[mapguide-commits] r5194 - trunk/Installer/Support/Web/x86/Apache2
svn_mapguide at osgeo.org
Mon Sep 27 08:52:07 EDT 2010
Author: jng
Date: 2010-09-27 12:52:07 +0000 (Mon, 27 Sep 2010)
New Revision: 5194
Removed:
trunk/Installer/Support/Web/x86/Apache2/README-win32.txt
My previous submission shifted some file offsets. Rather than update the wix file, let's just get rid of the cause of this shift.
Deleted: trunk/Installer/Support/Web/x86/Apache2/README-win32.txt
--- trunk/Installer/Support/Web/x86/Apache2/README-win32.txt 2010-09-27 11:29:48 UTC (rev 5193)
+++ trunk/Installer/Support/Web/x86/Apache2/README-win32.txt 2010-09-27 12:52:07 UTC (rev 5194)
@@ -1,55 +0,0 @@
-New version of APR
-Note that the included APR is now version 1.3, which adds several
-subtle changes in the behavior of file handling, pipes and process
-creation. Most importantly, there is finer control over the handles
-inherited by processes, so the mod_fastcgi or mod_fcgid modules must
-be updated for httpd-2.2.9 to run correctly on Windows.
-Most other third party modules are unaffected by this change.
-Connecting to databases
-Five SQL driver connectors (dbd) are provided in the binary distribution,
-for MySQL, SQLite3, PostgreSQL, Oracle and ODBC. Two keyed database
-connectors are provided, SDBM and Oracle Berkeley DB. All but SDBM will
-require you to install the corresponding client driver libraries.
-The sqlitedll.zip binary (containing sqlite3.dll) can be obtained from
- http://www.sqlite.org/download.html
-note that this binary was built with version 3.6.16 (earlier and later
-version 3.6 driver .dll's may work.) The lib binding is created using
-LIB /DEF:sqlite3.def and using the .h files from the _amalgamation zip.
-The Oracle Instant Client - Basic driver can be obtained from
- http://www.oracle.com/technology/software/tech/oci/instantclient/htdocs/winsoft.html
-and note that this binary was built against version 11.1.0.6.0,
-other version 11.1 drivers may work.
-The PostgreSQL client binaries may be obtained from
- http://www.postgresql.org/ftp/binary/v8.3.1/win32/
-and note that this binary was built against version 8.3.1-1, and
-again it may work with other 8.1 version .dll's.
-The MySQL client binaries ("Essentials" is sufficient) is obtained from
- http://dev.mysql.com/downloads/mysql/5.1.html#win32
-but note that once using the MySQL database, the applicable exception
-clause demands copy-left terms on the resulting combination.
-The Oracle Berkeley DB binaries may be obtained from
- http://www.oracle.com/technology/software/products/berkeley-db/index.html
-but note that once using the Berkeley DB code, the Oracle license
-demands copy-left terms on the resulting combination.
-NOTE: For whichever database backend(s) you configure, the corresponding
-driver .dll's must be in your PATH to test from console mode, and in the
-systemwide path if used for a service such as Apache httpd.
-The FreeTDS driver is not built on Windows, since the Microsoft ODBC is
-provided instead. The sqlite2 and ndbm drivers are not used on Windows,
-as there is no point in legacy support of these old versions. The ASF
-does not distribute binary builds of the gdbm binding.
More information about the mapguide-commits
