[mapguide-commits] r5680 - in trunk/Tools/Maestro/Maestro.Base: .
Commands/SiteExplorer Properties
svn_mapguide at osgeo.org
Tue Apr 5 08:23:45 EDT 2011
Author: jng
Date: 2011-04-05 05:23:45 -0700 (Tue, 05 Apr 2011)
New Revision: 5680
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DuplicateResourceCommand.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
#1649: Add missing duplicate resource command from Maestro 2.0
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DuplicateResourceCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DuplicateResourceCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DuplicateResourceCommand.cs 2011-04-05 12:23:45 UTC (rev 5680)
@@ -0,0 +1,85 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Base.UI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class DuplicateResourceCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ if (exp.SelectedItems.Length > 0)
+ List<RepositoryItem> toDuplicate = new List<RepositoryItem>();
+ foreach (var item in exp.SelectedItems)
+ if (!item.IsFolder)
+ toDuplicate.Add(item);
+ //They all have the same parent
+ var folder = exp.SelectedItems[0].Parent;
+ foreach (var item in toDuplicate)
+ //Keep testing until we find a target resource identifier that
+ //doesn't already exists. Note this would automatically guard against any resources in this folder
+ //that may already be open in an editor
+ var rid = new ResourceIdentifier(item.ResourceId);
+ var name = rid.IsFolder ? (rid.Name + "/") : (rid.Name + "." + rid.ResourceType.ToString());
+ var resId = folder.ResourceId + name;
+ int counter = 0;
+ while (conn.ResourceService.ResourceExists(resId))
+ counter++;
+ if (rid.IsFolder)
+ resId = folder.ResourceId + rid.Name + " (" + counter + ")/";
+ else
+ var rname = name.Substring(0, name.IndexOf("."));
+ var type = name.Substring(name.IndexOf("."));
+ rname += " (" + counter + ")";
+ resId = folder.ResourceId + rname + type;
+ conn.ResourceService.CopyResource(item.ResourceId, resId, false);
+ LoggingService.Info(string.Format(Properties.Resources.ResourceDuplicated, item.ResourceId, resId));
+ exp.RefreshModel(folder.ResourceId);
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-04-05 11:53:18 UTC (rev 5679)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-04-05 12:23:45 UTC (rev 5680)
@@ -492,6 +492,10 @@
icon="cross_script"
label="${res:SiteExplorer_SelectedItem_Delete}"
class="Maestro.Base.Commands.SiteExplorer.DeleteSelectedItemsCommand" />
+ <MenuItem id="Duplicate"
+ icon="document_copy"
+ label="${res:SiteExplorer_DuplicateResources}"
+ class="Maestro.Base.Commands.SiteExplorer.DuplicateResourceCommand" />
<MenuItem type="Separator" />
<Condition action="Disable" name="ResourceType" types="FeatureSource,LayerDefinition">
<MenuItem id="PurgeFsCache"
@@ -551,6 +555,10 @@
icon="cross_script"
<Condition action="Disable" name="CanCutOrCopy">
<MenuItem id="Copy"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-04-05 11:53:18 UTC (rev 5679)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-04-05 12:23:45 UTC (rev 5680)
@@ -101,6 +101,7 @@
<Compile Include="Commands\SaveAllCommand.cs" />
<Compile Include="Commands\SaveResourceAsCommand.cs" />
<Compile Include="Commands\SaveResourceCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\DuplicateResourceCommand.cs" />
<Compile Include="Commands\SiteExplorer\PurgeFeatureSourceCacheCommand.cs" />
<Compile Include="Commands\SiteExplorer\SaveResourceContentToDiskCommand.cs" />
<Compile Include="Commands\ServerMonitorCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 11:53:18 UTC (rev 5679)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 12:23:45 UTC (rev 5680)
@@ -1299,6 +1299,15 @@
/// <summary>
+ /// Looks up a localized string similar to Resource Duplicated: {0} ( => {1}).
+ /// </summary>
+ internal static string ResourceDuplicated {
+ get {
+ return ResourceManager.GetString("ResourceDuplicated", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Resource Migrated: {0}.
/// </summary>
internal static string ResourceMigrated {
@@ -1612,6 +1621,15 @@
/// <summary>
+ /// Looks up a localized string similar to Duplicate Resources.
+ /// </summary>
+ internal static string SiteExplorer_DuplicateResources {
+ get {
+ return ResourceManager.GetString("SiteExplorer_DuplicateResources", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Migrate.
/// </summary>
internal static string SiteExplorer_Migrate {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 11:53:18 UTC (rev 5679)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 12:23:45 UTC (rev 5680)
@@ -901,4 +901,10 @@
<data name="SchemaInformationPurged" xml:space="preserve">
<value>Schema information for {0} purged</value>
</data>
+ <data name="ResourceDuplicated" xml:space="preserve">
+ <value>Resource Duplicated: {0} ( => {1})</value>
+ </data>
+ <data name="SiteExplorer_DuplicateResources" xml:space="preserve">
+ <value>Duplicate Resources</value>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
