[mapguide-commits] r6037 - in trunk/Tools/Maestro: MaestroAPITests
OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Fri Aug 5 07:28:25 EDT 2011
Author: jng
Date: 2011-08-05 04:28:25 -0700 (Fri, 05 Aug 2011)
New Revision: 6037
trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
Unit test cleanup
Modified: trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs 2011-08-04 16:00:10 UTC (rev 6036)
+++ trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs 2011-08-05 11:28:25 UTC (rev 6037)
@@ -606,6 +606,9 @@
var conn = _mocks.NewMock<IServerConnection>();
var conv = new ResourceObjectConverter();
var ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector, new Version(1, 0, 0));
+ ldf.SubLayer.ResourceId = "Library://Samples/Sheboygan/Data/Parcels.FeatureSource";
+ ((IVectorLayerDefinition)ldf.SubLayer).FeatureName = "SHP_Schema:Parcels";
+ ((IVectorLayerDefinition)ldf.SubLayer).Geometry = "Geometry";
Assert.AreEqual("1.0.0", ldf.GetResourceTypeDescriptor().Version);
Assert.AreEqual("LayerDefinition-1.0.0.xsd", ldf.GetResourceTypeDescriptor().XsdName);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2011-08-04 16:00:10 UTC (rev 6036)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2011-08-05 11:28:25 UTC (rev 6037)
@@ -483,9 +483,6 @@
<SubType>Designer</SubType>
</EmbeddedResource>
</ItemGroup>
- <ItemGroup>
- <Folder Include="Geometry\" />
- </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
More information about the mapguide-commits
