[mapguide-commits] r5199 - in sandbox/maestro-3.0:
Maestro.Base/Commands/SiteExplorer Maestro.Base/Commands/Test
MaestroAPITests OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/Resource
svn_mapguide at osgeo.org
Tue Sep 28 05:26:53 EDT 2010
Author: jng
Date: 2010-09-28 09:26:53 +0000 (Tue, 28 Sep 2010)
New Revision: 5199
Added:
sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs
sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs
sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs
Implement #1448 for the 3.0 sandbox:
- Implement equality APIs (Equals() and GetHashCode()) for ValidationIssue
- Add a ValidationResultSet class that does the weeding out of redundant issues.
- Add some unit tests to verify issue uniqueness
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -121,7 +121,7 @@
worker.ReportProgress(0);
- var issues = new List<ValidationIssue>();
+ var set = new ValidationResultSet();
int i = 0;
foreach (string s in documents)
@@ -132,18 +132,18 @@
//TODO: This will validate resources multiple times, if they are referenced by
//resources inside the folder
item = _conn.ResourceService.GetResource(s);
- issues.AddRange(ResourceValidatorSet.Validate(item, true));
+ set.AddIssues(ResourceValidatorSet.Validate(item, true));
catch (Exception ex)
string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
- issues.Add(new ValidationIssue(item, ValidationStatus.Error, string.Format(Properties.Resources.ValidationResourceLoadFailed, msg)));
+ set.AddIssue(new ValidationIssue(item, ValidationStatus.Error, string.Format(Properties.Resources.ValidationResourceLoadFailed, msg)));
i++;
worker.ReportProgress((int)((i / (double)documents.Count) * 100), s);
- return issues.ToArray();
+ return set.GetAllIssues();
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/Test/SelectFdoProviderCommand.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -36,7 +36,7 @@
var conn = mgr.GetConnection(exp.ConnectionName);
var providers = conn.FeatureService.FeatureProviders;
- var provider = GenericItemSelectionDialog.SelectItem("Select FDO provider", "Select an FDO provider", providers, "DisplayName", "Name");
+ var provider = GenericItemSelectionDialog.SelectItem("Select FDO provider", "Select an FDO provider", providers, "DisplayName", "Name"); //LOCALIZEME
if (provider != null)
MessageService.ShowMessage(provider.DisplayName);
Modified: sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/MaestroAPITests/HttpConnectionTests.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -60,17 +60,28 @@
var props = isvc.GetCustomPropertyNames();
Assert.IsNotNull(props);
- Assert.AreEqual(props.Length, 1);
+ Assert.AreEqual(props.Length, 2);
Assert.IsTrue(Array.IndexOf<string>(props, "UserAgent") >= 0);
+ Assert.IsTrue(Array.IndexOf<string>(props, "BaseUrl") >= 0);
//It is of type string
var type = isvc.GetCustomPropertyType("UserAgent");
Assert.AreEqual(type, typeof(string));
+ type = isvc.GetCustomPropertyType("BaseUrl");
+ Assert.AreEqual(type, typeof(string));
//We can set and get it
isvc.SetCustomProperty("UserAgent", "MapGuide Maestro API Unit Test Fixture");
var agent = (string)isvc.GetCustomProperty("UserAgent");
Assert.AreEqual(agent, "MapGuide Maestro API Unit Test Fixture");
+ //BaseUrl is read-only
+ try
+ isvc.SetCustomProperty("BaseUrl", "http://mylocalhost/mapguide");
+ Assert.Fail("Should've thrown exception");
+ catch { }
[Test]
Modified: sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
--- sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-09-28 09:26:53 UTC (rev 5199)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.21022</ProductVersion>
+ <ProductVersion>9.0.30729</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{351D49A3-2E4A-4EC3-AFC2-D56598F44F51}</ProjectGuid>
<OutputType>Library</OutputType>
@@ -57,6 +57,7 @@
<Compile Include="ResourceTests.cs" />
<Compile Include="RuntimeMapTests.cs" />
<Compile Include="SerializationTests.cs" />
+ <Compile Include="ValidationTests.cs" />
</ItemGroup>
<ItemGroup>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Http\OSGeo.MapGuide.MaestroAPI.Http.csproj">
Added: sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs (rev 0)
+++ sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -0,0 +1,82 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using NUnit.Framework;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using NMock2;
+namespace MaestroAPITests
+ [TestFixture]
+ public class ValidationTests
+ [Test]
+ public void TestUniqueIssues()
+ //Test for the purposes of equality and hashing that any two issues with
+ //the same set of resource id, status and message are identical.
+ var mocks = new Mockery();
+ var res1 = mocks.NewMock<IResource>();
+ Expect.AtLeastOnce.On(res1).GetProperty("ResourceID").Will(Return.Value("Library://Test.FeatureSource"));
+ var res2 = mocks.NewMock<IResource>();
+ Expect.AtLeastOnce.On(res2).GetProperty("ResourceID").Will(Return.Value("Library://Test.FeatureSource"));
+ var res3 = mocks.NewMock<IResource>();
+ Expect.AtLeastOnce.On(res3).GetProperty("ResourceID").Will(Return.Value("Library://Test.FeatureSource"));
+ var msg1 = new ValidationIssue(res1, ValidationStatus.Error, "Epic Fail");
+ var msg2 = new ValidationIssue(res2, ValidationStatus.Error, "Epic Fail");
+ var msg3 = new ValidationIssue(res3, ValidationStatus.Error, "Not so epic fail");
+ Assert.AreEqual(msg1.GetHashCode(), msg2.GetHashCode());
+ Assert.IsTrue(msg1.Equals(msg2));
+ Assert.AreNotEqual(msg1.GetHashCode(), msg3.GetHashCode());
+ Assert.AreNotEqual(msg2.GetHashCode(), msg3.GetHashCode());
+ Assert.IsFalse(msg1.Equals(msg3));
+ Assert.IsFalse(msg2.Equals(msg3));
+ [Test]
+ public void TestValidationResultSet()
+ set.AddIssues(new ValidationIssue[] { msg1, msg2, msg3 });
+ var totalIssues = set.GetAllIssues();
+ Assert.AreEqual(totalIssues.Length, 2);
+ Assert.AreEqual(set.ResourceIDs.Length, 1);
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Check.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -0,0 +1,40 @@
+#endregion
+using System;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI
+ public static class Check
+ public static void NotNull<T>(T obj, string arg) where T : class
+ if (obj == null)
+ throw new ArgumentNullException(arg);
+ public static void NotEmpty(string msg, string arg)
+ if (string.IsNullOrEmpty(msg))
+ throw new ArgumentException("Empty value", arg); //LOCALIZEME
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-09-28 09:26:53 UTC (rev 5199)
@@ -160,6 +160,7 @@
</Compile>
<Compile Include="BindingListExtensions.cs" />
<Compile Include="Capability\ConnectionCapabilities.cs" />
+ <Compile Include="Check.cs" />
<Compile Include="Commands\CommandType.cs" />
<Compile Include="Commands\ExecuteLoadProcedure.cs" />
<Compile Include="Commands\GetCapabilities.cs" />
@@ -220,6 +221,7 @@
<Compile Include="Resource\ResourceTypeDescriptor.cs" />
<Compile Include="Resource\ResourceContentVersionChecker.cs" />
<Compile Include="Resource\ResourceValidatorSet.cs" />
+ <Compile Include="Resource\ValidationResultSet.cs" />
<Compile Include="Serialization\Enums.cs" />
<Compile Include="Serialization\IBinarySerializeable.cs" />
<Compile Include="Serialization\MgBinaryDeserializer.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -37,6 +37,9 @@
public ValidationIssue(IResource res, ValidationStatus stat, string msg)
+ Check.NotNull(res, "res");
+ Check.NotEmpty(msg, "msg");
this.Resource = res;
this.Status = stat;
this.Message = msg;
@@ -56,6 +59,34 @@
/// Gets the resource this issue pertains to
/// </summary>
public IResource Resource { get; private set; }
+ public override bool Equals(object obj)
+ if (obj == null)
+ return false;
+ if (!typeof(ValidationIssue).IsAssignableFrom(obj.GetType()))
+ return false;
+ ValidationIssue vi = (ValidationIssue)obj;
+ return this.Resource.ResourceID.Equals(vi.Resource.ResourceID) &&
+ this.Message.Equals(vi.Message) &&
+ this.Status == vi.Status;
+ public override int GetHashCode()
+ //http://stackoverflow.com/questions/263400/what-is-the-best-algorithm-for-an-overridden-systemobjectgethashcode
+ unchecked
+ int hash = 17;
+ hash = hash * 23 + this.Resource.ResourceID.GetHashCode();
+ hash = hash * 23 + this.Message.GetHashCode();
+ hash = hash * 23 + this.Status.GetHashCode();
+ return hash;
/// <summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs 2010-09-28 08:20:48 UTC (rev 5198)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -49,10 +49,11 @@
public static ValidationIssue[] Validate(IResource item, bool recurse)
+ var issueSet = new ValidationResultSet();
List<ValidationIssue> issues = new List<ValidationIssue>();
if (!HasValidator(item.ResourceType, item.ResourceVersion))
- issues.Add(new ValidationIssue(item, ValidationStatus.Warning, string.Format(Properties.Resources.ERR_NO_REGISTERED_VALIDATOR, item.ResourceType, item.ResourceVersion)));
+ issueSet.AddIssue(new ValidationIssue(item, ValidationStatus.Warning, string.Format(Properties.Resources.ERR_NO_REGISTERED_VALIDATOR, item.ResourceType, item.ResourceVersion)));
else
@@ -62,7 +63,7 @@
ValidationIssue[] tmp = v.Validate(item, recurse);
if (tmp != null)
- issues.AddRange(tmp);
+ issueSet.AddIssues(tmp);
@@ -71,7 +72,7 @@
+ return issueSet.GetAllIssues();
public static bool HasValidator(ResourceTypes resourceTypes, Version version)
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs 2010-09-28 09:26:53 UTC (rev 5199)
@@ -0,0 +1,85 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+namespace OSGeo.MapGuide.MaestroAPI.Resource
+ /// <summary>
+ /// A "bucket" class that filters out redundant validation messages
+ /// </summary>
+ public class ValidationResultSet
+ //HACK: Abusing the Key component of Dictionary<K, V> because there is no
+ //Set collection in .net fx 2.0!
+ private Dictionary<string, Dictionary<ValidationIssue, ValidationIssue>> _issues;
+ public ValidationResultSet()
+ _issues = new Dictionary<string, Dictionary<ValidationIssue, ValidationIssue>>();
+ public ValidationResultSet(List<ValidationIssue> issues) : this()
+ Check.NotNull(issues, "issues");
+ AddIssues(issues);
+ public string[] ResourceIDs
+ get { return new List<string>(_issues.Keys).ToArray(); }
+ public ICollection<ValidationIssue> GetIssuesForResource(string resourceId)
+ return _issues[resourceId].Keys;
+ public ValidationIssue[] GetAllIssues()
+ var issues = new List<ValidationIssue>();
+ foreach (string resId in _issues.Keys)
+ issues.AddRange(_issues[resId].Keys);
+ return issues.ToArray();
+ public void AddIssue(ValidationIssue issue)
+ if (!_issues.ContainsKey(issue.Resource.ResourceID))
+ _issues[issue.Resource.ResourceID] = new Dictionary<ValidationIssue, ValidationIssue>();
+ _issues[issue.Resource.ResourceID][issue] = issue;
+ public void AddIssues(IEnumerable<ValidationIssue> issues)
+ foreach (var issue in issues)
+ AddIssue(issue);
More information about the mapguide-commits
