[mapguide-commits] r6270 -
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks
svn_mapguide at osgeo.org
Thu Dec 1 09:16:38 EST 2011
Author: jng
Date: 2011-12-01 06:16:38 -0800 (Thu, 01 Dec 2011)
New Revision: 6270
Added:
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.designer.cs
Oops. Left out the actual updated SDK sample
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx 2011-12-01 14:16:38 UTC (rev 6270)
@@ -0,0 +1,21 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="ModifyParcelsFilter.aspx.cs" Inherits="SamplesWeb.Tasks.ModifyParcelsFilter" %>
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" >
+<head id="Head1" runat="server">
+ <title>Untitled Page</title>
+</head>
+<body>
+ <form id="form1" runat="server">
+ <div>
+ <asp:Label ID="lblMessage" runat="server"></asp:Label>
+ <br />
+ <a id="resetLink" runat="server">Reset</a>
+ <a href="Home.aspx">Go back</a>
+ <br />
+ <div id="debug" runat="server">
+ </div>
+ </div>
+ </form>
+</body>
+</html>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.cs (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.cs 2011-12-01 14:16:38 UTC (rev 6270)
@@ -0,0 +1,117 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Web;
+using System.Web.UI;
+using System.Web.UI.WebControls;
+using System.Configuration;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+namespace SamplesWeb.Tasks
+ public partial class ModifyParcelsFilter : System.Web.UI.Page
+ protected void Page_Load(object sender, EventArgs e)
+ if (!IsPostBack)
+ string agent = ConfigurationManager.AppSettings["MapAgentUrl"];
+ string mapName = Request.Params["MAPNAME"];
+ string session = Request.Params["SESSION"];
+ IServerConnection conn = ConnectionProviderRegistry.CreateConnection(
+ "Maestro.Http",
+ "Url", agent,
+ "SessionId", session);
+ IMappingService mpSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+ string rtMapId = "Session:" + conn.SessionID + "//" + mapName + ".Map";
+ RuntimeMap rtMap = mpSvc.OpenMap(rtMapId);
+ int layerIndex = rtMap.Layers.IndexOf("Parcels");
+ RuntimeMapLayer layer = rtMap.Layers[layerIndex];
+ //Here is now the layer replacement technique works:
+ //We take the Layer Definition content referenced by the old layer
+ //Modify the filter in this content and save it to a new resource id
+ //We then create a replacement layer that points to this new resource id
+ //and set the public properties to be identical of the old layer.
+ //Finally we then remove the old layer and put the replacement layer in its
+ //place, before saving the runtime map.
+ ILayerDefinition ldf = (ILayerDefinition)conn.ResourceService.GetResource(layer.LayerDefinitionID);
+ IVectorLayerDefinition vl = (IVectorLayerDefinition)ldf.SubLayer;
+ //Sets the layer filter
+ vl.Filter = "RNAME LIKE 'SCHMITT%'";
+ if (Request.Params["RESET"] == "1")
+ vl.Filter = "";
+ //Save this modified layer under a different resource id
+ string ldfId = "Session:" + conn.SessionID + "//ParcelsFiltered.LayerDefinition";
+ conn.ResourceService.SaveResourceAs(ldf, ldfId);
+ //Note that SaveResourceAs does not modify the ResourceID of the resource we want to save
+ //so we need to update it here
+ ldf.ResourceID = ldfId;
+ //Create our replacement layer and apply the same properties from the old one
+ RuntimeMapLayer replace = new RuntimeMapLayer(rtMap, ldf);
+ replace.ExpandInLegend = layer.ExpandInLegend;
+ replace.Group = layer.Group;
+ replace.Name = layer.Name;
+ replace.Selectable = layer.Selectable;
+ replace.ShowInLegend = layer.ShowInLegend;
+ replace.Visible = layer.Visible;
+ //Remove the old layer and put the new layer at the same position (thus having the
+ //same draw order)
+ rtMap.Layers.RemoveAt(layerIndex);
+ rtMap.Layers.Insert(layerIndex, replace);
+ replace.ForceRefresh();
+ rtMap.Save();
+ lblMessage.Text = "Layer filter has been reset";
+ resetLink.Visible = false;
+ else
+ lblMessage.Text = "Layer filter has been set (to RNAME LIKE 'SCHMITT%')";
+ resetLink.Attributes["href"] = "ModifyParcelsFilter.aspx?MAPNAME=" + mapName + "&SESSION=" + session + "&RESET=1";
+ Page.ClientScript.RegisterStartupScript(
+ this.GetType(),
+ "load",
+ "<script type=\"text/javascript\"> window.onload = function() { parent.parent.Refresh(); } </script>");
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.designer.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.designer.cs (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/ModifyParcelsFilter.aspx.designer.cs 2011-12-01 14:16:38 UTC (rev 6270)
@@ -0,0 +1,61 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.5448
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace SamplesWeb.Tasks {
+ public partial class ModifyParcelsFilter {
+ /// <summary>
+ /// Head1 control.
+ /// </summary>
+ /// <remarks>
+ /// Auto-generated field.
+ /// To modify move field declaration from designer file to code-behind file.
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlHead Head1;
+ /// <summary>
+ /// form1 control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlForm form1;
+ /// <summary>
+ /// lblMessage control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.WebControls.Label lblMessage;
+ /// <summary>
+ /// resetLink control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlAnchor resetLink;
+ /// <summary>
+ /// debug control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlGenericControl debug;
More information about the mapguide-commits
