[mapguide-commits] r6271 - in
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI: Properties
Resource/Validation
svn_mapguide at osgeo.org
Thu Dec 1 09:43:47 EST 2011
Author: jng
Date: 2011-12-01 06:43:47 -0800 (Thu, 01 Dec 2011)
New Revision: 6271
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
Add a new Layer Definition validation rule to check if a composite style is defined alongside a area/point/line style. If such a case is found, the composite style will always take precedence over the area/point/line style, thus that style will always be ignored.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2011-12-01 14:16:38 UTC (rev 6270)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2011-12-01 14:43:47 UTC (rev 6271)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4963
+// Runtime Version:2.0.50727.5448
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -548,6 +548,24 @@
/// <summary>
+ /// Looks up a localized string similar to Infinity.
+ /// </summary>
+ internal static string Infinity {
+ get {
+ return ResourceManager.GetString("Infinity", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The scale range {0} to {1} contains a composite style defined alongside a area/point/line style. The composite style takes precedence in such cases meaning the area/point/line style is always ignored.
+ /// </summary>
+ internal static string LDF_CompositeStyleDefinedAlongsideBasicStyle {
+ get {
+ return ResourceManager.GetString("LDF_CompositeStyleDefinedAlongsideBasicStyle", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Failed to load specified Drawing Source.
/// </summary>
internal static string LDF_DrawingSourceError {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2011-12-01 14:16:38 UTC (rev 6270)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2011-12-01 14:43:47 UTC (rev 6271)
@@ -539,4 +539,10 @@
<data name="DuplicateKeyExceptionMessage" xml:space="preserve">
<value>An item with the key value ({0}) already exists in the collection</value>
</data>
+ <data name="LDF_CompositeStyleDefinedAlongsideBasicStyle" xml:space="preserve">
+ <value>The scale range {0} to {1} contains a composite style defined alongside a area/point/line style. The composite style takes precedence in such cases meaning the area/point/line style is always ignored</value>
+ </data>
+ <data name="Infinity" xml:space="preserve">
+ <value>Infinity</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs 2011-12-01 14:16:38 UTC (rev 6270)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/BaseLayerDefinitionValidator.cs 2011-12-01 14:43:47 UTC (rev 6271)
@@ -91,6 +91,23 @@
List<KeyValuePair<double, double>> ranges = new List<KeyValuePair<double, double>>();
foreach (IVectorScaleRange vsr in vldef.VectorScaleRange)
+ IVectorScaleRange2 vsr2 = vsr as IVectorScaleRange2;
+ if (vsr2 != null)
+ var area = vsr2.AreaStyle;
+ var line = vsr2.LineStyle;
+ var point = vsr2.PointStyle;
+ var comp = vsr2.CompositeStyle;
+ if (comp != null && (area != null || line != null || point != null))
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, ValidationStatusCode.Warning_LayerDefinition_CompositeStyleDefinedAlongsideBasicStyle, string.Format(
+ Properties.Resources.LDF_CompositeStyleDefinedAlongsideBasicStyle,
+ vsr2.MinScale.HasValue ? vsr2.MinScale.Value : 0,
+ vsr2.MaxScale.HasValue ? vsr2.MaxScale.Value.ToString() : Properties.Resources.Infinity)));
ranges.Add(new KeyValuePair<double, double>(
vsr.MaxScale.HasValue ? vsr.MaxScale.Value : double.PositiveInfinity,
vsr.MinScale.HasValue ? vsr.MinScale.Value : double.NegativeInfinity));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2011-12-01 14:16:38 UTC (rev 6270)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Validation/ValidationStatusCode.cs 2011-12-01 14:43:47 UTC (rev 6271)
@@ -176,6 +176,12 @@
Warning_LayerDefinition_MultipleGridScaleRanges,
/// <summary>
+ /// A scale range was found in a Layer Definition which has a composite style defined along side a point, line or area style. In such cases, the
+ /// composite style will always take precedence and the point/line/area style will have no effect
+ /// </summary>
+ Warning_LayerDefinition_CompositeStyleDefinedAlongsideBasicStyle,
+ /// <summary>
/// The web layout's initial view lies outside the referenced map definition's extents. Usually means you will see nothing when the AJAX viewer loads.
/// </summary>
Warning_WebLayout_InitialViewOutsideMapExtents = 3601,
More information about the mapguide-commits
