[mapguide-commits] r5195 - trunk/Installer/Custom/apache_actions
svn_mapguide at osgeo.org
Mon Sep 27 11:16:04 EDT 2010
Author: jng
Date: 2010-09-27 15:16:04 +0000 (Mon, 27 Sep 2010)
New Revision: 5195
trunk/Installer/Custom/apache_actions/apache_actions.cpp
Add a whole bunch of MessageBox calls for debugging purposes.
Long story short: Don't try to run the internal msi on Windows 7 without explicit UAC elevation. For some reason, running the msi (via msiexec) and then hitting Install (w/ the UAC icon) does not grant the apache custom action within sufficient privileges to modify the httpd.conf which will be under Program Files (a no-go zone for unprivileged file access under UAC) most of the time
Modified: trunk/Installer/Custom/apache_actions/apache_actions.cpp
--- trunk/Installer/Custom/apache_actions/apache_actions.cpp 2010-09-27 12:52:07 UTC (rev 5194)
+++ trunk/Installer/Custom/apache_actions/apache_actions.cpp 2010-09-27 15:16:04 UTC (rev 5195)
@@ -331,12 +331,17 @@
if( FileExists(szFile) )
- //::MessageBoxW(NULL, L"File found", L"Test", MB_OK);
+ //::MessageBoxW(NULL, L"httpd.conf found", L"Test", MB_OK);
// Opening the file to read and write.
CFile cfInFile(szFile, CFile::modeRead);
DWORD dwFileLen = cfInFile.GetLength();
+ //CHAR msg[20];
+ //sprintf(msg, "Length: %d", dwFileLen);
+ //::MessageBox(NULL, msg, "Test", MB_OK);
// Read the entire contents of the file.
char *szBuff = new char[dwFileLen + 1];
@@ -344,6 +349,7 @@
szBuff[dwFileLen] = '\0'; // Add ending null to buffer.
cfInFile.Close();
+ //::MessageBoxW(NULL, L"read httpd.conf contents", L"Test", MB_OK);
// Creating a CString object to store the contents and help
// us to add the desired configuration.
@@ -355,40 +361,56 @@
strcpy(szReplace, szWebDir);
csBuff.Replace(szFind,szReplace);
+ //::MessageBox(NULL, TEXT("Replace MG_WEB_ROOT"), TEXT("Test"), MB_OK);
// Replace %MG_WEB_PORT%
strcpy(szFind,"%MG_WEB_PORT%");
strcpy(szReplace, szServerPort);
+ //::MessageBox(NULL, TEXT("Replace MG_WEB_PORT"), TEXT("Test"), MB_OK);
// Replace %MG_WEB_PHP%
strcpy(szFind,"%MG_WEB_PHP%");
strcpy(szReplace, szPhpDir);
+ //::MessageBox(NULL, TEXT("Replace MG_WEB_PHP"), TEXT("Test"), MB_OK);
// Replace %MG_WEB_APACHE%
strcpy(szFind,"%MG_WEB_APACHE%");
strcpy(szReplace, szApacheDir);
csBuff.Replace(szFind, szReplace);
+ //::MessageBox(NULL, TEXT("Replace MG_WEB_APACHE"), TEXT("Test"), MB_OK);
// Replace %MG_VIRTUAL_DIR%
strcpy(szFind, "%MG_VIRTUAL_DIR%");
strcpy(szReplace, szVirtualDir);
+ //::MessageBox(NULL, TEXT("Replace MG_VIRTUAL_DIR"), TEXT("Test"), MB_OK);
// If java, then include the tomcat configuration
strcpy(szFind, "%MG_INCLUDE_TOMCAT%");
csBuff.Replace(szFind, bJava ? "Include conf/tomcat.conf" : "#Uncomment to enable the Java API\n#Include conf/tomcat.conf");
+ //::MessageBox(NULL, TEXT("Set Tomcat"), TEXT("Test"), MB_OK);
// Toggle PHP API section
strcpy(szFind, "%MG_PHP_API%");
strcpy(szReplace, bJava ? "#" : "");
+ //::MessageBox(NULL, TEXT("Toggle PHP API"), TEXT("Test"), MB_OK);
// Toggle Java API section
strcpy(szFind, "%MG_JAVA_API%");
strcpy(szReplace, bJava ? "" : "#");
+ //::MessageBox(NULL, TEXT("Toggle Java API"), TEXT("Test"), MB_OK);
CFile cfOutFile(szFile, CFile::modeWrite);
// Write and modify the contents.
@@ -398,6 +420,8 @@
cfOutFile.Write(csBuff, dwNewLength);
cfOutFile.SetLength(dwNewLength);
cfOutFile.Close();
+ //::MessageBoxW(NULL, L"httpd.conf updated", L"Test", MB_OK);
//Check if the tomcat.conf file was included in httpd.conf, if so we need to do placeholder substitution there too.
@@ -406,6 +430,8 @@
if(FileExists(szFile))
+ //::MessageBoxW(NULL, L"tomcat.conf found", L"Test", MB_OK);
More information about the mapguide-commits
