[mapguide-commits] r6324 - in trunk/Tools/Maestro: Doc/Images
Doc/Topics OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Fri Dec 9 05:27:04 EST 2011
Author: jng
Date: 2011-12-09 02:27:04 -0800 (Fri, 09 Dec 2011)
New Revision: 6324
trunk/Tools/Maestro/Doc/Images/CoreTypesClassDiagram.png
trunk/Tools/Maestro/Doc/Topics/Concept_RuntimeMap.aml
trunk/Tools/Maestro/Doc/Topics/GettingStarted.aml
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoreTypes.cd
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
Remove unnecessary try/catch in Utility.CopyStream. Also some more API documentation updates (#1319)
Modified: trunk/Tools/Maestro/Doc/Images/CoreTypesClassDiagram.png
(Binary files differ)
Modified: trunk/Tools/Maestro/Doc/Topics/Concept_RuntimeMap.aml
--- trunk/Tools/Maestro/Doc/Topics/Concept_RuntimeMap.aml 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/Doc/Topics/Concept_RuntimeMap.aml 2011-12-09 10:27:04 UTC (rev 6324)
@@ -44,7 +44,8 @@
<code>Session:session-id//mapName.Map</code>
<para>
Most of this runtime map state can be manipulated through the APIs provided by the Maestro API. When manipulating the state
- of the runtime map, you must remember to call <codeEntityReference qualifyHint="false">M:OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap.Save</codeEntityReference> on the map
+ of the runtime map (which also includes modifications to layers and groups that belong to it), you must remember to call
+ <codeEntityReference qualifyHint="false">M:OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap.Save</codeEntityReference> on the map
to persist your modifications.
</para>
</content>
Modified: trunk/Tools/Maestro/Doc/Topics/GettingStarted.aml
--- trunk/Tools/Maestro/Doc/Topics/GettingStarted.aml 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/Doc/Topics/GettingStarted.aml 2011-12-09 10:27:04 UTC (rev 6324)
@@ -85,8 +85,7 @@
Then in your application's entry point, add the following line of code:
</para>
- <code language="cs">
- /// Code
+ <code language="cs">
ModelSetup.Initialize();
</code>
<para>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoreTypes.cd
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoreTypes.cd 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/CoreTypes.cd 2011-12-09 10:27:04 UTC (rev 6324)
@@ -1,7 +1,7 @@
<?xml version="1.0" encoding="utf-8"?>
<ClassDiagram MajorVersion="1" MinorVersion="1" GroupingSetting="Access">
<Comment CommentText="Runtime Map Classes">
- <Position X="24.312" Y="1.387" Height="0.311" Width="2.134" />
+ <Position X="24.124" Y="1.189" Height="0.311" Width="2.759" />
</Comment>
<Comment CommentText="Maestro API root classes / interfaces">
<Position X="23.786" Y="6.767" Height="0.441" Width="2.653" />
@@ -18,8 +18,8 @@
<Comment CommentText="Use IServerConnection.GetService(int) to create service objects of the specified type, passing in a ServiceType enum casted to an int. Use connection capabilities to determine supported services. All IServerConnection implementations have built-in support for resource and feature services and are accessible via the top-level ResourceService and FeatureService properties.">
<Position X="11.946" Y="6.668" Height="1.073" Width="4.942" />
</Comment>
- <Comment CommentText="The IMappingService provides operations to create, open and interact with a RuntimeMap">
- <Position X="24.298" Y="1.851" Height="0.609" Width="2.134" />
+ <Comment CommentText="The IMappingService provides operations to create, open and interact with a RuntimeMap and methods to create RuntimeMapLayer and RuntimeMapGroup instances that can then be added to the RuntimeMap">
+ <Position X="24.11" Y="1.653" Height="0.984" Width="3.113" />
</Comment>
<Comment CommentText="Schema API - Classes used to model the structure of a Feature Source">
<Position X="22.665" Y="9.539" Height="0.353" Width="4.34" />
@@ -61,7 +61,7 @@
<Position X="7.266" Y="9.617" Height="0.531" Width="1.971" />
</Comment>
<Comment CommentText="Used for creating, opening and interacting with a Runtime Map">
- <Position X="9.508" Y="10.805" Height="0.552" Width="1.971" />
+ <Position X="9.529" Y="11.295" Height="0.552" Width="1.971" />
</Comment>
<Comment CommentText="Used for querying MapGuide Server information">
<Position X="11.758" Y="10.034" Height="0.51" Width="1.981" />
@@ -273,7 +273,7 @@
<Interface Name="OSGeo.MapGuide.MaestroAPI.Services.IMappingService">
<Position X="9.5" Y="8.25" Width="2" />
<TypeIdentifier>
- <HashCode>AAAAAAAAEAAAAAAAAAAAAAAAAEAAAAAEABAAEAAAUAA=</HashCode>
+ <HashCode>AAAAAAAAEAAAAAAAAAEAAAAAAEAAAAAEABAAEAAAUAE=</HashCode>
<FileName>Services\IMappingService.cs</FileName>
</TypeIdentifier>
</Interface>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapGroup.cs 2011-12-09 10:27:04 UTC (rev 6324)
@@ -26,7 +26,8 @@
namespace OSGeo.MapGuide.MaestroAPI.Mapping
/// <summary>
- /// Represents a group of layers in a runtime map
+ /// Represents a group of layers in a runtime map. Use <see cref="M:OSGeo.MapGuide.MaestroAPI.Services.IMappingService.CreateMapGroup(OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap,OSGeo.MapGuide.ObjectModels.MapDefinition.IMapLayerGroup)"/> to create
+ /// instances of this class.
/// </summary>
public class RuntimeMapGroup : MapObservable
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-09 10:27:04 UTC (rev 6324)
@@ -60,7 +60,8 @@
/// <summary>
- /// Represents a runtime map layer
+ /// Represents a runtime map layer. Use <see cref="M:OSGeo.MapGuide.MaestroAPI.Services.IMappingService.CreateMapLayer(OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap,OSGeo.MapGuide.ObjectModels.LayerDefinition.ILayerDefinition)"/> to create
/// </summary>
public class RuntimeMapLayer : MapObservable
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-12-09 10:27:04 UTC (rev 6324)
@@ -1729,6 +1729,7 @@
/// <returns></returns>
public virtual RuntimeMapGroup CreateMapGroup(RuntimeMap parent, string name)
+ //TODO: Review when we split implementations
return new RuntimeMapGroup(parent, name);
@@ -1740,6 +1741,7 @@
public virtual RuntimeMapGroup CreateMapGroup(RuntimeMap parent, IBaseMapGroup group)
return new RuntimeMapGroup(parent, group);
@@ -1751,6 +1753,7 @@
public virtual RuntimeMapGroup CreateMapGroup(RuntimeMap parent, IMapLayerGroup group)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2011-12-09 06:34:18 UTC (rev 6323)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2011-12-09 10:27:04 UTC (rev 6324)
@@ -273,8 +273,8 @@
public static void CopyStream(System.IO.Stream source, System.IO.Stream target, StreamCopyProgressDelegate callback, long updateFrequence)
long length = -1;
- try { length = source.Length; }
- catch { }
+ if (source.CanSeek)
+ length = source.Length;
long copied = 0;
long freqCount = 0;
More information about the mapguide-commits
