[mapguide-commits] r5682 - in trunk/Tools/Maestro/Maestro.Base:
Properties Templates
svn_mapguide at osgeo.org
Tue Apr 5 11:14:10 EDT 2011
Author: jng
Date: 2011-04-05 08:14:10 -0700 (Tue, 05 Apr 2011)
New Revision: 5682
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs
Fix incorrect category label for user-defined templates
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 15:04:31 UTC (rev 5681)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-04-05 15:14:10 UTC (rev 5682)
@@ -2214,7 +2214,7 @@
/// <summary>
- /// Looks up a localized string similar to User Defined Resource Template.
+ /// Looks up a localized string similar to User Defined Resource Templates.
/// </summary>
internal static string TPL_USER_DEFINED {
get {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 15:04:31 UTC (rev 5681)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-04-05 15:14:10 UTC (rev 5682)
@@ -571,9 +571,6 @@
<data name="OpenResourceManager_SkipEditorRegistration" xml:space="preserve">
<value>Skipping registration of editor: {0} because an existing editor is already registered to handle {1} v{2}</value>
</data>
- <data name="TPL_USER_DEFINED" xml:space="preserve">
- <value>User Defined Resource Template</value>
- </data>
<data name="TPL_CSD_DESC" xml:space="preserve">
<value>Create a new Compund Symbol Definition using the v1.0.0 schema</value>
</data>
@@ -977,4 +974,7 @@
<data name="Prof_MapRenderingImageSize" xml:space="preserve">
<value>Rendered image size is: {0}</value>
</data>
+ <data name="TPL_USER_DEFINED" xml:space="preserve">
+ <value>User Defined Resource Templates</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs 2011-04-05 15:04:31 UTC (rev 5681)
+++ trunk/Tools/Maestro/Maestro.Base/Templates/UserItemTemplate.cs 2011-04-05 15:14:10 UTC (rev 5682)
@@ -50,7 +50,7 @@
this.Description = description;
- this.Category = Res.TPL_CATEGORY_DEFAULT;
+ this.Category = Res.TPL_CATEGORY_USERDEF;
this.Icon = Res.document;
this.Name = name;
this.TemplatePath = templatePath;
More information about the mapguide-commits
