[mapguide-commits] r6325 - in trunk/MgDev/Doc/devguide/source: .
images
svn_mapguide at osgeo.org
Fri Dec 9 07:30:16 EST 2011
Author: jng
Date: 2011-12-09 04:30:16 -0800 (Fri, 09 Dec 2011)
New Revision: 6325
Added:
trunk/MgDev/Doc/devguide/source/images/platformapi.png
trunk/MgDev/Doc/devguide/source/conf.py
trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst
trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst
#1614: More devguide content updates. Also change the sphinx document theme to a more cleaner looking theme (nature)
Modified: trunk/MgDev/Doc/devguide/source/conf.py
--- trunk/MgDev/Doc/devguide/source/conf.py 2011-12-09 10:27:04 UTC (rev 6324)
+++ trunk/MgDev/Doc/devguide/source/conf.py 2011-12-09 12:30:16 UTC (rev 6325)
@@ -95,7 +95,7 @@
# The theme to use for HTML and HTML Help pages. See the documentation for
# a list of builtin themes.
-html_theme = 'sphinxdoc'
+html_theme = 'nature'
# Theme options are theme-specific and customize the look and feel of a theme
# further. For a list of options available for each theme, see the
@@ -151,7 +151,7 @@
#html_split_index = False
# If true, links to the reST sources are added to the pages.
-#html_show_sourcelink = True
+html_show_sourcelink = True
# If true, "Created using Sphinx" is shown in the HTML footer. Default is True.
#html_show_sphinx = True
Modified: trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst
--- trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst 2011-12-09 10:27:04 UTC (rev 6324)
+++ trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst 2011-12-09 12:30:16 UTC (rev 6325)
@@ -107,6 +107,8 @@
single: Redlining; Creating a Feature Source
single: Feature Source; Creating
+.. _create-feature-source:
Added: trunk/MgDev/Doc/devguide/source/images/platformapi.png
(Binary files differ)
Property changes on: trunk/MgDev/Doc/devguide/source/images/platformapi.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst
--- trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst 2011-12-09 10:27:04 UTC (rev 6324)
+++ trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst 2011-12-09 12:30:16 UTC (rev 6325)
@@ -6,18 +6,169 @@
Using Transactions
+A transaction encapsulates a unit of work performed on a Feature Source that will either wholly succeed or wholly fail. Transactions ensure the Feature Source is kept in a consistent state whether the operation succeeded or the operation failed.
+In the MapGuide API, the **MgTransaction** class represents the transaction to be performed in a Feature Source. The following example shows how to use a transaction over a series of feature operations:
+**.net (C#)**
+.. highlight:: csharp
+.. code-block:: csharp
+ //This code fragment assumes you have imported the OSGeo.MapGuide namespace
+ MgTransaction trans = null;
+ MgFeatureService featSvc = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+ MgResourceIdentifier featureSourceId = new MgResourceIdentifier("Library://Data/Test.FeatureSource");
+ try
+ //Start the transaction, all changes below will not take effect until the transaction is committed
+ trans = featSvc.StartTransaction(featureSourceId);
+ //This does a SQL insert on the feature source
+ featSvc.ExecuteSql(featureSourceId, "INSERT INTO TABLE1(ID, NAME) VALUES(123, 'Test'), trans);
+ //This does a SQL update on the feature source
+ featSvc.ExecuteSql(featureSourceId, "UPDATE TABLE1 SET NAME = 'Joe Bloggs' WHERE ID = 32", trans);
+ //This does a SQL delete on the feature source
+ featSvc.ExecuteSql(featureSourceId, "DELETE FROM TABLE1 WHERE ID = 456, trans);
+ //Committing the transaction. The above changes will take effect
+ trans.Commit();
+ catch (MgException ex)
+ //Rollback the transaction. Any changes that the above SQL commands would've
+ //made are discarded
+ if (trans != null)
+ trans.Rollback();
+.. note::
+ Transactions are only supported by certain FDO providers. Check the provider capabilities of the Feature Source to determine if Transactions are available.
Describing a Feature Source
-Creating a File-based Feature Source
+A Feature Source represents a connection to a FDO data store. FDO data stores are modeled in the following fashion:
-Feature Source CRUD
+ * A data store contains 1 or more Feature Schemas
+ * A Feature Schema contains 1 or more Class Definitions
+ * A Class Definition contains 1 or more Property Definitions
+The **MgFeatureService** class provides various methods for describing such aspects of a Feature Source
+The following example lists the schema names of a Feature Source
+**.net (C#)**
+ MgStringCollection schemaNames = featSvc.GetSchemas(featureSourceId);
+ Response.Write("<p>Schema Names:</p><ul>");
+ for (int i = 0; i < schemaNames.GetCount(); i++)
+ Response.Write("<li>" + schemaNames.GetItem(i) + "</li>");
+ Response.Write("</ul>");
+The following example lists the class names for a given schema
+**.net (C#)**
+ MgStringCollection classNames = featSvc.GetClasses(featureSourceId, schemaName);
+ Response.Write("<p>Class Names for " + schemaName + ":</p><ul>");
+ for (int i = 0; i < classNames.GetCount(); i++)
+ Response.Write("<li>" + classNames.GetItem(i) + "</li>");
+Given a schema name and class name, the following example gets the matching class definition and writes out information about the class definition
+**.net (C#)**
+ MgClassDefinition classDef = featSvc.GetClassDefinition(featureSourceId, schemaName, className);
+ Response.Write("<p>Name: " + classDef.GetName() + "</p>");
+ Response.Write("<p>Description: " + classDef.GetDescription() + "</p>");
+ Response.Write("<p>Default Geometry Property: " + classDef.GetDefaultGeometryPropertyName() + "</p>");
+ MgPropertyDefinitionCollection identityProps = classDef.GetIdentityProperties();
+ MgPropertyDefinitionCollection clsProps = classDef.GetProperties();
+ Response.Write("<p>Class Properties (* are identity):</p>");
+ Response.Write("<ul>");
+ for (int i = 0; i < clsProps.GetCount(); i++)
+ MgPropertyDefinition propDef = clsProps.GetItem(i);
+ Response.Write("<li>" + propDef.GetName());
+ if (propDef.GetPropertyType() == MgFeaturePropertyType.AssociationProperty)
+ Response.Write(" (Association)");
+ else if (propDef.GetPropertyType() == MgFeaturePropertyType.DataProperty)
+ Response.Write(" (Data)");
+ else if (propDef.GetPropertyType() == MgFeaturePropertyType.GeometricProperty)
+ Response.Write(" (Geometry)");
+ else if (propDef.GetPropertyType() == MgFeaturePropertyType.ObjectProperty)
+ Response.Write(" (Object)");
+ else if (propDef.GetPropertyType() == MgFeaturePropertyType.RasterProperty)
+ Response.Write(" (Raster)");
+ Response.Write(")");
+ if (identityProps.Contains(propDef))
+ Response.Write(" *");
+ Response.Write("</li>");
Creating and Modifying Schemas
+The MapGuide API, not only allows you to manipulate data in a data store, it also allows you to create and modify the structure of a data store. :ref:`create-feature-source` showed how to create a data store with a defined schema, the `ApplySchema` API allows you to modify such schemas.
+The following example, modifies the `Default` schema by deleting the `Test` class definition inside
+**.net (C#)**
+ //Get the original "Test" schema
+ MgFeatureSchemaCollection schemas = featSvc.DescribeSchema(featureSourceId, "Default");
+ MgFeatureSchema schema = schemas.GetItem(0);
+ //Find the "Test" class definition and set the deletion flag
+ MgClassDefinitionCollection classes = schema.GetClasses();
+ for (int i = 0; i < classes.GetCount(); i++)
+ MgClassDefinition cls = classes.GetItem(i);
+ if (cls.GetName() == "Test")
+ cls.Delete(); //Mark this class definition for deletion
+ break;
+ //Apply the schema. This will delete the "Test" class definition
+ featSvc.ApplySchema(featureSourceId, schema);
+.. note::
+ Not all data stores support the `ApplySchema` API. Check the FDO provider capabilities of the feature source to determine if such an operation is possible.
Quering Data with Expressions and Filters
@@ -25,4 +176,12 @@
The Geospatial Platform and MapGuide's role in it
\ No newline at end of file
+The MapGuide API shares common code with products like AutoCAD Map3D. The common code that is shared between MapGuide and AutoCAD Map3D is known as the Geospatial Platform API
+.. image:: images/platformapi.png
+The classes for the Geospatial Platform API resides in the MgPlatformBase.dll library and is accessible in .net via the OSGeo.MapGuide.PlatformBase.dll assembly.
+By writing code that targets against the Geospatial Platform API (for example, using the `MgMapBase` class instead of `MgMap`) your code is easily portable between other products that are also built on top of it (like AutoCAD Map3D)
More information about the mapguide-commits
