[mapguide-commits] r5200 - in sandbox/maestro-3.0:
Maestro.ResourceValidation
Maestro.ResourceValidation/Properties MaestroAPITests
OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Resource
svn_mapguide at osgeo.org
Tue Sep 28 06:03:39 EDT 2010
Author: jng
Date: 2010-09-28 10:03:39 +0000 (Tue, 28 Sep 2010)
New Revision: 5200
Added:
sandbox/maestro-3.0/Maestro.ResourceValidation/LoadProcedureValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs
sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
Add a load procedure validator with unit tests for verification
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/LoadProcedureValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/LoadProcedureValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/LoadProcedureValidator.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -0,0 +1,88 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.LoadProcedure;
+namespace Maestro.ResourceValidation
+ public class LoadProcedureValidator : IResourceValidator
+ public ResourceTypeDescriptor SupportedResourceAndVersion
+ get { return new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.LoadProcedure, "1.0.0"); }
+ public ValidationIssue[] Validate(IResource resource, bool recurse)
+ if (resource.ResourceType != OSGeo.MapGuide.MaestroAPI.ResourceTypes.LoadProcedure)
+ return null;
+ if (resource.ResourceVersion != new Version(1, 0, 0))
+ return null;
+ var set = new ValidationResultSet();
+ var loadProc = (resource as LoadProcedure).Item;
+ if (typeof(DwgLoadProcedureType).IsAssignableFrom(loadProc.GetType()))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_DWGNotSupported));
+ return set.GetAllIssues(); //all she wrote
+ if (typeof(RasterLoadProcedureType).IsAssignableFrom(loadProc.GetType()))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_RasterNotSupported));
+ if (typeof(DwfLoadProcedureType).IsAssignableFrom(loadProc.GetType()))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_DWFNotSupported));
+ if (typeof(SdfLoadProcedureType).IsAssignableFrom(loadProc.GetType()))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_Sdf2OptionsNotSupported));
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_GeneralizationNotSupported));
+ if (typeof(ShpLoadProcedureType).IsAssignableFrom(loadProc.GetType()))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LPROC_ConvertToSdf3NotSupported));
+ foreach (var fn in loadProc.SourceFile)
+ if (!System.IO.File.Exists(fn))
+ set.AddIssue(new ValidationIssue(resource, ValidationStatus.Warning, string.Format(Properties.Resources.LPROC_SourceFileNotFound, fn)));
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj 2010-09-28 10:03:39 UTC (rev 5200)
@@ -39,6 +39,7 @@
<Compile Include="ApplicationDefinitionValidator.cs" />
<Compile Include="FeatureSourceValidator.cs" />
<Compile Include="LayerDefinitionValidator.cs" />
+ <Compile Include="LoadProcedureValidator.cs" />
<Compile Include="MapDefinitionValidator.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="Properties\Resources.Designer.cs">
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4927
+// Runtime Version:2.0.50727.4952
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -313,6 +313,69 @@
/// <summary>
+ /// Looks up a localized string similar to Convert to SDF option is not supported by Maestro.
+ /// </summary>
+ internal static string LPROC_ConvertToSdf3NotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_ConvertToSdf3NotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to DWF Load Procedures cannot be executed by Maestro.
+ /// </summary>
+ internal static string LPROC_DWFNotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_DWFNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to DWG Load Procedures cannot be executed by Maestro.
+ /// </summary>
+ internal static string LPROC_DWGNotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_DWGNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Generalization of source data is not supported by Maestro.
+ /// </summary>
+ internal static string LPROC_GeneralizationNotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_GeneralizationNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Raster Load Procedures cannot be executed by Maestro.
+ /// </summary>
+ internal static string LPROC_RasterNotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_RasterNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to SDF 2 Migration options are not supported by Maestro. Ensure your source files are SDF3 files..
+ /// </summary>
+ internal static string LPROC_Sdf2OptionsNotSupported {
+ get {
+ return ResourceManager.GetString("LPROC_Sdf2OptionsNotSupported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Source file not found: {0}.
+ /// </summary>
+ internal static string LPROC_SourceFileNotFound {
+ get {
+ return ResourceManager.GetString("LPROC_SourceFileNotFound", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Data from {0} is not visible in the map's start extent.
/// </summary>
internal static string MDF_DataOutsideMapWarning {
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx 2010-09-28 10:03:39 UTC (rev 5200)
@@ -229,6 +229,34 @@
<value>The layer has no type, or the type is unsupported by Maestro</value>
<comment>A warning message that is displayed if the layer type is unknown</comment>
</data>
+ <data name="LPROC_ConvertToSdf3NotSupported" xml:space="preserve">
+ <value>Convert to SDF option is not supported by Maestro</value>
+ <comment>A warning message about the lack of SDF conversion support</comment>
+ </data>
+ <data name="LPROC_DWFNotSupported" xml:space="preserve">
+ <value>DWF Load Procedures cannot be executed by Maestro</value>
+ <comment>A warning message indicating the lack of DWF support in Maestro</comment>
+ </data>
+ <data name="LPROC_DWGNotSupported" xml:space="preserve">
+ <value>DWG Load Procedures cannot be executed by Maestro</value>
+ <comment>A warning message indicating the lack of DWG support in Maestro</comment>
+ </data>
+ <data name="LPROC_GeneralizationNotSupported" xml:space="preserve">
+ <value>Generalization of source data is not supported by Maestro</value>
+ <comment>A warning message about the lack of Generalization support</comment>
+ </data>
+ <data name="LPROC_RasterNotSupported" xml:space="preserve">
+ <value>Raster Load Procedures cannot be executed by Maestro</value>
+ <comment>A warning message about the lack of Raster support</comment>
+ </data>
+ <data name="LPROC_Sdf2OptionsNotSupported" xml:space="preserve">
+ <value>SDF 2 Migration options are not supported by Maestro. Ensure your source files are SDF3 files.</value>
+ <comment>A warning message about the lack of SDF2 support</comment>
+ </data>
+ <data name="LPROC_SourceFileNotFound" xml:space="preserve">
+ <value>Source file not found: {0}</value>
+ <comment>An error message indicating that a source file in the load procedure does not exist</comment>
+ </data>
<data name="MDF_DataOutsideMapWarning" xml:space="preserve">
<value>Data from {0} is not visible in the map's start extent</value>
<comment>A warning message that is displayed if a layer reports an extent that is outside the map's extent</comment>
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -41,6 +41,7 @@
ResourceValidatorSet.RegisterValidator(new MapDefinitionValidator());
ResourceValidatorSet.RegisterValidator(new WebLayoutValidator());
ResourceValidatorSet.RegisterValidator(new ApplicationDefinitionValidator());
+ ResourceValidatorSet.RegisterValidator(new LoadProcedureValidator());
m_initialized = true;
Modified: sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
--- sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-09-28 10:03:39 UTC (rev 5200)
@@ -60,6 +60,10 @@
<Compile Include="ValidationTests.cs" />
</ItemGroup>
<ItemGroup>
+ <ProjectReference Include="..\Maestro.ResourceValidation\Maestro.ResourceValidation.csproj">
+ <Project>{3B29C138-666C-46D0-A55D-824E5192C091}</Project>
+ <Name>Maestro.ResourceValidation</Name>
+ </ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Http\OSGeo.MapGuide.MaestroAPI.Http.csproj">
<Project>{6EF1E775-444B-4E5F-87FB-D687C43A68D7}</Project>
<Name>OSGeo.MapGuide.MaestroAPI.Http</Name>
Modified: sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -24,11 +24,22 @@
using NMock2;
+using LoadProc = OSGeo.MapGuide.ObjectModels.LoadProcedure;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI;
+using Maestro.ResourceValidation;
namespace MaestroAPITests
[TestFixture]
public class ValidationTests
+ [TestFixtureSetUp]
+ public void FixtureSetup()
+ ResourceValidatorLoader.LoadStockValidators();
[Test]
public void TestUniqueIssues()
@@ -78,5 +89,71 @@
Assert.AreEqual(totalIssues.Length, 2);
Assert.AreEqual(set.ResourceIDs.Length, 1);
+ [Test]
+ public void TestLoadProcedureValidation()
+ var id = "Library://Test.LoadProcedure";
+ var mock = new Mockery();
+ var conn = mock.NewMock<IServerConnection>();
+ var lp = ObjectFactory.CreateSdfLoadProcedure(conn, new string[]
+ "C:\\foo.sdf",
+ "C:\\bar.sdf"
+ lp.ResourceID = id;
+ set.AddIssues(ResourceValidatorSet.Validate(lp, false));
+ //SDF2, generalization and 2 missing files
+ Assert.AreEqual(4, set.GetAllIssues().Length);
+ lp = ObjectFactory.CreateShpLoadProcedure(conn, new string[]
+ "C:\\foo.shp",
+ "C:\\bar.shp"
+ set = new ValidationResultSet();
+ //SDF3 conversion, generalization and 2 missing files
+ lp = new OSGeo.MapGuide.ObjectModels.LoadProcedure.LoadProcedure()
+ Item = new OSGeo.MapGuide.ObjectModels.LoadProcedure.DwfLoadProcedureType()
+ //Not supported
+ Assert.AreEqual(1, set.GetAllIssues().Length);
+ Item = new OSGeo.MapGuide.ObjectModels.LoadProcedure.DwgLoadProcedureType()
+ //Not supported
+ Item = new OSGeo.MapGuide.ObjectModels.LoadProcedure.RasterLoadProcedureType()
+ //Not supported
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -45,24 +45,21 @@
public static LayerDefinition CreateLayerDefinition(IServerConnection owner)
- if (owner == null)
- throw new ArgumentNullException("owner");
+ Check.NotNull(owner, "owner");
return new LayerDefinition() { CurrentConnection = owner };
public static DrawingSource CreateDrawingSource(IServerConnection owner)
return new DrawingSource() { CurrentConnection = owner };
public static FeatureSourceType CreateFeatureSource(IServerConnection owner, string provider)
return new FeatureSourceType()
@@ -81,8 +78,7 @@
public static MapDefinition CreateMapDefinition(IServerConnection owner)
return new MapDefinition() {
CurrentConnection = owner,
@@ -191,8 +187,7 @@
public static WebLayoutType CreateWebLayout(IServerConnection owner, string mapDefinitionId)
//TODO: Localize these strings. Once localized we can have *translatable*
//web layouts!
@@ -529,16 +524,14 @@
public static SimpleSymbolDefinition CreateSimpleSymbol(IServerConnection owner)
return new SimpleSymbolDefinition() { CurrentConnection = owner };
public static CompoundSymbolDefinition CreateCompoundSymbol(IServerConnection owner)
return new CompoundSymbolDefinition() { CurrentConnection = owner };
@@ -550,16 +543,14 @@
public static ApplicationDefinitionType CreateFlexibleLayout(IServerConnection owner)
return new ApplicationDefinitionType() { CurrentConnection = owner };
public static PrintLayout CreatePrintLayout(IServerConnection owner)
return new PrintLayout() { CurrentConnection = owner };
@@ -568,8 +559,7 @@
public static LoadProcedure CreateSdfLoadProcedure(IServerConnection owner, IEnumerable<string> sdfFiles)
IList<string> files = new List<string>();
if (sdfFiles != null)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs 2010-09-28 09:26:53 UTC (rev 5199)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs 2010-09-28 10:03:39 UTC (rev 5200)
@@ -76,6 +76,9 @@
public void AddIssues(IEnumerable<ValidationIssue> issues)
+ if (issues == null)
+ return;
foreach (var issue in issues)
AddIssue(issue);
More information about the mapguide-commits
