[mapguide-commits] r6038 - in trunk/Tools/Maestro/Maestro.Base:
Editor Properties
svn_mapguide at osgeo.org
Fri Aug 5 07:48:22 EDT 2011
Author: jng
Date: 2011-08-05 04:48:21 -0700 (Fri, 05 Aug 2011)
New Revision: 6038
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.resx
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
#1769: Implement in-place upgrade of edited resources. This was easier than I thought it would be!
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-08-05 11:28:25 UTC (rev 6037)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-08-05 11:48:21 UTC (rev 6038)
@@ -32,6 +32,8 @@
using Maestro.Base.UI;
using Maestro.Base.UI.Preferences;
using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI.Resource.Conversion;
+using System.IO;
namespace Maestro.Base.Editor
@@ -289,7 +291,29 @@
private void btnUpgrade_Click(object sender, EventArgs e)
+ var res = _svc.GetEditedResource();
+ var conn = res.CurrentConnection;
+ var ver = conn.Capabilities.GetMaxSupportedResourceVersion(res.ResourceType);
+ using (new WaitCursor(this))
+ var conv = new ResourceObjectConverter();
+ var res2 = conv.Convert(res, ver);
+ using (var stream = ResourceTypeRegistry.Serialize(res2))
+ using (var sr =new StreamReader(stream))
+ _svc.UpdateResourceContent(sr.ReadToEnd());
+ ((ResourceEditorService)_svc).ReReadSessionResource();
+ //This will re-init everything
+ this.EditorService = this.EditorService;
+ MessageBox.Show(string.Format(Properties.Resources.ResourceUpgraded, ver.Major, ver.Minor, ver.Build));
+ this.EditorService.MarkDirty(); //It gets re-init with a clean slate, but an in-place upgrade is a dirty operation
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.resx
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.resx 2011-08-05 11:28:25 UTC (rev 6037)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.resx 2011-08-05 11:48:21 UTC (rev 6038)
@@ -150,9 +150,6 @@
<data name="btnUpgrade.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Right</value>
</data>
- <data name="btnUpgrade.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
- </data>
<data name="btnUpgrade.Location" type="System.Drawing.Point, System.Drawing">
<value>526, 8</value>
</data>
@@ -235,6 +232,6 @@
<value>EditorContentBase</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Base.ViewContentBase, Maestro.Base, Version=3.0.0.5610, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Base.ViewContentBase, Maestro.Base, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-05 11:28:25 UTC (rev 6037)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-05 11:48:21 UTC (rev 6038)
@@ -1622,6 +1622,15 @@
/// <summary>
+ /// Looks up a localized string similar to Resource upgraded to schema version {0}.{1}.{2}.
+ /// </summary>
+ internal static string ResourceUpgraded {
+ get {
+ return ResourceManager.GetString("ResourceUpgraded", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Failed to decode the current bounds,
///you must re-enter the epsg code in the SRS tag manually.
///Error message: {0}..
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-05 11:28:25 UTC (rev 6037)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-05 11:48:21 UTC (rev 6038)
@@ -1049,4 +1049,7 @@
<data name="SiteExplorer_CreateFolderStructure" xml:space="preserve">
<value>Create Standard Folder Structure</value>
</data>
+ <data name="ResourceUpgraded" xml:space="preserve">
+ <value>Resource upgraded to schema version {0}.{1}.{2}</value>
+ </data>
</root>
More information about the mapguide-commits
