this; }
+ void Dispose()
+ delete this;
private:
Modified: trunk/MgDev/Common/Geometry/Parse/StringUtility.cpp
--- trunk/MgDev/Common/Geometry/Parse/StringUtility.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Geometry/Parse/StringUtility.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -25,8 +25,7 @@
void GisStringUtility::ClearString(wchar_t*& psz)
- if (psz != NULL)
- delete [] psz;
+ delete [] psz;
psz = NULL;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/FeatureInformation.h
--- trunk/MgDev/Common/MapGuideCommon/Services/FeatureInformation.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MapGuideCommon/Services/FeatureInformation.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -178,7 +178,10 @@
/// Dispose the object
- virtual void Dispose() { delete this; }
+ virtual void Dispose()
+ delete this;
private:
Ptr<MgSelection> m_selection;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -55,14 +55,12 @@
assert( 0 == this->GetRefCount() );
- if (NULL != m_lastUsed)
- delete m_lastUsed;
- if (NULL != m_serverConnImp)
- delete m_serverConnImp;
+ delete m_lastUsed;
m_lastUsed = NULL;
+ delete m_serverConnImp;
m_serverConnImp = NULL;
m_stack = NULL;
@@ -195,7 +193,7 @@
/// </returns>
void MgServerConnection::Dispose()
- delete this;
+ delete this;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -57,11 +57,9 @@
ConnectionPool::iterator iter = pool.begin();
while (iter != pool.end())
- if (NULL != iter->second)
- delete iter->second;
- iter->second = NULL;
+ delete iter->second;
+ iter->second = NULL;
iter++;
@@ -116,10 +114,9 @@
ACE_MT (ACE_GUARD (ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance ()));
MG_TRY()
- if (MgServerConnectionPool::sm_pool != NULL)
- delete MgServerConnectionPool::sm_pool;
- MgServerConnectionPool::sm_pool = NULL;
+ delete MgServerConnectionPool::sm_pool;
+ MgServerConnectionPool::sm_pool = NULL;
MG_CATCH_AND_RELEASE()
Modified: trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MapGuideCommon/System/UserInformation.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -338,13 +338,19 @@
/// </summary>
/// <returns> Nothing
/// </returns>
-void MgUserInformation::Dispose() { delete this; }
+void MgUserInformation::Dispose()
+ delete this;
/// <summary>
/// Returns the classId.
/// </summary>
-INT32 MgUserInformation::GetClassId() { return m_cls_id; }
+INT32 MgUserInformation::GetClassId()
+ return m_cls_id;
MgByteReader* MgUserInformation::GetReader()
Modified: trunk/MgDev/Common/MdfModel/AreaRule.cpp
--- trunk/MgDev/Common/MdfModel/AreaRule.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/AreaRule.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -39,8 +39,7 @@
AreaRule::~AreaRule()
- if (this->m_Symbolization != NULL)
- delete this->m_Symbolization;
+ delete this->m_Symbolization;
@@ -67,8 +66,7 @@
if (this->m_Symbolization != pflAdoptedSymbolization)
this->m_Symbolization = pflAdoptedSymbolization;
Modified: trunk/MgDev/Common/MdfModel/AreaSymbolization2D.cpp
--- trunk/MgDev/Common/MdfModel/AreaSymbolization2D.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/AreaSymbolization2D.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -72,8 +72,7 @@
if (this->m_pflFill != pflAdoptedFill)
- if (this->m_pflFill != NULL)
- delete this->m_pflFill;
+ delete this->m_pflFill;
this->m_pflFill = pflAdoptedFill;
@@ -120,8 +119,7 @@
if (this->m_pstkEdge != pstkAdoptedEdge)
- if (this->m_pstkEdge != NULL)
- delete this->m_pstkEdge;
+ delete this->m_pstkEdge;
this->m_pstkEdge = pstkAdoptedEdge;
Modified: trunk/MgDev/Common/MdfModel/CompositeRule.cpp
--- trunk/MgDev/Common/MdfModel/CompositeRule.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/CompositeRule.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -40,8 +40,7 @@
CompositeRule::~CompositeRule()
- if (this->m_pSymbolization != NULL)
- delete this->m_pSymbolization;
+ delete this->m_pSymbolization;
@@ -68,8 +67,7 @@
if (this->m_pSymbolization != compositeSymbolization)
this->m_pSymbolization = compositeSymbolization;
Modified: trunk/MgDev/Common/MdfModel/Label.cpp
--- trunk/MgDev/Common/MdfModel/Label.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/Label.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -39,8 +39,7 @@
Label::~Label()
- if (this->m_Symbol != NULL)
- delete this->m_Symbol;
+ delete this->m_Symbol;
@@ -67,8 +66,7 @@
if (this->m_Symbol != pflAdoptedSymbol)
this->m_Symbol = pflAdoptedSymbol;
Modified: trunk/MgDev/Common/MdfModel/LineSymbolization2D.cpp
--- trunk/MgDev/Common/MdfModel/LineSymbolization2D.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/LineSymbolization2D.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -70,8 +70,7 @@
if (this->m_pstkStroke != pstkAdoptedStroke)
- if (this->m_pstkStroke != NULL)
- delete this->m_pstkStroke;
+ delete this->m_pstkStroke;
this->m_pstkStroke = pstkAdoptedStroke;
Modified: trunk/MgDev/Common/MdfModel/LineUsage.cpp
--- trunk/MgDev/Common/MdfModel/LineUsage.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/LineUsage.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -64,8 +64,7 @@
LineUsage::~LineUsage()
- if (this->m_pDefaultPath != NULL)
- delete this->m_pDefaultPath;
+ delete this->m_pDefaultPath;
@@ -265,8 +264,7 @@
if (this->m_pDefaultPath != defaultPath)
this->m_pDefaultPath = defaultPath;
Modified: trunk/MgDev/Common/MdfModel/MarkSymbol.cpp
--- trunk/MgDev/Common/MdfModel/MarkSymbol.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/MarkSymbol.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -95,8 +95,7 @@
@@ -143,8 +142,7 @@
Modified: trunk/MgDev/Common/MdfModel/MdfOwnerCollection.h
--- trunk/MgDev/Common/MdfModel/MdfOwnerCollection.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/MdfOwnerCollection.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -51,10 +51,8 @@
// delete all members
for(int i = 0; i < m_nSize; i++)
- if (m_objArray[i] != NULL) //redundant check.
- delete m_objArray[i];
+ delete m_objArray[i];
// delete allocated memory
delete[] m_objArray;
Modified: trunk/MgDev/Common/MdfModel/Override.cpp
--- trunk/MgDev/Common/MdfModel/Override.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/Override.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -45,8 +45,7 @@
Override::~Override()
- if (this->m_pThemeLabel != NULL)
- delete this->m_pThemeLabel;
+ delete this->m_pThemeLabel;
@@ -120,8 +119,7 @@
if (this->m_pThemeLabel != themeLabel)
this->m_pThemeLabel = themeLabel;
Modified: trunk/MgDev/Common/MdfModel/PointRule.cpp
--- trunk/MgDev/Common/MdfModel/PointRule.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/PointRule.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -40,8 +40,7 @@
PointRule::~PointRule()
@@ -68,8 +67,7 @@
Modified: trunk/MgDev/Common/MdfModel/PointSymbolization2D.cpp
--- trunk/MgDev/Common/MdfModel/PointSymbolization2D.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/PointSymbolization2D.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -76,8 +76,7 @@
if (this->m_psymSymbol != psymAdoptedSymbol)
- if (this->m_psymSymbol != NULL)
- delete this->m_psymSymbol;
+ delete this->m_psymSymbol;
this->m_psymSymbol = psymAdoptedSymbol;
Modified: trunk/MgDev/Common/MdfModel/Rule.cpp
--- trunk/MgDev/Common/MdfModel/Rule.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/Rule.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -124,8 +124,7 @@
if (this->m_pLabel != pLabel)
- if (this->m_pLabel != NULL)
- delete this->m_pLabel;
+ delete this->m_pLabel;
this->m_pLabel = pLabel;
Modified: trunk/MgDev/Common/MdfModel/SimpleSymbol.cpp
--- trunk/MgDev/Common/MdfModel/SimpleSymbol.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/SimpleSymbol.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -44,8 +44,7 @@
SimpleSymbol::~SimpleSymbol()
- if (this->m_pSymbolDefinition != NULL)
- delete this->m_pSymbolDefinition;
+ delete this->m_pSymbolDefinition;
@@ -65,8 +64,7 @@
if (this->m_pSymbolDefinition != symbolDefinition)
this->m_pSymbolDefinition = symbolDefinition;
// Definition and Reference are mutually exclusive. Setting one
@@ -107,11 +105,8 @@
// clears the other.
- this->m_pSymbolDefinition = NULL;
+ this->m_pSymbolDefinition = NULL;
Modified: trunk/MgDev/Common/MdfModel/SimpleSymbolDefinition.cpp
--- trunk/MgDev/Common/MdfModel/SimpleSymbolDefinition.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/SimpleSymbolDefinition.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -42,14 +42,10 @@
SimpleSymbolDefinition::~SimpleSymbolDefinition()
- if (this->m_pResizeBox != NULL)
- delete this->m_pResizeBox;
- if (this->m_pPointUsage != NULL)
- delete this->m_pPointUsage;
- if (this->m_pLineUsage != NULL)
- delete this->m_pLineUsage;
- if (this->m_pAreaUsage != NULL)
- delete this->m_pAreaUsage;
+ delete this->m_pResizeBox;
+ delete this->m_pPointUsage;
+ delete this->m_pLineUsage;
+ delete this->m_pAreaUsage;
@@ -78,8 +74,7 @@
if (this->m_pResizeBox != resizeBox)
this->m_pResizeBox = resizeBox;
@@ -112,8 +107,7 @@
if (this->m_pPointUsage != pointUsage)
this->m_pPointUsage = pointUsage;
@@ -146,8 +140,7 @@
if (this->m_pLineUsage != lineUsage)
this->m_pLineUsage = lineUsage;
@@ -180,8 +173,7 @@
if (this->m_pAreaUsage != areaUsage)
this->m_pAreaUsage = areaUsage;
Modified: trunk/MgDev/Common/MdfModel/SymbolInstance.cpp
--- trunk/MgDev/Common/MdfModel/SymbolInstance.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/SymbolInstance.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -60,8 +60,7 @@
SymbolInstance::~SymbolInstance()
@@ -85,11 +84,8 @@
@@ -109,8 +105,7 @@
Modified: trunk/MgDev/Common/MdfModel/Text.cpp
--- trunk/MgDev/Common/MdfModel/Text.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/Text.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -76,8 +76,7 @@
Text::~Text()
- if (this->m_pFrame != NULL)
- delete this->m_pFrame;
+ delete this->m_pFrame;
@@ -457,8 +456,7 @@
if (this->m_pFrame != frame)
this->m_pFrame = frame;
Modified: trunk/MgDev/Common/MdfModel/VectorScaleRange.cpp
--- trunk/MgDev/Common/MdfModel/VectorScaleRange.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfModel/VectorScaleRange.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -51,8 +51,7 @@
VectorScaleRange::~VectorScaleRange()
- if (this->m_elevationSettings != NULL)
- delete this->m_elevationSettings;
+ delete this->m_elevationSettings;
@@ -136,8 +135,7 @@
if (this->m_elevationSettings != elevationSettings)
this->m_elevationSettings = elevationSettings;
Modified: trunk/MgDev/Common/MdfParser/FSDSAX2Parser.cpp
--- trunk/MgDev/Common/MdfParser/FSDSAX2Parser.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/MdfParser/FSDSAX2Parser.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -38,12 +38,9 @@
FSDSAX2Parser::~FSDSAX2Parser()
- if (m_handlerStack != NULL)
- delete m_handlerStack;
- if (m_parser != NULL)
- delete m_parser;
- if (m_featureSource)
- delete m_featureSource;
+ delete m_handlerStack;
+ delete m_parser;
+ delete m_featureSource;
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -68,11 +68,8 @@
m_selections.clear();
- if (m_stream != NULL)
- delete m_stream;
- m_stream = NULL;
+ delete m_stream;
+ m_stream = NULL;
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureAggregateOptions.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureAggregateOptions.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureAggregateOptions.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -194,9 +194,16 @@
virtual void Serialize(MgStream* stream);
virtual void Deserialize(MgStream* stream);
- virtual INT32 GetClassId() { return m_cls_id; }
+ virtual INT32 GetClassId()
+ return m_cls_id;
+ delete this;
private:
bool m_selectDistinct; // Apply Distinct operator
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -507,9 +507,16 @@
STRING GetLogString();
+ return m_cls_id;
+ delete this;
void ValidateEmptyArgument(CREFSTRING value);
private:
Modified: trunk/MgDev/Common/PlatformBase/Services/GeometryProperty.cpp
--- trunk/MgDev/Common/PlatformBase/Services/GeometryProperty.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/PlatformBase/Services/GeometryProperty.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -99,7 +99,10 @@
/// <summary>
/// Self destructing method
/// </summary>
- void MgGeometryProperty::Dispose() { delete this; }
+ void MgGeometryProperty::Dispose()
+ delete this;
/// <summary>
Modified: trunk/MgDev/Common/Renderers/DWFRenderer.cpp
--- trunk/MgDev/Common/Renderers/DWFRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/DWFRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -260,24 +260,16 @@
DWFRenderer::~DWFRenderer()
- if (m_wtPointBuffer)
- delete[] m_wtPointBuffer;
+ delete[] m_wtPointBuffer;
+ delete m_hatchFac;
+ delete m_fillFac;
+ delete m_obsMesh;
- if (m_hatchFac)
- delete m_hatchFac;
- if (m_fillFac)
- delete m_fillFac;
- if (m_obsMesh)
- delete m_obsMesh; //should not get here
delete (NodeTable*)m_hObjNodes;
// could be non-NULL if an exception was raised before this was
// added to the attribute resources collection
- if (m_attributes)
- delete m_attributes;
+ delete m_attributes;
@@ -369,11 +361,8 @@
m_lLayoutStreams.clear();
m_lLayoutLabelStreams.clear();
- if (m_obsMesh)
- delete m_obsMesh;
- m_obsMesh = NULL;
+ delete m_obsMesh;
+ m_obsMesh = NULL;
// clear the map info
m_mapInfo = NULL;
@@ -397,11 +386,8 @@
- if (m_attributes)
- m_attributes = NULL;
+ m_attributes = NULL;
m_attributes = DWFCORE_ALLOC_OBJECT(DWFObjectDefinitionResource(
DWFXML::kzElement_PageObjectDefinition,
@@ -838,8 +824,7 @@
IncrementDrawableCount();
- if (NULL != aggcxt)
- delete aggcxt;
+ delete aggcxt;
Modified: trunk/MgDev/Common/Renderers/EMapRenderer.cpp
--- trunk/MgDev/Common/Renderers/EMapRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/EMapRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -53,6 +53,7 @@
delete m_uuid;
void EMapRenderer::StartMap(RS_MapUIInfo* mapInfo,
RS_Bounds& extents,
double mapScale,
Modified: trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
--- trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -73,9 +73,7 @@
delete m_uuid;
- if (m_dwfPackageWriter)
- delete m_dwfPackageWriter;
+ delete m_dwfPackageWriter;
m_dwfPackageWriter = NULL;
Modified: trunk/MgDev/Common/Renderers/GDRenderer.cpp
--- trunk/MgDev/Common/Renderers/GDRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/GDRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -157,11 +157,8 @@
if (m_imsym)
gdImageDestroy((gdImagePtr)m_imsym);
- delete [] m_wtPointBuffer;
+ delete [] m_wtPointBuffer;
delete m_labeler;
delete m_polyrasterizer;
Modified: trunk/MgDev/Common/Renderers/KmlRenderer.cpp
--- trunk/MgDev/Common/Renderers/KmlRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/KmlRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -508,20 +508,15 @@
void KmlRenderer::ClearStyles()
- if (m_styleContent != NULL)
- delete m_styleContent;
- m_styleContent = NULL;
+ delete m_styleContent;
+ m_styleContent = NULL;
void KmlRenderer::WriteStyle(RS_FillStyle& fill)
if (m_styleContent == NULL)
m_styleContent = new KmlContent();
char buffer[256];
int thisStyleId = 0;
Modified: trunk/MgDev/Common/Renderers/RS_ByteData.cpp
--- trunk/MgDev/Common/Renderers/RS_ByteData.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Renderers/RS_ByteData.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -43,8 +43,7 @@
RS_ByteData::~RS_ByteData()
- if (m_bytes)
- delete [] m_bytes;
+ delete [] m_bytes;
Modified: trunk/MgDev/Common/Stylization/Band.cpp
--- trunk/MgDev/Common/Stylization/Band.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/Band.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -68,10 +68,7 @@
Band::~Band()
- if (m_pBandData)
- delete m_pBandData;
+ delete m_pBandData;
Modified: trunk/MgDev/Common/Stylization/BandData.cpp
--- trunk/MgDev/Common/Stylization/BandData.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/BandData.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -286,10 +286,7 @@
BitBandData::~BitBandData()
- if (m_pData)
- delete[] m_pData;
+ delete[] m_pData;
@@ -303,10 +300,7 @@
ByteBandData::~ByteBandData()
- if (m_pData)
- delete[] m_pData;
+ delete[] m_pData;
Modified: trunk/MgDev/Common/Stylization/DataValueStack.h
--- trunk/MgDev/Common/Stylization/DataValueStack.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/DataValueStack.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -32,8 +32,7 @@
//note this destructor will not call
//the individual element destructors
- if (m_data)
- delete [] m_data;
+ delete [] m_data;
inline void push(T* dv)
Modified: trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
--- trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -463,10 +463,8 @@
void DefaultStylizer::SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer)
GeometryAdapter* old = (GeometryAdapter*)m_hGeomStylizers[type];
+ delete old;
- if (old)
- delete old;
m_hGeomStylizers[type] = stylizer;
@@ -534,9 +532,6 @@
m_hGeomStylizers.clear();
- if (m_pRasterAdapter)
- delete m_pRasterAdapter;
- m_pRasterAdapter = NULL;
+ delete m_pRasterAdapter;
+ m_pRasterAdapter = NULL;
Modified: trunk/MgDev/Common/Stylization/GridData.cpp
--- trunk/MgDev/Common/Stylization/GridData.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/GridData.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -107,30 +107,18 @@
itr != m_BandVector.end();
++itr)
- if (*itr)
- delete *itr;
- *itr = NULL;
+ delete *itr;
+ *itr = NULL;
- if (NULL != m_pColorBand)
- delete m_pColorBand;
- m_pColorBand = NULL;
+ delete m_pColorBand;
+ m_pColorBand = NULL;
- if (NULL != m_pDrapedColorBand)
- delete m_pDrapedColorBand;
- m_pDrapedColorBand = NULL;
+ delete m_pDrapedColorBand;
+ m_pDrapedColorBand = NULL;
- if (NULL != m_pStylizedBand)
- delete m_pStylizedBand;
- m_pStylizedBand = NULL;
+ delete m_pStylizedBand;
+ m_pStylizedBand = NULL;
@@ -139,9 +127,7 @@
Band* pBand = new Band(dataType, this);
if (NULL == pBand)
return NULL;
pBand->SetName(name.c_str());
Modified: trunk/MgDev/Common/Stylization/GridThemeParser.cpp
--- trunk/MgDev/Common/Stylization/GridThemeParser.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/GridThemeParser.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -236,16 +236,11 @@
catch (std::exception &)
- if (pTheme)
- delete pTheme;
- pTheme = NULL;
- if (pBucket)
- delete pBucket;
- pBucket = NULL;
+ delete pTheme;
+ pTheme = NULL;
+ delete pBucket;
+ pBucket = NULL;
return pTheme;
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -55,19 +55,13 @@
LabelInfo& info = group.m_labels[j];
- if (info.m_pts)
- delete [] info.m_pts;
- info.m_pts = NULL;
- info.m_numpts = 0;
+ delete [] info.m_pts;
+ info.m_pts = NULL;
+ info.m_numpts = 0;
// the style was cloned when it was passed to the LabelRenderer
- if (info.m_sestyle)
- delete info.m_sestyle;
- info.m_sestyle = NULL;
+ delete info.m_sestyle;
+ info.m_sestyle = NULL;
@@ -253,19 +247,13 @@
- if (info.m_pts)
group.m_labels.clear();
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -56,25 +56,16 @@
LabelInfoLocal& info = group.m_labels[j];
- if (info.m_rotated_points)
- delete [] info.m_rotated_points;
- info.m_rotated_points = NULL;
+ delete [] info.m_rotated_points;
+ info.m_rotated_points = NULL;
- if (info.m_pts)
@@ -407,19 +398,13 @@
// at this point there shouldn't yet be any rotated points
_ASSERT(info.m_rotated_points == NULL);
- if (info.m_pts)
@@ -502,19 +487,13 @@
// the original label infos should still not have any rotated points
- if (info.m_pts)
group.m_labels = repeated_infos;
@@ -831,11 +810,8 @@
_ASSERT(info.m_pts == NULL);
Modified: trunk/MgDev/Common/Stylization/RS_FontEngine.cpp
--- trunk/MgDev/Common/Stylization/RS_FontEngine.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/RS_FontEngine.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -797,8 +797,7 @@
- if (pRichTextEngine)
- delete pRichTextEngine;
+ delete pRichTextEngine;
Modified: trunk/MgDev/Common/Stylization/RasterAdapter.cpp
--- trunk/MgDev/Common/Stylization/RasterAdapter.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/RasterAdapter.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -195,8 +195,7 @@
RS_InputStream* pal = raster->GetPalette();
DecodeMapped(reader, pal, dst, imgW, imgH);
- if (pal)
- delete pal;
+ delete pal;
break;
case 1:
Modified: trunk/MgDev/Common/Stylization/RichTextEngine.cpp
--- trunk/MgDev/Common/Stylization/RichTextEngine.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/RichTextEngine.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -43,11 +43,8 @@
delete pNext;
- if ( this->m_pHeadBlock )
- delete this->m_pHeadBlock;
- if ( this->m_pCurrLine )
- delete this->m_pCurrLine;
+ delete this->m_pHeadBlock;
+ delete this->m_pCurrLine;
@@ -1137,8 +1134,7 @@
size_t numComponents = this->m_components.size();
for ( size_t i=0; i<numComponents; ++i )
- if ( m_components[i] )
- delete this->m_components[i];
+ delete this->m_components[i];
void AtomBaseComponentCollection::AddComponent( AtomBaseComponent* pComponent )
Modified: trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp
--- trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/SE_StyleVisitor.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -467,11 +467,8 @@
void SE_StyleVisitor::VisitPath(Path& path)
- if (m_primitive)
- delete m_primitive;
- m_primitive = NULL;
+ delete m_primitive;
+ m_primitive = NULL;
SE_Color fillColor;
ParseColorExpression(path.GetFillColor(), fillColor, 0);
@@ -532,11 +529,8 @@
void SE_StyleVisitor::VisitImage(Image& image)
- if (m_primitive)
SE_Raster* primitive = new SE_Raster();
m_primitive = primitive;
@@ -609,11 +603,8 @@
void SE_StyleVisitor::VisitText(Text& text)
- if (m_primitive)
SE_Text* primitive = new SE_Text();
Modified: trunk/MgDev/Common/Stylization/atom.h
--- trunk/MgDev/Common/Stylization/atom.h 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/atom.h 2010-09-24 05:09:44 UTC (rev 5187)
@@ -2122,10 +2122,8 @@
~RangeCapabilityParticle()
- if(m_pMin)
- delete(m_pMin);
- if(m_pMax)
- delete(m_pMax);
+ delete(m_pMin);
+ delete(m_pMax);
Particle* Clone() const
Modified: trunk/MgDev/Common/Stylization/atom_element_style.cpp
--- trunk/MgDev/Common/Stylization/atom_element_style.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/atom_element_style.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -71,7 +71,8 @@
ATOM::Status StyleDescriptionElement::RemoveFromDescription(const ATOM::StyleParticle::StyleParticleType eType)
ATOM::StyleParticle* pGone = RemoveFromList(m_pDescription,eType);
- if(pGone != NULL) {
+ if(pGone != NULL)
delete(pGone);
return ATOM::Status::keOk;
@@ -88,7 +89,6 @@
/* Style Particle List Tools */
// Finds (the first) particle in a list (or set)
@@ -180,7 +180,8 @@
void StyleChangeElement::Reset()
// Kill the deltas.
- while(m_pDeltas) {
+ while(m_pDeltas)
ATOM::StyleParticle* p = m_pDeltas;
m_pDeltas = const_cast<ATOM::StyleParticle*>(p->Next());
delete(p);
Modified: trunk/MgDev/Common/Stylization/mtext_parser.cpp
--- trunk/MgDev/Common/Stylization/mtext_parser.cpp 2010-09-24 03:43:12 UTC (rev 5186)
+++ trunk/MgDev/Common/Stylization/mtext_parser.cpp 2010-09-24 05:09:44 UTC (rev 5187)
@@ -1892,12 +1892,12 @@
// Takes a pointer to an existing parser and destroys it.
ATOM::Status MTextGenerator::Destroy(ATOM::ISink* pOldSink)
- if(pOldSink == NULL)
+ if (pOldSink == NULL)
return ATOM::Status::keInvalidArg;
// TO DO ... validate that it's one of ours?
- delete(pOldSink);
+ delete pOldSink;
More information about the mapguide-commits
