[mapguide-commits] r5188 - in trunk/MgDev/Common/Foundation: Data
System
svn_mapguide at osgeo.org
Fri Sep 24 01:10:37 EDT 2010
Author: waltweltonlair
Date: 2010-09-24 05:10:37 +0000 (Fri, 24 Sep 2010)
New Revision: 5188
trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp
trunk/MgDev/Common/Foundation/System/StreamReader.cpp
trunk/MgDev/Common/Foundation/System/XmlUtil.cpp
Minor cleanup...
Change code like the following:
if (pointer)
delete pointer;
to just:
delete pointer;
Calling delete with null is safe.
Modified: trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp
--- trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp 2010-09-24 05:09:44 UTC (rev 5187)
+++ trunk/MgDev/Common/Foundation/Data/NamedCollection.cpp 2010-09-24 05:10:37 UTC (rev 5188)
@@ -59,11 +59,8 @@
/// </summary>
MgNamedCollection::~MgNamedCollection()
- if (m_pNameMap)
- delete m_pNameMap;
- m_pNameMap = NULL;
+ delete m_pNameMap;
+ m_pNameMap = NULL;
@@ -263,11 +260,8 @@
void MgNamedCollection::Clear()
// Clear the map
- if (m_pNameMap)
// Clear the list
m_dCollection->Clear();
Modified: trunk/MgDev/Common/Foundation/System/StreamReader.cpp
--- trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2010-09-24 05:09:44 UTC (rev 5187)
+++ trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2010-09-24 05:10:37 UTC (rev 5188)
@@ -440,11 +440,7 @@
if (len > allocLen)
- if (NULL != temp)
- delete [] temp;
+ delete [] temp;
temp = new char[len];
allocLen = len;
@@ -487,10 +483,7 @@
MG_CATCH(L"MgStreamReader.GetStream")
- if (NULL != temp)
- delete [] temp;
+ delete [] temp;
MG_THROW()
Modified: trunk/MgDev/Common/Foundation/System/XmlUtil.cpp
--- trunk/MgDev/Common/Foundation/System/XmlUtil.cpp 2010-09-24 05:09:44 UTC (rev 5187)
+++ trunk/MgDev/Common/Foundation/System/XmlUtil.cpp 2010-09-24 05:10:37 UTC (rev 5188)
@@ -87,24 +87,16 @@
MgXmlUtil::~MgXmlUtil()
- if (NULL != m_parser)
- delete m_parser;
- m_parser = NULL;
+ delete m_parser;
+ m_parser = NULL;
- if (NULL != m_bis)
- delete m_bis;
- m_bis = NULL;
+ delete m_bis;
+ m_bis = NULL;
if (NULL != m_doc)
if (m_ownDomDoc)
m_doc->release();
m_doc = NULL;
More information about the mapguide-commits
