[mapguide-commits] r5681 - in trunk/Tools/Maestro: Maestro.Base
Maestro.Base/Commands Maestro.Base/Editor
Maestro.Base/Properties Maestro.Base/UI
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Mapping
OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Services
svn_mapguide at osgeo.org
Tue Apr 5 11:04:31 EDT 2011
Author: jng
Date: 2011-04-05 08:04:31 -0700 (Tue, 05 Apr 2011)
New Revision: 5681
Added:
trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.resx
trunk/Tools/Maestro/Maestro.Base/Commands/ProfileResourceCommand.cs
trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
#1650: Port over the profiling feature from Maestro 2.x. Also fix the Clone() method of MapDefinition to detach any event handlers (we don't want these cloned!)
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/ProfileResourceCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/ProfileResourceCommand.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/ProfileResourceCommand.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -20,10 +20,27 @@
using System;
using System.Collections.Generic;
using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.UI;
+using Maestro.Base.Services;
namespace Maestro.Base.Commands
- internal class ProfileResourceCommand : NotImplementedCommand
+ internal class ProfileResourceCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var ed = wb.ActiveEditor;
+ if (ed != null)
+ var exp = wb.ActiveSiteExplorer;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ var res = ed.EditorService.GetEditedResource();
+ var diag = new ProfilingDialog(res, res.ResourceID, conn);
+ diag.ShowDialog(wb);
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -96,5 +96,13 @@
base.OnBeforeSave(sender, e);
+ public override bool CanProfile
+ get
+ return true;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -127,5 +127,13 @@
+ get
+ return true;
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-04-05 15:04:31 UTC (rev 5681)
@@ -343,7 +343,7 @@
<ToolbarItem id="Profile"
icon="clock"
tooltip="${res:Menu_File_ProfileResource}"
- class="Maestro.Base.Commands.NotImplementedCommand" />
+ class="Maestro.Base.Commands.ProfileResourceCommand" />
</Condition>
<Condition action="Disable" name="EditorFunction" property="CanValidate">
<ToolbarItem id="Validate"
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-04-05 15:04:31 UTC (rev 5681)
@@ -302,6 +302,12 @@
<Compile Include="UI\Preferences\OptionsDialog.Designer.cs">
<DependentUpon>OptionsDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="UI\ProfilingDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\ProfilingDialog.Designer.cs">
+ <DependentUpon>ProfilingDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\RenameItemDialog.cs">
</Compile>
@@ -490,6 +496,9 @@
<EmbeddedResource Include="UI\Preferences\OptionsDialog.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="UI\ProfilingDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\RenameItemDialog.resx">
<DependentUpon>RenameItemDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -326,6 +326,15 @@
/// <summary>
+ /// Looks up a localized string similar to Close.
+ /// </summary>
+ internal static string CloseButtonText {
+ get {
+ return ResourceManager.GetString("CloseButtonText", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to This resource {0} has unsaved changes. Close and discard these changes?.
/// </summary>
internal static string CloseUnsavedResource {
@@ -1256,6 +1265,153 @@
/// <summary>
+ /// Looks up a localized string similar to Failed while profiling LayerDefinition: {0},
+ ///Error message: {1}.
+ /// </summary>
+ internal static string Prof_LayerDefinitionProfilingError {
+ get {
+ return ResourceManager.GetString("Prof_LayerDefinitionProfilingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to *** Done ***.
+ /// </summary>
+ internal static string Prof_LogMessageDone {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageDone", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Profiling FeatureSource: {0}.
+ /// </summary>
+ internal static string Prof_LogMessageFeatureSource {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageFeatureSource", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Identity fetching (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageIdentifyFetching {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageIdentifyFetching", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Profiling LayerDefinition: {0}.
+ /// </summary>
+ internal static string Prof_LogMessageLayerDefinition {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageLayerDefinition", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Profiling MapDefinition: {0}.
+ /// </summary>
+ internal static string Prof_LogMessageMapDefinition {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageMapDefinition", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Full map rendering (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageRenderingMap {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageRenderingMap", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Rendering scales (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageRenderingScales {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageRenderingScales", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Runtime layer creation (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageRuntimeLayer {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageRuntimeLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Total for runtime Map Generation (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageRuntimeMap {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageRuntimeMap", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Runtime map generation in one go (ms):.
+ /// </summary>
+ internal static string Prof_LogMessageRuntimeMapTotal {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageRuntimeMapTotal", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Time to render scale range [{0} : {1}] (ms): .
+ /// </summary>
+ internal static string Prof_LogMessageScaleRange {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageScaleRange", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The resource type is not supported for profiling.
+ /// </summary>
+ internal static string Prof_LogMessageUnsupportedResourceType {
+ get {
+ return ResourceManager.GetString("Prof_LogMessageUnsupportedResourceType", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed while profiling MapDefinition rendering: {0},
+ /// </summary>
+ internal static string Prof_MapRenderingError {
+ get {
+ return ResourceManager.GetString("Prof_MapRenderingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Rendered image size is: {0}.
+ /// </summary>
+ internal static string Prof_MapRenderingImageSize {
+ get {
+ return ResourceManager.GetString("Prof_MapRenderingImageSize", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed while profiling MapDefinition runtime: {0},
+ /// </summary>
+ internal static string Prof_RuntimeMapProfilingError {
+ get {
+ return ResourceManager.GetString("Prof_RuntimeMapProfilingError", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Updating References.
/// </summary>
internal static string ProgressUpdatingReferences {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 15:04:31 UTC (rev 5681)
@@ -907,4 +907,74 @@
<data name="SiteExplorer_DuplicateResources" xml:space="preserve">
<value>Duplicate Resources</value>
</data>
+ <data name="CloseButtonText" xml:space="preserve">
+ <value>Close</value>
+ <comment>The text on the close button</comment>
+ </data>
+ <data name="Prof_LayerDefinitionProfilingError" xml:space="preserve">
+ <value>Failed while profiling LayerDefinition: {0},
+Error message: {1}</value>
+ <comment>An error message that is displayed when the layer definition profiling fails</comment>
+ </data>
+ <data name="Prof_LogMessageDone" xml:space="preserve">
+ <value>*** Done ***</value>
+ <comment>A message written in the log to indicate that the operation is complete</comment>
+ </data>
+ <data name="Prof_LogMessageFeatureSource" xml:space="preserve">
+ <value>Profiling FeatureSource: {0}</value>
+ <comment>A message written in the log when profiling a featuresource</comment>
+ </data>
+ <data name="Prof_LogMessageIdentifyFetching" xml:space="preserve">
+ <value>Identity fetching (ms): </value>
+ <comment>A message written in the log when profiling identity fetching</comment>
+ </data>
+ <data name="Prof_LogMessageLayerDefinition" xml:space="preserve">
+ <value>Profiling LayerDefinition: {0}</value>
+ <comment>A message written in the log when profiling a layerdefinition</comment>
+ </data>
+ <data name="Prof_LogMessageMapDefinition" xml:space="preserve">
+ <value>Profiling MapDefinition: {0}</value>
+ <comment>A message written in the log when profiling a mapdefinition</comment>
+ </data>
+ <data name="Prof_LogMessageRenderingMap" xml:space="preserve">
+ <value>Full map rendering (ms): </value>
+ <comment>A message written in the log when profiling runtime map rendering</comment>
+ </data>
+ <data name="Prof_LogMessageRenderingScales" xml:space="preserve">
+ <value>Rendering scales (ms): </value>
+ <comment>A message written in the log when profiling a scale rendering</comment>
+ </data>
+ <data name="Prof_LogMessageRuntimeLayer" xml:space="preserve">
+ <value>Runtime layer creation (ms): </value>
+ <comment>A message written in the log when profiling a runtime layer creation</comment>
+ </data>
+ <data name="Prof_LogMessageRuntimeMap" xml:space="preserve">
+ <value>Total for runtime Map Generation (ms): </value>
+ <comment>A message written in the log when profiling runtime map generation</comment>
+ </data>
+ <data name="Prof_LogMessageRuntimeMapTotal" xml:space="preserve">
+ <value>Runtime map generation in one go (ms):</value>
+ </data>
+ <data name="Prof_LogMessageScaleRange" xml:space="preserve">
+ <value>Time to render scale range [{0} : {1}] (ms): </value>
+ <comment>A message written in the log when profiling a certain scalerange</comment>
+ </data>
+ <data name="Prof_LogMessageUnsupportedResourceType" xml:space="preserve">
+ <value>The resource type is not supported for profiling</value>
+ <comment>A message written in the log if a certain resource is not supported</comment>
+ </data>
+ <data name="Prof_MapRenderingError" xml:space="preserve">
+ <value>Failed while profiling MapDefinition rendering: {0},
+ <comment>An error message displayed when profiling mapdefinition rendering fails</comment>
+ </data>
+ <data name="Prof_RuntimeMapProfilingError" xml:space="preserve">
+ <value>Failed while profiling MapDefinition runtime: {0},
+ <comment>An error message displayed when profiling a mapdefinition fails</comment>
+ </data>
+ <data name="Prof_MapRenderingImageSize" xml:space="preserve">
+ <value>Rendered image size is: {0}</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.Designer.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -0,0 +1,98 @@
+namespace Maestro.Base.UI
+ partial class ProfilingDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ProfilingDialog));
+ this.Results = new System.Windows.Forms.TextBox();
+ this.panel1 = new System.Windows.Forms.Panel();
+ this.CancelBtn = new System.Windows.Forms.Button();
+ this.backgroundWorker = new System.ComponentModel.BackgroundWorker();
+ this.btnSave = new System.Windows.Forms.Button();
+ this.panel1.SuspendLayout();
+ this.SuspendLayout();
+ // Results
+ resources.ApplyResources(this.Results, "Results");
+ this.Results.Name = "Results";
+ this.Results.ReadOnly = true;
+ // panel1
+ this.panel1.Controls.Add(this.btnSave);
+ this.panel1.Controls.Add(this.CancelBtn);
+ resources.ApplyResources(this.panel1, "panel1");
+ this.panel1.Name = "panel1";
+ // CancelBtn
+ resources.ApplyResources(this.CancelBtn, "CancelBtn");
+ this.CancelBtn.Name = "CancelBtn";
+ this.CancelBtn.UseVisualStyleBackColor = true;
+ this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
+ // backgroundWorker
+ this.backgroundWorker.WorkerReportsProgress = true;
+ this.backgroundWorker.WorkerSupportsCancellation = true;
+ this.backgroundWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.backgroundWorker_DoWork);
+ this.backgroundWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.backgroundWorker_RunWorkerCompleted);
+ this.backgroundWorker.ProgressChanged += new System.ComponentModel.ProgressChangedEventHandler(this.backgroundWorker_ProgressChanged);
+ // btnSave
+ resources.ApplyResources(this.btnSave, "btnSave");
+ this.btnSave.Name = "btnSave";
+ this.btnSave.UseVisualStyleBackColor = true;
+ this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ // ProfilingDialog
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ resources.ApplyResources(this, "$this");
+ this.ControlBox = false;
+ this.Controls.Add(this.Results);
+ this.Controls.Add(this.panel1);
+ this.Name = "ProfilingDialog";
+ this.Load += new System.EventHandler(this.Profiling_Load);
+ this.panel1.ResumeLayout(false);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.TextBox Results;
+ private System.Windows.Forms.Panel panel1;
+ private System.Windows.Forms.Button CancelBtn;
+ private System.ComponentModel.BackgroundWorker backgroundWorker;
+ private System.Windows.Forms.Button btnSave;
Added: trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -0,0 +1,472 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using Maestro.Shared.UI;
+ public partial class ProfilingDialog : Form
+ private IServerConnection m_connection;
+ private IResource m_item;
+ private string m_resourceId;
+ private RuntimeMap m_tempmap;
+ public ProfilingDialog(IResource item, string resourceId, IServerConnection connection)
+ : this()
+ m_connection = connection;
+ m_item = item;
+ m_resourceId = resourceId;
+ private ProfilingDialog()
+ InitializeComponent();
+ m_tempmap = null;
+ private void CancelBtn_Click(object sender, EventArgs e)
+ if (!backgroundWorker.IsBusy)
+ this.Close();
+ else if (!backgroundWorker.CancellationPending)
+ backgroundWorker.CancelAsync();
+ private void ProfileFeatureSource(IFeatureSource fs)
+ //TODO: Determine what profiling benchmarks to use
+ string resourceId = fs == m_item ? m_resourceId : fs.ResourceID;
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LogMessageFeatureSource, resourceId)));
+ private static void SetTempLayer(IMapDefinition mdf, string resourceId)
+ var layers = new List<IMapLayer>(mdf.MapLayer);
+ for (int i = 0; i < layers.Count; i++)
+ mdf.RemoveLayer(layers[i]);
+ var layer = mdf.AddLayer(null, "x", resourceId);
+ layer.Visible = true;
+ layer.Selectable = true;
+ layer.Name = "x";
+ layer.LegendLabel = "";
+ private void MakeTempMap()
+ if (m_tempmap == null)
+ IMapDefinition m = ObjectFactory.CreateMapDefinition(m_connection, "");
+ m.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]";
+ m.SetExtents(-1, -1, 1, 1);
+ m.ResourceID = "Library://non-existing.MapDefinition";
+ var mpsvc = (IMappingService)m_connection.GetService((int)ServiceType.Mapping);
+ var rid = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.RuntimeMap, m_connection.SessionID);
+ m_tempmap = mpsvc.CreateMap(m);
+ private void ProfileLayerDefinition(ILayerDefinition ldef)
+ //TODO: This was a line-by-line port from 2.x to match the 3.x APIs
+ //we should find time to clean this up and ensure the profiling numbers are
+ //truly reflective of actual performance metrics
+ if (backgroundWorker.CancellationPending)
+ return;
+ string resourceId = ldef == m_item ? m_resourceId : ldef.ResourceID;
+ MakeTempMap();
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LogMessageLayerDefinition, resourceId)));
+ using (new Timer(Properties.Resources.Prof_LogMessageRuntimeLayer, backgroundWorker))
+ try
+ IMapDefinition mdef = ObjectFactory.CreateMapDefinition(m_connection, "");
+ mdef.ResourceID = "Library://ProfileTest.MapDefinition"; //Flub it
+ IMapLayer layer = mdef.AddLayer(null, "Test Layer", ldef.ResourceID);
+ layer.Visible = false;
+ layer.Selectable = false;
+ return;
+ var map = mpsvc.CreateMap(mdef);
+ using (new Timer(Properties.Resources.Prof_LogMessageIdentifyFetching, backgroundWorker))
+ var rtl = map.GetLayerByName("Test Layer");
+ rtl.Visible = true;
+ rtl.Selectable = true;
+ map.Save();
+ catch (Exception ex)
+ string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, resourceId, msg)));
+ return;
+ ILayerDefinition lx = (ILayerDefinition)ldef.Clone();
+ if (lx.SubLayer.LayerType == LayerType.Vector || lx.SubLayer.LayerType == LayerType.Raster)
+ using (new Timer(Properties.Resources.Prof_LogMessageRenderingScales, backgroundWorker))
+ if (lx.SubLayer.LayerType == LayerType.Vector)
+ IVectorLayerDefinition vlx = lx.SubLayer as IVectorLayerDefinition;
+ //VectorScaleRangeTypeCollection ranges = vlx.VectorScaleRange;
+ List<IVectorScaleRange> ranges = new List<IVectorScaleRange>(vlx.VectorScaleRange);
+ foreach (var vsr in ranges)
+ return;
+ string tmp1 = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.LayerDefinition, m_connection.SessionID);
+ try
+ double minscale = vsr.MinScale.HasValue ? vsr.MinScale.Value : 0;
+ double maxscale = vsr.MaxScale.HasValue ? vsr.MaxScale.Value : 10000000;
+ vlx.RemoveAllScaleRanges();
+ vsr.MinScale = null;
+ vsr.MaxScale = null;
+ vlx.AddVectorScaleRange(vsr);
+ m_connection.ResourceService.SaveResourceAs(lx, tmp1);
+ return;
+ var lst = m_connection.FeatureService.GetSpatialContextInfo(vlx.ResourceId, false);
+ //Create a runtime map just containing this particular layer at this particular scale range
+ //We are profiling the stylization settings for this layer
+ var mdf = ObjectFactory.CreateMapDefinition(m_connection, "");
+ if (lst.SpatialContext != null && lst.SpatialContext.Count >= 1)
+ mdf.CoordinateSystem = lst.SpatialContext[0].CoordinateSystemWkt;
+ if (string.IsNullOrEmpty(m_tempmap.CoordinateSystem))
+ mdf.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]";
+ double llx = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture);
+ double lly = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ double urx = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ double ury = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ m_tempmap.DataExtent = ObjectFactory.CreateEnvelope(llx, lly, urx, ury);
+ SetTempLayer(mdf, tmp1);
+ mdf.ResourceID = "Library://ProfileTest.MapDefinition"; //Flub it
+ var rtmap = mpsvc.CreateMap(mdf);
+ if (m_connection.ResourceService.ResourceExists(rtmap.ResourceID))
+ m_connection.ResourceService.DeleteResource(rtmap.ResourceID);
+ rtmap.Save();
+ return;
+ using (new Timer(string.Format(Properties.Resources.Prof_LogMessageScaleRange, minscale, maxscale), backgroundWorker))
+ //TODO: Use extents rather than scale
+ //using (System.IO.Stream s = m_connection.RenderRuntimeMap(tmp2, m.Extents, 1024, 800, 96))
+ using (System.IO.Stream s = mpsvc.RenderRuntimeMap(rtmap.ResourceID, ((rtmap.DataExtent.MaxX - rtmap.DataExtent.MinX) / 2) + rtmap.DataExtent.MinX, ((rtmap.DataExtent.MaxY - rtmap.DataExtent.MinY) / 2) + rtmap.DataExtent.MinY, 50000, 1024, 800, 96))
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_MapRenderingImageSize, s.Length)));
+ finally
+ try { m_connection.ResourceService.DeleteResource(tmp1); }
+ catch { }
+ return;
+ backgroundWorker.ReportProgress(0, ("\r\n"));
+ private void ProfileMapDefinition(IMapDefinition mapDef)
+ var mdef = (IMapDefinition)mapDef.Clone();
+ return;
+ string resourceId = mdef == m_item ? m_resourceId : mdef.ResourceID;
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LogMessageMapDefinition, resourceId)));
+ using (new Timer(Properties.Resources.Prof_LogMessageRuntimeMap, backgroundWorker))
+ foreach (var ml in mdef.MapLayer)
+ try
+ return;
+ ILayerDefinition ldef = (ILayerDefinition)mdef.CurrentConnection.ResourceService.GetResource(ml.ResourceId);
+ ProfileLayerDefinition(ldef);
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, ml.ResourceId, msg)));
+ if (mdef.BaseMap != null)
+ foreach (var g in mdef.BaseMap.BaseMapLayerGroup)
+ if (g.BaseMapLayer != null)
+ foreach (var ml in g.BaseMapLayer)
+ try
+ return;
+ return;
+ try
+ return;
+ //m_connection.ResetFeatureSourceSchemaCache();
+ using (new Timer(Properties.Resources.Prof_LogMessageRuntimeMapTotal, backgroundWorker))
+ mpsvc.CreateMap(mdef);
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_RuntimeMapProfilingError, resourceId, msg)));
+ try
+ return;
+ //Flub for runtime map creation
+ mdef.ResourceID = "Library://ProfilingTest.MapDefinition";
+ var rtmap = mpsvc.CreateMap(mdef);
+ rtmap.Save();
+ using (new Timer(Properties.Resources.Prof_LogMessageRenderingMap, backgroundWorker))
+ //using (System.IO.Stream s = m_connection.RenderRuntimeMap(tmp2, mdef.Extents, 1024, 800, 96))
+ using (System.IO.Stream s = mpsvc.RenderRuntimeMap(rtmap.ResourceID, ((mdef.Extents.MaxX - mdef.Extents.MinX) / 2) + mdef.Extents.MinX, ((mdef.Extents.MaxY - mdef.Extents.MinY) / 2) + mdef.Extents.MinY, 50000, 1024, 800, 96))
+ //Just dispose it after being read
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_MapRenderingError, resourceId, msg)));
+ private class Timer : IDisposable
+ private string m_text;
+ private bool m_isDisposed;
+ private DateTime m_begin;
+ private BackgroundWorker m_worker;
+ public Timer(string text, BackgroundWorker worker)
+ m_begin = DateTime.Now;
+ m_isDisposed = false;
+ m_text = text;
+ m_worker = worker;
+ #region IDisposable Members
+ public void Dispose()
+ if (!m_isDisposed)
+ TimeSpan ts = DateTime.Now - m_begin;
+ m_isDisposed = true;
+ m_worker.ReportProgress(0, (m_text + ts.TotalMilliseconds)); //ts.Minutes.ToString("00") + ":" + ts.Seconds.ToString("00") + "." + ts.Milliseconds.ToString("000")));
+ m_worker = null;
+ m_text = null;
+ #endregion
+ private void Profiling_Load(object sender, EventArgs e)
+ backgroundWorker.RunWorkerAsync();
+ private void Profiling_FormClosing(object sender, FormClosingEventArgs e)
+ if (backgroundWorker.IsBusy)
+ e.Cancel = true;
+ if (!backgroundWorker.CancellationPending)
+ private void backgroundWorker_DoWork(object sender, DoWorkEventArgs e)
+ if (m_item.ResourceType == ResourceTypes.FeatureSource)
+ ProfileFeatureSource(m_item as IFeatureSource);
+ else if (m_item.ResourceType == ResourceTypes.LayerDefinition)
+ ProfileLayerDefinition(m_item as ILayerDefinition);
+ else if (m_item.ResourceType == ResourceTypes.MapDefinition)
+ ProfileMapDefinition(m_item as IMapDefinition);
+ else
+ backgroundWorker.ReportProgress(0, Properties.Resources.Prof_LogMessageUnsupportedResourceType);
+ private void backgroundWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
+ CancelBtn.Text = Properties.Resources.CloseButtonText;
+ btnSave.Enabled = true;
+ WriteString(Properties.Resources.Prof_LogMessageDone);
+ private void WriteString(string message)
+ if (string.IsNullOrEmpty(message))
+ return;
+ bool scroll = Math.Abs((Results.SelectionStart + Results.SelectionLength) - Results.Text.Length) < 20;
+ Results.Text += message + "\r\n";
+ if (scroll)
+ Results.SelectionLength = 0;
+ Results.SelectionStart = Results.Text.Length;
+ Results.ScrollToCaret();
+ private void backgroundWorker_ProgressChanged(object sender, ProgressChangedEventArgs e)
+ WriteString(e.UserState as string);
+ private void btnSave_Click(object sender, EventArgs e)
+ using (var diag = DialogFactory.SaveFile())
+ if (diag.ShowDialog() == DialogResult.OK)
+ System.IO.File.WriteAllText(diag.FileName, Results.Text);
+ MessageService.ShowMessage(string.Format(Properties.Resources.Log_Saved, diag.FileName));
Added: trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.resx 2011-04-05 15:04:31 UTC (rev 5681)
@@ -0,0 +1,267 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="Results.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="Results.Font" type="System.Drawing.Font, System.Drawing">
+ <value>Courier New, 9.75pt</value>
+ </data>
+ <data name="Results.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="Results.Multiline" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="Results.ScrollBars" type="System.Windows.Forms.ScrollBars, System.Windows.Forms">
+ <value>Both</value>
+ </data>
+ <data name="Results.Size" type="System.Drawing.Size, System.Drawing">
+ <value>444, 245</value>
+ </data>
+ <data name="Results.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name=">>Results.Name" xml:space="preserve">
+ <value>Results</value>
+ </data>
+ <data name=">>Results.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>Results.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>Results.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="btnSave.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
+ <data name="btnSave.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnSave.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 6</value>
+ </data>
+ <data name="btnSave.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnSave.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnSave.Text" xml:space="preserve">
+ <value>Save</value>
+ </data>
+ <data name=">>btnSave.Name" xml:space="preserve">
+ <value>btnSave</value>
+ </data>
+ <data name=">>btnSave.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnSave.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>btnSave.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="CancelBtn.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>357, 6</value>
+ </data>
+ <data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="CancelBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="CancelBtn.Text" xml:space="preserve">
+ <value>Stop</value>
+ </data>
+ <data name=">>CancelBtn.Name" xml:space="preserve">
+ <value>CancelBtn</value>
+ </data>
+ <data name=">>CancelBtn.Type" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Bottom</value>
+ </data>
+ <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 245</value>
+ </data>
+ <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>444, 40</value>
+ </data>
+ <data name="panel1.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name=">>panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>panel1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>panel1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <metadata name="backgroundWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>444, 285</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Profiling Resource</value>
+ </data>
+ <data name=">>backgroundWorker.Name" xml:space="preserve">
+ <value>backgroundWorker</value>
+ </data>
+ <data name=">>backgroundWorker.Type" xml:space="preserve">
+ <value>System.ComponentModel.BackgroundWorker, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ProfilingDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -37,7 +37,7 @@
internal RuntimeMapGroup()
_disableChangeTracking = true;
+ this.Group = "";
this.Type = kNormal;
this.ObjectId = Guid.NewGuid().ToString();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -75,6 +75,7 @@
this.IdentityProperties = new PropertyInfo[0];
this.Parent = parent;
+ this.Group = string.Empty;
internal RuntimeMapLayer(RuntimeMap parent, ILayerDefinition ldf)
@@ -84,7 +85,6 @@
this.LayerDefinitionID = ldf.ResourceID;
this.ExpandInLegend = false;
- this.Group = null;
this.Name = ResourceIdentifier.GetName(ldf.ResourceID);
this.Selectable = true;
this.ShowInLegend = true;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -27,6 +27,7 @@
using OSGeo.MapGuide.ObjectModels.Common;
#pragma warning disable 1591, 0114, 0108
@@ -49,11 +50,21 @@
OnPropertyChanged("BackgroundColor");
+ protected void DetachChangeListeners()
+ var handler = this.PropertyChanged;
+ foreach (var h in handler.GetInvocationList())
+ this.PropertyChanged -= (PropertyChangedEventHandler)h;
+ handler = null;
partial class MapDefinition : IMapDefinition
- internal MapDefinition() { }
+ internal MapDefinition() { }
private static readonly Version RES_VERSION = new Version(1, 0, 0);
@@ -109,7 +120,9 @@
object ICloneable.Clone()
- return this.Clone();
+ var mdf = this.Clone();
+ mdf.DetachChangeListeners();
+ return mdf;
[XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")]
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -206,6 +206,30 @@
/// <summary>
+ /// Creates the web layout. The schema version used is the highest supported one by the connection
+ /// </summary>
+ /// <param name="owner"></param>
+ /// <param name="mapDefinitionId"></param>
+ /// <returns></returns>
+ public static IWebLayout CreateWebLayout(IServerConnection owner, string mapDefinitionId)
+ var ver = owner.Capabilities.GetMaxSupportedResourceVersion(ResourceTypes.WebLayout);
+ return CreateWebLayout(owner, ver, mapDefinitionId);
+ /// <summary>
+ /// Creates the default layer. The schema version used is the highest supported one by the connection
+ /// </summary>
+ /// <param name="type"></param>
+ public static ILayerDefinition CreateDefaultLayer(IServerConnection owner, LayerType type)
+ var ver = owner.Capabilities.GetMaxSupportedResourceVersion(ResourceTypes.LayerDefinition);
+ return CreateDefaultLayer(owner, type, ver);
+ /// <summary>
/// </summary>
/// <param name="owner">The owner.</param>
@@ -348,6 +372,19 @@
/// <summary>
+ /// Creates the simple symbol. The schema version used is the highest supported one by the connection
+ /// </summary>
+ /// <param name="name"></param>
+ /// <param name="description"></param>
+ public static ISimpleSymbolDefinition CreateSimpleSymbol(IServerConnection owner, string name, string description)
+ var ver = owner.Capabilities.GetMaxSupportedResourceVersion(ResourceTypes.SymbolDefinition);
+ return CreateSimpleSymbol(owner, ver, name, description);
+ /// <summary>
/// Creates the compound symbol.
/// </summary>
@@ -366,6 +403,19 @@
return comp;
+ /// <summary>
+ /// Creates the compound symbol. The schema version used is the highest supported one by the connection
+ /// </summary>
+ public static ICompoundSymbolDefinition CreateCompoundSymbol(IServerConnection owner, string name, string description)
+ return CreateCompoundSymbol(owner, ver, name, description);
static readonly string[] parameterizedWidgets =
KnownWidgetNames.CTRLClick,
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -1703,8 +1703,12 @@
protected virtual double InferMPU(string csWkt, double units)
- var cs = CoordinateSystemBase.Create(csWkt);
- return cs.MetersPerUnitX * units;
+ try
+ var cs = CoordinateSystemBase.Create(csWkt);
+ return cs.MetersPerUnitX * units;
+ catch { return 1.0; }
/// <summary>
@@ -1742,6 +1746,30 @@
/// <summary>
+ /// Creates a new runtime map instance from an existing map definition. The runtime map resource id is calculated from the
+ /// current session id and the name component of the Map Definition resource id
+ /// </summary>
+ /// <param name="mdf"></param>
+ public RuntimeMap CreateMap(IMapDefinition mdf)
+ var rid = new ResourceIdentifier(ResourceIdentifier.GetName(mdf.ResourceID), ResourceTypes.RuntimeMap, this.SessionID);
+ return CreateMap(rid.ToString(), mdf);
+ /// <summary>
+ /// </summary>
+ public RuntimeMap CreateMap(IMapDefinition mdf, double metersPerUnit)
+ return CreateMap(rid.ToString(), mdf, metersPerUnit);
+ /// <summary>
/// Creates a new runtime map instance from an existing map definition. Meters per unit
/// is calculated from the Coordinate System WKT of the map definition.
/// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-04-05 12:23:45 UTC (rev 5680)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2011-04-05 15:04:31 UTC (rev 5681)
@@ -31,9 +31,25 @@
public interface IMappingService : IService
/// <summary>
+ /// </summary>
+ /// <param name="mapDef"></param>
+ RuntimeMap CreateMap(IMapDefinition mapDef);
+ /// <summary>
/// </summary>
+ /// <param name="metersPerUnit"></param>
+ RuntimeMap CreateMap(IMapDefinition mapDef, double metersPerUnit);
+ /// <summary>
+ /// Creates a new runtime map instance from an existing map definition. Meters per unit
+ /// is calculated from the Coordinate System WKT of the map definition.
+ /// </summary>
/// <remarks>
/// Calculation of meters-per-unit may differ between implementations. This may have an adverse
/// effect on things such as rendering and measuring depending on the underlying implementation
More information about the mapguide-commits
