[mapguide-commits] r5933 - in trunk/Tools/Maestro: Maestro
Maestro.Base Maestro.Base/Commands Maestro.Base/Editor
Maestro.Base/Events Maestro.Base/Properties
Maestro.Base/Services Maestro.Base/Services/DragDropHandlers
Maestro.Shared.UI Maestro.Shared.UI/Properties
Maestro.Shared.UI/Resources
svn_mapguide at osgeo.org
Fri Jun 17 13:44:56 EDT 2011
Author: jng
Date: 2011-06-17 10:44:56 -0700 (Fri, 17 Jun 2011)
New Revision: 5933
Added:
trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.cs
trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.resx
trunk/Tools/Maestro/Maestro.Shared.UI/Resources/ErrorLogTemplate.txt
trunk/Tools/Maestro/Maestro.Base/Commands/CacheViewerCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
trunk/Tools/Maestro/Maestro.Base/ViewContentBase.cs
trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx
trunk/Tools/Maestro/Maestro/Program.cs
#1723: Add a cleaner message for lost connection.
#1724: Add a more flexible error dialog for displaying handled exceptions.
Modified: trunk/Tools/Maestro/Maestro/Program.cs
--- trunk/Tools/Maestro/Maestro/Program.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro/Program.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -30,6 +30,7 @@
using ICSharpCode.Core.WinForms;
using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
using Maestro.Login;
+using Maestro.Shared.UI;
namespace Maestro
@@ -134,7 +135,7 @@
catch (Exception ex)
- MessageService.ShowError(ex, "Error storing properties");
+ ErrorDialog.Show("Error storing properties", ex.ToString());
LoggingService.Info("Application shutdown");
@@ -147,7 +148,7 @@
static void Application_ThreadException(object sender, System.Threading.ThreadExceptionEventArgs e)
- MessageService.ShowError(e.Exception);
+ ErrorDialog.Show(e.Exception);
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/CacheViewerCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/CacheViewerCommand.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/CacheViewerCommand.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -24,6 +24,7 @@
using Maestro.Base.Services;
using Maestro.Editors.Diagnostics;
using OSGeo.MapGuide.MaestroAPI.Commands;
namespace Maestro.Base.Commands
@@ -42,7 +43,7 @@
- MessageService.ShowError(ex.Message);
+ ErrorDialog.Show(ex);
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -24,6 +24,7 @@
using OSGeo.MapGuide.MaestroAPI.Services;
@@ -37,7 +38,7 @@
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -31,6 +31,7 @@
using Maestro.Base.UI;
using Maestro.Base.UI.Preferences;
namespace Maestro.Base.Editor
@@ -132,7 +133,7 @@
- MessageService.ShowError(ex);
e.Cancel = true;
Modified: trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
--- trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -58,8 +58,15 @@
string sessionId = conn.SessionID;
if (!string.IsNullOrEmpty(sessionId))
- conn.FeatureService.GetProviderCapabilities("OSGeo.SDF");
- LoggingService.Info("Session kept alive: " + sessionId);
+ try
+ conn.FeatureService.GetProviderCapabilities("OSGeo.SDF");
+ LoggingService.Info("Session kept alive: " + sessionId);
+ catch (Exception ex)
+ MessageService.ShowError(Properties.Resources.KeepAliveFailed);
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -793,6 +793,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Failed to keep session alive. This would happen if connectivity to the MapGuide Server has been lost (it has been stopped or restarted). Refresh the Site Explorer to create a new session. Also close any existing editors and re-open them..
+ /// </summary>
+ internal static string KeepAliveFailed {
+ get {
+ return ResourceManager.GetString("KeepAliveFailed", resourceCulture);
internal static System.Drawing.Bitmap layer {
get {
object obj = ResourceManager.GetObject("layer", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-06-17 17:44:56 UTC (rev 5933)
@@ -1022,4 +1022,7 @@
<data name="SiteExplorer_ShowSpatialContexts" xml:space="preserve">
<value>Show Spatial Contexts</value>
</data>
+ <data name="KeepAliveFailed" xml:space="preserve">
+ <value>Failed to keep session alive. This would happen if connectivity to the MapGuide Server has been lost (it has been stopped or restarted). Refresh the Site Explorer to create a new session. Also close any existing editors and re-open them.</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -23,6 +23,7 @@
using System.IO;
using ICSharpCode.Core;
using Maestro.Packaging;
namespace Maestro.Base.Services.DragDropHandlers
@@ -64,7 +65,7 @@
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -24,6 +24,7 @@
using System.IO;
using OSGeo.MapGuide.ObjectModels;
@@ -73,7 +74,7 @@
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -24,6 +24,7 @@
using System.IO;
using OSGeo.MapGuide.MaestroAPI.Resource;
@@ -91,7 +92,7 @@
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -24,6 +24,7 @@
using System.IO;
@@ -73,7 +74,7 @@
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -25,6 +25,7 @@
using System.IO;
using OSGeo.MapGuide.MaestroAPI;
@@ -79,7 +80,7 @@
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -25,6 +25,7 @@
using Maestro.Base.Editor;
@@ -203,7 +204,7 @@
return null;
Modified: trunk/Tools/Maestro/Maestro.Base/ViewContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/ViewContentBase.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Base/ViewContentBase.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -26,6 +26,7 @@
using System.Windows.Forms;
@@ -86,7 +87,7 @@
public void ShowError(Exception ex)
public void ShowError(string message)
Added: trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.Designer.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -0,0 +1,107 @@
+namespace Maestro.Shared.UI
+ partial class ErrorDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ErrorDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtMessage = new System.Windows.Forms.TextBox();
+ this.txtDetails = new System.Windows.Forms.TextBox();
+ this.btnClose = new System.Windows.Forms.Button();
+ this.btnSave = new System.Windows.Forms.Button();
+ this.saveFileDialog = new System.Windows.Forms.SaveFileDialog();
+ this.SuspendLayout();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // label2
+ resources.ApplyResources(this.label2, "label2");
+ this.label2.Name = "label2";
+ // txtMessage
+ resources.ApplyResources(this.txtMessage, "txtMessage");
+ this.txtMessage.Name = "txtMessage";
+ this.txtMessage.ReadOnly = true;
+ // txtDetails
+ resources.ApplyResources(this.txtDetails, "txtDetails");
+ this.txtDetails.Name = "txtDetails";
+ this.txtDetails.ReadOnly = true;
+ // btnClose
+ resources.ApplyResources(this.btnClose, "btnClose");
+ this.btnClose.Name = "btnClose";
+ this.btnClose.UseVisualStyleBackColor = true;
+ this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+ // btnSave
+ resources.ApplyResources(this.btnSave, "btnSave");
+ this.btnSave.Name = "btnSave";
+ this.btnSave.UseVisualStyleBackColor = true;
+ this.btnSave.Click += new System.EventHandler(this.btnSave_Click);
+ // saveFileDialog
+ resources.ApplyResources(this.saveFileDialog, "saveFileDialog");
+ // ErrorDialog
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ resources.ApplyResources(this, "$this");
+ this.Controls.Add(this.btnSave);
+ this.Controls.Add(this.btnClose);
+ this.Controls.Add(this.txtDetails);
+ this.Controls.Add(this.txtMessage);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.label1);
+ this.Name = "ErrorDialog";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtMessage;
+ private System.Windows.Forms.TextBox txtDetails;
+ private System.Windows.Forms.Button btnClose;
+ private System.Windows.Forms.Button btnSave;
+ private System.Windows.Forms.SaveFileDialog saveFileDialog;
Added: trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -0,0 +1,75 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using System.IO;
+using System.Reflection;
+ /// <summary>
+ /// A flexible error dialog for displaying error messages and exceptions
+ /// </summary>
+ public partial class ErrorDialog : Form
+ public ErrorDialog()
+ InitializeComponent();
+ private void btnClose_Click(object sender, EventArgs e)
+ this.Close();
+ private void btnSave_Click(object sender, EventArgs e)
+ if (saveFileDialog.ShowDialog() == DialogResult.OK)
+ File.WriteAllText(saveFileDialog.FileName,
+ string.Format(Properties.Resources.ErrorLogTemplate,
+ Assembly.GetExecutingAssembly().GetName().Version.ToString(),
+ DateTime.Now.ToString(),
+ txtMessage.Text,
+ txtDetails.Text));
+ MessageBox.Show(Properties.Resources.FileSaved);
+ public static void Show(string message, string detail)
+ var diag = new ErrorDialog();
+ diag.txtMessage.Text = message;
+ diag.txtDetails.Text = detail;
+ diag.ShowDialog();
+ public static void Show(Exception ex)
+ Show(ex.Message, ex.ToString());
Added: trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.resx
--- trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/ErrorDialog.resx 2011-06-17 17:44:56 UTC (rev 5933)
@@ -0,0 +1,1845 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>50, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Message</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 108</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>39, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Details</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="txtMessage.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtMessage.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 40</value>
+ </data>
+ <data name="txtMessage.Multiline" type="System.Boolean, mscorlib">
+ </data>
+ <data name="txtMessage.Size" type="System.Drawing.Size, System.Drawing">
+ <value>470, 53</value>
+ </data>
+ <data name="txtMessage.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>txtMessage.Name" xml:space="preserve">
+ <value>txtMessage</value>
+ </data>
+ <data name=">>txtMessage.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtMessage.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtMessage.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="txtDetails.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="txtDetails.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 133</value>
+ </data>
+ <data name="txtDetails.Multiline" type="System.Boolean, mscorlib">
+ </data>
+ <data name="txtDetails.Size" type="System.Drawing.Size, System.Drawing">
+ <value>470, 210</value>
+ </data>
+ <data name="txtDetails.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name=">>txtDetails.Name" xml:space="preserve">
+ <value>txtDetails</value>
+ </data>
+ <data name=">>txtDetails.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtDetails.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtDetails.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnClose.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
+ <value>407, 349</value>
+ </data>
+ <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnClose.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="btnClose.Text" xml:space="preserve">
+ <value>Close</value>
+ </data>
+ <data name=">>btnClose.Name" xml:space="preserve">
+ <value>btnClose</value>
+ </data>
+ <data name=">>btnClose.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnClose.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnClose.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnSave.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
+ <data name="btnSave.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 349</value>
+ </data>
+ <data name="btnSave.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnSave.TabIndex" type="System.Int32, mscorlib">
+ <value>5</value>
+ </data>
+ <data name="btnSave.Text" xml:space="preserve">
+ <value>Save to File</value>
+ </data>
+ <data name=">>btnSave.Name" xml:space="preserve">
+ <value>btnSave</value>
+ </data>
+ <data name=">>btnSave.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnSave.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnSave.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="saveFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="saveFileDialog.Filter" xml:space="preserve">
+ <value>Text Files (*.txt)|*.txt</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>494, 384</value>
+ </data>
+ <data name="$this.Icon" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ AAABAA0AMDAQAAEABABoBgAA1gAAACAgEAABAAQA6AIAAD4HAAAYGBAAAQAEAOgBAAAmCgAAEBAQAAEA
+ BAAoAQAADgwAADAwAAABAAgAqA4AADYNAAAgIAAAAQAIAKgIAADeGwAAGBgAAAEACADIBgAAhiQAABAQ
+ AAABAAgAaAUAAE4rAAAAAAAAAQAgAJrwAAC2MAAAMDAAAAEAIACoJQAAUCEBACAgAAABACAAqBAAAPhG
+ AQAYGAAAAQAgAIgJAACgVwEAEBAAAAEAIABoBAAAKGEBACgAAAAwAAAAYAAAAAEABAAAAAAAgAQAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAACAAACAAAAAgIAAgAAAAIAAgACAgAAAgICAAMDAwAAAAP8AAP8AAAD/
+ /wD/AAAA/wD/AP//AAD///8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHd3d3d3dwAAAAAAAAAAAAAAAAAAAA
+ AHd4j///+Ih3dwAAAAAAAAAAAAAAAAAAd4//iHd3iI//h3cAAAAAAAAAAAAAAAB4j/hxGRmZGRGYj4dw
+ AAAAAAAAAAAAAAeP9xGREZEZGRkZF4+HcAAAAAAAAAAAAH/3EZEZGRGRkZl5mRePdwAAAAAAAAAACPgR
+ EREXEZcZGRkZGZl493AAAAAAAAAAf4EZEZcZERkRkZGZl5kZj3cAAAAAAAAH+BERcRERkZGRGXkZGZGR
+ mPeAAAAAAAB/gRlRkRkRFxEZeRkZkZmZefhwAAAAAAiPcZExEREZGRkZEZGTlZOVkX93AAAAAAf3kREZ
+ F3FxERlxkZGXU5GZmRj3AAAAAH+BEZERGPgRGXGRGRGP95GRk5H4cAAAAI95EReViIiBERkRkZf//3EZ
+ WZGPcAAAB48RkZEYiIj4cREZEYj4//eZGRl4hwAAB/gZERF4iIiPgRkRl4iPj/iRkZl4hwAACPF5GXmX
+ +IiIjxE1eI+I+IkZGTGYhwAAiPGXEZEZeIiIiPEXiIiI+JGRkZGXiHAAeIeXlxkRl/iIiIh4iIiI+XkR
+ lZGViIAAf4l5GXGRGXiIiI+IiIeIkRGRORGTiHAAf3l5eZMZEZiIiIiIh4iJEZEZEZFZj3AAf3l5eXlZ
+ GRmIiIiIiIiXGRlRkVkxj3AAfxeXl5eXkRGX+IiIiIkRkRORORGRiHAAf5eXkZeTWTkXiIiIiIEREZUR
+ kRERj3AAf3eZeXl5eXGI+PiIiPhxGRGREZGRj3AAf4l3l5eXl5j/j4iIiI+BFxEZcRcZ+HAAeIiZeXmX
+ mY+Pj4+IiIj4ERkxkZEXiHAAiPmJeXl5eP//+PiPiIiPgRERERkXiAAACPd5eXl5j//4//mY+IiI/xFZ
+ GVEYiAAAB/iYmJeY/////3l5iPiIj4cTUxl4hwAAB494l5mP////+ReRmI+IiPiRlTl4iAAAAI+JiYl/
+ ////l5eXl4j4iPeXGXGPcAAAAHj3iXmX//+Hl5eXmZiPj4l5eRn4gAAAAAj4mJiZeP+ZeXl5d5mI+JEZ
+ cXj3AAAAAAePiHmJeYeYl5eXmXeYeXl5eX+IAAAAAAB/iYiYl5eXmJeXl5l5l5eXl/hwAAAAAAAI/5h5
+ iYmJeXl5eXl5eZeRePgAAAAAAAAAj/mIl5eYl5iXmJeXl5eXj4AAAAAAAAAACP+J95iZiXl5eXl5eXl/
+ +AAAAAAAAAAAAIj4mImJeYmJeYl5eXj4gAAAAAAAAAAAAAf/+JiImJeXl5eXmI+HAAAAAAAAAAAAAAB4
+ j/iYd4mHeXl4/4iAAAAAAAAAAAAAAAAAeI//iJiZiI//iHAAAAAAAAAAAAAAAAAAAId4j////4iHcAAA
+ AAAAAAAAAAAAAAAAAAAId3d3d3gAAAAAAAAAAAAA////////AAD///////8AAP///////wAA//+AB///
+ AAD//AAA//8AAP/wAAA//wAA/8AAAB//AAD/gAAAB/8AAP8AAAAD/wAA/gAAAAH/AAD8AAAAAP8AAPgA
+ AAAAfwAA8AAAAAB/AADgAAAAAD8AAOAAAAAAPwAAwAAAAAAfAADAAAAAAB8AAIAAAAAADwAAgAAAAAAP
+ AACAAAAAAA8AAAAAAAAABwAAAAAAAAAHAAAAAAAAAAcAAAAAAAAABwAAAAAAAAAHAAAAAAAAAAcAAAAA
+ AAAABwAAAAAAAAAHAAAAAAAAAAcAAAAAAAAABwAAAAAAAAAPAACAAAAAAA8AAIAAAAAADwAAgAAAAAAP
+ AADAAAAAAB8AAMAAAAAAHwAA4AAAAAA/AADgAAAAAD8AAPAAAAAAfwAA+AAAAAD/AAD8AAAAAf8AAP4A
+ AAAD/wAA/wAAAAf/AAD/gAAAD/8AAP/AAAAf/wAA//AAAH//AAD//AAB//8AAP//gA///wAAKAAAACAA
+ AABAAAAAAQAEAAAAAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAIAAAACAgACAAAAAgACAAICA
+ AACAgIAAwMDAAAAA/wAA/wAAAP//AP8AAAD/AP8A//8AAP///wAAAAAAAACHd3d4AAAAAAAAAAAAAAh3
+ iP/4+HeAAAAAAAAAAAh4+IiXF3iPh4AAAAAAAAB4+HkRGRmZF4+HAAAAAAAH+BkRGRGRGZkZj3AAAAAA
+ f4ERGRWRGRkZkTj3AAAAB4iRlxExGTkZGRmRiIAAAIjxEREZGRGRkZWZWZiIAAB/GRGXhxGVEVk4eZGX
+ 9wAIiBGXGPhxGRkT//ORkYiAB4lxEfiPiTEZeI//WRmPcAiHkZGIiP9Rk4j4+JGRmICIiXkZGPiP81iI
+ iIkZGRiIeIkXEZGIiP+IiIiVGTGXh393mXkZGPiIiIiJGTGRl/d/l5eRkZGIiIiIlRGRFZH3f3l5eXcZ
+ eIiI9xkRGRkX93iJl5eZF4/4+I8RORURGfd/h5eZeYj4j4iP95EZORiHiIl5eXn///iPiPhxkREYiAf3
+ l5ef//+JeIiP8RGVOIAH+JeY////eZePiP95eX9wCIiJef//iZeZePiIlxOIcAB/h5ef/3l5eZePh5WX
+ hwAAiIiYmIl5eXeZeJl5eIgAAAeIiYmXmJeXl5l3l4iAAAAAiIh5iXl5eXl5eXiHAAAAAAf4iJiYmJiY
+ l5iIgAAAAAAAePiIeYl5eYiPhwAAAAAAAAh4+IiIeIiPh4AAAAAAAAAACHiIj/iIh3AAAAAAAAAAAAAA
+ h3d3eAAAAAAAAP/wD///gAH//gAAf/wAAD/4AAAf8AAAD+AAAAfAAAADwAAAA4AAAAGAAAABgAAAAQAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAYAAAAGAAAABwAAAA8AAAAPgAAAH8AAAD/gA
+ AB/8AAA//gAAf/+AAf//8A//KAAAABgAAAAwAAAAAQAEAAAAAAAgAQAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAIAAAIAAAACAgACAAAAAgACAAICAAACAgIAAwMDAAAAA/wAA/wAAAP//AP8AAAD/AP8A//8AAP//
+ /wAAAAAAB3d3cAAAAAAAAACHiP/4+HgAAAAAAAePh5F5f/hwAAAAAIiJGRkZGXj3AAAACIgRERGRmZGP
+ gAAAeHkZGRkZGZmX9wAIiJERcRGRlxkZiIAH8ZGYgRkZeIGZf3AIiRF//3EXj/iRmIB4gZGYiPEfj4kZ
+ GId/eXkRj4/4+JGRkfd/l5GZGPiPiRGRl/d/eXl5F/j/ERkREfd4eZeZiP+I9xGRl4d/iXl3//iPjxER
+ l/cIiXmP//mY+PeRWIAH+JmP+JeXj4eTn3AIiHl4iXl5mIlZ+IAAeIl5eZeXl5l39wAACPiYmJeXmXmP
+ cAAAAH+ImJiXmHiIAAAAAAeIiHmHiIhwAAAAAACHiP/4iHgAAAAAAAAACHd3gAAAAAD/gf8A/AA/APgA
+ HwDwAA8A4AAHAMAAAwCAAAEAgAABAIAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAEAgAABAIAA
+ AQDAAAMA4AAHAPAADwD4AB8A/AA/AP+B/wAoAAAAEAAAACAAAAABAAQAAAAAAIAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAICAgADAwMAAAAD/AAD/AAAA//8A/wAAAP8A
+ /wD//wAA////AAAACHd3gAAAAAh3iIiHgAAAh4iXl3h4AAh4ERkZGYeAB4d4EZH3GHCHiY+BGPiXiHh5
+ mPiPgZeHeJEXj/gZGYd4eZl/iBGVh3iJeP+PgReHiImP+X/3mHgHiI95l/94cAh4mJeZeYeAAIeIiYeI
+ hwAACHiIiIeAAAAACHd3gAAA+B8AAOAHAADAAwAAgAEAAIABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AACAAQAAgAEAAMADAADgBwAA+B8AACgAAAAwAAAAYAAAAAEACAAAAAAAAAkAAAAAAAAAAAAAAAEAAAAB
+ AAAAAAAADAx/AB0ddAAeHnkAISF3ACIieQAsLHwAc3N0AHd3eAB2dn8AeXl6AHt7fQB9fX4ACwuEAAoL
+ iwASEYkAFxiLABkZjAALC5MACwubABAPlwAUE5IAEhKZABkZnAApKY8AICCbACwsmQAyMZ8AOzudAAoK
+ owAJCaoAEhKjABwcowATE60AGhqrAAUFswAJCbMABwe+AAgIugAUFLQAGBexABsbtQATE7sAJCSlACws
+ pAAjI64AKiqrADQ0ogA6OqMAMzOtADo6rAAkJLQALCyyACUluwAqKrsAMC6/AC8wsAAyMrQAOjq1ADMz
+ uwA3OL4AOTm9AD9AsQBBQZsAfn6AAEREpgBRT64AREW3AE9PtQBBQb0ATEy7AFNTtQBbW7MAVle/AGxs
+ rQBiY7IAaGe2AGFhuwB6ersABwfCAAYIxwAKCsQACwzLABMTxwANDNMADg7ZABAP2gAREdEAEBDaAC0t
+ wgAvL8kAMS/FADQ0wQA3OcUAOjrEADIyzAA8PMoAODbTADo60gA8PNkAQT/NAD5AywBDQ8QASkrCAEJC
+ zABHSM8ATEzNAFJSxABZWcUAVFTKAFtbywBDQ9MAR0jXAElJ1ABERNoASEbaAEdI2QBLS9wAVFTUAFxc
+ 1gBUVNoAW1vZAGVlwwBsbMYAY2PKAG1sygBzc8QAc3PJAH19zQBkY9IAa2rTAGRi2gBsbNsAdHTUAHt7
+ 1gBzc90AfHzaAE1N4ABYWOEAY2PlAGJi6QBxcegAgH+9AIGBggCBgYQAhoaGAIWFiACKiosAgoKRAIyM
+ kACEhJoAkJCRAJOTlACUlJUAl5eaAJubnACdnaoAgIC9AKOjpACurq8Aqam1AK+vtQCjo70Aqam9ALOz
+ swC6urYAtra4ALe4uQC7u7sAw8O7AMjIvACCgsIAgYHNAI6PyACQkMcAk5PJAISE1QCMjNUAgYHcAIyM
+ 3gCamtQAlJTcAJub2wCmqMMApaXJAKmpzwC/v8AAoKDTAKeo1QCsrdQAo6PdAKur2wC4uNYAtrXbAIeH
+ 4gCNjeAAlJTiAJub4gCcnOoAnZ3yAKCg4gCsrOQAoaHoAK2t6AC8u+MAsLDoALy86ACnpfcAtrbxALu7
+ 8QDCwsIAy8vEAMPFzQDLy8sA09LHANPTzgDa2s4Aw8PUAMrK0wDCwdwAysrZANPT0gDa2tIA29vaAOTk
+ 3ADq6t0AxsXjAM3N5ADExOwAx8nrANTU5QDU1OsA3d3sAMXF9ADNzfQA0tLzANzc8wDd3fgA5OTjAOrq
+ 5QDi4+oA6+vrAPT07ADj4/QA6uryAObm/ADr6/wA8/P1APz88wDz8/kA+fn5AP7++QD5+fwA/v7+AAAA
+ AAD///8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACZkUAKBwcHCAqRkZcA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACZCpmh3e73/////+7dqJYJQJcAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAk5mn+fT04r+ujk6rrbvO6/T0o5QKlwAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAJqZ3fnowU4YDhIfISQhJB8fFUfI6/bZlEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAk9L/6K8/FRIT
+ Hx8hHiQmJlEqUlMiH27R/6MKmQAAAAAAAAAAAAAAAAAAAAAAAACa7vROAQ4SEhMfHR0dHiQkJlFRUldX
+ UykXh+3mkJMAAAAAAAAAAAAAAAAAAAAAAJ7/4xwBEhITExMTEx0eHiQkJiZRUlJUVVVXImbp+ZSTAAAA
+ AAAAAAAAAAAAAAAAnv/bFQESEhQSEhMTHx0eHiQkJiZPUVJUVFVYWCk00P+XkwAAAAAAAAAAAAAAAACa
+ /9sBDhISEhISHxIfHR0eIR4kJiZPT1JSVFRVWFYqM9D5kZkAAAAAAAAAAAAAAJPv5hESEhMSEhQSExMd
+ HR0dHh4kJCYmT1FSUlRUVVZVKjbq3AoAAAAAAAAAAAAAntX3HA4TEhMSEhISAQ4THRMdHh4kJCQmJlAm
+ UCRUVVVVWCJ29pyQAAAAAAAAAAAAmv9ODhMTExITFBdKAgEOHRMdHh4eJCQmJiZqRhMkVFRUVFcgxPeR
+ AAAAAAAAAACZ3+gOExMfExMSGaPYwAIBDh0fHh4eJCQmJHz4+H8dHlRUVFQqNOygkQAAAAAAAACe/0sS
+ Hx0dExMgt6ml4NkCARIdHR4eHiQheuH4//h/Eh5QUlJSH8v0kQAAAAAAAJ7V6A4dHR0dEyK406moqO7Z
+ AgESHh0hHh5J3u7u7//4eiZQUlJSKn3zmpkAAAAAAJP3uxghHR0dHznY09K6qKbu2QUBHR0eHkjY2N3u
+ 8O//yyZQUCZRUT7R1AoAAAAAAJ7/QTQtHh4eHR172NLS0qil7twFARIdSKmp1NXd3/fnNiYmJlAmJiKw
+ 8JEAAAAApqjsLzk0Mx4eHh0df97T0qioqO7ZBQFHqaWoutTV4eY2JCYmJiYmJidH9JqbAAAAmt7iMjk7
+ OzMeHh4dIX/Y1dLSqKXu2UqnpqamqKjY5jshJCQkJCQmJiQy66iZAAAAk++1Pj07Oz0zHh4eHR6A2NPS
+ 0qio7qmmpKSmpNbcOR4eHiQkJCQmISQX5d2XAAAACv97Qz07OztcNSQeHiEdgN7T0tKoqKWmpKSfqtw5
+ HR4eJB4eHh4eJCETzu6RAAAAB/9CRj08XFw7OzYnHh4eIYDd1dLSqKimpqSq3DkfHh4eHh4eHh4eHiET
+ v+5AAAAAB/8yazw8XVxcXDs7KSQeHh5/2NXS0qiopanbGhIdHh0eHx4eIR4eHR4Tv/GPAAAAB/9Ga15g
+ YDxdXFxcXDUkIR193dXV1dKoqOHcAwETHR0dHR0dHR0dHx0Uv+6RAAAACvh/bmZeYGBdYFw8XF47IYDu
+ 3t3V1dXSuqju3AUBEh0dHR0dHR0dHR8Uwd+QAAAAkO+2bmdgYGBgYF1eXTc1yPjh8N/d1dXS0tKo79wF
+ DhIdHR0dHx0dExMZ4t2ZAAAAm9/kbmtoZGRgYGBgXDXI+PTv8O7f3t7V1dKoqOHcAg4SHR0THR0dExMb
+ 5qeaAAAApqj0a3xob29kZGBdWcb///f37+7v7L7e2NTS0qjw2gMBEh0TEx0SExNC8J4AAAAAAJ75boVq
+ b2Rjb2Jaxv////f39Pj0bjW14N3X1dLS79wDARIdExMfHRKr95kAAAAAAJP/y32Bb3Jvb2HH////////
+ +PaBNTY2tuDd3NXV0u/cBhErKyAgFzDb4JEAAAAAAJ7V9G6IcXFyYY3/////////+YM1Xl47Nrbg2N3V
+ 1dLywSsuLi4rLkzwpp8AAAAAAACe/7WIgnF1Y4r1///////2eVlgYGBeXDe24N3c1dXfsS4uLi40Grn6
+ mQAAAAAAAACZ3/V8xHZ1dWOM9v////aLWm9lYGBeYFw3teDe2ODIMzk0NDQuGujdmgAAAAAAAAAAnv/L
+ gLJxdXVjjPX/9Ytab29vaGhgYGBdN7Xg4cY0Nzk7OTQuvf+aAAAAAAAAAAAAnt35iMOHdXWJY4zPi2Ry
+ cm9vb29gaGRgXlyyslw7PDs7OSxO99WeAAAAAAAAAAAAAJfv7YLEhHWJiXJjcolzdXRvb29vb2hoaGBd
+ WV5eXjw7OUvw75MAAAAAAAAAAAAAAACe/+uBxIiJiYmJiYmJdXV1dXJxb29vb2hkZGBeXjwxSOf5ngAA
+ AAAAAAAAAAAAAAAApv/sgsTCeYmJiYmJiXV1cnVxcW9vb29oaF5ePDFE5/+hAAAAAAAAAAAAAAAAAAAA
+ AKb69YiyyoeJiYmJiYmJdXV1dXVxaW9oYGY8Mk3s/58AAAAAAAAAAAAAAAAAAAAAAACe7/zNgsPIh3l1
+ dXV1dXV1cW9vaGhmPD4xtvnvngAAAAAAAAAAAAAAAAAAAAAAAAAAmd3/9bWBssSyhHl2cWppamhqZmZF
+ PoD0/92XAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJue7v/1zYGBhYaAh4KBbmtnRUbK9P/fnp4AAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAl57d/Pz05MiIbmZthbbk9P/31Z6ZAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAACekZ663/H5/////+/fup6TngAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACh
+ m5IKBwcHCJCapgAAAAAAAAAAAAAAAAAAAAAAAAAA////////AAD///////8AAP///////wAA//+AB///
+ AABAAAAAAQAIAAAAAAAABAAAAAAAAAAAAAAAAQAAAAEAAAAAAABubm8Ae3t8AAwMkQAMDJUACwuaAAwM
+ mAALC54ADw+dABISmwAXF5kAEhKdABUVnAA5OpsAPT2dAAsLoAAODqEACgqlAAoKqAANDakACQmtABMT
+ ogAQEKUAFhakABwcpQASEqoAFBSoABERrgAVFawAGhqoABwcrwAJCbEADQ2wAAgItAAODrUABwe+AAgI
+ uQAICLwADQ2+ABMTtAAdHbIAIiKgACUkowAgIKUAKiqmACsspAAtLaYAISGpACUlrQAqKqoAMC+pADMz
+ ogAxMaYANTWnADw8oAAzMq4ANzmoACMktgAqKrMAJCS5ACkquwAzM7IAOzuzADQ0vQA5ObwAQD+1AH9/
+ gABBQaIAR0evAElJrwBEQ7AARUWxAEZFtgBJSLEAR0e7AEhIugBKSr4AVFO3AF9fswBZWrcAVVa4AFlZ
+ vgBubr8ABwfAAAcHxAAICMMACQnGAA8PxAALCcgADAzJAAoKzQANDc4AHhzAABISzQAUE8wACwvRAAwM
+ 0gANDdYADQ3YABIS0gAsKsMALS7BAC4uxgAxL8UANDTCADk5wwAzM8sAPDzJADw80gA9PdoAPkDbAEFB
+ wQBKSsMAQUHNAEpJygBVVMcAUlLOAF1cywBERNMAR0nWAEhI1wBCQ9sASEfZAEtL3ABRUNYAXFzUAFhX
+ 3gBaWtwAZmbBAGtrwABra88AcXHBAHl3xAB9fMcAf33OAGJi2wB6edsARkbgAE5N4gBOUOYAUlLiAF1d
+ 4wBlZeMAa2vhAGVl6QB4d+UAe3vjAH+AywCAgIEAjo6PAJCQkQCVlZUAoaKiAKioqQCsrLcArKu4ALCw
+ sACysr8AtbW+ALi4uQC+vr4Av8C/AMPDvQCHiMsAi4vNAIiG1ACNjNEAj4/bAJaV1gCZmdEAnJzTAJub
+ 1QCcm9UArKzPAL+/wQCxsc0AurrMAKGh0wChotYAqqrQAKSk2QCop9wAqKjZAKqp3wCtrdwAsrLQALm5
+ 0AC9vdYAtbXdALq73ACenuMAnp3oAKem5ACtruEAoqLsALW14gC9u+IAsrL3AMC+4QC+wOAAwMDAAMXF
+ wwDGxsYAysrDAMTEyQDLy8sA1NTLANjYzgDBwdUAzs7QAMPD2wDAwN0Ay8zcANLS0gDV1dQA2dnUANbW
+ 2ADZ2dkA3NzZAN7e3gDh4dkA5OTaAODg3ADm5t8A7O7eAMPC5QDHyOAAyMrjAMrK6ADNzeoA0tPjANLS
+ 6ADT1ekA0NDsANnZ6gDh4eAA5OThAOPj5QDk5OYA6OjkAOXl7QDq6esA6ursAOzs7gDz8+sA4uHwAOzs
+ 8wDn5/8A6Of/AOrq/QDy8vMA/Pz0APLy/wD6+voA/v75AP///wAAAAAAAAAAAAAAAACZlQIBAQKVmQAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAJlCmMjZ8/3989nImEKZAAAAAAAAAAAAAAAAAAAAAJyVoPPqvKRPOC1J
+ g7Ln86CVnAAAAAAAAAAAAAAAAACXoPPHhCkJFhMTISQkJxZQuPOglwAAAAAAAAAAAAAAl9HkRgkJBgUP
+ Dx8hJFVVW10bSeXRlwAAAAAAAAAAAJXbuCkJBgYGBQ8TFCEhJFVZW1tjL7zblwAAAAAAAACX0bgYCQYD
+ BgYFDw8THx9TU1lZYmJjHbjRlwAAAAAAnKDkKgkFBgYDBgUPExQUHyQkVCRUW2JjL+WgmQAAAACV80cW
+ BQUGM7ANBQ8RDxMfHyRlwXBTW1tdR/OXAAAAmaCrGA8PBTWf3/MNBg8UFBQfOdT9+kokW1sbx6CZAABC
+ 7UcbDw8qsM3I7fMNBQ8TFDHQ4PP982VUVFWk85QAAJjmPhsPExutz83L7fRDBREvns/Y7fTnXFQkVS/n
+ mACZoMc+PSEPExuvzs3K7fM2K5rLyM7Z5DsfJCQlE7LImZXYqUBAPBMTDx65zs3L7fOaoqDIzdA6Ex8f
+ JCEhg9mVAvOFQEBAOx8UEx65z83Iy8jIoKKwOhMUHx8TISFF8wIB/YBoaGVAPCcUEx6zztHNyMjIuToP
+ ExQRFBQPEzX9AQH9UWtraGhoQDsfE0zR0dHNyPROBRMREREPDxMPLf0BAvOTa2tra2loaShw5N/X0dHN
+ 7fpDBQ8REQ8PDw9H8wKV2atybGtra2k8dfD07dnf183L7fo2BQ8PDw8PFoHZlZnIx3R5bHFrZX35/fTz
+ 9Oa7187N7fo2BQ8PDw8Yq8iZAJjqgnl5eWqH/P39/f3wckzH2dHR4Po2BQ8PCTHmmAAAQvO2h3lsfvz9
+ /f39+X08PHDi3dfR8PpJLzExUfNCAACZoOOIe3l++f39/fl9ZmtrZXDi3tHX1EsvNzeyoZkAAACV86iS
+ inmN+f35fWp5cWlrZXLi4OZzOj09UPOVAAAAAJyg5aeOinmQxZBseXF5cXFxZ3K+dTxAQD7ln5wAAAAA
+ AJfRw76Oi4lueXt7e3lxeXFxaWhoaUBHuNGXAAAAAAAAAJftw8CRfouKint7eHh4cXhxcWtMSrjrlwAA
+ AAAAAAAAAJXR58G/kH6Liop7fHt4eHhycKbl1ZUAAAAAAAAAAAAAAJeg8OHBv4+Nfn6KfHR0dbLi8J+X
+ AAAAAAAAAAAAAAAAAJqWrvPn4bWnpYamvsbq86CVnAAAAAAAAAAAAAAAAAAAAACZlJiu2fP9/fPZyJhC
+ mQAAAAAAAAAAAAAAAAAAAAAAAAAAAJmVAgEBApaZAAAAAAAAAAAAAAAA//AP//+AAf/+AAB//AAAP/gA
+ AB/wAAAP4AAAB8AAAAPAAAADgAAAAYAAAAGAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AACAAAABgAAAAYAAAAHAAAADwAAAA+AAAAfwAAAP+AAAH/wAAD/+AAB//4AB///wD/8oAAAAGAAAADAA
+ AAABAAgAAAAAAEACAAAAAAAAAAAAAAABAAAAAQAAAAAAACAgfgBxcHEAAACLAAAAjgAAAJEAAACXAAAA
+ mQABAZwABAScABAQmwAUFJ4ALy+GACoqigAwMIIAMjKFADQ0hgA8PIwAAACiAAQEogAAAKYACQihAA8P
+ oQALC6cADw+mAAAAqgAGBqoAAACsAAQErgAICKoAFRWnABgYpQAUFKkAEhKsABoZqgAAALEAAAC0AAcI
+ twAJCbYADg61AAAAuQAAAL0ABQW9AAgHvAAMDLsAEQ+2ABIStAAUErUAFxe3ABsbsgAUErgAFBS6ABAQ
+ vAApKaIALCykACkprwA9PK4AJSSzACkptAAuLr0ANjW1AD4+uAA8OrwARkaQAEJBswBKSrEATk6zAE5N
+ tQBDQr4AUFC1AFFQuQBRULwAVla/AH9/vAAAAMEAAADFAAcHxQAAAMsABATJAAEBzgAHB88AHB3BABwb
+ xgAAANAAAADWAAEB2gAAAN4ABQXeAAgI2QAmJsEAICDFACsrwwAqKsQAJCPPACcoygApKs0AMS/KAC4w
+ yQAxMcQAMDDJADU1yQAxMc0AOTnLADQ10wA1NdUAODjSAD4+0AA6OdUAPDzWADEx2AAyMt4AOjrYAD49
+ 2QA7O94ABwfjADU15QA+P+UAPj/qAD5A4wBGRscATUzKAEBA2gBGRtgAQEHdAEtL2QBUU9IAX17VAF9e
+ 2wBhYMEAY2LEAGRkxABjY8sAZmXIAGlpywBubcgAcXHDAHR0xQBzc8sAdXbPAH9/yABlY9oAY2LdAG9w
+ 2AB0c9AAfn3RAHx81QBAQOEARELhAEZF4wBFReUAS0vjAEtL5QBGRukARETtAEpJ6gBJSe4ASkzuAExM
+ 7ABXV+gAUlHsAHl55QCCgYIAjIuMAI+OjwCampoAp6anAKioqACxsbEAuLe/AIKCywCCgcwAhobMAIqK
+ zQCMjM4Ajo3VAIaG2wCWltMAlpbUAJGR2ACXltoAqKjZALGx1QC3t9UAurrWALKy3wC0tN8AjY3jAIOD
+ 7wCxseIAsbHkALW15AC4uOEAvLvlAL+/5QCurv8AuLj/AMC/wgDCwsIAz8/OAMTD3gDExN4A0NDQANXV
+ 0gDX19YA39/TANra1QDX19gA09LfANra2gDd3dgA3t7eAODg1ADp6dQA4eHcAOfn3wDs7d4AxcXmAM7O
+ 5QDBwegAzMzqANPS4ADQ0OQA3d3iANLS7QDT1O8A5+fiAOXl5QDp6eEA6+vmAOXl7gDo6OgA8fHtAPT0
+ 7gDj4/EA7OzyAOvr9ADt7fUA4OD/AOXl/wDo6P8A8vLxAPX18QDw8PQA9fX1APf3+gD5+fkA/v7+AAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA////AAAAAAAAAAAAAKShAgKhpAAAAAAAAAAAAAAA
+ AAAAAKWip8nm9fXmyaeipQAAAAAAAAAAAAAAosXq2ItBNTVBreDyxaIAAAAAAAAAAACm3rk4GB0cJCpO
+ TCdF2+amAAAAAAAAAKbqiCAYBxISJCpLU1VYMrH0pgAAAAAAot6IIAcGBxIcHCRLTlNVcjKx4qIAAACm
+ xbQiEgcLAQMSHCQqS2UYVXIu28WmAACi5j0dEh9J8g8DHCQkd/K5ClNTRfKiAACnvzkcEoLUzfIPBhw9
+ 1ejyuk5OLeCnAKTJqjsnHC62083yDw3GzfLgWktLK63GpKHmgmJZJBwnt9PN8s3J18gyJCoqKkHmoQL1
+ R2BjYiscLrXN0c3XtzAcJBwcJDX1AgL1SGdlZWUwJITX3tH0PwYcHBwSHDX1AqHmhmxnZ2VajvLq197J
+ 8g8DEhIcEkjXoaTJrnpxcVqg9fXx4NjV0/IPBhISIKrJpACnv312brv19fXvZWLc19XyERggN9inAACi
+ 5o+Xc8L19e9sZVpl3NfXijE3SOqiAAClqLl/mnXD7nptcWxlZb+vWTs8ucWlAAAAo9yuf5p1mnSTcXFs
+ Z2xlZT6q3qMAAAAAAKbpsoyfm5uampOTem9sRKrqpgAAAAAAAACm3LmRjZ6empqXfHiCuN6mAAAAAAAA
+ AAAAo6jp2LKRhoSKrr/mxaMAAAAAAAAAAAAAAKaip8nm9fXmyaeipgAAAAAAAAAAAAAAAAAAAKShAgKh
+ pAAAAAAAAAAAAP+B/wD8AD8A+AAfAPAADwDgAAcAwAADAIAAAQCAAAEAgAABAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAIAAAQCAAAEAgAABAMAAAwDgAAcA8AAPAPgAHwD8AD8A/4H/ACgAAAAQAAAAIAAAAAEA
+ CAAAAAAAAAEAAAAAAAAAAAAAAAEAAAABAAAAAAAAAAB5AAEBfAB6eXoABgaIAAEBlQACApkAAACdABYW
+ lwAcHJwANDSJAAQEoQAAAKoAAQGuAAEBsgADA7QABQW2AAEBuQAmJaEAKymnACwqrQAhIb0ALS28AERE
+ vgBZV7IAAADBAAgJwwAJCcYAFhXJABkazAAeH9cALCzBAD8/wgAwMMoANDTRADY21wA5Od0AUlDCAFJQ
+ xQBaV8AAUVDKAFhXzgBgXtkAZGLHAGBgzQBzcc0AYmDRAGhm1QBub9sAbGzcAHJy1gB9etMAbW3lAHt6
+ 5gCEf8QAi4mJAJCQkACbl5cAop6+AKWhoACkpKQAtK+8ALGwsQC+ubcAtrC9AIWBxwCIhMUAjIjFAISB
+ yACFhcsAjIzPAJSQygCAgNAAj4/QAIiF2ACRkdQAnZ3TAJCQ2gCins0AqqXIALy2wQC9vc8ApqHSAKyn
+ 1QCvq9AAq6vVAKio3AC9vdEAgoLnAJ2d5wCNjfEAoKDpALa24wC2tu4Au7voANDJyADHx9cA0tLcAOXk
+ 3AD399oA2dnkANfX7ADd3fcA9fTiAPX15QD5+eUA///mAPb26AD//+kA///sAPj48AD///EA///5AAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD///8AAAAAAAA+OAMDOD4AAAAAAAAAAD43Oz9fXz87Nz4A
+ AAAAADs5PTYlHx8lRD05OwAAAD45OhQMBwwRGQcTTjk+AAA3QBhIXgEHEQdlRBJANwA+O0IgVW1gAQVh
+ b10EQTs+OD8rDBVVbVFRY1wJESU/OANfKBEMF0xpaFYIDAwWXwMDXykhERFLaGhLAQcRFl8DOD8zHCFb
+ cG1iaUYBBSc/OD47UjRbcHA0KWlvRgpDOz4AN1A1ZnBYGxsyaWQvQDcAAD45VDRaHiQjHTIqTzk+AAAA
+ OzlQU0ovLi1HQDk7AAAAAAA+Nzs/X18/Ozc+AAAAAAAAAAA+OAMDOD4AAAAAAPgfAADgBwAAwAMAAIAB
+ AACAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAA4AcAAPgfAACJUE5HDQoaCgAA
+ AA1JSERSAAABAAAAAQAIBgAAAFxyqGYAACAASURBVHic7L13kFzXeSf6O/d27p7unpmenJBJJAKDyIwg
+ M4G0xSTRihgMJMt+q+C3663yH7tVWy67Xr21XbXe592117u1Lku0KIqiSIqkKJMyRYkiwUyJRBrMYDDA
+ YDChe2Y6hxvO++Pek273IFAQI05h0H3vPfeE73zf7wsnNHAlXUlX0pV0JV1JV9InL5EPugFX0qWlg8PD
+ cQDtANoAtFJKWwE0A0i4f00AYoSQMIAwgCCAAAAfAM0txgZgAqgBqAIoU0rLAAoA8pTSHCFkEcACgHnb
+ tucBzJqmOfudBx/Mvk9dvZLeh3QFAD6E6eDwMAEwAKCfUtoHoBdADyGkq6mpqa+9vYO2tbXp8UQyGIvF
+ QpFwNOzz60Gf7g/ouh4AIT5qUx2ghFJKbJsSSikIAWwKABSapgEUFKCUaBoFpZZNqWnbVs0yrVqtWq2W
+ K+VKoVisZBcXaul02shk0lo+nzsD4Byl9CyASUrppGVZpw8fPnzqzbfeogDoB0a4K+mS0xUA+BCkg8PD
+ KwCsopSuIoQsB7ByYGBZV3//gL+9vT0WjyfioVAo5vP5QppG/LruQyAQgM/ng9+vw+fzwefzQdN06LoG
+ n0+HpmnQNA2EaNA0AkLUobZtG5RSWLYN27JhWRYsy4JpWrAsE7WaAcMwYZoGqtUaqtUaTNMCpbZhWVa5
+ Wq0WcvlsPj03Vzx7dtI4c+b0OUrpSQAnKaVjtm2P/tO3vz3mVncFFD6k6QoAfADp4PDwOgBXU0rXAbhq
+ 5arVq1YuXxHu6OpKxGJNyWAgGAsG/L5AMIBgMIBAIAC/349gIABN01AzDNRqNRgmE1QDpmGgZpgwDROG
+ acA0LZiGCcu2YFk2bNv5c4CAQNMIdN0BDF3X4ff7XUDxIeD3IxDww+/3IxAI8O9+vw/VShXVWg2VShWV
+ ShXlchmlUgW2bZmGaRTzudzCzOxMdnz8ZGnyzOlxAMcppUdN0zz2nQcfPAwHDK4AwockXQGA9yEdHB7u
+ BnANpfQaABs2bNi4ZvWaNU3tbR2t0WgkGQqGgqFQEMFgEMGQI+zUpqjWqqhUaqhWqyiXKyiWyqhUKjAM
+ E7Zt8/IppUt8B5isyd/P90y8TpXvmqYhFAwiGosiEg4jGg0jHA4hFAohGAzANE2USxUUiiUUCgXk80UY
+ plGtVMoLc3NzmYmJ8fzY6IkxAO/atv1OrVb79XcfeugsrgDCB5quAMBvKR0cHr4awCCAzb29fbuu2bgp
+ 0tvXl4rH4y3BYDAYCYcQCgcRDARBKXWEvFJBqVRGoVBEsViGYZpLCrcqoOcDgUsT+ot7ptYfDgWRSMYR
+ b4ohGo0iEnHAoVyuIJcrIJvNYXExC8M0KuVyOX3u3Nn02OhIeXZ29iVK6dumab71nQcfPIorYPC+pysA
+ cBnTweHhqwBsB7B14zWbrt+wbkOyo7OjIxqNxsPhEAmHggi4Al+pVFAqV5DPF1AoFFGpVpfUvr+JoF9s
+ vksV+vM9IwSIREKIxxNIJuJoiscQi0ZRrpSxuJDDwkIWuXzeNs3aYiaTmRkbHcmePDn2OqX0DcuyXv3O
+ gw8ewxUweF/SFQD4DZNr3l8LYMeG9Rt2bx7c0trZ2dkZiUSikXCIhMNh6LqGSqXKBT6Xz6NaNXApJvjl
+ AoTf1BVY+tn52xYKBdHSkkQiEUcykUA4HEJmfhHz8wvIZnO0Wq3m5jPpcyMnji2cGj/5km3br1YqlUMP
+ f//7k7gCBr+1dAUA3mM6ODx8PaX0hr6+/k/v3LGzub9/oCfWFItHwmESjUVAQFAslVAslpDNFVAul2Ca
+ zG+/GOGuFyZd15ygnM8Hn98ngnhEg6ZrbuTfifgTojmDSwg0dwaAgoKAgGgEBASOTBFeF6UUlFLYtg3L
+ FjMDhmGiWquhWqmhUCqhVqtdVJuXAgRCCJqTCTS3JNHS0oxkMo75+UVkMhkszOdotVZZmJ05d/bw4Xdz
+ MzPTT1qW9dK3v/OdX0IAwRUwuEzpCgBcQjo4PNwB4CYAN928a9cNa9eu62ppbu2IREJ6U1MTNI2gUCi5
+ Wr6AarXqChVwKVpW13QEgn74fT74dB98Ph0+nw5d12FZFgghfBoPAIhO+LQfAHf6TwytAwjqNfvUdZ1f
+ ayCgxAUCyxZ5NAJd0/m1YZruTIQzReiAXB7FUhmU2hdtFbDU1BRDqrUFqVQL4vEmpDMLSKczyOVyRqlY
+ nB0fHzv35puvv2rb9oulUunnj/zgB9NwFjNdAYLfMF0BgItIB4eHr6aU7u7r67//2uuu7+rv6++LRiNN
+ 8XgcgYAflUoF2Vwe+XwB1aoB27YAXMi8dr5rREMg4IPf74eu+wBqQ/fpjoYmTmZKmFA7Ajg5eRbT56bo
+ 7Owc5hfmkcvmSLFYQKVSQa1Wg2masCyLg0QjoQMEMGiamAoMBALYuGEjQpEwjUWjSCQSpLmlBW1tbeju
+ 7uYMY1sWAAKfpnEuMmomqtUqipUycrkC5heyKJcrFxW8ZG1JJuJItbUilWqBrumYS2cwOzuHarWSm56e
+ nnz3nV/NTE+fe7RWq73w0Pe+dwRXrILfKF0BgPOkg8PDWymlezduvOberdu2tXd2dvbGorFAPB6DbVMs
+ ZnNYXMyhWq3Csiz+3vl8cU1zBM6n69B9Onyaq4EJAFDHPCeAaZoYHR2lE6dOYWpqiszPzyOfz6NarSJp
+ Wejw+ZAKBNDs9yPu9yOm6wgTAj8FfLYF3bZBLAvUtEBtC9S2QS1LtEnTnGidpoFqGixNg6lpqFGKMoCi
+ bUOPx1HSNOQIwbxPRy0SdaYCo1HEEwna0dFBenp7sXLlSvh0HdS2AUqhEY33uVypoFgsYTGbRzozj1Id
+ IDS2CjRNQ3t7Cu3trWhLpTC/sIjZmTQWs4u1XDZ39siRd2bHxk48bhjG8//83e++DmERXAGCS0hXAKBB
+ Ojg8vJNS+jvXXnvd723atLk7lWrrboo3aeFQENVqFQuLWeTzRZjSNN35tL3Px/xzHT6dmefU8c815+vJ
+ kyfpyIkRnDl9mqTTaZSLRXTbNgbCYfTEYmgPhdCk6QgBINSGFgiA+H2AroNoOoimAa7pT6lTsQ0KSK4C
+ 2NoB7utbgGmDWiZs04JtmoBlgpombMu5pqYJ26iBWha0UBhGMIRKwIeC7sOiriPj9yMXjSIUiaCltRVd
+ 3d1YuXIlVixbDkpt2DaFTlxqUKBQLCGXz2N2LoOFxSxsm9GpMSgQQhCNRtHV2Y72jhQopZiZnkNmPmMV
+ CoWZkWNHz77z7q+fMk3zpw/+8z8fwhUguKR0BQCkdHB4eDul9NYbb7z505s2b+5raW7piCfiJOD3IZ93
+ TNqL1faapkHXNOi6BqI5ATlmwlNQjJ88SY8cOYKJiVMkk8kgWa1iXTyO5YkEOqNRxHx+aD4dejgMPRAA
+ 8ftBbRtWuQK7XIZVLsGuVmEbBqhhwHI/qWmC2jZsy+IamUmfYoizuICmgegaQJxlw8TvA9E1B1R8DsBo
+ muasJDRN0FpNqtMEtUxo0Shq4TByfj8yPh/OhUKoxWJItrSgr7cXV69d6wICdXYjufhXLDkB0rl0GnPp
+ hSXp6iRn9WJ3Vwc6uzoQCYcxMzuL2ZkMLZbyMyPHj0++/fYbTxmG8ex3H3roFVwBgotKVwAAwMHh4Q2U
+ 0jtuuOGm+wcHB/taWlo7k80JohGCbDaPhcUsDMO44Oo7FnzTeUCOcqGv1ip484036bHjx8j0uXOI5PPY
+ lEjg6o4OdCaTCEfC8EVj0IJB2NUqzEIBRi4Hs1CAXS7DrlRglsuwK1VQ6gboUM/dtMEXyqP9zn3KX1ZB
+ AXy2gF06rgllMweaDvj90DUdxO8DJQSwLdg1wwEFywI1TUDTYMeakA8GMef34Ww0CiSTaOvowOrVq7F1
+ yxYE/H4QKUBaKpexsJDDuZk5ZOYX6mjMrlmsoL09ha6uDiQTCczOpTE9PUPz+fzMyPGjk7/61Vs/rFar
+ z3zv4Yd/jStAcN70iQaAg8PD/ZTSfYNbtg7t3HltT3t7e08ymSAaARYWc8hm8zCM8095OUE04gq+7oga
+ oSAA8oU8Xn/tNXp85DjJTE9jra5jsKcHyzo6EI/H4Y8nQPw+GAsLqM7NwVhchFUowCoUYZZKjqBTobu9
+ g6UKO3WElbrTep6ccgmUUvbNlQzieiQUoIQ5L5563Gs+vegE/6hrLWi6DkI0UDiuhV0zAcuCTS1oPj+M
+ eByLgQDOhkLINDcj1daGVatXY8f27YiEw+4+ZSf+sbCYRTozj3MzaeTzBdEOzxoGQjSkUi3o6upAa0sS
+ 0zNzmJ2Zo9lc9ty77/xq8tixIw+WSqWnf/Doo6dwBQgapk8kABwcHo5QSu9avXrN12666eZlPb29A4lE
+ QvfpGhaz5xd8ru0d1Q7dnXoDcbQ9pTZefvllevjdw2T+3BQ2hULYvnw5+nt6EGlrgxYIoJbJoDI1BWNh
+ AWY+DzObg1WpKGJLqNDd9cm9T93hY6NIvaLrEWMq3ZPjFE7DlfwyY1Dl9Qb53NeJpvPAItGdWQtqU8cl
+ sW3ANJ21CMkkcqEwJkMhzDY3I9XVhbVr1+LmG2901iCYlhODoDYy84uYOjeD2bmM1MX6wGoq1Yye7m4k
+ Ek2Ynp7F9MycubiYmXzrzTdOTUyc+t+nT59+8ue/+EUBV4BASZ84ADg4PHxTc3PzFz71O7fcsHr1mlXJ
+ ZCIU8PuRLxSxsLCIWs3geRub+URZTENhA7Bx/PgIfeutN8mp8XFs1HVct2oVBgYG0NTdA2pZKI2Po3J2
+ Esb8PMxiEVapBGrZQoap81+9Cc8uXQlkQb46Hd8gf4OHVPmkTr2QQgV1ku/ijEwLT111MQYKQHOXGulO
+ bAFwLQtKQW3LDU7aIMkkFiNRnA6HkW1rQ19/PzZv3ox1V18NItWZmV/EuZlZnJueRbVaU6t363dmDlrR
+ 29uDcCiIc+dmMJfOVM5NnR1/9dWXfzk3N/fw9x5++AUAlttKG5/w9IkBgIPDwwOU0rv3fup3vrB167ZV
+ yWSyORqNoFyuIJOZR61muELewMyHY/EC7ly8a27btoWfPf8zevjwu8Q3N4fbrr4aG9euRaK3F3a1itL4
+ OMoTEzAWFmDk87CrVaVNQpeSegFzKyZMcNgzrqldo56Z7ER6V247AWdz6k41KpaApw3UE1hQ63bvsEVF
+ lIqmS2GGhnEG4pjsII6ZD0pgUwpQ21HHtg20pjAbDmG8qQmB7m6sXbsWt91yixOAdIOapVIZ07NpTE5N
+ o1Qqq+1yk6bp6Opqx0B/L0zLwuTkFLLZ7MKJkWPjr732ykOFQuHxHz722DgEEHxirYFPBAAMHzjwu1dd
+ ffU39uz51Kqenp5liUQTMWom0pkMSqXK+QVf/Of4yABmZ2fw4i9+gdETJ7A9GMBNmzejd80aEJ+O8vgp
+ FMfGYKQzMIoFR+gbmObOjXoLgwuXK0X1nOks6G2UeC1U5HQLra/H8x5x26NIg/R6XQ8atk0CL+XaW44D
+ Auw7CByLwG2fHomg2BTHRCSCdFsKK1etwp49e5BqbXWWJ7tnHZybmcXk1DSKxVIDq4jA59PR39eDZcv6
+ kU5nMHn2HF1YyJx56603xk6Ojf73f/7ud38EBwQ+sW7BxxoADg4Pr6KU3nfvffc/cM0111wdj8fDmqYh
+ l8ujkC/AME13tRzAWZx/d9fQswU6BBgbG6MvvfRLMjc+jjuWLcO2bVvRMrAMlelp5A8fRvnUBKxCAWal
+ LIRAZv4G9r1XQJjYKspaMsWFglYBgt1vbJ5L/XNLF7cl4PEClaLJxdsNi3dhiULup8gjvIh6N4etG6LQ
+ XCuEsrPLYKVacS4SxXhLC7qXL8fNN92EFcuXwzItWKYJ07RwbmYGZ85Oo1gsqy1yjZV4PIb+/j40JxM4
+ OzWNubm58sTEqdFf/Pz5R3K53A8ff+KJ41CB4BOTPrYAMHzgwJ0bNm78k1tvvX1VV2dHbygcRrlcQXYx
+ ywVf/LExd1iVL9SBM+10/Pgx+vIvf4nixAT53Q3rsXnbNkRSKRSOHEHh6FFUZ2dhlUpOoIsCxFmCA2GX
+ uy4DqwIeQQYRcgjK4wJ1cQAZqDyTgGyjD3uPi7vkAihuAjNxqJSfAZDUAEpYQJJlcPtGHS1uA66vLrkR
+ 7p4Cue9sdoLI/ZVnHVglROONoo6f5YxJMonZWBTHm5rQtnIldu3ahTWrV8O2LJjuyUiTZ6dx5uwUj+PI
+ gMtWFi5f3o9q1cDp05PILsxPvfnWGydHRo79l4e+972n4ByU+omyBj52AHBweLibUvqZ+z/z2f1bBgev
+ boo3hSmlyGbz7rp0R+Bl4Zc3sBBJ4584cYK++OIvUDszSe6+ZiM27NyJQDSK7BtvonD0CIzFLKxKma+w
+ Y2wLuL47FdpcFWqu413h47k8vWFPxPSdVIjHFWAWjAotXC7dXEQy8+UanbLZCkXWLmZyyFAl2sxAg1Cp
+ PUzL11kNHJ4kAPJMObIPCuf8YrcC9+xSABR6IoHZaAzvRmPovGoNPrV3L1auWOGsQaAUuXwRE6cnMTk1
+ LcqS6Or3B7BsWS+6u7tw9uw5zMzMlk6Nj429+OILD2bm5x/58Y9/fAafIGvgYwUAB4eHr1+9evW/vfOu
+ 39vW19c7EAw6S3fz+QI70JILPQMAtlmG7dojxMbMzAyee/ZZ5CdO4Z6NG7Fx5074AgEsHDqE4vHjMHN5
+ 2IYBJ4AlCbNiIrva0DVDBR9SPnfG5uMbmdWElcUEURJ3Kt0Rmp8qdTChcxSwx+wmbhkUsN0wI2VTeVJ3
+ bKgMwpfnuiVyL8fV5ADzJCQNLkONLNAS3RSYoxTyMifebo6iDljr8QRmo1EcjjdhYMMG3HXXXWhraeHt
+ PTc9i1OnJ5HOLDSMD6RSLVi5YgCGaWFi4gwymfSZN19/5a2xk2P/9eHvf/+XENbAx3qmQP+gG3C50vCB
+ A5+77bbb/tPd99y7o6urs0PXdRSLxQa70QRLs+2zTqIwjCqeeOIJHPrpc7ituwufu/tu9K5ahdyrryL9
+ 3HMojY7CKhad6TvF/BbaTXbUuYZUWkqUz0YIXAcKKsa41TCBcUWHCbD3XeVF1wBfEvZFRTzQz0pZYo0B
+ M+nZB5GnHIioX2kba0TduKgWDq+HUgFM7nu0WkUkn8dy00Jxdg4/eestzC4uYuPGjQClCAUD6OxoRyAQ
+ QLFYgmFaSpnFYhmzc3MIh8NYvrwfmqYn2to6u0Kh4NaWlubKu+++e2QpKn2c0kceAA4OD3cPbt78ta98
+ 5avfvOHGG66JxWJh27ZRLJaUteVeptc0SZ9SEy/87AX6+OOPkS2E4MC992LFxo3IHjqE9DPPoDQ6BrNU
+ 9DAse51wt6GxGe8+4e8uHcFXnnjzk3rBZn3ic/lubuL+z60A1jIulI0qdCshkrsCptkVu0ZYNUzAiXCZ
+ OSkk5KNskYFUH/XWXQeYYt0AUV6kYKsQAQpariCay2HAsnD27Fn85Fe/gmlZWLFiBTQCNMWiaEu1wLZs
+ 5KRVhQBgWTYWFxdRrVSxbFk/IpFwMBCMtHV2da2PRkKxzs7OyZMnT+a9VPo4pY80ABwcHt5y9dVr/+Jr
+ f/i1+9asWbPK7/drtVoNlUpNWbfvPROfCT8hFMePH6ePfP8REpqaJAc/tReD112P8vHjmHniRygcPwar
+ XOYmrTBZwT+JJCwi8O8yLfWKrChH9X2F7y3HDUQ+JhxLuaTCrQBcjSlpZeceEcLk0e6szfDIKZdbIuWB
+ qIe4boTwAAjkuITq4NS/LbeBg6jrLzXEWqU/rC8ujUpFtOSyaKvW8ObJk3j75Em0t7cj1dqKYDCAjvYU
+ wuEwSqUyajVDWcpQLJUwP7+AluYWdHS2aYRorStWrLoKoBtSra2njx07Nq0S++OTPrIAcGBo6PZdu3f/
+ vw989rPXtrW3txPinLvn+PrUo/ElDeber9Wq+P7DD+PtF35GHtiwHrfdeSf8lQpmHn8cubfeglUuqVxI
+ HbNblCdMcJm5hYkra2SvbaBKoGBsWUSIJIxew9vJwxf6EAEUtpzVo+0VL8IxSwBKQAlb9yB8fJaTwHnO
+ a6dy0ZTn4lMCcvlyO1Q8csx4NtsiEUohOaOJxwphloEDGDLMEPgKBfRWKtAXF/HskSNI5/PYsGEDCIBQ
+ MIC2tlZYtmMNyOBdqxlIpzPw+wNYsWIZiKY1tbd3dPl9vh3JZGLmyJEj455efSzSRxIAhg8c+MLnPv/5
+ /3D77bdvjsZiUdu2Ua0aYLvk6pPL0sRZzPPqq6/Rh777IFlv2xi67z60tbUh/cwzyLzwcxgLC1Dk0dXK
+ qknr0ZLEqaERd6hyTbhvzMp02iWHwVxJaaQCAVdgZS0rWxSiTg5J9fIDZqMIw12WQCj+0hJeOSRRVp/V
+ WSlE1C8ZPGx6kRVge9vH2+AGOilV6lEsFanXAAU1TITyefRbFiamp/HC4cOIJxLo7uxEMBhAe3sKgUAA
+ hWIRhmHykiilWFzMolKpYMXyZQiGgsGmpmRrsrn5mmgkVD58+PDHLi7wkQKAg8PDTYObN//BN77xjX+7
+ Y8eOjX6/38d+zmpp4RepVqvi29/+Nk689EsyfN112H799aiOj2P26adROX0G1LS8XLWk2c1liqjCwH1Z
+ xXjwrt5TbW1KmTA6pfJ5dyJJDJF27rEyZF8dTF/zhgnhl00SZmbLos3awhxzqnxI/aEc7Fi74XnG2yv1
+ WbJZwIFUsiQoYX0hIrNMQln4eVu9+dhUrITSpTJShTxipRL+9dgxzBUKPEgYi0bQ3BxHrWa4C4jE+BSL
+ ZSwuZtHRkUIyGddDwXCqp6d3g9+v65FweOTs1FRNqfojnD4yAHBweLi7t7f3T7/+jW8MX3XVVWsI0Yhl
+ 2bCs8wk+249P8etfv0P/6R//D1lvWfjS/fcjEYsh/cxPMH/oZVilkpOd81/9uKp76pkQMUta0bnSG55I
+ l8S8FELe6kCGt4OgYcjeq/6k/HVTXlJsAICqjdkzd4OR8ipfmEOWZHPhSkh99kT/hUgKjc5iB1ByuDaU
+ LOkE4P6Rtx7FAuGIKSOzA7y2DV+hgAHbxpnpabx44gQ6u7vR2twMv8+H9rZWEDjbv+VUqVQxNzeP5mQC
+ 7R1tRNd8zctXrFxrmWZHJBI+Pn7qlBwc/MgCwUcCAA4OD6/asGHDnx8YHv50T3dPv3oqrkfsPENhGAYe
+ fvhh+tKPnyZf3jKInTffjPLoCcw8/gQq0+fU9+RwuvuFCZY3qOYIjVoZUd7xJIlHJVmAN86wFAhRuXOE
+ eK7VYhTXmWej/Cb36dmUGq/arZnIjZTqlywNGc1E1QRSRFDMEqB+XBrKDPXWI5XrGZN668BrunnylCtI
+ FfIIFot49tgx1GwLa65ag4Dfj/a2FILBAPL5EgxT7Aa1LAuZ+UUEAn709HRB13zxrs6eZSBYHY2Ej46O
+ ji5I1XwkQeBDDwAHhoauue766//yC1/4wp6WlpZ2ohE3wi8NtEJ6cZHPF/Df/va/IXBqnHzt7rvR2tyM
+ zHPPYeGVV2BVKwA8PvqSiUgfnoCfqpqkZbRQhFD1EihUEaPuP6YrqSRapI612VJlYVqzpgnLxJEZZmq4
+ 75NGQi13TYoLcHeB9YO4lg5bBqS+W4ed3npk80LxHGRQoxyIKYhrhDhxGy9O8rYtsahBXTbt3rNtBPI5
+ 9Jom3j4ziZGZaWzbtg3UthEOh5CIN7k/eFrhxdq2jYWFRdiUYmCgD5qmR9va2rt8Pm1jJBI5OjIyMrdE
+ tz8S6UMNAAeGhrbu3rPnbz772c/ubGpqam6kdRvHypxA3//+X/9A9sab8OnPfAZ2Oo2ZJ55AeXJSBODo
+ 0iOnaBVmDUNiJv7A9c89IORoexkYluYRGQ7kQ0Dk6TWloYoJL9108ypuAHVbI5nyvA8SglAAlEgtkYRL
+ BTEBSkr18lkGdeBE3Dr4FadfHVUayrMUFFTxVbE4vOOgALQ01rRURHe1itzCAp49ehQdnZ1oa22Bpmto
+ S7XAMAzkC0UFW/L5PCrlClas6Ieu+0ItLam2QMC/LRgMHBkZGZmGArUfnfShBYADQ0M7b7n11r+9//77
+ N0fC4Vh9Di+nOLS3LBOP/uBRvPCjJ8iBLVuwYccOZF97DXP/8hOYhSI/rosLBmQdKxTV0mfxiG/Uqw25
+ sLnto41Kkcxo2ayVBdprzks1MhhyNipKjE3U8jigEOktftvtN5d0sUlHsjMU0PJqa6nDgmbeFUnevsj1
+ q8aJVC1VrCgvSNUl6VQkFSO9gk8Vi4xWa4gtLiJWqeLZ48ehhUJYuWIFdE1DW6oVlFIsLGaVqoqlEvL5
+ PPr6ehEIBALNza0twVBwRzDgP3Z8ZGSqvscf/vShBIADQ0PX7tu372/uueeeTcFAIOxG8uoW9HhTqVTG
+ //z7/4n0W2/iD26/Ham2Nsz/7GdYfPNN2IbJwkJg3MlMWmF8n98i4Kf2NBBQUa4IRCkaSC5d3hnE5hSV
+ Azk97fHKnScpbgzXtBK384yidHkKjhImkETBANkSEWCh9hhoYIXVaWGoYCiXLzXeY0RJswPgroETwwA/
+ Mk2pSwySk08pUcQ+5D1V/nwe3ZaFF0dHkS6XsXHjRvh0HW2pFmiac0ScvFu0VKogl82jp6cbwWDAn0wk
+ k+FwZKvPpx8fcUDgCgD8JunA0NDOO/bt+5u77757c8DvDzXmelJ3O5vN4a//+q/QMTeHL957L7RiEeln
+ nkFxfFych+++u+QUe6MrJhgNbAKuwSgcCSEyI0uAwIuSnF/ZrGbvSw2TlwG5/KxoWymjkkeNrnPzQAIG
+ UY7YSCSvI6Cea9ZG6snDKmWbkMSSaCq3u94mR+OSGtljqlDz2KSMJC54Mpp7rQAB71R5j4MdoUCpiH7L
+ xsj0NN6ZmsLOnTsBStGcTCAY9COby8M0LTBiV6pVLC7m0NXVjnA45Esmm5sj4fAW3acf/aiBwIcKAA4M
+ DW29pDgmygAAIABJREFU9bbb/vaee+7ZtJTw11sBBKdOTeCv//qvcFMwiNtuvx3lkRFknnsOxuKiKmyQ
+ GZIIVpXkpF7QZaEEL09eaNM41ccr1BfEnnlJnKR2Skd9sY04dRmpakzw5klakDRwqxtpaH5dbwLIoCMi
+ +2K7M2+Tt52sUWx5L4sTUHZLnjYUdbAWeLGDCzknjGpt1dlakoXHLCIJD0Eo4dsY7GoFXZUyFrJZPH/8
+ OAYHBxHw+xGJRBCNRJDLF2AYBq+hVqthfiGLrq4OhEIhvSmeTAZDwS0+XXv3xIkT06gn7YcyfWgA4MDQ
+ 0DW79+z5r/fdd9/mQCAQdvissc0rg8Drr79B/+F//HdyX28vtu/di/zbb2P+xRdhVSoS0zYQVq5ZANlf
+ 9k7Jq7PYjMXqNRggM65Un2zCNsjtNXtFUEtePkSVd2R9KWRN0pLUw33SnmS55WoJbGpRbY6wE1xtC9VS
+ YS8pMQwm4VJx9aDqCKfq+EDsOiT19KHyq9I4qMC4FHg55lEd4BGALSKyDROJXAG0WsYz77yLlavXIJlI
+ IhDwIx6LIl8ooloTB5IahoGFhSy6ujoRCoV8yUQy7vf7N+m69uvR0VE2O/ChBoIPBQAM7d+/+oYbb/yr
+ Bx54YGcoFIqdT/jl9NOf/iv9/j/+H7J/wwZcfe21SP/0p1h8/XVQwz0RxvsCky31ljDfqbzARBU6puAk
+ i9R5ypcJ0zoBU8xuQpW6FbAgaj2sFCKF321Zk7H3XIFnr6s55A5L/i/AwcIrELJvrAIX74ILkCoAUJUg
+ qJ+tkc0HLxS4mtmzolIBDqlOLxQyYHU0urddYiy9kK2cesQLJYBNEc5mEbNMPH3kCLr7etHZ3gGfriMR
+ b3JAQDqVuFYzkM3l0dPdhWAw4G9ONieJpl0Far81Pj7O1gl8aEHgAweAg8PD3Zuu2fTnX/rSF/dGo9HE
+ xQg/pRQ/+tFTePbhh8hXdu7EwKZNmPvxj5F/911nOS/qh1xW9kuNhtCmRMTlGhgPwgWQ7QLB5BRwfwKM
+ KMzLAUIGAsIWGVEOCJRVwixYyK4K4Y+8bZeXAShCrNBAIkQjawEesx5OwZSIEKrSJRd9FGBVVko20MhS
+ o2lD8JSKoIB8DJlosxdgiGgLGwNuKUmuhkQMGwLgCJtFcekfKBTQbtt4+sgRtHZ2oq+3B5pGkIg3oVAs
+ oeKCACFAtVpDoVhEX283fH6/P5FobrEss980jTfPnDmTk2r90AHBBwoAB4eHm3p7e/90+OBX7mlubk5d
+ jPDbNsUPf/gYfv7I9/GVG65H17p1mH7sMRRGRvjgeensXVu/5K5aJVggfaFs0w6/VKxNxzogjuYjcoVS
+ UVQKuUm+sMhBRGHeJrBrt2xF07uvctuFm/oS6AgC8Ao8S6m4dlbXMTExEqLk2hNcu/I1Bl5Bl+55QyFe
+ bdz4m9se1m5vHQqiu61zs8jTjR78heKrNGA1dxidfhYL6AHB00ePIt7WhuX9/dAIQSIRQz5fRNU95p0Q
+ oFyuolgqob+/F36fL9jcnEoVi4V4Lpd9Yy6drkgd+1CBwAcKAIObN//Bt/74j7/a1dXVw5j3fFN9tm3j
+ Bz/4IQ499ij+YNcutK9eg+nHH0dpbMzDZQzxZS3N9SrPI6k45QOAqtH4ghhZ4oUAEiItVPHOnfMyBLZx
+ JeRtGfN/G/ZeWAFKki0EaWmveIsKjpZeF1N7ElhRdWutCnByffX9UwGNSP0SD7iDQ9V5FSLVJfse6oix
+ Mij3eRxZlkoSA8LbKzDWpTiRpweldrnv8l9Jcrd5klIRvRrBM8eOoymVwoplAyCuJZDLqzGBcrmKSqWK
+ np4uaJoWSaXau6fOna0dOXLkLbcyG55mfdDpAwOA4QMHvvDNb37zT1avWrVK8ODSAECpo/kPPfZDfHX3
+ bqRWrsLMYz9E6dS4qjR4UibSIMX8FW6+0EiojN1o5LzqTdaOzn+kQU7i/UZZszwaFeD+KvOXHf6Xhcrr
+ 16jhwzoRqmuTaiGQuneYiAnoUoRfPSRAmbOXC5LBR2k/ddR2HYgooOWUR2UUZXaJWzZbq8CtMJkAPM4j
+ E4VIdXmsCyLKJ8US+jUNPxkZQaK9Hcv7+6FrGppiUSzmnNkBhhvFYgmWbaGrqwOapjX19PSttMxa7ujR
+ o0ckAn6yAeDA0NDtn//85//j9u3bN0gGMcCCWt4165TiiSeexC8efRRfufkmtPb3Y+bJJ1GaOOXyBRX8
+ 4pnqoRK3M7GSmVte3FansfirwnznD1iJQnl4fAtJl8ryxV53Zxy4pmIaiDVGNENqF7NxUcdCPBhGJKFi
+ bwh+bhDAZ32lnIm5TiWSF+12QoiMpEldWRelEiFAkn+v7vYTFoGaHGGk0ty+GMB6uiiLjlmglcrwry5L
+ VpxEtrBAsrwcIGFuhVR7qYRejeAnIyNIdXejv7cPfr8f0XAYCwtZmJbF6ZfPF+D3+9DR0Qafz59oaW1Z
+ bVvm1PGRkZPSyH0oQOB9B4ADQ0Nb9+ze/Z9vu/2OQZ+u66bleKPEHQy+5FsCgWeffQ7PPvRdDF+7A6n+
+ Psw9+1OUTo7VU7ARSRWkh+KeS0pPgAKVAJpKjOcCTQPZq2+CopGoOMBTYkbmt6tRO3DzlS9ok8GHipWM
+ HoUPsYGIFy6BjsecpkpLxDPJxZGfcnp52yoqlxDAuwJvCZBVzAH2PnXDfW5PXI0vK27+H6OTamSIb7zR
+ ok/cbVBbrzSQEAp+tISnbSiW0KMR/HhkBP0rlqOzsxPhUBB+vx+Z+QVl5iOXLyAWiyCZTJBIOBr3+fxr
+ Afru6NjYND5ER46/rwBwcHi4e9269X/x2d9/4PpwKBQyLXF8lwoAwhV45ZVX6SP/+I9k6Jpr0DkwgIWX
+ XkLh2PGGdrWM9Exrc0nkWkjOK6mSJSVbPRLLY5tAjgja8v0G89hqvZKhrSpG97hucKaVRNRpDxVn+8la
+ sE6fSuvqudwAgEtz2V1hjRB9ZSfxsO9OHnnloCAbc7DEXdnKUZokUQHwkJ6DHvvq0lBpvAR+VHqbjbMt
+ bnuhqO57HRowR4dA+TUVKumCQhGduoZnxsawdt16tDQnkYg3ASBIZ+bVXYSLWbS3pxCNRvREIhmtVKu9
+ 1Ur5tcmzZz80MwPvKwAMbt78tT/8oz96INXa2moYpru8EmDCQIgMAMDY2En8/d/+f+Rzy5ejb9VKLL7x
+ BvKHD0tWmyTAEEU5w0d4yQ2PDJE0Q71WcvUpEQyqoIunWmZmi2euOSoVrG7+kZqh/C+JsGTty0mFgwYA
+ 4wqeADtZoN3jzF2NzZWkp++exin5WN1OnEyNJ8hySDyFUK59RWlKf6mn/25feKCSo4NEdS77YhejAuyc
+ QopvI8OUe1vQUsEExeJxS6YUWrGABAGeHR3Ftdddh2AggNaWJEzTxMJiVgGBQqGA3t5u+Hz+QDKRTJ4Y
+ PVE9cuTI61CtgA8MBN43ABg+cOBzX/3qH/zfq1avWm6ZJmo10xlDQjx/AEAwPz+Pv/rL/4zfbW7GmrVX
+ o3xqAouvvyqJtcRIBBLX0Ybk5NqggcXgaLo6Ix1yTmaRiOlkpnvdK6KyH1FfVz/dLjCGUy1rUveCLGCS
+ 0SDla2TaO9pfPrdf1OPAIosVONXWryJUAIw1i62d9dBH7R5DDnYeoLswSPg1vM1UHjMm3xLiMlorOx+h
+ tlGcDiy3jShYwVsoLTqSN4PVjZq0mInyVwXoBPJ5+CjFv46NYc+ePQCliLvnCeSl48erVQPVag09PZ3Q
+ NC3S2dHdbxjV3LFjx466RX+g7sD7AgAHhoZuuOWW2/7TjTfesJGAkHKlBnaGn1f4CSHI54v467/6S+yw
+ bWwdHEQtk8H8Cz/nvyArJ8Wsa/BQWWHG+a9ecIgieA1q4MxMGwukfPyOYv7LephZHYoUK3kE71O3rURq
+ rfeXiAjk1XXK/555O665udHOHjPry7VYPPjJ4h68wRSwGQoqggXwTTlcsKRuysob7NeBpZHg7ooKJjzm
+ 4ZnelIGLQbHUKblm+RVOU6Ue1kACxd3jMwwujbjN4nYkUiyiVKvh0OnTuO7aa0FtikRTDPlCAeVKhZdT
+ LJWg6zra21Lw+wPxcDiy0rKME6Ojo5P4uAPAweHh7tWrV//Zfffdd30oFAqwaRJm8quJoFqt4e//7u/Q
+ NnMOt9xwA6hhIP0v/wLLqEFoXJFkre4Ra0WhqszjDqgnst3QHmPD42mqLLuKcmMBv7o2USGvEtws6b9L
+ gi9yMqmTnsidVoSEaXcCeGIYnP0puG/LrQciaTqZElSQA/JjLjyiIFl3q11iwOG2jUqWk0QvPqbe6RNe
+ OpG7yF+QeUGURtS+yZUoU6kSd8l0UbovMRIFKLXRbBg4lc1islTC5k2bYNo2mmJRzC9mYZomfz+fLyDe
+ 1IREoonEYvFIuVTqKpdLr52dmsrhA/xB0t86AAxu3jw8PPyVz3V0tLeUSmXUpB1VcsCPnfP3yCOPYPb1
+ 1/D7u3ZBIwSzzz0HM5/3UEaYrlS962E7yseZsAzsdSmjvDhMnjYU2skDDhLDLaFrBK/IhoGnjZRZCw1C
+ 04pxUAdgjKEb9lYiiPewcgqbKvqfvyEsBLWiuuXMylvqN3k82CveFtb1DVCkjSp5mAAv5ZixchQUhNf8
+ h2S68zI93aJUop9nabL4TUT2XfTdNgx0EYJDk5PQ43GsXbMaPr8PAb8fM7Np3lbbpsgXCujp6YTfH/An
+ kommEydGCkeOHn2TFeXt1vuRfqsAMHzgwJ333Hvfv9t0zTWrqtUaiqXyElF/5/rllw/hhccfw/4tWxCJ
+ RrDwyquonpMO7lT+q9eZPFcjXlU4UdWtclFeQFHvu4yhVL8EayqRMEm9SYhBXNNblE6Ud+tj2JI28/SF
+ MrO7bkGNm6uhEDFhqcsM2V3w9pTvDoToj3eloLIxh6NYY0EGpJWb1AtZEh29IK0AB9RMyn1BO3YlDACp
+ H5xPPEDldlCCAQUcaKWMnkAQz58+jRWrV6OrsxPNyYSzW1A6VcgwDBiGie7uDui6P9qcbO4zjOrUyMjI
+ GD4gK+C3BgBD+/evXrtu/f9z5747txCi6blcHpbl/AgDAwCHzwk0QpDJzON//cPf43O9PejqH0BxbAy5
+ I87vMChD6kqs8yGNqDcL/07Vu2LkIe8IU96TtTeVyxD3G2CJpLBkH1OVeq5xvUtYXRNFtEmahmKlyaa/
+ MkfNhEb6PV/q5pGnAZW+EtFPJoCAA0hEooh8so5irnuETwI70SePyybvH5BeZm4KN+fr3BmJctR7TwVn
+ 4V4oTRQLrljvpeeUPaeeevk79SCoFAoKWiygRffh+ckzuO2220BtG7FoBMViCUV27DwISqUSAgE/kskE
+ IpForFKtLjeM2munT5+eZy3A+5h+awCwZcuWrw4dOPh7rS3N8YXFRdRqjukvT/NprqYrl8v4u7/7H7iB
+ UmzctAnGwgIyL77YWMd7fVMpKQxDvSfvuszHNYcspOx/ol4TwZEKjFCvsezN477HGHKJFgsGJl5rXuqH
+ fCWZw8QjgJ4Lz+HEvD0cwIQKg6CSB7Sk8/aU+xKYclekgXav52bRgPopQJn+Mli713UgrwKRPAIq5Hs3
+ eHvvAjb15KGN3pRKV2ZRRJv8+TxMSnlQ0LZtRKNhpOcX3F8ggrtSMI9UqhWRSFhPxJtDR48eLh45cuQ1
+ AJZEtvcFCH4rADB84MDv3n33vd/auHHDimKxiGKxBNu2ua8POMJPNAJq2/j+I49Q7fhxcuvWLYBhYv7l
+ l2GXy5J2AgD1AE4hiFD8uaWMTPGOyiSCiaGQ3PnqbtVlNyTz0KnX1ZBEagBP7H6dCEjfiWeY1Ui43FHq
+ 5mdg4f0hJCdbvW/rdJl6gMhlaAkNZFnnfSaNtKGnXllrg8UMVEhVBFOVNHh/Aow/pC59ZKODQnITGgCg
+ WAcsOlPnikgAIYEWcyu8royTX3K9FPBTTQwKoIVSHMsuokg0bFi3Hj6fDz6fD3PpDM9qWRYMw0B3dwd8
+ ui+cSCS7jFp1emRkZBSOGfe+zQxcdgAY2r9/2erVa/583513bSME+vzCIv81VnW6TwMhwK/e/hV++fST
+ 5HMbNiISjyP37ruoTDkHrLLxljGeJSIPNBpQiwE1oDCBDCAMPBq8Kl00AGOGCfIGEwjwoQonyUU1aAd1
+ zW7PwhzuCBAARBztVedcEFGfUmMDM1pULJXiYgORFsooWVnfxPZBeHshAFBqPRckV5gVQILSGQ7MvHyP
+ cLuMIC/38eCmaKNEO3Vq0L2mavuVdRiQ2sLbL7kUbuF1fXHzUUJgV6vo8vvwwtmzuGrDerSlWpGIx1Eu
+ V6SfJycol8vwB/xIJOKIRKLRQqHQUy6VXjt79uwC3kcA8F3uAjVN+/Sdd921PhYNB2ZmM6jVaqDUiYIS
+ 4lgBmqaBUhu5XAFPPfUj3L9sGVp6ulCaOI3i2JgojI8DV791GgbSc4dP3LxEFTilUPllIt5XzQq5fokh
+ KRBsTqL7059G9513wReLglIKs1jE1FNPYfKxx1BbWKjvg1fZS43gK+Qk0GL3mEwSzrxE9WC4cMgcCihC
+ IpfLesT7KkXMmZaTVbVLR8qEggmi3BlPx8SqSCr6pkz5KlIIXzyO9ltvReuePdAjEU7P9PPPY/ZfnoWV
+ y/JyVDdEAj4euPS2SQ2KUgqxtoHyZip5BPpCLGDiaxxUwFLcFffKnpnDxkAA//Ttb+Mv/uzPQE0Tywf6
+ sJjLI5cr8HZMTEwimYgjmUgEbrzhppW//vWv7nzl1VfHAZh4n4KCl9UCODA0dPOePZ/69zt27LiqVCyj
+ kC/CsmywX7IBCDTNsQIsy8TD33sIK7OL2L5+PaxsFotvvNHwOC/lNF2gfpDlhTUNNDp/xN93JYILm9fX
+ 9ZYvgKh73z6s/MM/RNtNN0ELBLhV4wuFkNywAT333IPq/DxyJ0ZBCWc/NXQhBy+5cKqnD/JTcHjlpA5E
+ hNwKN0kBMDeTLDY8EaVlihB56cADaKozLV14XAUq32EnI6ktZyCS2r0LK//0T+Hr70c4FkMikUAsFkNH
+ Tw+a16+HNjAA26YoTZwCZS4Zt2wEcKvHpLhtkoBMAJFLJR4vlSnjlupZf8DiRvxMJFafEoQWAU9KKUKl
+ ChYsC2PZLLZs2gQKwO/3YXZOTA1algXLstDZ2Q6f7g8HgsHOWq16cmxs7AzeJ1fgsgHAweHhSHNz8797
+ 4IHf3+sP+APp9AJM93fW5Pl+BwCAN15/A8d+8QLuXbcOfr8f+cOHUctkpN4yRKfyOCtJMIFgQsbOQni8
+ 6sm9z4RT1nZgG3rcd/jyWOe66447sOab34Q/meTFid8oBDRNg6ZpaNm+HZVMGvkTJ3g/Gh1I6dTBliEz
+ zpQ2HzWWOI/8yRodnKm93ZbPQ+D95gFFmX1FDWIzVYOWMyuMECYhartk856/IsolhKJ19270fPnLyGQy
+ KBaLyGazmJ2dxdzcHGq1Grq6utC+fDmwfBkqmXmUTo2DUtET2RaQtzPX0Yky3pCsI+JlKAkw+MyKEHAK
+ 57ZwGWS+ZCaZWKlq2xbadB2HZmbQNbAMA/19SMSbUCpXpKXCjisQDofR1BQjTfF4ZGJi3Dd97txLuXy+
+ gvcBBC4bAAxu3nzP/Z954ODqVSu75ucXUamUXbMfcITfHQDiTIX84AcP4/7OLnQNLENlchJ5tsOPa0Sx
+ DVTRXLSO1SDMf8lawNJiIytL72STejqN+MqEX/HjGUO7JrJt29A0DbquuyCQQfbEKO8UYfXK/SAecFCs
+ Ei/ESf95sY0fOuowMH+Tn4zk0okVxE4xkjctMWvBZWoJBrhxICwF8BvKgaONqK5mBwC0ucKfTqdhmian
+ IaNjPp/H7OwsUqkUUqkUsGwZygvzKJ06Ja0gVQjQoF7FTuBjzfdvcGH2vMfLc65sT6yHWWoC/Jwl2nIY
+ hVIKq1RCeziMl+Zmcestt4BSimAwUDcrUCqV3QVCfn8kHG2amZ2eGxkZOQYBAPWEvUzpsgDA0P79AytX
+ rvqz2++4fbBWq2mLi1kYhskHigf/NA22ZeCpH/0IA+k5bF22HGahgPyRI7BqVQjxbaBRAKGxnAv3f6al
+ VAGTLQeem4pjPdSgjhhsL0MQXFj42acXBJq3bUNlfh65EydcBe9G8GWJ42qEiilKlsfrkkC8J2sz7p9K
+ VAG8WoyASPsibdmC5ZFASELKEIYjMt8LIdtaHuOZ1y1WzFEOzkw/pnbv4cJvMJdPAgB2bRgG0uk02tra
+ 0NbWBto/gPLCPIrjE7zfSseJaAn7kLf2i9gJ4YfIOMKqSpc8jasoIAacFEo13L0AUfgKoPCXSsjaFKcK
+ eWzevBmapgEUyMyLOJFhGNB1DclkHOFINLK4uNhRKpcOTU1NLcCZGmy4ofVypMsCAFu2bPncF7/45Xva
+ 2lPJudk0PyeNaX/H7NdACMWJkRG89fxPce/q1QjFm1AcG0V1dkYhaL0p6loPktAT5luyN5gFLfuxzGRT
+ BIL9D6UmXpGsNMnFaX7vPdu2oes6fD4fWrZtQymdQf7EiBAPxlhsk4ln7omLTt1CJ/6ixHQeBnWf84qU
+ 7gkaMio49CH1NGFt4ptt5BI8Yi+3Txk9Aon0IBRo27MHvRcQftv9JaelQKAyP4/i6QkOQSygabvt5YLI
+ g33iSFPWD3nPBpXoKjrEyoCkeMT4OFXJyKGePsDyU8tCyu/Hobk5rF67Fm1tbWhqiiKXy6NULvN3i8Ui
+ mpNJhEMhPRZr8o+MHJs/duzYryAAQIKdy5d+YwA4MDS08ZpNm//jrt27ri4WSiRfKEiBP3DTnxDn11Se
+ ePyHuL2pCf39/ajOzCA/egJU+ukuZccoVD62wU6olZ4LRekRByLxoqRKJcxomLjMUXTtuwNXffNblyT8
+ 7M+yLOi6Dl3XkdqxHaWMAwKsf2KuvfGoyv6saCrhTCrZLHXv26T+LpUJywlGJeCEEnKog0iOXOInwIhN
+ +TSlCiyN+TS1R9X8jegm05U9q9VqmJubQ0dHhwsC/ajML6A04YAAi9swmkrcBELkXXz8PyURTgTnOWVg
+ QCRa1DOa+MosKA/Cs5GyiwUkg0G8nslgz+7dsG0bfp8PU9OzvBzbdiyrVKoVgYA/UiqX22vV6tsTp0/P
+ 4rcYC/iNAWDL4OD+L3956K5YLBabnUtz3wYQpr+maaCw8eKLP4d15DB2DQwAlKIwdgJmvqDyJMBRQAgA
+ C85x72tJUtA6refVAiyfMP0Y8NvSQRrdd+zDVd+qF/5GQt/omRcEWrdvRzmdcQODUCSLCbLYu+/tnKz5
+ JatAwjVx0q5aKkBguzYrgbTwhgqdyDU6jwd4EFIWHGlMGB0F46s2G6S2tu5VNX8jejUSfvZnGAbm5ubQ
+ 3t6O9vZ22H19KGfmUZqYcBtEJAvQ03QJ+aksrI2YyCvc3ntSH9nshsAOdUqS5QIIIraF8XIZZjiCdWuv
+ RjzehGKxJK0NAKqVCmKxKCLhMInF4r7Dh9/JHT169DU404LyKsHLln4jADgwNLTjuutv+PfXXXftqmw2
+ T0rSij/AobOmaSAaUC5X8OSPHsdnBgbQ3NWF8pkz7uB5duJz1JXVkayuHcKLtdzuc8IGXyK+LCQX0Pji
+ gqBn3z5c9a1v8r6cT+jZp/ce+25ZFl8N1rJtG0qZDAonTggN7dUqrqaxIVvwFPKBW8IsUlSU23rGoZK5
+ Kqtz6i2DEUesJVAecavBZXiJzlQyt52FWao5w76m9uxB7/73LvzsularYXZ2Fh0dHejo6HBAYH4epdOn
+ VR5i7yhanXL3wOmSQ1GbAt4j3WWW8FoznEY8rxQTUNwFtSyrVkV7OIxDiwu48847QV0rYGYuzV0em1KY
+ hom29hR03RcyDLPZNGrHx0+dmoLqCly29BsBwJbBwaEvfenLdwWDoXA6nVF+PFFofwLbtvD0U09iZXoO
+ 61MpWKUSCuPjsN1FQpxV1VGE+OFIj5ScZ3pMnOzD7hFPDgghgFs2W0FGge479+Gqb37rooR/qWfyc0op
+ TNMUILB1K0qZDHKjo8KH9bapDqzEIpRGjynE2Xuqya72mypXEEq63qgQ+Th4eCwTz649Zp0Id81pdWrv
+ 3obC3wgAeNFUBFS992R3gFsC8+7sgNsBHtHgQkqkT5kKBIL7qPTpjozcJul/m6rg7C1DIYtER5LPo6rr
+ GM3lMLh5EIGAv37HYM1AJBJCOBwikUjUd/jwO9kjR4++CgcALjsIvGcAODA0dO2uXbv/ZPv2bSsWs1l3
+ vb8rSGy9v+Ys9z17dgovPfcT3N3fj0hLM8qTZ1CZnfNoLpFsLg3yj0e66+DdPHwe1yMNquEFJU+dZQ02
+ deY8cDT/pQt/ndnZIKhlGAb8fj/8fr9rCaSRHx1zGUQCNM4xkjZlTrrUXSp1kOlv/luCBHwREpEJxM1f
+ D9jyJbT1lpN4Lihbt3mJBxEgZIo4mr9v//6LFn6ZXuezBpgl0NXVhY6ODpg9PagsLKB0eoK3QVBU0Sr8
+ LiMBJ20jneLSi3reYe6W0n9RtLThTLrpZmoJBvFaNovtO3egKRpFMBhEOj0Pw2TTghSmYaCtLQVd10O1
+ mhE3TePE+KlTZ/FhAoAtg4P7v/jFL90ZCARCjbS/5mp/0zTx46efxHbTxLJEAmY+h/LkJGzTyc+RlUI4
+ 43Uc6Cav5pf8MT6Y7DERLKtwhCQWsobrvgzCf748tm1zS8Dv96Nl61YU02nkR0dBqC3m8KUe8k2+LiMK
+ ERRRbX6POqDIPHr5+DJVG6p0YKQm1A3oyaCgWEru29JzRW6Y6eveSO1eWvjPR6eLcQVkd6CzsxOdnZ0u
+ CMzzwCDl5r7r2jD+ctvJ6yAO9zjdpXxGQcEBiV6wXZNJ2c5NRTksN5XfFLhrFQoIBYM4nMvhhuuuAwBY
+ to3M/CJn/1rNQDAUQCgUIpFo1Hf4yLvZo0ePvoLfghXwngDgwNDQthtuuOlPduwkK2arAAAgAElEQVTc
+ sWJhYREFj/YnBNB0R/uPnhjFOy88jzs6OhBMJFBLZ1BNZ+COgmThS76kBAZc77l09wqKlElJhKjD6GV/
+ +bJr3z5cfQHhP9+98+VdyhIIBAJo3rIFJRcEHGaVdjzKTeV9dojAH1H5Wf1sgDJ/Lxrq5FVUOCCrdNkw
+ 5g3wgIHTEhWwWINSu3ejb2hoSeE/nwWwFJ0b5anVapiZmUFXVxe6urpgdHejsrCA8sQEBzzOM5x8VOEh
+ FRDB6chJS8EtIELVOAk8/MXGjbqWZR0N3euE3483s1msWrsWqbY2hEMhpNPz7mlZTjIME22pVui6HiqX
+ Sk2mZR6bmJi47LGA9wQAWwYHv/D5z3/hrlAwFJmby7iDLBS4pukgcLT/T555CjsrFXSHw9B8PpRnZmCV
+ yy7fiqg07410j1FUPBNtkLWaMzCEj5jX0+ODSFWmBXV8/sst/BcCg1qthkAggEAggOSWLc4U4dgoa6ii
+ tQlcULVlSogeqsFS8Vi28imEFyyYXBJZ7hrwDnGNxhZFUEZu4YNJpYgBSu3Zg76hIczNzdWt8LuQxr8U
+ 4WffDcPA9PQ0uru70dXVBbO7G6X5eZQmTjutI0SmkNJP1id2CIogCLhFwOnAND+g9JmzgYQYatzJsziI
+ AlaxhHg4jMOFAnbfdBNs24ZlU2TmF7gMGYaJYCiAYDBAIuGIduzYkcWjx469DjEjcFlA4JIB4MDQ0Np1
+ 6zf86c27bl6dXcySQqHIgzVM++uaDhCKkZERHPv5z3FrqhWhRBLV+Qyq6TTAgjtuFzgNGTLXmauSs6B0
+ mfJBFWtf6pHd8ePECFPXwjif8F8MEDS6fyH/lt2rVqsIBoMOCAwOOlOEUkxAa0R8ZtZyLebVQUQiH6Mh
+ I7DXpVrqPtTzEp1Gi6zSvJ9yXiD3+R3hb7TI51LocynfvZaA2d3NZwcA2zVuPDv3mHr39tXNxTcwSbTk
+ 1gSoIJ/ET5SK++opxxLwukXF/DreKRSxbM0adHR0IBwOwlGmJncXTNNCS3MSPp8/PL+wEDON2luTk5Nz
+ +CABYMvg4P1f/MKXPh2PNzXNzAgTTwT+dBAC2JaFZ378NK6t1dAVjQKEoOJqfyVJbr8zLvXCL6MEIylh
+ V94DNOR3IK0WpGIYAILufftw9R+rwn8hTSTfa3T/Upjbtm1Uq1WEQiEEAgEkBgdRTqeRGx0DO+tAOtFL
+ MuO9fZV8cW+knj+RLQb1KTxPGgKsSzNOPZfhZcq3SZr/UoTfS09v5H8penppW61WFUvAcEGgfPoMuDnU
+ oFdyXVT6Xkcp74YnBsIKUIJbHeq6E+FUMUCwiiUkolEcKRax++abQSmFaVmYX1jktRqGiXAohEDAT4Kh
+ kDU2diJ9/PhxtjrwsoDAJQHA/i9/ubOvt+8/3HrrresLhaKWzxdgWray4UfXdGgaMDY6hqM/fwG3tLYg
+ EI2iNj+P2uKil8MAyPjIrtUv3je4eSZno4ASrZYKEYPjpGCyGWv+rz+CL5n8QISffWcgEAwGEQwGkdi8
+ 2Y0JjDmN1eAqKQ+nSRt4WLBL3Zm6FI3FmQmcJp4trSIWA8l8ZrsyGQozGjtEbdurCv+FzPxGwr9U5P9C
+ 3+V7tVoN09PT6OnpQXd3NzKVChbeeht2rSZpb4kibj8pp4O0+MxVaoIz3f4TNdZCXZZj7kIDwoNKK3nl
+ 9RUxXcc7pRJWr1uPVCqFYMCPczNzsKQfGqXURjKZgN/nD01NnY3mc7lfzqXTOahnBrzndEkAsHXLljs+
+ 85kHPtvd3dVybnoGtWrNMQRdhtB1HZpGYFkWnv2XZ7C1XEJXMAii66imM7ArFSmyAh7b44RS3FlVP7FB
+ EPuw5fvg32mj6LWb3fGngYHPfx6pG28Ujy9C6C/EnEtdny8/pc5CoVqthlAohFAohOTgoDNFODbm8c0p
+ d5FIA07j1irz11HPGTIucKaXycz8XckmoC7TEmUqUBA2tXcv+j3Cf7EAcCn0utB39lmr1XDu3Dls2LAB
+ gUQCmUwa+ePH4ZJG4BynmcRHbAmvyyi2wpxUmPn8Lrsnc6Fs+jOas/gUUeJbVrmMpmgUI5UKbrrpRvh8
+ OsqVKrLZnNMi4lgB0WgYPp9f13S9NjU1ee7E6OgxCCug0VBfdGroap4n3bRy5YruQrEIo2bCsuVOOg0m
+ GjA7M4PZk2NYHQ6DBPwwsznX9LdhU9tZfcX+pPc5oRnTOaXCQWZX67mflBJQSlwIpKDSdA8vj1IRZ3C9
+ BQqg5847eYcuRfgbmbQXy8zn+zMMA5lMBrZto6mpCeu/8Q103HqLA/GUekaYSvcEIXnsmrp6nr/k1mOD
+ l0KZFHCkELQjbnmiCwQ2Yb8nYHOtD0qR2rMXffv3vyfhX8oS8OZnlsHFCD/7zOfzOHToELq6utB2880w
+ qQ2LUlguP3Chl+IoFBTUXY9vU8qXT3P6gS2pdttFGVM59LJdGjLopLxN7DsBpbYT/+IkpGguFjHy7ruY
+ np6GRjR0dbRBhhPbtpHNFuDTdQz0D3TGYrEdAIIA/HBO9Gpkd1x0umgAODA0dMPtd+zbFY/Hg/lc3v1h
+ T8Yo1J3712BZNg4dehlbCUGQUmi6D2axCNuoKUzskpyjsM2+y8AAV4YZw1P+lnPNLAEKh8E5mggU4Kfy
+ UCcTpTZ8sZjz7ALCfz4mXirPpf6xcthad8uyOAh03XqLswuE2g6OuXRwNBWjnfwngSOnL+UC7jChYEpQ
+ yi0G0R9A/AaeNBiSWWWDIrX3/PP8F9vvpYTftu3zxgMa3ZOfnTp1Cj6fD3o4DMOisGwL1Jb5jNFF8I2s
+ N+R2cZ6l8o5DgFIbDAeY++CAA3tD3rXpgAinvusL1GZn0JfL4dHHHoPPp6Ozow2dEggQAmSzOVAA4Ug4
+ Mrhl2zW7d+26Fg4A6O7fewaBS7EAbti6ZUtfuVxGqVSGabFf9nU6omkO09RqNYyfHMP6aBTw+WHk8zAq
+ ZQ6WTBUzKwCUrapy2Zg4gm0z5uWYyoRZijxTwbTqNJcguSwoys+xnod5GjFZo/uXov0b1eX9M00Tc3Nz
+ sG0b8Xgc677+DXTecosq/KzfytAwOrluEqeb03f5Z8uZTHOA5KAKvpCIt0n+zpgbQPuevejb33ie/0I0
+ vZDmZ4K/FB0vVAf7lMHDpBYsSmEy64nzhASOnLasXtfqtKlKa04bV8CJoJUMlpRZLjLfUF6L1AaCzkoZ
+ v377bWi645F3tKfU0XXPz9Q0H9avW9/e3Ny8DcIK0HDpljxPF/Xi0P79PX19/b/X2ppK5PNFGIas/QGA
+ HfRJ8dIvX8SaYgFRywLx6TALBR6EkeBWFM7jAI5JL8m8ot2Yacor5UQFGNPz/AzdJXNPgA9g5PPuvaW1
+ iXyv0f1LEf5L0YiGYWBmZga2bSORSGDd17+OjltugUUpbIuZ4oLXhHAykKB8+oCTR6GkEHib0YVNLXoY
+ loEHHzYCtO/Zg76h9675lxJWWeNfDN0blSN/xuNxmKYJo1iEZVOYrB7qKBduCXDecP64S8lB0cnATHzB
+ SwwgXeJI/AdQZZpWBRD5zwa1KWpnpxCfm8ND3/seAKCzPYWmpihkxZ7L5ZxDQ5pbm/v7B/asX7++F6ob
+ 8J6sgIsCAE3Trr1j374eTYNWKBRgmgbvOKWu9qeAYdRw/PhRXBOLgfj9sCoVmOWypIUl0koDyVDZyWRL
+ aOr+2Y2RVBBV1lbieCYREGPs7jDY5JNPXjRjNXp+sdrsQhpQrke+zxa3WJaFZDKJdV//OjpvvRU2AajL
+ xKK/Mi66PaXu8mGqrp+wmdaDxPSQtJzcD6lMuEKT2ru3Ltp/sZq5UZ+X8u+9dJTzemnW6NPn82H58uWY
+ mprCxPPPixgAHLrYtloPwEBB6jj1tJsJOHV4SeZRL19Sxm5M0j0ArQKM825vtYaXX3nFwVmNoD3V6rbN
+ ketarYZyuQJN0/QNGzcl+np7twMIwAGA9+wGXKzpsGPZwLLOUqmMWs2AJZlXAKBrGkAoRkdHQWZm0EYI
+ QAiskuT7q9OgQquw20T8qRaA+79LXPaYm8WU8rIYorO32UBwwHUHYeLRR/luxYvV7BfKw2u9SLC4EDiw
+ aLZlWWhubsa6f/Nv0HGLFBhkVfIZESo66hKKutOF1PZoLU4fKdjFiedeEwpIMyrte/egf//5V/hdyp+s
+ 7S8EokvFAuRPBhA+nw89PT1obm7GqVOncOrZZ2FTwOICLK0OoY7CgEwCrqjE1N3/T92bBlt2VGei39r7
+ nHPnW1W35kEltYQESEJoACQBBk2IwXa4I1z4BXZjhO1nA7YxOOLFi3jGr90vov+1wcLY4e6mjQl3vOe2
+ O16HaVQlNIGgobEZJJBAQ2moujVX3fneM5+91/uRuVau3Ge459ySX0fvqnP33rkzc+fOXN8aMldmMkjx
+ HOqPDB2H0ZHwHax1bhtGGW3utd3cxa8sL2H15En84Ic/RJqmPcwARq3qthm/8sqrdk1PT78ZrwED2HQY
+ 8KMPPPCGt771bf/bHbe/7Yql5RVsbFSjsf80TVAulcCc4xtffwJvXFvD/lIJSFO019eRt0VbiF0yWYiN
+ /BNpUMcDfSw7ThgqQuPpQpumUTSiveUoOKvXUV9axJ477xwI5GL4IPAPyzRGYRh5nqNWq2FqagqTk5OY
+ uekm5yfwyss6VZVMPvFkqojkEPvtB2C7POS+MMznL/bcezcOP/DRgU4+w4RtVof9nvdqk15xy+UyDh48
+ iJ07d+LUqVP40V/9FZZffAEJgDQhpEiQJEAitCielVIZVvhQoFPpo5IhPBJpHkYOQ33ZTQdtG1hy1tvw
+ bZ1mA1MzszhNhJ95xzswNTWJxaUV1Gp1za/T6WD79hmkaVpZWFhIG43602fPnbsEoI0wJDjSsakGQERv
+ fec737m/3W6jXmsoAcjnJeSyaLc7OHnyBF5XqQAAskYj2P4+biSgPAORzRfYSyRSUW3CPTeNG9wTK8EM
+ K5rvJ3lngYB85c9/9Sh+9NnPukUagb6ENqwEHzb+KHHFUejMmTOqCdzwO7+DfffdH9RZBPliTSnWbxFg
+ +3CWuoQOtQYZxebsCHz3EOAf5hsH3ctRNAkGgd/GBWLwX7p0CU//1V9h/slvqNcEieT32lDYti2Pv99s
+ fGLXNlDX4NxL9kgDUJ4LVWE1TB8IkcItBS/lD+Q616jj+eee087APbvFDHAxsixDrVYHM+j6G960fc+e
+ Pbcg9ANsSQvYlAEw81v279+/q1aro9Vu+bH/UPAkTQDk+MH3v4d/VqthrFYFmJE1Gq4nVIhKPl6q2lzD
+ NrT+DayVPVOwYJa82NYgSTMiqlxlPKIWwxHD6YcewlOeCZAO7QxPvMXwfyqG0Ww2cfr0aWRZhrm5OVz/
+ O7+Nfff5jkHOzWr0gbi1zmHqBFJVYQ0BBrSz1MYBO/deC/7LZWj9wC/MrhhuaBAAos7CYcCfwM2pSAjO
+ 5PNygzzdyLfDMzvzxiD+lT6DFNfa0gplyLRjqXPnZJUrw9AhQeEDlmZ91OaZM5heuIS//8pXAAC7du5A
+ uRwr6dVqHUlC2L//wNzU1NSNcGaADAmOPBow0AT46AMPvPH2O+749Nve+taDi0vLWFurqv1PBKRpCZVy
+ iizL8fjjj+LWVhM7SmUwEbJaDXkn6909KZxRe0qNRIevGbbEyDrWGmVh9TWfzpIOMwIbj/KTRmCsvPgi
+ qpcWcPAd70CWZX0JtJ9UGgSAfmlHAY0cWZZhfX0ds7OzmJqawtSNN7pZhC+94gmTFNRRVdtF+1iqNo7J
+ 4Mh8YGbsufdeXPnRj+omHYPKXQwbdD/sdbGOe9Uf0A3+p770JZx68ptO7SdCKUlQ0rNnBCDj2WjprkhP
+ LozsI1MumUHNwizI5kMIC4sG+oz/khdK8pQwvW0WL+WMe+66C5VKGcsra9H24lnWwczMFJIkrSwuLnCj
+ Xv/R2XPnLiKYASMtIT6QYxDRLbfffsfeVrMFpwG0TRVI5x9hfX0Ni+fOYj8BzDmyZhPcaUOmQ4gM6rqW
+ zimEISsBZm6qUlb/KdAGwlBXr38uNRuOKz/xWJSFS+Yf+iq+/2/+DUolt1XisNJrq9J/lPg2TavVwsmT
+ J9HpdLBr1y7c8Nu/jb33v8e1eu68LKXS3HezajxRHTD7ujQ15SuKAey5554tg38r32zj2KOXtB8E/qe/
+ 9CXMP/kkEjAScgwgIUIKQsLK/eJOQF8rxGavBc6VOF21xEuje2wISoxjkDAUMvVMhiIDy1VNghHNip3c
+ qOH0q69idX0dAGHXzrlCnTBqtQYAxhvfcP3s7t2734RgBiQY0QwYyACY+Zb9+/btrNUbaLVEBQwFT1O3
+ yefTTz+NazsdJBs1MMN1/BV7bpUKDWH7n1uY0ahP7Lihe5VNE+wmydLmw+ZGicbED1zcJU7YdQillODU
+ Qw91MQE5D5LexTjDSsWtMotms4kTJ06g0+lg9+7duOETn8De99znBqby4CasFGXqz9W1r4SoQyrE2XPP
+ 3bjy136tC/yvBZPbrN4krOgM1A/8Bw4ciCT/ySe/6fTghFCixEl9375JQkhIHNaKGKGgopMTOJw4v33y
+ mhVB+gwTJSRZmUmFlEhz0Va9ikCIgcbCZAI1qjnQuHgBO9fW8Mgjj4ASws657bq0nhyNRhMAYd/+Azun
+ pqbeiHg0YCQzoK8J8MBHPnLw6quv+d/vuuvdh5eWVrC2voFOJ1POVyqVUCmXwXmOJ554DLc2GtjuNYK8
+ 0UCeZR7I9ogUrcLhK8IvpSK93AzT02qINhogkJazwww9bY/w8tDhy0i8hrF8/DiqCws48Pa39yVg97rN
+ Cd6G94rTL90waTudDtbW1jA7O4uZmRlMXX+9m0D0yiv+40x9sK1vhk5rtT3evj723HNPX/AP8w2D7je7
+ HhRmz0AA/65duxz4v/hFzD/+OJIsQ5J1UOp0kHY6KLfaKLVbSFttJI0m0GoAjQao3gA3GsjrdXDDXaPZ
+ BBp1c+3O3GyBW0133Wq5Z+22u253gHYbyDpAlgN55s9uzwQhNIasZ+m1g6AoiCpqqJExvW0bXiXCe+65
+ B2OVChaXllGrN8Ly9TljenoSaZKUzpw5XVpdWfn2wuLiCrZgBvTdHjxJkpvefde7d2ZZjnq9Ztb7d+SS
+ po471hsNLF64gH1pAuRA3mmDO1lEXF2A50B0GgkSwIZoo1gG/UDYvsfm6wnILnzZ671GSpJf2SZNEuR5
+ jlNHHwLAuPlTn1Zp1A/8wzCAzZ4PE94rrNls4pVXXsHVV1/tVsf9+CfADFx49DH3oURhVVuO24ABnRQj
+ i2Xs3kTyb3Y/KuBHAb09VyqVGPx/+gWcePiYDtUleY4UjDQ3+0dxDvZ7+Lnvd5prLgQShDXsylJKL3bV
+ KmawHzlKjKYA8h3J/seUgBPRChIgSV06It8riWCLykiUP09Uqzg9P49mq4VKuYy5HTuwsBi2EsuyDI1G
+ C6VSklx73XVjzz77zPXPv/DCq4jNgN5ytnD0ZQDMfNNVV161u173zj9Z5h1noPP+GTmefebHuKrdBlVb
+ yMfGkWcZcvHmkw4Wp/OACmDmcAmAImCC3Q43qhlI5duJKn6L58AsYjIX2y10g9lFMkPD5iAkYJQoAZgx
+ /9BR5My49dO/36WKjiLFN3u+1TD5NRoNvPzyy7jmmmuwb98+8Mc/DmbG+cceQ8qZq3EiOzKl3aRSwjwH
+ 9t57N676tV/DxYsXB+7VtxVpf7kSfxD4f/DHf4wTDz2kzvAJez2YGCUAJfYrKyUA5WGx1NyTUGLLIWo7
+ BzpiH+QJ0XUcMgF55qVxEEZur8HECyBPX1LbxoZw9ykoSYCUPFNI4e0TIE3QmJ/H9m3b8Njjj+MD73sf
+ 5nZsU3oS2dZstlAuT+CKQ1fumJ6efj2AryGYAG5oboijn71ARHTj7Oy2qVqtHhGFf4g0TQFmHD/+Iq4t
+ Vzz3YnDWCZBl+Ap1tSBVq5UShTCsVcSF9L3C1AuOfSNK6VmgHooBZh/O7lLypLAPbgJGSglSIswfPYof
+ fO6zKJfLkcfgML9QjNHS9ArvNTZuf/V6HcePH0e73cb+/fvxxo9/HHvvuw8ZQ6e1MmvtuXcZIt977z1d
+ 4C92vo0C/kFxLQ0NCpP3Z1mGLMvQ6XSQJAn27t2Lubk5A/6vImVH9SUwKvDABzkk+LYlYfbyM5RhRUZ3
+ z4BX23V42dj8koJN2jz37+MwdwUMcO5Mgyxzv04b3GyC602gWgM21sFr68DqKnh5Gby0iH3NJr7/wx+C
+ ibBjxzZMTU2FchFUS5uanp4dHx+/FvFwYD8DuOvoyQB+9cMfvuGOO++8YWysklSrNTRbnei5W/jDLWd8
+ 4cJ5HEgSJKXUVU6WO/tHQBlQG6CugLWE6etKK1qaqHiRm7xIG0UeWT1AVTYhNiLNW/mI0UQAWdXIdR6d
+ eigwAZfV5kSvxR0R/JsBfdCv0WjgxRdfRLvdxoEDB/DGj30Me+67z7mG5fIO1m+Vb5fefgG/ZTjyDVv5
+ luK1BXSn00G73dZfq9VCq9VCo9FAs9lEs9nUMImTJAn279+PXbt2YXFxET/44z/GyYe+quKuxB705DSA
+ MlzPP8GNAuiwW+T5x9rezlyynUrmCPJLGQlRoCt5Joa9MyG8Wp8IEpMw/Ch+iGp9UIAre00lY2xfW8P8
+ yZNOnyfCjm2zsJhut9vIMgZAlauvufbQbbfd9nrEHYFbZwBpmr7h5jffsrPZbKJeb6jvtzRoyXsqzZ+c
+ x9jqKsYbVdcD3eqAs6wAd1PfBekDmBmAkopZ47PGMcwDHvgcpJmq+GQku0o+/35hFD5AOTlHbayqYUqE
+ EhFOHz2KH37uc6h4D8etSPHNfv384kcBXKPRwAsvvBAxgb333uuYAHOYCOTrbO+98VBfrzx7lakYBqBL
+ Wgtwm80mGo2GArrVaqHT6aDT6Wj8zbSNSqWCQ4cOYc+ePVhaWnLg/+pD6uRTUtADZSKUEqfJCXBE4osV
+ r9vLkNCJJ1ESygqxHSL9PSOMVLEPTxIgCW7Fzjq1vate2BDrm4PmCx014MjvwHGafH4encVF/PjZZx0D
+ 2D4bYVS0ACLgmquvnp6bm3sd4BWgy2UAAN64b/++nbVa3S/8IYcreFpKwABefPF5vL5UQtZyE37cTDUj
+ gQk6Dh3Sh58Qpaw0w5pIogeCVQmmdWfZjKhckqag3Gm9BxVOS0MIq+BANhghPzzohpNOHTuKp/7kTzA2
+ NjayOTCq1OzHIIZJ12g08Pzzz6PdbuPgwYOeCdzjNQE/i5DQ5eQzTFkEqAJgAbSV2gJ8AXgv777NGIs9
+ W/CL5Hc2Pzu1n8gBP3HMusRwkt9L/cTi16/SK/1CFtvmZKijwDzIm9aJ78RDEgsqzYwF1T4LCm7IksAP
+ L0oGidFLiVzHdGt1DfubDfzjP/4jmIHtygACrjt+c509e/dvm5qcfB22sEhILwZARPT6mZnpiWq1VpD+
+ Xj1OXd/hqfl5HC6XHbCYYT0a9FbVciNxFcixzsXKEEQb0BJp45CPqHoEs2mEwBA0PyEyyTcktAXxBfCJ
+ yPWOOzdSxwTmHwpMQNY+uBzpP6hzcatMI89z1Ot1PPfcc2i32zh06BDe8LGPYc+99yLzmtSeezYHv4Bd
+ VPReIC9Kb1ueXmUbFNbrXAT/Dz/7WZx86CFv2zvmXAY5DYAZKTutjYBoCJk9lyffIRiW5BNwB2kNIlDi
+ f6avgAspgrIvIw1+xIUKKZS8yPwC/UpennQdX5H0xNjVbOKF48dRShPMzs5gempSYgNw82+YgcnJyemx
+ sbGrEDsEDaUFdI0C/OqHP3zNzW+++Q3j4+NJrVbTlX+Y/bJfaYKECJ2Msbi0iLk8BxJnEkRDZmxez776
+ KLLYIdVvNlTSBKIWCWg53EHMApvC12vIl21sc4jvdQH30dlTDsF5kDERymmC+aNHwQBu/uQnUa/X+4K4
+ eN8PwMPE65WnXPcyHQCgXq/jJz/5CW644QZcccUV4N/6Lf89wFV9wG8B3S/fzcrT73pQWK9zuVzuCX6h
+ aqfys2MAoEjk2R0gAt5YR41J/EwSOEPBS2dd1ssSEkUkbISHxDXixvcLkHitSuey2a9RUzLCku8+vt2g
+ Vl44ubqGC+fPq0azbXYa1VpNi9fpdOAFZfmKKw4fuPHGG6969tln1xF3BMZStnB0MYAkSV530803bxeu
+ 3+l0Im5YKpUAAuZPnsR0rYZSuw1OEmf7Z3bxqbgiVTOwNZFDl6VmBHZgwa6qPRGCrWRimLDYuUWesZn5
+ ZRqSTE6eI1tGwRRsu8QDopx4JsCsTEDmD4zCAOT5ZvH6pRmG8dTrdTzzzDO48cYbcfjwYeBjH9P99JrN
+ pgJ+GO1i0P0o18Ocy+Uyrrjiigj8J0TyQ2x9N8Tn7H9WNTZhL7l9c8eihoK+q/1O+tCdmHXPAzv/31CF
+ y4kE/GabevMdRq77sqgE8wUNugSz/zBfaNsd0Dx9GnToEH78zLO48YbrMTMzDZy/aArtnMLSNMXhK68a
+ 27Vz51UAnsMIHYFdJgARXXPwwIEd9VoD7U68RBMzo1xKwcx46eXj+Gdpikx2Nc0zXWLKxVelO1RA6KXz
+ Hxtsd/c51FVZJrreMRtNwLyJvdngojqWr8sw+3SCdDb3luHou7yWIEtzE8QccEOETz34IMbHx7c0RDhK
+ /OJvFNNBmECr1cK+fftw4cIFVKvVSIUf9f393mvDe10Pcy6C/ymj9qdwwC+D/NAfe9U/9K0r8H0bJzrx
+ x6n3dpFOMgupeIvetL9k4hmHl9RhuhVDpgcrWSaJmg/63JsHSZLojygR0R8oOOJG+gidag17Wm08/aOn
+ 0clzbJud8RgNEdvtDsCMPXv2zUxNTV2JEUcCihoAAbh6dnbb9MZGFXmWdSVI0xREhDNnTuNNqWMGdqE6
+ Zg5L2fvqooLkjq48N7Wdo1y4FmMAHozqUFGsOFVAjD8QOt4AACAASURBVCZhGokBNQFCh01oLgBmurDJ
+ 37+T8hwpEZAEc+CWT34SGxsbPSetjCpZhwXeZvnbYbdms4nvf//7SNMUtVpt0/dvVsZ+5ZDrQWGDzr0k
+ /3yk9pPr4vZOPm6CD1RN1z0UQMFJx+zmE/UNkPj9B9qwHYK60IynF6EFSvwQnmcQOsogNOZJhpJgWohg
+ i1WAHrg0tKzb2xFjZ7uJl155BWmSYHp6SgWOKLWZx+j2bdumx8bGDiEwgKHMgIgB3HrLLZQkyTWTkxPl
+ S5cW0Wg2XYH8S8vlEkppipxzLCwsYJfv5WSEVXwt+BXEHLywwtPQGwsE7Jo28BXtPbdUsgfWEl4TuHNA
+ enwWfu4nv5tFG1nzUCajZoi8gL1rleutSIhQThKcOnoU4Bw3f/L34NZK7PQEzWvBBCRev/gW9EXJXq1W
+ e6bbrCyD7je7HuXcT/In8JRMhDKzUfs9dSeuzaz0V8pQUMdapcpesblBflGZQJfSQ+9oJHG+/Yk3UD09
+ iu8AQ3mAd0yl8G4gDGqp0AnvFs5khw6Fztm9GbP1Bl49fx5pkmBqcgLT09NY94vaAm7/QBChVK6Mj42N
+ HUySpJznufUIHHhEEW644YarbrjxTYdKpRLVdA5yqNg0cdK/08lQ29jAeKvlKzgH22XCWSSrVILbe57D
+ o+jGNly8qo3UJCP33DosF+4r1Ocl25MLpFnMAYbJn6Gdi4WHLFzCmCnsW852XBKAhHNnDiQJTh07hqce
+ /DympqZ6jg5sVeIPk14AL73znU6n76o6l1sWG3+z6+J5EDPrZ/ML+J3aDyP9Ez/U59uG5R1m5p4Hlozt
+ J5AxegTaABBcxcWuh9Gvg9ZKYseDVSOwtr8VXup6EC0N5t9CfphPguTd5uzmEXi6Z0KyuIT1tTXf4Qcz
+ EuDek+duZeEsy0r79x+Ye/3rX38FYl+AgWZAxADSND18/Ruvn2k2W2gbaSalLZXcxp+vvPwS9rTbyNY3
+ lP1FW8yZQyVvIUy1damsngnNmK15zqJOcHeSsNiF0XzIN5JnKtp2MO/Q9HFOQXuQMD8awk4ypZRg/thD
+ eOrzD2J6erovE3Cv3zrwJb2A3nrTXY4X4ajSfrM4veL2egYE8O/evburt19ceksMlNk5+ZTJ9fgLSMXZ
+ h2wregAqxVkcEsIQH5MsFRQATEmX4WwtRqEZUhNB2IeA31KVFFP6IfTKpggCjBk5S7+AMAOgduY0JqtV
+ /OCppwAIAwglJAI6fp7OgQMHS3M7dhxEMAE27QcoqghX7D9wYLbZbIAL234xuxVXs5xx6tQp7E9TX3nk
+ l6GGl+as0lcQpev8GUkq9SdwZOjqIGCGMQGCRHccP+yNJ3Bm4fgM7/oaCs76TrNwlmohiEwN55Dkd3th
+ VhuRrRbhly52TICRglCmFPNHj+Gpz38eMzMzXUxA6q/XbzPwSlpxwimOw48K7GGY0aDng/Kzz4ph9gzE
+ 4F9aWlKb31JumYJ3X0qulz8h5wSU+rF9kZrW9mQ1+2SmnsTzeGB/CQGqk7h+wyWlK0G+uPEK+EEifwyw
+ Q6dBkOjkOiKdLi5sirzLgWdE3rFI7oV5WdG9o9Xyrt4dTE1OIJTcHZmfer9r1+6JyampfRiBAdg+ACKi
+ Q9u3b59pNBpm6e/AQku+A/Dc+XO4Jk1daJ77xT9ihiG4siByD6SVyEGStclibs1BUqvqZpiRyPmQUEpr
+ uAFR8TEczF0JWVRIf6f2nSQSItIPM/4K/jXSEVVKEswfPQZmxs2/+7tYXV1VtW2rYJPfMC6z/fLpFV4M
+ G3S/2fWgsH7nSqUSgf8HhQ4/58vP3sknUHNoQo40vC6nHkh/jWlHzwQ8rw+9/kIuQmdGaxcpLO8MuwWL
+ lHdqvdIlHJ4lT0muoqigIcDkJSE5hz4B+cZtWYYT8/NgAqamJrTPIVSHo+jZbTsmx8fG9qLbGciow/FR
+ HAU4ODk5Mba0uIw8zwRDDnBEzgRICMvLS9iRJPrBICDPTI2xs9kjY8d/pFR60fUnWk1VHpAFuVSX1wdM
+ pUecXzmPkTgK3iJ3kvwpNHwOtd+0W4FM3CjfULUpAZwmmD92DDkzbvnd38XKykpPP4FhwSs2/WZzBfo9
+ 6xVeDBt0v9n1oLB+5yL4nzLgt+69KSUoeSaQ+DUbhEmL5FUN09ASeRuAfBurk5lKk8A0iFl98Z2iEFhJ
+ bixMMfsYomgYLdTsCUCqjQotOyEn2kHkdSipWD/DxyGDI3eebrVwYmEBlVIJExNOAyCSdzOyzAngiYnJ
+ yUqlsgfdowB9j6IGsG9sbCxtNlvIfaZSOUmSolQuIc9zrK+vY6rTgUhp18ABlOGVhr3KR3KvZ0Has33K
+ 6JNn8RCJHEwDG9e2iQZEReOubojQscNRmdmWXz2PxBwAkCQ4/fAxAIw3//bvqCYwCgOwE2WG0RT6PesV
+ Xgyz91u9HvbcC/wnow4/8vP53bnsVX6xU62q7c6J0p4MyZFtK/dEGX4Ym+d4xSkEjUBYjTAQga0A03r3
+ sRcU5ON1j4CxL3c4DOkBCGsThGFMyyRc2Hi1itXVVRARJifGMT4+5pcFc7nnbqsjlNKkUiqVdiFeF2Cg
+ BqB9AP/LL/3S7K5du68aHxujRrOBVjueAlxKE+V7zWYTpXbb9QHIVlwQwgjfzuzCNIZfaJF8YxTkaiAW
+ DQ/3Uf4R1+Rgk8lD07Th1nw/s3ogWu2BfdvmDOnUiN4faRoIWgP5hhImUEpSnDr2MJ7+wp/27BPo95PO
+ vX69+aP8oPU1OviHyVOuhz33Az/BS30BPVzHX4n9JBnv0GW9UQMjFuAnYSn0QBJK+gSHrTBhzMt5dRSS
+ dkx8HjEdqblp7uRK9UrjyqsrMXnEOLL0nqyCc18o7RCMRh88sxGzZWUVjUZD62BifNyX36UwGmJp27bt
+ u/fs2TOLmAn0PfRhqVTae/XV15SyrIN2qx1VMrM4AAHnzp7FTLuNTrXqK9uA3pc/IhLTaApUTcfmuUQL
+ lc8GqDE7sEwhSlLEeVe2rv3NdGLNRzy4AvD1vcWySloO8a3HoFNlE5x++Gv40Z/9GWZnZ5F6p6leP5l4
+ M8ow3ijA3Qz8wwC91/Nhz0Xw//Czn8XJo0fVwcct6OHAXyZGmYR6/QQe9j9VBZJIrJKXzAm7iDJK5NKa
+ HgKPMyIASYKcDPjEXA3oDHELhzAUSIcwEAPZd+glCbk1AShMMrIZhvwL4YCWGQCaFy+iXKvh+EsvAQDG
+ x8aiPABC5k3FnXNz2L179y50awA9D2UAaZruPnTFofFmq2XG1OVgpGmKPM9x/uIFzMF9FBO5xU09IATY
+ EOD6a+G8bFl0gXHYhTo0G6+js1fDrSag70EMdJu3JoIwkNwUgvVfN9dgfWdUIHsrGoMngtAifj0BvzLt
+ 6a99DT/6sz/vyQRsz/5rMZQ3KlPYDPC9rvud+8XrJflPHX3Iz9l3i3iUEc9jdTP+EIShLpzZLeFDa8aH
+ 0IVITQfaJJqAIwJGdVEKeSs/8HnoxiJw6cW0IJXkof2lcLnXFDUzBCS6GYRGO9Fn4o9g9AwCpjptnJyf
+ R6vdxthYBcVD+uzndu1OZ6andyIeBejLALQPgIh27t61a7LVbDu1nuF7OB0nTP0iIJcuXsSORGdVwGkI
+ ZvkxiyWCn/BTfOTVOs69ERRMlEhjkFogc9/rKASzRGWTq9yzzScQAiisqR/yCR04otmoBqiWFcNm6WZ5
+ BTdVBuH0I18DOMebPvEJLC8v6zBerznzowB62PBB96NcF8/9nsm1Bf/i4iKe/tznMH/Uq/1AtIKPTuxh
+ AwiK3V4D3cRtb30AnOR2pql11SXTNpI8WqrbpfSCyzVmYpmOp9EE8AtXW9osEE7hsJ5+8VJ1Rs572nIk
+ 5fUJLQtjOstx9uxZZFnmGUDI031iDkaCbdu2lcfHx7djyCnBWgdENDc9MzPRLqzpDy/pSqUEzMDyygpm
+ k9QI8kAICHUXJL4FiTwSyY0ghy0rt+q+Mg9h6ayRAuEhlMNKBLljeb/xAuzKT/NEKCuZPDmky30jRdqA
+ FjIcxH6eequJ+b/5T/jRv/7X2L59OwC8Jnb+5YJ/FI2gV7riM9u+vcB/8uhRyMSdFOLb7yf2gHWuv+PX
+ jsBJrGzfS0tS34a5G5JQak+8376RBWHHbvjJQF7dZ+NbElR/UmaRkAWtkkbQEkJKs7QYB9NFy+VuEqF6
+ xQpHtATIcGB44xQzLl26hDxnjI1VukwT1yaE6emZsXKlsh3dHYE9D9EACMCOqcnJMaeOCnBCB0mauiHA
+ tbVVHEyCeLXgL1ZSOCJxbCKRumtqWGBs+mEaxDC2EpsGD3mEXl+boYgQ7xiiy0SH0trhHB+g1RYRNwAZ
+ JpSySXw77Ricg1st8EYVtLGOZGMDJ770V8jqDdz8f/0rnZa7GShHfVYMG3S/2fWgsF5nue4HfqvilwBU
+ SOx/9mv4BZU4akOLbAEUhSm5qkGa6g/bd3g2In1JLE45BsxqJgSGI3nrM//eHNLrH0DrtAHbKRwOGSkQ
+ lhaYQGBOMZq96znBTwpiMAgTWYbllRUkSYKKX6PSgkXaYHJyslwulWYRq/9RjdrDDgNur1TGStVqWHAg
+ MAHW6YzVahWTFD6TwfopQZKz2kUBpvFSIOGQVpOPNh8mfEM3umBE9rZ8uGUM/l7dhWXGV6SZFDm6z5+9
+ 2SOfYKSMa2DSvIUI5BtY1Iecwa0W8toG8tU1ZBsbbqFUctLu1H/6GzCAm//VH+HChQto+glXozKAXuHF
+ sEH3m10PCht07gd+t2w3hyE+8kuusQxYxwxZacOvp0cRQ2dtCyHFPIrjy0QCXCPhvVkGcDAxrBg3zKw4
+ VBhDO84j4j4AxAnNqv8weUifQo6AFbBfS8AzCGPBYKLdxvn1daSlFOVySV4B8QVgdqZSpTJWKZVK0xiy
+ E9BqANvKlXKps9oxfQAmYpoiSRI0Gg2M54ZDGgC7ypJKAcKHB9VcuSDbp6FyrLrHmoCi1Mp92fLhcGi+
+ RW1CRvcLCokyBDM0KEmNbIsLHHiGgp9bLeT1OvLVNeTr60Dml1P3xClurPN/8zdgZtz8r/4I58+f71qd
+ ZysMoFc8G7bV61HOvW3+o0iZ/QKeDvwVeOCTW8NfKZSCWm21QWd3GzjpgHtg+tqhz5ZJ+9onRG0Zxu+h
+ Nr0QjFCxSGZLr1H54GaFOtkjGfjRCQ4SPEDIah2+NFJGYRwRDww0TgDSTge1eh1pkqBcKodcPfxcuwHl
+ cqlUKpWmEBjAQF8A2wk4XUrTxDmtSMcUtCMw9UuBtVotlPzLAHZzBgwYnGocQ54lM6lsbQ2O5/RIRcgz
+ r32wNA4Ji2C9NygOYcG/N5TNcHN5ieSrzVLkSFFvk+RJ+h1a3GbTbTW1toZ8bR3cbvt3C7d3EUUtLRHj
+ 1N/+DQDGm//IMQExB/4ppP8wzwaFDXMe1OFnwe+G+MIS3lLFiXGpDYgNEpEgNjkrlOzaOwJ676of5AZI
+ 24qsluiRxSa95qXx5B7BExBwO/5oYo6hJVjmQgb+UNPE0xIJR2Eo12KjEUjU1K/PmJDzyI0P0UIYaVoq
+ JUkiDKCv5JfDmgDTaamUZFmme6ZbluRWMyG3SYP3AoxA7QssH6c9pfA+9v65LnYAKPsqsiYW7u6JQquB
+ ha2Q0c89SagqZDIK6zrJZ/j6EuTa+mG9t05ComHY+V8uPAc6GbjRQLa8DF5fR95qQRmeEoYQizAB0mqd
+ /9u/BYPx5n/5Rzh37lwXE3B18U+v+g8KG+ZcnNX39Oc+h5MPHfWdfWxW702czc9AyhD9HNrRZ2ra4cOo
+ 7UzBW07OXkiIWIjaCEaDZekOFPYRiVpDk8IFgtuvZ+EIk8LJg5gNVfiyGComeUpAZmgL5h3EIVXYfoyi
+ upUjaTXRbrdBREhL4uXL+p2qRBClSZJMaBGG7AQEgIk0SdzQlJfwdhgw8WsBZFmGJMuQe9tHh/qk6Awd
+ ShGmJhXiazvas8iMAGraHgxVq9z8CYRY/Dy2TWE5biAYrXpDLUzF94SzdWBCljl1f20N2eoKuN4w2bjy
+ 54bDE7tvth1Ksqa9YwLAm//Pf4mzZ89GTEC+8bWS/ptdb+VcLpdx+PBhBf9Tn/0sTh07hoRk4Q7f259Q
+ AL9vgaTYcNbm1GbyQsK3XRK1T2Cm6vOPAEtDlabTTZECZcwk3v0ubk5FxIQxe/ftEhqXxeFaBIaUIDCC
+ YumMmlJ4xs73QfJjgJotN68EwSkv5hF6Q0Q0Zmqw+JLosH0AE0maUKfjpsRGWTOQytzpPNftvxQQkF9c
+ cwowAaRxynBJe1jwBpMu73hGX5EJhHgmiLrjR4zEvpTMJ3SVJrS6En6zCd7YQLayDN6o6pdLZrnIGOkw
+ BBttKBRPVMEygFN/+3dgBm76wz9UJqD18z8I/MWwXvG6wP+5z2L+2FG3Zh8F8JcTzwTASEkEv/T6u7zy
+ Qg2Jz70FWRD+se0tVJJ4IDrB40Cd+MSO/4skN+iQoUBPuszWz0C4Cwea8vmKxllcPpyQgMWc6QF6mVuS
+ W+altNcDD3CvyptN5LnbzjQMSxZ1ZwIzKEmSCro7AHsyAasBjMkOuSyVxjJ8Qn49NE8cnRBHXOajqZKe
+ 8K0JLSZAKKp/h+WVXVwtdCZqHQUBLqn0gk1g4AmWgENcnRXWg4talVSf55nr4FtccrZ+p2MICEKZjsiE
+ mEx+XS8j74TBbonr03/nzIGbPvOHXZrA5ar6w6r7m0n7YtjExASuv/56HD9+3IH/6DHnvpu4+fplMEpJ
+ ost4297+RMFjhEKkmRfZgS+DmgVWmBTquaBtWwasf83Mv9DWMXF1IcYyHJJJQwXIskkXMYEQJCkSHxLM
+ kqIE8+9gdkPKvu4T74hnRwHCPYiIxFPIMoCeh2UAFUrctslxgzu1Vr2imN0+6NogCMsywePKmAB2jrZF
+ rbpSWk1CkCMxhdi8NAi5cJRfrAD4v6YjR5hRbAka0R+58pJ5r39bq4V8aQX50hK43fQfbcZx7eHbQ9aH
+ E7PCfjNY6ilsBlGCX1sA3VJ+GOlffN7vmbbhgLBe515h4+PjmJmZcVITpP77JQbKFGx/+20EwVGQ4qGt
+ A3LJt4N26vmdd4uyT8O8UJZcEl/37NNGjeVpTXafdnMGxAXXEJPyGq/NaZ8VxRGElrTzLmThGIKP6wvq
+ zF7WLEhNU6vVWMZIYLNCl9U6ItcT90IiopJUtamunoeaAESUJl7FB0IfgPJM89Isz7WBwKbzg41E9zVh
+ ++G0/m1DyMdKbemkHInjK8C7gEq9hRo2Z6kRqwLAc3+pKM0n5rZcqE3HG3Lk1Q1ki4vIN6puZ1dTs4yQ
+ J0c5icyyzh7unMMmDnVx+MgRvP4P/xBnzpx5TaV/r+tBYYPOxetarYZGo4Fbb70V/Pu/jwTA+aNHfY8/
+ oczi6ee+Wdx8XVUH+omG20ztBldeYQKk7ycPLPXWE2ZOcU4x6bMy5kDOhQ4/si5Enm6KGoEyCVMvCHMF
+ 4pmL8aHlSoJ0V64oHdleYxHtl4jMmpu9jkBQ7FQAuxbAQCaQdF+TaXhAmIHjVD6PLHOVQlJ9+uURMtii
+ ldm3N1nkGPALB7fsU5IKo/AfaABunkCAz2zfh1DC4qR/n05VMJMnt5rIzp9HduoUeHUNyDoQxJr1j3we
+ ZHIjI43EDKJQr4bzy0SUQ/+TgV/Sr62t4Wtf+xqazSZuu+023PTpT+PgB97vpb5oBKxLYumSV6q1uhvR
+ zlTYJL00rDCbX0gm90/dvhrea8/nT6pqiCRlz0hIyTT8RMiF2JrG3MPEBcK+A5pWygAxD8y7DBRDrhZn
+ ATpy7ScTOrLzC8v0OkSjMm1kgY/CdXREc4Udhw32ffQMwS2SAefxpoA2nnCsUFQJGBc8PM/1mbHxGcpc
+ QmwJdyVhtveOEGSYRt/lut8hXJGFIRTeBQ1zz/MsR7aygs6Z08iWlpC3O35lIP+dZNmNYWCmiiU+eZAr
+ E1IqkJcTDhz5IK7z4G80Gl3g3+wHYNPwXnEkbJjzoDDLBN7ylrfg+k99Gnve9z6/1F2QiokBByD+GoBp
+ XgNuGS4WKWjoQqpaQB6y8JOwjCRmoynA0bfuGiwsh0yGHL7PugfLHpFkX+4LoN425EtiRwGMbISWJZTb
+ sh/yBU7gOy5Vo/HspAD+opZBZPMNwZJ1v0MZALsDiV+gUN5n1RB9qTdcdT8QGCK34OxiCEW2AuXmXYLf
+ EKrLg7WBmBHmEGjiHDr0KIygyFk9MBXwsOUE0G4ju3QB2dmzyNerkdrVXXbDgYQQjZeTMGJVbkX6m28+
+ cOQIrv3MZxT8Em8U6b/ZMxum5RjxvJkpsLa2hocffhjNZhNvfetbce2nPoWd732vr24vCSOO6+fuS92R
+ kfjqPcdeegoQSPtNiBKFDhkABcYgUph9XROQJBHT6CUjCRQPmluGZcFqtBj9RratHaewZbWlDnmZJwVN
+ QgpNpVIP06LvfRfM+h1WA+i4RrWZSsPHHIaSNMCHrUR1bE73UVetQE5eygoWmP0+HSKBWb22DOPU/FUb
+ kDjKsX05ySTyxcl9+Vx7sfo42DpiAPnGOjrnzyJbWAK32tBFwRxVhvzZX3gmpIzEMkxSluRWTI7ayZkJ
+ B458ENd+5jM4e/ZsX8nv8rs81f9ywa+l7nMt90UmcPWnPoW5974XTKT1oFgGdHnuaCltO9xm6NCu2W97
+ 84s/cOgkTIBgZyN4CagJanJJPENiAjiJweiVkvg9eu3z1HLKjWdYHjNMFLwUyX4iKVOyeiFH73C/tNS1
+ jWeXxHeLkCTg4jj+gMMygBYzwzZtDBTTYNKrCpHE0IoIePTAIFNNDDiFPQ9SWj5V1bDAdJQpBOgb5gJA
+ n5FvWOH4ljGQySdUqEzn5SxDvrSEzoXz6Kyugv2Oq/o98dcZxmTIwaNethVjZRqsSYUAmEglvwU/0F+y
+ j6Li97ounkdhDoOui/dFJnDl7/0etr/nfv/9IkGCtC8ipyhBAXZusSp8jNglX8dWr06C8xmT73dAeJED
+ Nat1GLSGIN2CPsFR2ye2PBGaKeQBD8ICMhMfJj8FNrN5n64Q3kMzQKQB2DrvNgWImbmNIQ/LAJp5niNN
+ Ev8tAYjhpZ4JpKlpvCQCaQQT6Ruwk6ehkbQRVa2PeGCQ1A7glrkEQRxlyAhzExCeWU0hABTIGw1kFy4g
+ v3gBebUG6MrGJnMZ0tQyc6RpaD+HEQ2RphCoDMzoCf5RpX/x2ajgHyZMa29I8MuxurqqTOBtb3sbrvjk
+ 72Lm/vcEJi7akTBgIQ8VFB5+RF7VJ40TXIcjhVxhnpj0mk7imgZyMszK8wA6mz5hMzQLA0iTNGIikre/
+ 1e9hhu48zMLqYo0CWkYzlMihLGllTMHevWKX+Q4ijMIArF7RyHPmJPEWG1sVw3PQxKsYpbRrKC9ECyAS
+ uz1IVM/BSASkdM8YbuuphHUpIVWY4ncFga9CQaOSk/DxmK7IAu9qvLqObGkReXUD3MkQtJACkYcMYI2J
+ WP+SwhjOAOMD4OMc/GBvtd992nASfqsSv98z/c4RwN8L+DZcNIH3ve99uOOOO8DMOA1g7dFHVcJJ73ag
+ F5G6AnxpNtO4ouGR1RTCaEHO0m8g9Mu+qYp0VJSa/uyFkHxdUZJDignHGJTmjOaqHoLmjRySeebgKcnM
+ PgxaEWuZRCdhAFQpO+wByAsavmhHPmme53mru+C9D8sA6lmWgRK38Acy16DSIShmRZqmyFNxrPBDW/77
+ BXNsv9i2n7yJOYCp0L4u2I3W2nq1X2srSgSDgNf6FLAWJMRFp4PO6hryhUVwo2G4iEYLNrsVSVpQw9N0
+ fQLTDyIJKLAMZsLBD/aX/O5zLs/Wl+tBYYPOW7keFGaZwJ133onvsBuD33js0eAU5JsqLNAR+gSIA205
+ h6pAVGT+sKn4BEHIuLzJD+sbIJO48TASlj4CnzdFbCKaJuy0EtZr60koJdAreXchP1OIqDOSRG1U9cIS
+ ms93bMzNAYAbqbI+Ee6zxFRiNgyA0ev15rAMYKOTZXmayHpfcrhPy3JGBc7/O0tTEOcgFmdGX2gWRwuA
+ c6MG2VowYDLF9xwEkdQOpgSrDSkNbkFvAcvFsX42jdNsIlteQra8Cu60UfRSlB2D4kYrSHXPVFjKIHHJ
+ cqtwzfQ/F/gHqfnDgl8OywTe/va349vMOMOMjccekxpU+ElNa7uS8+1nD4wwlTeWplGfns+vONtT3hXa
+ 1k4zlhjuSChu/Ui97vpCn5/VPBDoTejfppPqEiYmWoDTlikmN/PSvFxGpVIBM6MjDmmGCbhrAnOe5Xle
+ L3xE30YSBsDMvNFpd7iknQ1C8O5D8ixDDjfvu0POv9su3FF0iYZ8lLHtYjFpayfYh7YxjJIQBRiNEep4
+ I4ShhGybG+CNKvKlJWTr6+CsHRqL4jkLUuHOywxKYVbt7Cq+faLlcsdBM9Q3qpPPVq9HOW8W1u++X1jx
+ ECbw/ve/PzABAmqPPebbUSoytIPMpxDgFxQwpRCrrjvPwriNhKFoO/mMCIbJE0GXDtehSJc+J/JORiGd
+ 0KnMS7RTlsHwi4QEYaFCXeosoueQNJ4XoC+F0K8wgJxZt5wrHgkBnU7eybJMGIDVAHo2lvUDWG132h3Z
+ /su2LbPbfojZTQBpktszPUTJjbT2BKkLeUCluw6b+TiupmXbENMFGBKG0nMIj+O4s276YHJiAJzn4NU1
+ dC5eQLa6Cuh+fYEbK9cmBGJTyuKCBmOYY6F22YTlRNj/GoG/369X/FHOm4X1u+8X1u9YX1/Hww8/jHa7
+ jXe84x048PFPYOre+0J7E6sk1AVgIOAPMDetDc8dIA5qdrpumATgmXgwqBG0BGEsPqET5ZHDjZqzPp2o
+ 7oGZkEr/UDHohjDHSFRNh+VrGNE4u6gmFMrbLpUwOTGhS8lrqczoAwC02+12J8s2gC7y7HmoCcDMa61m
+ s1MqDDfIdSfrgPMc01PTMGDAwAAAIABJREFUqIExKRXkG8H1EXTbL0G1KYRbtd3Wnn/o9kgPzhzgQAjR
+ oiIGrSwtI62WddBZXgEvLoJbDYN4L2GkZaLOO32LhrE52wk9GkqhPKLCHjxyBNcNcPIZ5b7X9aCwUc6D
+ rnvd9wvrdwj9iMfge9/7Xrzzne/Et5hxHkD18cdVm5IltkCBPmRnILG5rYwPE34YooBr2/XqwNNChSYs
+ agzu/XZwjgythje5aIZ4ZejHegL2KIPlJ4YnaR7Ug/4AoFEqYWZmBp0sQ7sTzwsQ+x8A2q1mp9NuVxEY
+ wMDG0gX+mXm5Vq83y+VyIYpL3+m4Ney3bd+Gjdx9KOu2YMaOsSqOF9Uqk5njEnH8sQF+uYZJAkd0Xh3v
+ oTGw5CfE2em4Xv5Ll8DNun+XDAqZireMyCxiIo1u/QukzKFgxvPQhzGAA0d+cSD4tyLZ+2kFEraV86Dr
+ Xvf9wvod8aw1wtraGh555BG02238zM/8DPZ+7GOYvOdeiD0uwoQAnccvpoHz0ouBLUqkbNktJkMw48zP
+ 5K0tppLfg9rv3hNNUyaZLSiymIIEdxEgTkOJDl0mQUuwKKfgSxPKZstl8lNqdf9qaYpt27YjzxntVrun
+ ExCDUa3V2u12ex3QKSsDtQBrAiytra03K5WK7mUnlQwA7XYHCRF279qFdc48YMK0GOmgU9XcAL/f64vj
+ +MJx5cXsM2QvpaOvUUYA72wU+g643Ua2cAnZwiLQboVn8jEG3LolmKr6Dv2WxSijETWNEUYobR8H4Hz7
+ PzPYt9/X90iA73VdPG/GUOx50HWv+35h/Y4i+OW8vr6ORx991DCB38LEPffokKlYwRYgIDvyz9rDXySq
+ QEHBeYggzjWsE5OC/5D/l5jxexHiqk36nJXBQNudkKj0lb4Ca4pYH6WQP6sDkOxcID4CYd5BgXkBqBJh
+ 9+5dSInQ9EvP2UPWCFhfX2s1m811DAF+wDCAPM8XlxYXa5VKucu7iJnRbreRpin279uPlWjNQIIFif90
+ hDXyDYC0ibVeXQg7RDFbQoUCP2joRn57sJJG9LpDo4nOxYvoLC4jb7VcKBfLYLQRaW0v6ZVpqQ4KI3UC
+ wwHEOUipBQc+eATX/eFnIvBL/Q2r+g+rEfRKV3xm269fWPG6132/sH6HBXyv6/X1dTz22GPIsgzvete7
+ sOc3fxMTd92t2lfuEaOOPhZ47LQDmdTDZDzoyDAJQLk0QQQGAX6bMQF9ErJFYDnONVhsc0+GPkbQIjwV
+ +MQSQYSZj8nkwS6ThkiZBodXdmsGJh4IWEtTHDxwAGmaoNVqR/Vs63dlZaVVr9dXEUjdSOnuQxlAs9lc
+ OH/ubHNsrKIFsI3eardRLpdx5eHDWBFJCYBzRtjAOdYaRDI7kEOlq1EV/NcLYzAsQiUCVBNw1S2Z92Au
+ 9QayixeQLy+BO+1YWnN4V3TtgSzFg5cW0sTqvGS9AYvVyYwDR450SX5gc3APowls1QTYLKzXdS9mMCz4
+ i4C3YcX7jY0NZQLvfve7sfs3fxNjd93lZ3bCjLqw0pAFvUp3Aa044BiGLYwjRwCeBbPqAL5Ni+ATJiQu
+ xUUmQLK2BISZCMMyGoiqA4EZ2WfWALBi14YSgPVSCYcPH0a5XPYagMnWpF5ZWszXNzaWsQnw5VDkLi8v
+ X3zl1Vfa4+PjKJVSVSmk8ZvNFoiAq6+5GhuVCpLpKS9FHZPRxToEmF1EE5BTlMYBjAJyy1QtyB0xmDEH
+ 1SS4WkN+4QLy1VUgC55Syqc1r4IGwlC9TwCvzEDyNgwBYM/DnNnARF0dfsMAfKvq/magHxR32OtBYf2O
+ fip/8Wx/GxsbeOKJJ5BlGe666y7s/l9/ExN3342cCDmzrpvnNhUJMoMgnX+BWUPBFCSwSm8YBoQALvHj
+ 4qiM/tsllsgMP81YJiwFCU66qpPmT/ZG7oPAMkXWcqowQrGcjPLOOTSnpnDt614HAGi1rKOfi58kbun+
+ xaVFWlhYEAYgv15iy6WTiye+/vXVM2fOnMzyjCuVChLdi9kdzVbLqzRue+JsbDygiIykDEq0MghZBceV
+ woITQRtgG0YaxjYy20iBNXC9juzSJWTra3540jc+B7AaUoHdjkzIRSmBAVlOLDA4bREts3zvwSNHes7n
+ 1/QjSvt+16OCX6ttk/yL8QeF9Ts2A3+/X5Ik2NjYwDe+8Q3keY67774bO3/91zHx7ndrWwlY7aQgEi0u
+ 0thsCrMvoDAGFnixxpL2pCQJk3QMgl2fAXtNQL5JDRNoXwOgQPd6iEpzMqVSnwahN4gWA9VAElURJE9C
+ Pj2D8fFxbZNGI/b0TRIhzKSzvLKysLS0tIEhwA8g0t05y7JzjXojGxsbQ5oGBsDMaDZbaDSbyMHYtm0b
+ 6qXUFTJ33DHPM/04BygDVt/ZFjL0H2wI0k0RplATgRWbmjT5+mdcqyO7dBH5+qoCPmgT0MQs1CBNQubn
+ JUHvGXyusYrAB3knnz/4g6EW85DvHMQc+sWR61HO9rpcLndpdMU4m4X1O4YBv73uxQSq1SqefPLJwAR+
+ 4zcw/u67VAtzAiQoywb7EJU7UuFdsK5RSKZ8wa4mDzgKHYNkJTArvTjTw7zL55EQwoInkgdCv4KMB4QS
+ QDUGIoSyQEwU+11QBtCYmMC2bdvAzKg3Gmg0m0b19/VNjE6n3Wq320voBv/mGgAAZuYz1Vq9NTExjiRN
+ uoip0Wwiy3Ls2rULK0pwOfJOG6reAEZyi1S15gjB6gk5PMjEaUN64Dko3lH/gOUr9TqyCxeRr605cHKI
+ p+yfWdU4Sa/DfeHr9M4OE0rDhZWLfOkV/Ftz793smQ2DefdW1H9ZuntmZgaVSryv/P9o8NtftVrFt771
+ LQDA3Xffjbnf+HWU3/UuZBEiAJXAZIAlYNJrjgQFe1Qq/xd1XjQDZoifge6lZfT4QBMcRhD8D2SWBpPv
+ MeWzWkuY7ivPSGnT/uL1vBlr5TJ27dyJdidDvd4M9SCfTy5FvV5rNJvNBQCZ/1lG0POI9Pw8z8+srq7W
+ x8fHkKrECM/dyxlXHr4SC7K1tYnkJLmFFut6AYHAPchcQo0b/rL/7wEv1WAxDSCv1ZFdvIR8Y92Xw1c+
+ Q9/hlA/RKljzYCmy4waus9LQTDAdoGlFa2MwDh754JYk/z+lut9LA7Dr9u/cuROHDh3C2NhYVzw5/v9Q
+ +zdjAt/+9rcBAPfccw/mfv3XUXnXu7x26BkwAwZCRmqGvyKprcih6K+UG75dQ++B5q5gDl3BEkvNBKOV
+ iFYAm3fEMDwBAZpHce/uIiOQtMulEq688koQGPV63baC1jczsLq6XK/Xagvotv/7HpEG0Ol0zly4cH59
+ YnICujOJSV+vN1AulXDdddfigoJfogXrSqArgM+NTe2WABJi9Z/uIhnNAQg2uUEt2HUA1mvILl1Etr7q
+ pkZaniOtSvBaQcgiUItR9HxDSTpWBROmoylU9oEPBvCPsp/fsODXeiqcR2EOQAz+hYUFPPOFL+CZP/1T
+ HDx4sEsTKKbd7OgH/uKvX/hm5sB3vvMdEBHuvfdebP/or6H8rneJJelW7AmC38yxlyZKtJ3JvN99pIA7
+ SGWD5djqZKPKE6mKLqYDqSS3ZQmMSYsDWQhEAkjzcEU39VU4y2+hVMIbXv96lEol1OqNQlv4PgAAFy5c
+ aGxUqxcRawAWHV1HxADq9fr88RePb0xNTSJNCWnqNiEU4qjV6yAQbr75ZiyNjSGdndXPL3TthQLCiVJt
+ IN9q4ngTJK9R2VhYiM3R6wT1BjoXRe2HNr5oImykPbSayTAon6coIaqNGJ5D8VdI8Q4c+SCuGyD5pezD
+ SvjNwD8I8KOA/0cPPoj5o0dx6tgx/PQLX8DBgwdVEyim3ewYpOLb61GBL3tPEhHq9Tq++93vgohw3333
+ YftHP4rSu96lQ4Su1QJdiy1teX/C3ZI16q33UtNqBAkbW5xg8hZQBh0DhbyLjCRoESFucateYVAgRH0F
+ 9lm6axfWZmdx6y23AABqtXqUJ0DKAC5eON9eWlo6j271fygGgMefeOLEU0/9YD5NEp6YmCh0BLqXg4By
+ qYTpmRm0xsd1go9RBbykN+7BGi5TFiVPL6FJngsxUvReeFOAGy1kCwtuB16/gQn5FpchOXEogqhgXvMK
+ q/TIQ0IwC9zQIsTg4OIXEQ588Bcj8IfyD2/bj6LuDyPlhwH/0w8+qDv2lIhw7msP48U//3McOHBAp5cO
+ cxRBbsOGuR8G+BJGRKjVavje976HJEnwnve8B9seeACld75DaQZErvc+CdARez504MVgYymTb+PAMLxy
+ L5qDZQCeAgCR8IzYvg8SvchwrD5APcIdQ2DTaViMx2jNzmB6dhYlvyZgtVZ3OURMIEG5nGanTs2vnjhx
+ QhiAZQJ9j0gD2NjYyOv1+su1eiObmBhHKS0h0AejWqujXm8gZ2Dfvn1YIXGl9ZUU9DBEbMGDTIStruGn
+ 6ViH3lyc0AOg4/OtJvLlJWRra57B+NTG88oFG4DY97MwiZC/q0gG6bJfjghkopA4eRw8cgTX/cHgcX5g
+ 66p/r7TFZ73i2jCgN/hPHT0KAqNEbovuMhMuHTuGV/78z7F///6e5kDx2Mzel/NWJX4xTK5rtRq+//3v
+ KxOYeeABpO98p7aR8HPH0kU1N5JUJbDAzoFKpTyHxUgkFoAwGCRi3XucEgp1Yc5KT1HNGTESIduEGyJV
+ k8SUY3V8Avv27UOe56jXG54BhLdLedqtVqPZbJ7L87yDrWoAADjP81dXV1frE5OTXgMIafM8R7VWR57n
+ uOaaa3AhtwwmNIoAXb418BApSyhTcKjkOLJKYQK32shWVpEvL4OyeC60dd6RmhPm4eqVdGgwmBtx3Ysn
+ V8TE/Dcc/MUjXWq/K97ldfTJ9aCwQediWG/wH0MCICVCCrdTTxmMMoDFhx/G/F/8xaZM4LXq7BNQDwK+
+ 1QDkul6v46mnnkKpVML999+PmQceAL3jHciNnUa9ygq77Fh4TujjHCRSn2OchmckZKFhmlbUfdEgbbiq
+ 9YV/kb0QVI5IiyLCpXIZ11x9NbKcsVGrRR+k5eIca2urG7VazUp/2b9voIoXaQAAuNPpvHL+3PnV6alJ
+ VTss0a2vV5EkhFtuvhmnACSlckTAypILhoEthgKUjYolcwHC57mbPEO+voZ8aRF5uxOeixTQd0uulocG
+ DSHUmBTTq5L2vUQan5m8e+9wvf1bsfVHkfjFdrBhlUqlD/gZKRHKIFTAKBGjnBDKCaGSJFh65BGc+ot/
+ i3379vVkAsOA314PC/p+YC9qAJYJPP300yiXy44JfOQjSN5+p+sQ1jn/Qeh0fYdIVwP4ADof5uUPkZgC
+ 8Qq+IZ0fzjOMAvATesQc0F8AaaQA+DDrYkyFgicA0rExnKtUcOsttyBNCBsbta4vK6WOfs+eO1tbX18/
+ A6Djf1vTAGr1+ks/fe6nazMzU0jT1DABF2GjWgUAvOlNb0JjehqY3Rakr0htFskskjgo3bAlUhdcRDE8
+ LgFm5KvryBYWwe2Wa2ydNOQiSaOEwRr/Nk8V8VZkqpfE2gIVysjktuvqAX5XF5dv648K+n5pu8D/Jw78
+ BC/5CSiR26izQgnKTLptVxnAyqOP4My/+3fYu3dvxAReC/APawL0ui4ygUajgR//+Mcol8t473vfi6mP
+ fAR4+9uD9qcqvpGwMO8VFZB8nC7p7t+PeGjOZx3sc6GrQjoBeULd6buYkvohcLemYeLnO3eisWMH3nTj
+ m8AMbGxU/TeZvMnV0an5k61LCwunEWsAIw0DAgB/5Stfefkf/+G7P80ZPD4+piMBks/a+oa7Y8a+vXux
+ Vim7Altvua6OwZCD5dK2L0DDPLo5z5FtVNFZWEDebEAaOBqT15GEwBRYa5GVyejeBGzKwR74YnZIegYO
+ HvnFnpJfync5qv/lgl/rsgf4n3rwT3Dq4aNI1OaH7tNXApAykBKQgtymnV47WH7EMYE9e/agUqlcNvg3
+ MwWGkfq9GEKj0cBPfvITVCoVvO9978PUr/4qcOedhtKcANDiC9hVERd1XR/HEp6KIPRMhG0Eq973yIPD
+ dYLunn8AkSeg7hdgGJf81mZmsG/vXsi0+/WNavgKbSJCWqLWiZMnzr/88suiAWydAQDgRqPx/PraenN6
+ egqVclg3lJlRq9Wxvr6BTpbhuuuuw7k892/wuwr7XMhkGN34HxnJrP8YoXOn0UC2tAiu1zyDiXUZ0exz
+ BPUpSHEZaQiIV+ss4kJkMnStcvDIB4ea2DOsit/rut95mHhy3Q3+BzF/7GHXsUUO8GV24JctukvkOr1S
+ XxspGKlnEquPPYaz//7fY/fu3ZBFYS4H6FuR+r00gF6awE9/+lNUKhW8//3vx8SHP+yZgBGjvnl17N43
+ ul3mW4Au7Z6Q0K2DqozdyzRjq8YHtlKQ3EHnD3shyneZXzhEGzXsRt4J4Gy5jOuuuw5ZnmN9o4p6o+gD
+ 4NJVq7VavVY7jaD+iwkwUP0HuhkAAOSdTuf58xcurE5PT3uX4PCQGVhd20BChNtvvx0nmJGOjXu1331G
+ 7E5rJKy32bpWTQACYBlAq4VseQX5xoZqFbm37ylEdrVl5u2T3EeSntTUcHsShapnMVl8RYraf/r06ZHc
+ e0e5Lp5HMQ/kulvt/xOcOnrM+b6TU+9LRF7Cu+uSqKie+yVelU3YaQIlckzg3Be/iF27dqk50Evi2+ut
+ AH8YlX8QM2g2m3jhhRcwNjaGD3zgAxj/F/8CfOed3q3ckrKnpy4Am/JzWAdQaCvCaHjSLfmNFI76FxAE
+ n5giIbVhGqqsmp4raZeJScyPj+P2228HAVhbr/pyh3emqes8P3fu7Pra+vopOKlfHAUYePTUAJrN5vM/
+ efaZpW3bZpEmKcql1DABxuraOsCMm268EdncHPLZmbjzjeAc/nLbJyCPHYPIOYdbUszoawDQyZCtrSNf
+ XQFnudcQ3Jc70Pq95sxSvrrvnM9GJo9InloLPii4+YbXHvC9/adPn+7y8AMGq/7DagS90hWfaS2PoPbP
+ H/O9/XDSXCW+qP6wJBgOu2JuCqBMwNpjj+H8F7+Iubk5lMvlkQHfD+ibqf/DMAEbp9Vq4cUXX8T4+Hhg
+ AnfcEfqPRKJb6ey/Xnf6jeolSG9TQ/4fx/Wm0QxjIYF3XNdddd7nmdUkwEBr107wnj246cYbwQysra8X
+ cgKInHl+8uSrtYWFhZMA2ohNgC1pAPz//pf/8tP/9t++9SwI+ZSOBoR8VlZWwXDAuvLwYVxKU61wkdg9
+ sg3S2W7fpUVkIGfkGxvIl5fdgh4+UogamIF7TdAkGGKAxGmkUJHfAcQkcOU5eOQX+0r+rar+W7X/B4X1
+ UvtPefAnxIEBeIlfhu2QElJ2LJh995nYowk7plEmwvrjj+P8f/gPmJubgywSe7nA7wfyrTIBIkK73cZL
+ L72EiYkJfOADH0DlV34F+e13hLYlCmD1Vak970IFVqvRWipqC5YBohA3gLYL2EbIaDnELIBhHOGhxluY
+ nMSVhw8rXUvfm8SRo1RKWy++8Pz5559//hUE9X8o+x/owwAA5LVa7dnVlZXGzMwM0pK4BLsI1VodKytr
+ IGbcdtttOBntx+eJl+An2UjtC8swthoBYflwRl6vIVtZRl6vee5tFuhgz0DU+dtwa8PxmQHraBFpJhJs
+ gHXwyBG8/g8+o+AHBkt7e7/Z9aCwfud+YT1t/qNHjc0fq/tlMBJilXayuaXIM5V4ABIWSeb7DihB9fHH
+ cf6LX8T27dsjJgD01gb6DfeN2tvfS+UfxBTa7TZeffVVTE5O4md/9mdR/uVfRnb77dA1ISAkZxgehGyE
+ fqyJ4BzDyIIWpL372lkn1CUMVJlNbO/bjsBenYLUJ/zk2Bhuu+02gBlra+uoF+YAiPvv2trqWrVaPQkH
+ fKsBXBYD4Ha7/ezJk/NLs7PTIJCfT86KneWVVQDAe+67D+cnxpHO7RD57MEqmbGSHuu97/AzxeNWC/nq
+ GvJazSsKwWVY8e0bAx7kAc8eoJDWJcMs7GfBEYVvd+fh9wd9wT+stO93PSr4taSFsEqlgiuuuKIL/AmJ
+ /U4q+csglNiBOvHSwrpzKd8MtO8IXtRccuZASgk2nngCF/7yLzHrXVH7qfH9gD8q4IdR/XvFbbfbOHHi
+ BCYnJ/FzP/dzKH3oQ+jc/jZPY4FpybLjbO59RUNdfIl0Hn8AvSEfuEVCJL1lB1qtRkL3UvmNIhCbCJ6R
+ 8N69ODc3h/fcdx8A1+cmbSURhQGcmp9fW1lZeRVxB+BQ6j8wQANYWl5+5jvf+fbS7OwMJibG1R9A8lxa
+ dgtwjFUqOHj4MFYrFaOGdwlaH+p5bFikz0ntPEderboJPlkWAO5xLJiHATqrIgtYjqzKHYXGDy7AoRwO
+ /P/H0O699nordv8w515hAv49e/YEm//oUQdSL/XLHDrynM3PfuKLSPqgZhraVKkX6pB0bb0S2GkCTzyB
+ i3/5l5iacn4hg6T9Zp1+/RjCqKp/r7idTgenTp3C1NQUfv7nfx6lD30I7be9VdFm256MTZAUgEyCSqFX
+ qzEYtSCAOTYZCAUnIatKROmNFmbKAABLMzM4dPgwxjymVlbXlK5V6aUE5XLKL730Yuf0mTMvwUl/0QCG
+ mgoM9GYAAMCPPvro6Z/85Nkn6/VGe3Z2BqXUDgc6DWBtfQPMjFtvvRWv5rlWVOiJNVY5e3BEdjqDOUde
+ qzlX31bTPSVR3QNLiWbvkS+EAhwIewcaAMKaGKHs5Z1zXeB3z4br6LPP5HpQ2LDnQeC/dOkSnnrwQZw8
+ ekyHqLSjj7zdD6h0InKjAcqFI3kQGCbrnRBY8ElPCSgnhOo3vo5LX/oS3ASxtCfwiwAfVeUfVfXvxwRO
+ nz6tTCD90IeQTU9HzD+o24EVOh5B3tGM3aQfolBTkYlQkPIylwThu2HrxaSJf+6fahjm2atjY7j1llvB
+ zNjYqGJtbd3E8GVloNVsbpw48epzp0+fvojAAGwH4KZHXwYAIG+32z86c/bs8rbts0hSq6y4rcIWl1aQ
+ 54z7778fpycnkezYYZDqGJBdcSWs3x/Ue7TbyNfWkXnVP7bTTcvpkr0CbhfZshRdXUjzLzIJl8XhX/4V
+ rKysbMm9t9/15YJfK74P+J9+8POYP3bUq6XsnXmC1C8xI2UoUZEy21BvqvqL+cRwdUWm4l1TIUmCClwG
+ ofb1r2PhS1+C7BsxitR/raX9Zkzg3LlzmJubw0033YT229+OPPeiw0p3KoBRpDYZKRuiRpoTXBX6eD4H
+ 6h0/1hJsLmqMQFkwAdmePTg9N4f733s/mBkrq+u67bkcov6fPXd2ZW1t7WXE0t/6AGx6DGQA1Wr16e9/
+ 7x8v7d61ExPjYyiX0ijK0vIKAMa2mRkcuuoqrIyNqQkAAToxcnJqv13DHwQgZ2TVGvL1dRBnoVoodN5E
+ ZgB5wc/s70MHIavaxeafaB9h1iKDceiXfgnLy8t9gWzvR7kunkdhDva6C/yffxDzDx9FwoQSe99+cuq/
+ c/V1PyVeErXfEyIHSSZ1DJg16rXyXA0mRNqP6ubIA6WEUHvySSx++cu6xuAwQ32vRUffoDi9rjudDi5d
+ uoQbb7wR+R13oA1CR2gLYX2foiHey54vRPH3FOoKpvPOxo3SBaM1LDkmz02JmLAwM4uDV1+NbTMzqmnH
+ h/vOUinF8Refr507f/44YgYwdAcgMJgB8Ff+63997jvf+fZ3ms1WZ3Z2BuWynR4MLCwsY32jCiLCHXfc
+ gZdV9fadfL7CZY520Ukjb9SRr62Cmw2I7740ETzzEAALR2AvsViklSqwobOxNysW5gOk09PIsmwk8I9i
+ AoxqHtjrbsn/IE4cE99+D3iQV/+Bivftd58b6sLlGepBtC5WUHuyE/AjSH5pJ+dYhNDfQIT6k9/A4pe/
+ PFALuNyOvlHi9LomcsuLjY2NARMTyMDBT1U6PJl79shH0tqSEgU7PZ6/HyS4aE9al8pXu80lfVMUDhwf
+ H8Mdd9zhvqFWcz430r7CfEDIsk71ued++tKLL754AkDL/8QEiAy+QUc/BgD4joR6vf7D02dOr27fvh1p
+ qQSiQFidrIOVVWef/PNf+AUs7NiBZPduKJA9F3COP3COQZ4IOcuR1+rIa41oRV5Zn0+JEgH/HH1SkOjO
+ wy+osZpe3qWMQ/LZXNUf5tmgsF7nzcJ6gX/+4YdR8pI/jPPDe/sFt1Ed31Ymq2INVsWUpal0/QUj8UCi
+ lAZOLWBwK+w65tP4xjew9OUvg5m3JPWHAfiguIOu7b3UbYccMWcgN43Yi98utR5huBTezCoq76TxpObM
+ eoFFkOt74nyokI8MLTb378elgwfxz3/hFwAAyytryLLMvFnal3H27JmVldXVYuff0B6AcgxiAAwg39jY
+ +N4/fPcfzs/t3IHJiXGUy7FT0LnzFwAAeZbhjW94A86mqSLVy3FXSVYaM7uNPNZWwVk7qOge5XbRDt2c
+ 0xRKQB3WD3DXYXKRcA/PBbyqJX0JnfX1iEC2YvcPCut3HtXmP3nsYUckxEiJC+P8FDz8KCZSRbIxyABR
+ gjy74DCPzk3k8gTmObTtGBTJ5zQBN+LQ/OY3sfzXf41OpwNmHrm3/3I0gn5S395XKhXn0dmoI2Ogw1IX
+ 7EkjSHhXx8YkUiltVfVuK95K7l6qf9AwGJGqD8NAvPAjYpyansYb3/AG5B70ov4Txe9M05RfeP6n1bNn
+ zz6PWPqPZP8DQzCArz700PPf/va3vt5sNtvbtm9DueQmiggNLywu49LCEtqdDPfcfTeOg1DyPa+Q0ig9
+ enaQZcjqVeSNRnAXVqkUCM8O9clZJ277zgGLdzE7oGkQVb9EnP+7v8X27dsvy+7fSqdfMUyuy+Vyd2//
+ w8finn443343q491Qo9bm95/rar1wiBJN8bUGhRd1deNEqFlmgIOUSA4MHH1OyBC60nHBNrtdpc2cLnh
+ VzNCAAAgAElEQVS2/SAm0Ova3qdpipmZGTzzzDNo//fvOp2YKEJG2JAzMFBorfQyCTxFWiaBHva/Vf1h
+ 8u+lGRjtANMzeG5yEvfcfTc6WYallVUsr6yFMhEgC/W2282NZ3/y7HPHjx8/gQB+Uf9fMwYAn1lWr9e/
+ d+LVE4s753YgTVNdKUjo+uKlBWRZhrfcdhsmrroS1ZkZgEMpBJiulz9HXqu6df06fhtwb5cp4QJKyEK+
+ 0jBypdOBAYSeQq8JkKRjUwZWf4D5//v/QfnSpWhNvMvRAoY59wuTlXwi8B87hsSDPAVQge/08+ArIRCn
+ w7kjRlapLotTiMQP4A4dWL6GSNKz5uc0AIR2UGJ30k5s35SA9je/iZW//mvU6/WeTOC1sv8HSX0LrjRN
+ MTk5iWq1iv/+93+Ppl9mPKIhkqXfwrcFsAZTSZif8EcLWBvfahJdAC/mD8s0AhNY3LkT49dei7fcdhvy
+ LMfS0opvJqtzuPv5kyeXlpeWXoQDvWgA1gQY+tiMATCAfGFh4R8eefSRc5OTkzw7O41yuWIeA5cWlsC5
+ e++dd9yBVyJjXdDv77IMebWKrNWMAOzsdukDMNzDj7foWn0Fce/W8WOEXX7DY2UKBROitbiEU//5P+PQ
+ oUPKBIa19eV61PMo4E/hPNFE8ruOOEKZGSUOq9tIb7JoOgSpRxK+GipewM9e+nmNy0o2rSGiwFN9/Qkh
+ pwydeFSCY0rtb30Lq//xP2JjYwN5/v+19+ZRchz3meAXmVlnV1VXV99o4j4IHgB4gAAJitRlUZY8JuVH
+ eUzJs+/JHsuyrZGe7Oe3trVP1h+e3Zm365m15bezs7u2NLZESiIlgjdIWCIJHgABUiRBHCS60UCj76u6
+ q6qr68oj9o/MiPhFVgEE76uDLHRVHpERkfF9vyN+EeG9ZWn/ZqQ+YwyWZSGZTKJSqeDhhx9G/bnngOWy
+ 1HCMoB2A5vBb2kHEpiFKSoMEC/nquhq7ZyQ8WIE97CBsSQKcS1NsKJHADddfL/uIrv4HZTYYLMtyjx07
+ Wh05d+4E3qL6L9rhQokD8B5/4onxkyeOP1AoFiudnTlELD0oaKm8jNm5PADgS3fcgdmuLqCnJ8iASbVd
+ RvwtL4O5nlThJRGAaeUPhJHGIZJLSGvKBUGEs49EGsqwYig7lzNg7N57ceI//SesXr26pSZAv79V8Ku2
+ eh3wP/po4GzjiDABMDG7j/vhqYbyRlM5DeHroOAXqq04DkBsbimnVstGCmhEdPRg1RppCwRf/fUTWTDP
+ IJiHwADnmWewdOedKBaLFySBN6v6n08DEMcsy0IikUClUsH+/fux8NOfwD5yRBKpGYhruvMPBaxIQoKH
+ AQ3NZwKlKoSSnh+5p8VFovzL/f2YWLMGX7rjDgBAfrGA5Urruf+l0mJhaGjw+YmJiRkAdeje/7edAABl
+ Bhx66aWXp7u7OxGPx2AFvgBhCszMzfsXuy527NiBMeIMhCiVY4OXy+CNBkSMgD9k6LeIL/mptBddWxEE
+ 50qiq4Ci5jqrlWOVuiuBErzA8fv24vh//s9YvXo1YrHYG5L4b9b7DzSD/8W//3uMPLov2JOeyeg++YGY
+ 0ivMLuZ7q6V0IN1Ms2e5VE+FV8QL7tf6rtR9g6YJ+Qikqstlq0N0czEsGQGH/cwzKN91FxYWFuC67ltW
+ /S/0nd5rmqYG/sW7fwr78PP+4idMjWDoQ35BBB9R16l2AHle71eagzDchGhxLbmHqvzU5zCcSmHHjh3S
+ +bewqKv/4jvnHK++enJxZmbmJJT0DxPAG0rm61/il+G1116bSrUlr/jkpz69zXEco1KpotGwZUdarlSR
+ bc8gHo9h7dq1uPeJJ7DBNOAGM/vAOdxyGW6xBG6rqb4gnZUHteVcxPlJqlQAIoaXdGrJ38QYk8TA5HPk
+ DLFg9IAzhsJrr6I6P49Nn/scyuWyjA94Mx7/1zsGtAa/r/YLBxtHlClbPwI1n59KLvJq1C9mwJ/YI9pN
+ Npi8xggkOJe/g1sJIzRLRUN7pujY4uksuAYA3NFROIUC7I0bkUgkZNDQmyGB15P6wubXwP/Tn8I58rwf
+ wcggfSdR+MFMYqEUpbbTepK6B/+IsGD5XEF/TL0TeS+R6nLNgeB9GVIQ6c9rdHbi6TVr8PU//VMkE0ks
+ Foo4NzYhz2ttzlC59957Xjrw1FMPAVgGUAZQAVCDTwJvmAAuRgPgQcbu0tLSU2fPnp3v7u6CZZlkvUBf
+ KE/PzoF7Hvr7+rBp2zbMRGMSiNxxwMsV8GBvcymhidNOIpcJNT+kcoEJnV76CaiSFSj48j8itiCHDcWV
+ DDA4h8EZxu6/H8f+j/+9pTkg/r7j4Ic/iy9CpFYk6KwMfodSUlpJdsV/vlYgl1oT8enwjQXZxsw/52el
+ pJ8CsmpmagPL9iXmgAhLBgtChplvsrgHn0X5rrswMzODRqPRpPJfDOBfT+q3BP/dP4Vz5Ig/h4HRdRGY
+ D34xQ1L2tuBfFjg3eQvzQFU38CFwuSswle56jtDaTDpmZT5BOTjDufZ2bNqxA/19feDcQ36xQO6GLB8A
+ nD17Jp/P54XtL9T/Bt6k+g+8AQ0AAOvo6Chxj398z417BqqVCqvX6rBtRzZStVpHd1cnLMtCT3c3Hjxw
+ ABstE2615jv+igXwhk1lCalrAF+JWSY7ImNK1de4gtwnOjaIA0f5AcgNQYfmXM+i+NopVPN5bP7c57C8
+ vCzHt4E3b+e/LvgfJQ4/xoNJPYYEkkW0fOGBV20TkBiR5nSJBBDgyo4p1VzhGxArA/gZy9XTxP1SNeYB
+ B4cAJN4PhwIR/CXkvPEx2MUC6mvXIZVKycVG344x/lbgL/z0bjjPPy+HSqOMBZ+gTQFYhuGHTJNaax9G
+ G5CaDIokIOuqmwIqIEslRvOQbcnk63M6sniirw9f+ZM/QUcuh2q1hnNjE/A8JciF+h+JmPbjv9w/fvDg
+ wb3lcnkBvvRfhi/9BQm8YwQAABgdG6v29vSkrtu1a3e2vT2+uFiAbTvB8A/gui7i8Rja29Po6+vD0VOn
+ YM/PI5ZfgFcowqtUpP1OqijbXAsVpt/FgaAxWpEAnWEs1VnpCEPgHtTzFZwsps4WCAlQcwB4Y+Cnx4Dz
+ gV84/ALwQ8znN2SYLxCo/6TCQqKr9tDVc1H/JpVddDwgmPIbZByW8GBylVowZURJAEi+VWARIxLiuBFs
+ 4OmNjcMuFFBds+aiSeBivP0C/NVqVYLfPnI4AD8LCNQHf5QZvjYgwM9ajN23AjOVK7KNznMdo/mxEHmq
+ Ng5/zvT1wdizB1+8/XY4joOZ2flg6i95G8Hz5uZm5vbvf+zxY8eOvQBd/a/jTar/wMWZAID0nsEpFotP
+ /eIXvxhvb8/w9vYMYrGIduH45Awc24ZtO7jt1ltx0jQRac+A16r+XP+gbqRtmpEfVJoHKgCnprw8LoRh
+ 0FBcOXQ4lKMQCADJoCYPQXizFbgM+OvnTzxwP4797d9izZo1cmHMt6L+n1fyc3/RDgs8CO81fFWV8SAc
+ NRh6MvzuKvQ72cmkM5O0JyjYuayblOi0BSUQ/CFU0YEF6GUrCacjIVumsgnUWT/JSS4ALGYgygEcPIjK
+ j3+MkZER1Gq1CwL+9cb4BfiTySSq1Soee+wxFO6+G/bzR4jZ5Ev/GAv2QYD/W62LyGQbUk1ArQAMOQxI
+ NQJKv7qUD/93vtV/yH8MsLNZ/Kq9Hbfdeitsx4VjO4H6H+RLpFU0anpHX36xNDY2dhS+tBdSXwz/iW79
+ htMb0gAAGKeHhxez7ZncjTd+7Lp4PBEplUqwGw0I/Nm2jWg0hkw6hYGBAbwyNIT69AwiZ4YBz9OkNk1C
+ Gqul+0iUHwsAK0FP7mFQdWeCGMJ5IyAG7YBkboIjAEDptVOo5Bew+XO//rqawIWOiWW8enp6MDs7i5e+
+ 9z2MPLovmLevpvJGDEN6+uWsPjBpj3Kmk5WsqwC1aAamOhtVd4SqrrV8+F4EE4GgpB+CvFgwgcB3iCkC
+ Ul5tlachyi5JhYGPj8MpFlFatQrt7e2IxWKvqwGcb6hPjPNL8B85oiZGMSY/vjblq/2tnKg6KAmBgrQr
+ vU81Oam3f1V43X9FNMo/QAUeA8NwXx/Mm27Cb9/+RdiOjdm5hcD7rxrfCJimVCouPPjg/Qeef/75p+FL
+ fqr+iwCgN5XeKAEAgLF27Vo3nc587Oqrd3SVy8uoNxpwHL8MjAH1eh39vd0wTAO9PT144JmnsREMTj6v
+ EYAcwgt6onD8aePbopeG/IFqMguXDivN8y8AT/RW+pIUkAIpKI4GJFM6NYjqQh6bf/2NkYD43gr8QvKL
+ jTkscBnbLzqxWkeOyfpTu5tzpq1VL2siCY7Wq5kAxHLgankFai6EpGEAfj9KUycMQ3s+sZFB1EqmvOHe
+ +AScQgHF/n5ks9mWJHAhpx+1+cPg9yW/IcEfMwzfFDCYNKFknD/0thPlVFSg+okG6pDGoH1Y6HqmhEur
+ 8/VsFr/s78fvff3ryOVysBs2Rsen4Dj6vpeMMViWxY8cPjTx3HOH9s3NzU1AEUAVSgt4U+o/8MYJgAHA
+ 0NDQXCIR77754x/fGY1FrVJxydcCgso2bBuxWAyZTAp9fX0YGhvDwuwM4mOjkAE5EqzEecWUpCdIVYQg
+ WlOQhbTrdfEmHFaSFOQf3nSdfC3yESyQuhzFU6dQy+ex8bOfPS8JtPoeBv+Lf/89nNv3CEwwEkEHOaEn
+ GtinWvQYqSsAzcYmxVXDWUyWXnU4rnd8KQFFXamkY4aWJxgFP+nY8jX4BEUDjpg86R+jDjADHHzCJ4FC
+ Xx+y2Szi8fjrSv2ww0+A36GS32Ah6e+vZGQGWikdglP1VW3RPCUYWj0p0VKqVODWzZQmggh9Xu3rQ/pT
+ n8Jtv3mrb/vP5bFA5v3L5zGG5eVyYe+99zxz6NChx9Es/Rt4k95/kd6MBsAAsHXr1nkd2Y4bt115ZWe5
+ vIyGbQcM5jdqtVZDb08XIpaFjZs2Ye/Bg1hrWXBmZ4NMlF0u1H0GEC8+V8dEDUXP5QIb/gUi8o/ygCIB
+ Ll3V+miAyk9Kf6ZMEJFVcXAItYWFliQAXAT4v/c93+HHRPisUPXVKr5yqI82Mq0MaXgFwqDsTLUdC36L
+ +BaxAhNYiEBAyUbMGyDyjSKAfDXos/1btTX2Rbml+RIUVzhZTUCSwEJPD3K5HOLx+EUP9SnwPy9nJkYN
+ f5gvZohFUnzJbwTlNUHIT5ReMwMgz+uNrROnar2AEBi0fEDyav6o/8pd3Tiwfj2++ed/jmQyiVqtjrHx
+ KTiursUHWg9/4YXDE889d+iRmdnZcSgCEGP/Ivz3Tac3QwAAwAYHB2disWj3TTfdfE08Ho8UCyXYjiN9
+ b47jwDJNdOY6kM5kMJPP4+zZEWRGR4McZFYAIKP2RCcW52S8evCPAJzkZK3zQ9/HjauYd9Drmb8+AQRB
+ 0LIwSAeikBCFwVOo5XUSAC5O8o88uk+u2iP+RoMO6m/XJYbWOJHQvtNPl0jK/g6wJ6WPGJoiuFRgghoB
+ 0bbGkl90A0BrKuJaMQLyFKaJAqzKTPcHSH4OiIABhuGDaXwcbqGAua4udHZ2ntccCIO/SG1+5u9w7Kv8
+ anp0hBnBLkhMl+ykvGFQ0jbRNaaQWaDdD+04yLPCezEIZZQx4Ff9fVj/+c/j4zffDM91MTUzT+L+mWxv
+ gKFcLhV+/rO7n3n24MFfQnn+3/LQH01vlgAAgK1ZvdpJp9N7duzY1rW8XEWjUYdNtIDlSgWduRzaEnFc
+ t2sX9h46hB7LAp+cgAQ+p1I3aEIhtf2DmlQWDSutBCFmgp4vYtXlvVw1qPghKUQLDGJyn0HZKZhSH0uD
+ Q6guLmLjLbfIOAHZEIwhnU4jm80ikUhgaWnJl/z79gX77zG1gi8L1H7G5HEBbApcWQWhgoqORwhRdTIe
+ qOuq/lSj8K/3r6b2uXJkiTbjEOvN+XXXweMnQo6qEJJsVBmUlqG0DkV2mJyEUyhgtrMTXV1dmjnAGEMk
+ EkE0GkWpVMIvfvELFO++G87zSu2PGAZiDIgxA1EYcsakyVS8v6g2JSblmdeBr6nvjPQZck5fvJNqEUzP
+ g74z1USY7e/HS9u24bvf/S7geSgtlTE2PgWP03F/P0fLMvmRw4cmDj136JHZ1tL/Ldn+Ir0lAhgaGpqN
+ RiLZGz920850qi1SKJSCABpffnmeB845+vt6wD0Pjuvi0PHjWF2twF5e1ofyuOo8QfZQawAER4j3XnRg
+ Lu+hoggK+YzcpxdffvPCnVsAggMeExFgDEuDg6gtLKBn0yZEOzpQr9dlHf3RjygikQhe+od/wMi+fTAZ
+ J2PTal6/v5afcpAZMnwXsm7U6abJE6YAq4iMSWVGtA8R9rIza3KKSjJGzpFOy0DeD2mxVhKPahIAk4Ex
+ YvtqIIhUhK/eGgDYxATsxUVMd3SAc67tPyC2/np2715U9u+HfeSINJ2ihoEo4Ev+YKgvYqj9DzVJrNVd
+ 6yVKogvykkQrIK1mQWr3QZGIERAnyHUiUSJy43E82duLT9xxB7Zs2gQAGJ2YCnb8JS0XtG2pVFz42c9+
+ euDQc889CV36C+ffW5b+wFsjAABgAwMDVdMwbrz22mu6G41GEB1oQ1RqaamMVKoNiXgMl11+OQ6fOgV3
+ uQJrdCzIQfxDm05f6EN8lUAlklvNGiBUK0YGpHHMgqMkMwblkGSKQsCE7ayYHRCgMFAaGsL0s88iFo1i
+ 9dVXo7u/H7lcDqlIBGOPPILD/9v/ivzxY2orbmYEQ1TCBGAwDSURGVPrKlBwy4pz1dFY0C4S7FTacEEm
+ jJS3GeCy+kzVSw7GBKTEQRxnoY5Nh7+YyFFT/ZkkNKEJiCcLX4Nvn/tPYFMTcA8ewtzcHM5WKhg6exZD
+ Q0MYOn4ck/fdh+qDD4KfPasF+MQYEDfEUJ8f5kv3PzRIWVrXmbWsl2ohWldST/IMcV4QpCIH1lQGxhiG
+ Vq1Ccc8e/NEffg2O42BhoYDxySntWYCY8htxn37qiYlnDx58MJ/PT8IH/xLeZukPqICzN5p4UABn//79
+ r7RnMj/6xCc/+Zf9/T3thUIJjUZDmgIAcG50Ap25DhiOgy9/6Uv428FB7L7yClSPH1c5SnEjOiSX49/g
+ XKut3PE3AL6/YSjxDVAi4D5NSM1Cmhx0jqE4Jb+p0ALQF+0vve0uLuLMD76PoR98Hw5nwXpzinTEMJ90
+ +hlMLtttUk5SyAfnQlowWWZAdQxPeUikf4DGAHLp+QtXgXZpLs0pQ85541oob3jSlQYc9TQFB8q7EJSs
+ TDQRci3UagaAcdGeAbktL4Pt3w/7X/f7y3cB8Lj/fvyYiWCPgkCbijJ/BEWQAgW+aE/RncT7o0KCkpVo
+ KL0O5LvUTvX3IZIh6sHV80QZRF6lXA6He3rwzTu+BM9zwT2O2fkFv0WJADCCeIvp6cm5gweffWpwcHAI
+ PuCrUHb/m5r3f770VjUAAGCduVzB8/ienTuv7fdcj1VrdTSCST8AQ7VaRTQaQSqVQm9PD+ZKJQyfO4fc
+ 7Aw8p9mhJjUATYKLXqji0n2wcNnR9VcnswqkOrQ8NMYh+Ssno+qxnKtr5AunEiGQnEYwxi9X7mVBXDp8
+ lVhu0a3Zk0IN5RCR+aSkmhSikftSfeWiPH7pwvKZdnhlj1LL3E+GYWh3GozmwmRZxE1iboIu+dR1SnKq
+ 3+If0Yaaw02YBYwFk4wCHwljiBhGENorYvvV6kjhqb50VEIL4NFbRYFf1AuhdmJBuTlaxF34/4WdjNIU
+ Y8QfYpo43NeHjbfeils+82twHBez83m5foZ8IwxgzIBhsMYv/vXRsWeefWZvqVSawztk+4v0thDA6Oho
+ OZNO25duvfy6DRvWpcrlZTTqjcBb7lewUqmiq7MD8VgMO3fuxKMvvYSkx8HGx5uwy6UkIyE6pLf5p5ni
+ wBbYl3sJyIgXch0dKRAH5HHx9kP+ANrZGfOXlWZMqrJi2MmS4Kdz+UVAinIaic4i6wTDn2rKVKek48FC
+ 9fdBY2jFV90RIGMpBHzErBDdNyAd3/sePIer50qTSnJw0AY0lEICO7DvBQjI6xC7GIknS/BDSUwZ/CT+
+ EvCL9Qelrc/I8mgB5ZmyfPo0X1luULWcklToWkADtdjwU9WXDqdS0IcIhNT/XH8/Bq+9Fn/1V38FzjmW
+ K1WMT06T1X4V+AFgeHhw8qGHHnj4+IkTR+Hb/Et4B2x/kd4OAgAA1Ov1Ce65W66//vpLIxHLLJcrcrFI
+ wN+xxfM89PZ0AQByXV3Y96tfYV0kAntuDoCOTSAUCsxDbwKAVOODG6mvzx8PJzkysoKOzIpp9yj5qC8j
+ IsrQHANOlspiQvozmOAyCk2osCoMFQSMQV5Ed5SaB5H3UpUN7qWqppRJJE/ZHYmmAUaAHzyHMx9s2ugD
+ yUMAQnZyToBE8qZrCrTUBChRCSKlqrvQoMh3k+khvdFAE1CjJ5BPCtvzmv0NCmoloRktN8gsR9EOobag
+ uwprUYWhD8jfcjaLR/v68Lt//MfBdF+O8clpLC2FHX8GDIPBthvlvffec/TJAwcetG27hGbb/y2P+4fT
+ 20YAhULB6czlKu3t2V1XXHF5rtGwUauJYUEAYFgql5FIJBCLRbHmkgEgkcArr72Gzvk5uA1bXkdBDUAD
+ oWg4TvdygpKQ6sJgyE92XqgMmRpapHD3f8qMgp9k1TimJIgBAIa/AIeYEGMywOS+ViBUUwpcsSa/EXI+
+ UEkiS8PkSXmpUGVFGZRlEiYAFpSVnCemQriufvtwEidAnhImhaZnqTqI8ku4kedp12ltIilMbkUmpL/Q
+ AMyACPyNSoTkVxK6CYhEE5G1IYVpiohsUS9xXBsKhQ582YTiWkIe3LLwXF8f1nzhC/jN3/gN1Bs28osF
+ TE3Pas0PAKZpwjBMfuTwofHHH//lg2NjY2egVH8a9vu2Sn/g7SMABoANDQ1NGgyJXbt3X9PV1RUrl8to
+ 2E4wv9mvbbVaRU93J2KxKC6//HIMl8soz+dhjI8pzAdAVhpAgFimVgHy8aygwCGceKGpQAwQc4WFZ1++
+ MvomyXOFRxyGEVwTjDUw5qvNtNIIq40+ESipT6UHk51TcZSQTWQNf6bK6edBbFXSkVWn1F6D1ikJd+nA
+ FRIXrc8bgjhEuUEJlpCLKIcEf1B+onoz7Rr/APWDSPvdz8wHvuFLZcMwJAkIyQ8giJ4UoxUq37Dn3mCq
+ XvS49ltrlxbAD99PXkNYYxCf0/39GLn+evzlX/wFPI+jVq/7M2UdV3tfpukPk+bnZ+d+/OM7nzh46NCT
+ UJJfSH/q/Htb08VOB75QkiMCABqTk5MPPXD/A68xxrzu7i7E4zEILyzgLyB6ZmQMnHO4joPPf+5zGOrv
+ Q3z7Dgg13d/Hj4Mu980Db6laBxCAWFNQyCufBYLlnpXQp6sO8aAkHIFzT3iACREwBCfJxZwRkDIAYhgL
+ osOIoB4leWiIruwgMl8CVulvCP4NHPqSp0S9EdAY97UOEelIy02EuGZOqV7LlDaCgC5DWo9/L2VGXWUR
+ IGJ0BRLRVkFjsqC1/Z/BfYJUiDkn8wrOCZ+B71BVodPUjKIRjXIwV5AhKDghj8lxewgtS/ksVFmY2vST
+ EKAkU/kelTYAcl5cs5DL4dlLLsHv/d7vwXNdcHDMzuVRqzUv9GkYJgDUn3rqyZlTg4PPwZf24vOOeP5p
+ ettMAJHGxsaWkslEeeCS1ddeeunmdrtuo14PmQJLZcRiMbQlk8h2ZJHp6sKBo0cx0LBhl4rypfjjyLod
+ IJUBrnUxSCQzRvwBQU+Q67ppkJCJRAFAOsWYGi6UUpA8N/hf5kUs3xDoSd7aN0iQUsUZJBdhn+s2ulLN
+ NZYQINLKJH6I8ipTwMd9AA6m36NsdVJuFvZFQOVJykfrL9pT+x2UR4uvl88PVu/lQf2JlsJa3EufIVL4
+ Wvp+/ENcEWGoXKru/rewdGz1PNqPDAC1RAK/6OvD9V/+Mj52442wHQfz84uYmp3XcmIMME1/q71jx45O
+ PPDA/fe/+uqrx6CkP13wQ8z5f9vT20kAsn1ODQ6O2HYjveeGG6/q6MhGy8v+ZCFhCjDmawK5jnZYloWN
+ Gzfi5MQE8ot5xMfGpHEr5/wxIdX1kW21KKj/4bqgIsOFQT46LKT0Y4yrzTIDyIVfssiGMUBO1GahzmAY
+ gn8gYc0A4eEVZQKEahqUGwTY8K+ny6ICuootVHGia+iEwxT3+eVicrcayDZRrSi0Atl0BBx0LF0N34nq
+ +9dxSgS0zWSZyFuj2oDWvky1cagMmqlB8m51TOSlgz9EVFDORvGfst9DeZHzYeefthhK8MyX+/qAW27B
+ V//gD2DbNiqVGiamp+G6qu8DPvgNg6FQWFz4Hz/4pwNPPf30Y1ARfyLqj672874nAG0gvzOXWwTY7h1X
+ 7eg1TYNVK7UgNkCNCtQbDfR2+zMGb7rpJjz08lG0mSYwMaHlJsfwOVmwQoJcsDlTL56T25kITSH3hTof
+ GOno4gKiyot8BCJU4G4AUiZzCnVQ1RHDcfEyl6BgGuAYnVCiOq3QFuT6gKHqGIGzgfHme0VROGOk9Iro
+ ZD6MaTURqwiLI0Y4XyjbXQMacN68RcAT1WbCvogwoJvtcKaVQYA6rA3Q6Aa9zch7oORHUqv71DlBZKoc
+ w729OLprF/7j3/yNH/ruuJiYmkWlUtUIzzSNYEFdXt//2L6xp59+am+hUJhBa8ffO2L7y7K8Q/my0dHR
+ YiwaKQ4MrL528+bN7Z7nolZvBGHCAMBQqVQBcPR0d4Fzjq1bt+L4wgISlQqc6SkJTNn7IfDtv0JpOVPN
+ gAwHNnn3yfhZE50KtVD+VXsWylEE0hMUIAWwDDntNeCqFuovBaN/nQEEtrQoApP5gz6f5CF5RfGLRlD0
+ aVITYAF50M4cLp8EgnqGoQqvaRUg5ZT3URJo0qACIpTlJsCSGokuYVtL8plOGucAACAASURBVGZiCddF
+ IyqEnhW+JwR+TQNgZE4DeX+tzs3mcvjXDRvwtW99C525HABgcnoG+QV9lV/GDEQi/nyHl19+aXzv3p/f
+ e+LkyWNQY/5h1f8dAz/wzhEAAGBwaOhcvV6N7dq9+6qe7u5YvV5HnQQIMeZvgRyLxZCIx9GR7UA01YbX
+ 8nl0VKuozeelLa86XgBsTd33z3JNaxBvhzCHvCG4HuTVsIBQZOxqC0kBBm4YBFCEZAQTSJDo4KJSTge4
+ uI5IIlI9I1gTkEOp4KLt1GMZKateanodnScgCEGCUZAFg/oujBNxTLGU0lK0c1wfmgsRxPmiC8VvCigw
+ Mh8Buldeq3fwIJ3Imp8NNGtVTdOFZZ7K/yDqQeMEaLQhA7CcTuPh3l7c8tWv4vpdu3y7f6GAyelZTfIz
+ 5i8QyxjD7Oz0/A++/4+/fObZZ38BHfwi6Eds9vGOqP4ivZMEwACwRCIx67relVdt33FJIpkwK8tV2GF/
+ wNIyOrIZGIaBtWvWogxgvFRCcnYWdrmsvVEBODGoJ1uYOOe05cKo5hD0LBpXQBUDwyD5gQYOqcVJ5Hiy
+ Gq+U3mnhtKRebhhBlrIcxFShkkGeIz4BKbmY3nGD/DitP/zfYixdA7MoN0ReDLpTT4GfNA0BFiGOUHkB
+ IkW155FrW2ga9LsiIf0a8RwazKSBOKi/or1mkMs8FNIV+JlqY6p9qEAiSm6EVMinEYvhyb4+rP+3/xZf
+ vP121Bs2qtUapqbn4LgeaTd/fQPLMtFoNKr337/31NNPPXXfUrmch3L80Yi/d8zxR9M7qgEAwNTU1HLE
+ suZS6czOrVu35gyDsWqthnpdzRVwHAeVSg09XTkYpoEtl16K0UoFS9UqMDwM7nmyJcjEWchXrYfSqe+t
+ /AgIawR+MpqOKRKRINQxq/3wHX3EaddymIkQAC0+g/6MoI5SXSbl1tVZspISCAC0Z4q86FXqj7THL0AA
+ ogSMlpc+R2oEOkPQa8JrE2jmEH0GbafQ73Akprq3lcqvwK/yY02aBG2jUAsFVSPajix/8Ncw8EJ/Pxqf
+ /Sy+/id/AtdxYTsOJqdnUQ0N+RmGgWg0AgDuU089OfbQgw/cc3p4eAi61/9dcfzR9I4TAACcOXNm2vPc
+ 2qZNm69at25tinscdekP8Bu4WquhYdvo7e6EaRjYvmMHThYK4K6LxukhOf0VALHHVeAJQJ2F/kXiMv9K
+ vZNLShf3MxVfEA6QkX8NFjjNlShgAHgQMKSUECVZjGCsnHZKDwikmSIjnzJUR2dyyEEWMDinHKGtbGHG
+ WLBPg4p8p6AzSLmFSSHMEOrgk5I1RE4aUOg1IQCL801qdihfOf8AKmAqLImb7XQFSn2RDnpekUxLnwEt
+ P/lQzcBgOjFoeTCGE319OHPzzfjr73wHnuvB9VxMzcyhWCqL1yrfWywWAwC89urJyTvv+tFDL7zwwnNQ
+ Xn8q/d8V1V+kd4MAGACcGhwcKpeXErt33bC9t687ZjfsYDVhtYLQUnkZnsfR3ZUDOMfWyy/H0cVFxDhH
+ /cwZaK+CvjVtIb/QNeQHY8ps4FQBpveFOjlNnPqUtUcGEl+dJdqCul4bRw/JHMYEvxDJxEL5gXiENFAI
+ tV5UgEhYnCdIRjadABsBAwUGbU4CYEF0RvieADjixvPNyJNlFNcx9QxxH+h52naMNQGfPlsjrFBdlNqv
+ k4JertAx6ORgMIbTPT14fudOfPs734FlWgA4pqbnkF9Y1PoTY0AsFoNhMMzPz+b/+//9fz3x5IED+6DA
+ L2L+BfjfFdVfpHdFAwgSi8di047nXr5t27aBdDpl1qo1NBo2XI86BYswDBO5jnZELAtr16/H0YUFtIGj
+ du4cJEL9LAlg/Ncm5wgE+XEajgdh9/rXiJnrcvgouE4MtwkxpZYZU8q4LILByOxipncikh/IcQp/lU/Q
+ xblfKiOIKRBAawYCIRkCvuAxLTq1LsH9eijw0bKEnVxCI9DsZkJKTNwjtDIi1WU+ggCYKj99lRK0IPe2
+ AKksB9BcRnK8qQ4gbSmuIec07ST0MULnz3V14cnLL8c3/ue/QHdnDpxzzMzlMT0rpviqFI1GYFkWqtXl
+ yt57f/7akwcO3FfW7f5WXv8PJwFMT08vM4bxaCS2c+vWrblEIsGqAQlwEta6WCgiHo+hLZlAqi2F3oEB
+ vDQ/j3bGUB8fFdmpfQWCpJxidJYfUyAkcQSqe4gRAwpN8QgSoRdsdyUCj+WVzJA90Z/Oq/IIcY/feYPz
+ onxKahGmYBQcjByjEljdo55BgSPIQJEOlbJUk9F9n6r+Akiy+OQe0VZNgA0auGmuPCU9RstFn8HUb01y
+ qzZoBigFrtIqqLZF66IRY6tn0etF3ch9U7kcHtu4Eb//Z3+GTZs2wXNd5BeLmJ6dBxUNjAGW5a9r6LqO
+ vf+xR8cfeOC+n5wdGRmG8voL1f9dtftpejcIgJO/bGRkZM51nbnu7p6rNm3a0B6NRAKnYB2AkNocheIS
+ Uqk2xKJRdOY6kOvvx9G5ObQzoDY+oXqSABMAIie0ryJKgIfPEWmkFsJRHV6E4Qpe0VRY+ouhxZRe9XAB
+ TqWaqwhHWt4wkMVtNF8NPMFJOSshALMwiWgsAki+TeYAJRVVInKO6c8n9de0Dt78DIg8SJO0cvApgmAQ
+ W5zT9mgJUpmvTlotJXkLrUYsfxYGfqv3AAAzHR14ZN063PGtb+Hqq66C4zhYKlcwPTsvl/UWmoxpmojH
+ Y+Cce4efOzj2k5/cdc8rx469jGbw1+ATgNjh911N76YGINPp4eHRWrVS3bhxy/Y1q1enLMtErS5WEfJf
+ quu6KBaXkMmkYFkW+np60N7Xh6Nz8+gAUJ+cDAJ1aFfh2h56Cr0ghNAkP+RQnXzdqgdIMOudP3gaeTYj
+ +csOTcYb6XnVval9rtaXE38MWQZDTmLxz4m7Ra39f/V1A4nHQlQrAIwK7mEgNZDXtRwfD24xNHCJtiHS
+ UlxH7lImlmgbGhBECEnmSWz8oAJNaj8tFxPtpfIX9dCuZXo99FetE5b2G8BcRxYPr1mL27/5TezevRu2
+ baNarWNqZg4NsgYm4Hv8k8k4OAdOnjwx+YPv/+NDzx0+/Ax0u184/d7RWP/XS+8JAQDA4ODgUKlYMLfv
+ 2LFtYNWqOGNAvd5Ao2FLsNi2jaXyMrKZNAzDwKr+PrT39eGVhQV0MAO1iYkgNyWj1JZXAJhYX1/2NK3D
+ 0R7V/FtIW+kRUL4BgOSnACt0fgFnAeiWG2uKoJnguVLShvlKFDpQJYwWHRyA3JFXlV1UVlfThdagO/Mg
+ QUfBaGh1ZBqQxPFmVT9UV1F/bZVj/69YvYejBVihl4u0hiIRkp9OIrLquuQXZW56hj/78Hx+gOmODjy8
+ Zi2+8I1vYM+ePbAbNmr1Oqbn5lELhrMFUTHG0NaWBMAwNnpu7r/9t3947MBTT+2HLvlb7ez7kSEAWdFK
+ tXp2ebnceeWVV27u6+uNeq6DWq0G21Zzput1nwQ62jNghoGBVf3oWLUKxxcX0W5ZqI2Og0PtDyhfnwRk
+ MJymee6gjZ+Lb0Llp2QiQK+p9VCdSQTk+JLXH34TZKFJsuBfChHhezAQBCA2kYBYrotO9lH5hYEYEpGE
+ FpkCRKCV0OFAShJG6JgktCDfMOiEVKeEAgiHIeR9FIyUMMK/5TNanQ+OKwAz2WZ6nso0oO3Vcr1AWSdd
+ 0xH3TOZyeGTdOtz+zW9K8NcbDUzP5lGr1Ylm59exrS0Jxhjm52YXf/jD//HcE0888VC90ShCn+MvVP/3
+ FPzAu08AtKK8WCza9Xr9TKPR2LB162Wru7o6LT9GIEwCDSyVy8i2Z6Qm0HnJJTheKiFjWaiNnmt6iHwv
+ IdDLbsFEByYTUwmqaEcQu+IoCQsI5x9V7dW9XKqbYpyba52UgpmpZ5PvooxCOlICkveFwCnO6ZqFAhZ1
+ 1ulcQZ8LDQyaVhG6h4KWgpSaA03DhGg2F9RzWhME6D1avky1M2kBsaioure1ZEcoT1U+v7bnurqwf+NG
+ /M63viXVfgn+el09MWiDtrYkTNNCobC4dM89dx9/+JGHf5bP52dw4VDfd93up+k9MwFEmp2dXa5Wq6fB
+ +WWXXrq1N5frMB3HQb3W0BZOrDcaKC2V0Z5JwzRN9PX0YtX6dThZqSBpRVE/cxYEGjrTBH9Vh+IaAAVI
+ OBcKKfN32iGg1ByNTN0nnXz+A2QnEoA3DKYvNy7uIT1XyjNGOibENeIDKBrxrzBCpCDukfMImGoRSU3U
+ ZCH3CO3Av4aChDVJZpB7VLgRkaayran6HV6fEDJPqUmE6tHUFvR8qL3D92rlaSHd6dRehM4xxjDY040n
+ L78cX/mzP8M1V10Fx3ZQrzcwPTuPaq2OcEomk4hELJTLS5X777t36N699/54fHx8FLrkf0eX93oz6b0m
+ AA6AT05OFquVyrAViezYtHFTZ0e23XBdN0QC/m4xxaUyMqkUohELnbkcNl66Ba/Va7AiETjnzoF7Lg3T
+ F7f6PV4MNTLf6+8FgKRSnCk9mQDUT3o4qw5WDhDS8I9SL7OQob7U0pbD8KU86cEy32APQbHmPFiz11pe
+ J5lHl2iKYIJrQ5IZoWvFMGYT2On1mobQDH6QZ4i2D0tdeQ9hvVZlomQgXmOra0S+1L4X4NfnD6jnho8x
+ xgDDwLHeXhzZuRPf+Iu/wOZNm+A6Liq1GmbmFqTNT+uRSCQQjUZQWV6uPfTQA+fuuefuHw4PD4eH+4Td
+ L8D/nqr+Ir2XBKAJ6bHx8Xy5XD4dj8Wv2bhpU7Yj2244joNavZkECsUi2tqSSMRjSKdSuHLHDgzV63Ai
+ EUQWF/0JRFCgASdhwkyo6AKIQTARARDgg4qWktrmEGG2qjfK7zJkmQm7nhKATh7+43z6kNKeThoiDURn
+ 8hnkhNgTUJRVRsIxkk/wu9VOvuoapm0QIolMAzMFTdgEEGZHCJjyN5N1NEC1kzDAW6jqLQhE+w1FSsJk
+ aiX5JfA1bYLJ9m1EIjjc14fhm2/Gt7/zHXTncvBcD+VKBbPzeTl/hTo7k0kf/NVqpf7IIw+N/+THd/3z
+ qVOnTuH84HfwPpH+wHuvAQCkIUZHR+eWlkrDbW1tV69fvyHb0ZE1PNeF3bDlZpyMMdi2g4XFAuKxGDLp
+ FCKWhWt37sRIo4ECY0jbNqrz8z4IhYjngZMOgUQlnUACWwO7BhV5nX9KgF1pCjpB+EA2iOiRoJIdkHRf
+ CkxGOnQIiIC/GCYNGJKjAgS8COoI+B2bM+LlDiohN/YQpEXKQSU3qbb2m046ksCV9WBgoXoZpH20/Ji+
+ rVeTqt8EfkI2Iu/QPecDP80bUBoHA1BKpfDLvj7UP/tZ/PV3/hqWZYJzoFAqYWYuD9vWt+8GfPDHYlFU
+ q9XGo/v2jd9114/+5eSrr56EHuP/vvH4t0rvNQHQICEOAKOjozPFYmG4ra3tqg3r17fnch0G50Cj3tB2
+ HnZdF/P5Ahhj6Mi2g3OObdu2oWRZGLFtdESjqEyMa03N5MOUL0CIR3IEUqJDhcvK2QMClMRK0IBCGIXM
+ NtCupR0T4umEcJpVeEji4KHnalOHVQZKo4ACtIK/KrN4PkAiAsUz5fWifFy2v24/6xuDQMQgCDKSbUOf
+ o6v14Xq3Bn/IrwAd/KKuTf4D8mxG6xm0w0xHBx7o6cG63/kdfP3rX4fnuQDnmF9YxFx+IVjOC9o7SqXa
+ EIlEUKlU6/v2PTL+ozt/+C8nTp48jtbgpx7/99TpF07vNQEArUlgulBYHI7F4js2bNjQ3tnZYTDGUG/o
+ Mwg59zCfL8B1HWTb2+FxD1u2bEG8sxNDjQZSiSSqchKRLjUAwF/ZVwzfiWNo+m6AgJmRZcmkVCN/ocAj
+ 7hdPp5F/aj3CZqlHUUiBQMtEx+QVNhmR6CJfRRDiGb4KTsHGSDnVveJaWqZWElaVkYmakfIx9Wm6vvk3
+ RP7BsVZLkMnrwu3W4jpKyoz8K0yBwe5uPLp+PT7zh3+IL95+OzzHget5mMsvYi6/SLaXF/lT8FdqDz14
+ //hdd/6Ign8J+pLeAvzvuce/VXo/EIBIGhGMjo7OFAqLpyKWtW3D+g3Z7q6caZom6kHEoGJjhkKxhGq1
+ hmwmA8/zsHbNaqzZuBHDnMNIJhGrVtAoFoOrg3+ZAbGkuBgyksOEepCAShSYUg2nwCcEoElY9VeumBM8
+ ggceQCUFFXBpiK+4n4eOCXISN1MSkeUg4KbSkFZL2fQ0H1IHTWITkLHQ/eT5zev8MZmXFsQUVvtDzws/
+ n/6mbRwO8FF1bTYHqvE4nu/pwYu7duFr3/oWrt+1Gw3HgeO4mJtfxGJxibxCRdSZTBqWZaFUKlYeuH/v
+ uR//+K5/bqH2twL/+0btp+n9RACA0gI4AD42Nja3uLj4quu4mzds3NjVmctZ0WgE9XoDtXpDe0Hl5WWU
+ lsrIZNKIWBZyuQ7s3r0bI40G5gwT2UgE1ckpDZyiUxiBdGaAv3OtmN/DpE8QRMhqEcYI8pPhP0L9Du4S
+ 0pU6IWmHpB1UJaXqiqzE9Fj/X7X0ltjAw2CGtiAHjRgMg7ZJeqNZ2oqi0ntlTALJW6ncgrTUSAIFvKil
+ Bm6mn5f1DJVPz0MRjqgbVfu5qAtDU97i/tlsFo/29sL77GfxH//mb9CZy8FxHdTrdczlF1CuVMgdfjJN
+ C+l0CqZpIJ+fX/r5z392+u67f/rDU4ODYYcfDfShK/usEMAbSJIEJiYm8vmF/Mnl8nL/ho0b+ro6O6PJ
+ ZAKNRgONhkN2FWao1WpYWFhELBZDeyYNzjmu3LYNXiqFMwDS6TS8mSl4jq1sfai1AcTS42Tza80m1p1I
+ ggGYBCEAbcEOsMAJF7CIPuuNSGj6nHCHDRGEgdAkFvFcTVo1S0c5ciGlmQ5wcSUFoIonoO0RIhZaBigy
+ IPGQ+sIaxLQQbdG0L4HQkiDArBPE+RyFgE6UIOcYAM808VpPDx5Zvx67v/xlfPWrXwUPRpiKpSXM5RdR
+ r9ugiTEgErHQ1tYGxoCpyanFn/zkzuM/v/fnPx4+c0YM9bWK8qNj/e9L8APvXwIACAlMT08vzs3NnpiZ
+ mW1bv3Hj6u6urng63QbXdeDYjrbIqO04mJnNw3YcZFIpeNzDhvUbsH7LFoyAo55IIm0YqAUbklI3n5Lq
+ RKIxIf1FR2Xkt+qokJ1Y9WZG8gPgq/rQj0lAiQ4PChaSEeRlGkDEmgaa1kHKREGnS0ZIMhClpkuAi0Sd
+ eVp5oXwJCOdJ2qGVHd8S6FBlFWHE9H7BseE8aL6qDM33FtJpPN3Tg9M33IA/+tM/xU0f+xgcx4Hjuphf
+ KGB+oRCsU6naEPAX82hrS8LzOM6cOTP3T//0/x1+6OGHfj4+Pj6G86v976ux/gul9zMBAIQE5vP58sTE
+ xPHh00O1jZs2b+7t601m29sZYwyO46Jhq5mEAFAsLqG8vIxUWxssy0R7JoNd112HBdPEKDPQnk7DnZ6C
+ 5ziBysvloIC0vkUnFMNkYhvtoHCMkIYmDQlmxSLDIODTAmaEycCZlIaShKR0Z3pnJ51cqLxMMo5YyZc1
+ A4EAVEBUBy0kWYh6hr3ssgxoNgcYU2G0IoWlv0GOq2t0SS5eRxjsTTa+0I4YdVZCbuJhAPAMA6e7u/FA
+ /yqs/sIX8Jd/+ZfIZbPwPA+Nho38YhHFpbJWB5Ha2hKIxxNwHMc7evTlqb/7P//L/ieffOLh/MLCLFqP
+ 83+gwA98cAjAA8DL5XJ9cHDwxOzMdLmnp2/zwMCqdFdnB4vHY3BsO1iIUZFApVpDPr+IiGWhPZOG53m4
+ dMsW9K1dg3OmCSeVRiYSQXVmRj2RSMSmxOhSYpDP0iDCQneTztgqP9XhgmsMmbM6x4i9T3Nnap6Cij9S
+ pdElJBOF0zUNyibQZwC2WkCDCYCJe0GCbyQ5kTIQ7YMUu4k46DH6W5GHqvuFNAha5oVMBs/09uLEzp34
+ 3T/+Y9z6b/6NXGC2vFzBQqEYRPYx0BkkhmEgnU4jGo2iWq05B558Yuz/+X//+0NPPfXU/nqjQbftbjXU
+ 9762+cPp/U4AQIgEAHinh4dPz83PTkeikUvXrlmX7si2m5l0GgD8JcZI5KDjOpid92dupVJJcA709vTg
+ +t27sRixMGZZSGXbYS0twVleDiQg096e39kMMoOQSFFyTEYekvuUGkFpIyy5CeCFIBd5E/uaUo3Klqrv
+ 6hh9PgvdJ/8KsAT/aCYNdPBT0FGJLWBDJ+uIewxadvJdA7tWpgsTANVU6Pnw8xrRKE529+CR1aux7tZb
+ 8e1vfxur+vrguC4cx0VpqYzi0jJR+f3EORCJRJHJpGAYJhYXC9UH7t879qM7f/Szw4cPPwsf6OeT/NTb
+ /4EAP/DBIABAHx3wAPCRkZHR/Pz8qdLSUv+6deu7OrLZaDabQTwWhR9C7E/YEJ2qtFTGQqGEWCyKdKoN
+ nsdx6ZbNWLt5MyZNC4VkEh3pDKpjo0Q6Ba5CAUROwKWJJkUZ4Y5NxWuzNGVQ8ISU9Nq9jMmIQ9Xhg+vk
+ pqfU807LyGgRpYquNAEKoNAUYfKvIcqhaSzE4w59x17VNGook0rq8JoGensExymRhM6ZTNUvvB7BWFcX
+ 9nd3I3/jjfiDb3wDn/3MLfC4B3COWr2B0vIyasTRRzWRRELY+x5GR0cX77rzR6/u3XvvT145duwomu39
+ cITfBw78wAeLAACiBQDwxicm5qamp46+/NKLtS2XXrqxq7MrmW3PINueAQAsV6rwPE++5Eajgdm5PCrV
+ GpLJBAzG0N7ejmuuuQZWRwfGk0kgk0E6kUBtejoAfkjiSjs7cAT6R4N//YuVjR+c4ToAhKag8if2vsqu
+ SeIR1iESkBHpqs4pDUOVg1r/QsOgABT2PwWkWp0X2jnd4w9CDMo8kG1D7m2S/iAES363WqWY1jtc1oVs
+ Fgd7enBk+3Z8/I478Cd/9Efo7OwE9zhc10W5Wsdytdok9QGh8qcQjcZQr9e9l158cfK//Ne/ffyJJ564
+ f2Rk5CyapT6N7X9fRvhdbPqgEADQHDHoAfDy+Xx5cHDw2MT4eDHbkds4MDDQlkmnjK7ODvjDhTaqZOEG
+ xhiWysuYzy/Askykkklw7mHt2rXYs2cPFiwL44kEErkc2gwDtfx84Mgz5Pi/LIUm9RTYdC+B6sAkdkh2
+ 4KBQTZWUACXI06Qs0S5aAQVoDZwmKaz4Q54P74JLy3s+UIrzrUJxw/fKa+VzKTnpdnx42I+WkwEop9M4
+ 2t2N/evXY+1v/Aa++93vYsumTdLWr9s2KjW6Pb3e5NFoBKlUGwzDQLFYrD388ENj3//+Pz504MCBx8rl
+ 8gJaD/OFN+78QIIf+GARAKCrWB79DJ85MzQ1NXmmWFrqW7dufVcmnYpkM2l0dfp7DCyVl2XMgD9y4GBu
+ fgGlpTJi8RjakklwzrFlyxZcsX07ZiMRTCQSSHV1I8E4GouLUN2UBqwI6Mv4W1lY6RGXIFPXS3vfP0zO
+ BfcSgAIgE3aCvLia6EPNkbBNLpKUqgpFSvqCTqOlvgQFOlM7z7SqCkJoHbYb2vMP5/Pmq9/huANNzQ+O
+ VdracLK7G4/09yP56U/jm3/+5/jExz8OHkh4x/VQt23UbQceb9bKGWOIxxOIxWLwPA/Dw8P5H/7LP5/a
+ u/fen7/wq18dhm7vC8cfBb+L93GE38WmDxoBiBT2CXgAvLGxsanxifGjL7zwfGnjxs0bu7q6kslEnPV0
+ d6ItCB4SizmITlet1TE1PYtKtYZELAbLspBIxLF92zas3bIFc7EophNJpLu6kABHPSACTgAkklw5CMQM
+ AKB26eFNEhGys6vlPvxoOibBpv6GpLU4x3XnmyAJbQHzsDlAAUvKJI4I8wDh8pK2ez1tQKj2hHN0LYTk
+ BZIXzTscJlxJpXCquxv7+vvh3XQTvvL1r+O3brsNqbY2vzN4HLbrom67vu3flBgiEQvJZMJfr79StZ98
+ 4vGJv/u7//rLJw8ceGB4ePg0Wkv9VnH9H2jwAx9cAhCpiQgWFhaWBoeGjp8dOTvFOdatXrMmk4gnzEw6
+ ha7OHAyDYblS0WxBYRbMzM7D8zgScX8bp/b2LK6+6iqs3rQJs7EYplIptPV0IxmJoD43J0UvdboJAhCR
+ hkrM+7/VFmWBZkAm7hBBLvMJz+Qj/wCgPgNqM6vrwyDV/A6yVCDajP+9lW9APIWRKml5U6JqOheUl/g6
+ wiYLJQS6jBcAlDMZnOzpwaP9/XD37MHvfu1r+J3f/m10d3dLzc71OBzXbZL4lDTj8RhisSg4B0ZHzxXu
+ /NEPR++66877nnn22V++jsr/gXb2nS+x17/kfZ/E+g8WgCiAGIAEgOSVV1xx2fr162/59l/9L799+WVb
+ c/FYlAFAfmERI6MTmJmdl5kotZYhmYjjkoF+9PV0w7QMf1dX08LIuRE8/fTTOPPaa4iPnEVqbByFo0cD
+ 4Ih5ANCsgeCM5tSiiBABL/Iwg3QayqAgEhQTTMgNfvMQ0EQ+XM9TglaURmgQrYlCNCqV+OLp+tp8XDk4
+ pcZA7ftm8Ld6Vmtp7+e7kMthMJXCKz092LBjB2679VZccfnlfi04D5DI4HHufzwPnHN4Hgfnnvzr78xr
+ AQDK5WX76aefmvqnf/rHQ0NDQ8+NjIycgw/ySvARTj4B/A+Fvd8qfRgIAFAapQmfBKIA4gCSANo+8YlP
+ 3PKFW2/7ym/91m9t6OnqjBuGAc/zMD4xjfHJaRSKpZC97H9PtSUwsKofvd1dsCwThmnAsizM5/N44vHH
+ cerUKfChIWTm5sBPn0ZldlaTwn7BlKSXkrYFSYTBCZIP1TPEcKRQLAQg5dwANEtdegzke8tlwaB2LxKk
+ Rk0FzXkYEFPrsX2i6gf11SMada2Gri3oJhKYzmZxMpHAubVrsWPHDtx+++1Y1d8feusMHvzNUDkBP/0O
+ +Co/ALiuy4eHhxfvuefuicd/+cv9R55//jB8i2cwugAAEA1JREFUtV6Afxm6ut/AByyy742mDwsBAKr/
+ m1DaQByBNrB169aNGzds+Mx/+A/f+OKu63b2pJJJEwBq9TrGxqcwMTWDalVt6UwdXYlEAgP9vejt7kQ8
+ Hodh+Hv3GYaBR/fvx7Hjx7Fw+jQ6ZmaQmJ7C0okTch0/CgS52KY4xkPPQgsgAU072GjSvmkXHSgNgtTl
+ Qmq5HlHXvB5geFjz/BuJXsDsgAK/gRZlAFDq7MJIOoWjySSimzfjhuuvx5fuuAOeCOwKNA9/RWa/TQTg
+ lbRXH9M0g7bkyOcXKvv27Zu++6c/OXhqcPDw+Pj4BHzgV6FAL6Q+ncn3oVL5w+nDRAAiUZPAgjIJEgCS
+ e/bsuWHH9h2/+bU//MMbN6xfn4lFIwzwdyYeHZ/E9LS/00srjSAajaC/rwe93V3oyGa08ydffRVHjhzB
+ 2ZER8LNnkc3nEZ2aRnn4tNbJfYlK8j6Puq60Bl19l15+sRZg0C2b5gsA2m+Rfxh8whchFh8Vqotuj4e1
+ A1WfJgIgmgEtQyv1nwGoZrOYTKcwGItjcvVqbL30Unzqk5/EdTt3kpmegGGaYIYBZhgh4HOi8isNyjD8
+ 1ZOq1arz/PNHZn70wx+eeuXYsWeOHj16DLrUp8CnO/V8KFX+cPowEgCg+jrVBqRvoKOjI3fN1Vd/6vOf
+ //wdX7jtC+v6enoS/hpw/p6EE5PTmJqZkyHFTIpWBYqerhz6+3p8ImAMhmnCCrSCJ558Eq+88gqmxsYQ
+ m5xAdrGAyMwMlofPEFue2O9GQAlcnz4rwU7ALVRwPwiJh6Qs5AYjArQcJHZfNI68hxIDk2ZLswbAIJci
+ EeZD0CZUSxHN1DSRh5oDAKodHZhNpXA6HsdIZycGNmzA7t278YXbbvOlvWGo6EfThBF8BMDD4BcEQIHv
+ OLZ36tSphXvuvnvmyQMHHj969OjzlUqlBAV0SgBhW/9Dq/KH04eVAABofY5qA8IsSGzZvHnDhg0bbv7S
+ l758+6c/+an+XC4bNZi/xs5ioYSJyWnMzudh244kAZ0MgLa2NvT1dKEzl0V7Jq0VoLy8jGcPHsTJkycx
+ PTmJ6OQkOkolxBcW4IyPwV5aIopxi7nuwbPkvoAMwWpFIiwpkNBMv55KXv/8hVV2qtojfI38BM8y9N80
+ L21GniwHA49FsZzNYiaZxHAshonOTgysWYOrr74at9xyC7IZpU0BgbQ3TX+LdEOfRqVAr7775QqWevdc
+ fu7caHHvvT+f2/foo8+cHhr61fjExCSU1BfAF9/F5pxU6n9oVf5w+jATgEhhbSCCEBHs2LHjyksGBm76
+ /d/7/c/vueGG3mx7JsKY36GKpSVMTs1gbn4B9Ya+D5z/XZFBriOL3u4uZNvTSCTi8jxjDA3bxsFDh3Di
+ xAlMTE6iMTWFbLGITLmM6OIi7IkJuNVqS3+ApnJDBygY015iqyg6Ulwp6aW5IfMkIJctF3IWhp6tg15t
+ T8asCOrt7Vhsa8NkLIbheBxuby/WrF6Na6+9Fp/5tV9DLBrVX5JhSDXfMC88Ok2BT47xiYmJpQcffHD2
+ /vvue37k3LmXhoaGhuGDm6r8YeCLGXwfGalP00eBAABdGzDhkwAlgiSAxM5rr72mv7//+n//+//+13ft
+ 2tWdzaQjhmGAc47ycgVT07OYzy+ivFzRgE81AoDBskzksll0dXUgk04hmUwoAAXq/qlTp/Dy0aM4c+YM
+ Zufngfl5tC8vI11ZRnJpCcbCIurT09LhJxX/kL/AkM8nm41KkItBQwJ4X4HQhuyAVtqHbjZo+xKQZmUA
+ eHs7qm1tWEzEMROJYjQaQ60zh77eXmzZvBm7du/G9iuv9G8mwBU2vVDxLzZx7rdDQAR8cnJy6ZGHH567
+ 9957XxofH3/5xMmTr0EBPyz5KfDDQT0fKfADHx0CEElgwYQiAuEfkBrBdTt3Xtvb17f7f/p3/+4zN1x/
+ Q0+uIxs1Dd8GrQcTiubm81gslPxMz2MeAAymwZDNtqMzl0U6lUIqlSSNzmCaBhhjeO3UKZw4cQJnz53D
+ 7OwslpeWEF1YQLpWQ6ZeR1u1Cmt5GaxUQmMhD8bVJBwxHz+sPQChWXWynAyMq63JVbBRKz+BIg+eTsNN
+ JlFJJFCMRpA3LcxFIljIZJDKZNDX14eNGzbgmquvxvZt23yACvMlSHJDVCHxGQNjhvQ/XGzyPI+Pjo4W
+ H3744fkHH3jgpYmJiVeOnzjxKnw7Pgx8KvHFBB4ayvuRA75IHzUCEEkIN2EWCP+AIII4gMQ111xzVX9f
+ 33W/eeutn/n0Jz/V09PdnYhELAYOuJ6HQqGImbl5FAqlFttEA2EyEEOKuWwGmXQKbW1JJBNxCVzOOQzD
+ BGOA4zg4fuIETg8PY2x8HPn5eZRKJdRqNZilElK2jYRtI+k4SLgOoraNiO3Aatgw7AZYow7esIFGA8zz
+ ANf1/yJQty3LB2AkAhaJwItG4FkRuJYF27JQtSxUTBNLhoGSaaIUiaDS1oZ4PI729nZ0dXZi7dq1uHTL
+ Flxz9dUyyMYD1IrJADzu+fZ60BAscJSKoVTGjGBr84vrirZtu6eHhgr33X//whOPP/7CxMTEsZOvvnoK
+ PrDrwYeCvkaOCztfAP9D7eG/mPRRJQBANwtoJCENJEoAiF9xxRVbLhkYuG7Xrt2fvu3W2wbWrVvTnojH
+ DQDgHketXkd+YRH5hQJKpTJcT61RqP6CdHJ1LpmIoz2TQltbG9qScSQScc0+dl0XYAYs05B5nDl7FmNj
+ Y5iamUF+fh6FYhHlpSVUKxXUGg00Gg1/vTvHged5WoCMrDwTAPT/mqaJaDSKWDSKeDyOdDqN9mwWXZ1d
+ GFjVjzVr1mDzpk3K6+6H4sEkTjqx4IbreUFkXmAyBPkbEvytCeBCJLC0tFR/+eWX8/ffd9/Ciy++eGR0
+ bOz48PDwOSjg16BLfhrIE47k+0hLfZo+ygQgUtg/IByFwjSQWsHq1atXbdywYWdHR8eOr3zlKzt3bN/R
+ 2ZFtj5mB/ep5nr/U1EIBheJSMAPRw8WSga8dM7QlE0glk0gk44jFYojHoojHYohGI7LQPrh9MDLTgGmY
+ cjPR4AGavX3hFvCv9SW1H1LLRd7MNyNMYqPbtgPbsdFo+ItqOq4Lz/Pgeh4Mw4Rp+oA3TQOGYQYEoMBP
+ v+sEoJsCrut6ExMTS48//vjC3nvvHZqfn391+MyZ4zMzM/NQwK6FPkLaC1U/7OBbAT5JKwSg0oWIgPoJ
+ 4gBi1+3ceW13d/f2Xdftuvlzn/tc99q1a9NtyYQlMnNdD+XlZRSKSygUS6hUanBdtbVZKzJoJgX9XDQa
+ QTIeRzQaRTRqIRKJIGKZsKwIzCBMWUhWM5DuF5Ks2jh6ED7ruT6QXdeF63oS4K7rwnZcuI4D23FJHRgB
+ vAK9OKYAb2rANwzDD6+WRKDKWSgUqq+88srCww8/XH7pxRdfnJ6Zee3YsWMn4AOaAp9K/jo5twL8i0wr
+ BNCczkcEYa0gBiC+du3agXVr127PZrOX3/KZW3buufHGjoFVq1LxWEyKTNd1Ua3VsbRURqFYRLVWR61W
+ x8WQQauIxPP/pXmd7+/F5PPG8hcgFwSggG9qJGBZFiIRC6ZpwbJMmQdjDOWlcn3o9FBh/2OPlZ49ePDU
+ Qj4/NHLu3GtTU1Oz0IEvQF9Hs7RfAf4bTCsEcP4UJgI6fCiGEDVCuGzr1k39/f1XZDKZSz/9a7+27Ybd
+ 1+dWrVrVlkwkLDFhB5zDdhwsL1exHOxmVK830GjYwEUDlV73Vsjg7SOFVlpANGohGo0F2ko0kPSAiLFY
+ WipVT58+XXz88ceXnjt0aLhQKJyZnJwcGj5zZhQK0NS5RwFPh/KoV38F+G8grRDA66dWzkJKBtRxKEnh
+ sssu29jX27s1nclsvmrHVdtvuunmzLp16zLZ9kw0ErEM7ge0gwNwHQeVah3VWg2VSgWVShW24zvU3igZ
+ vP1Av7j8TdNEPB5FLBYLPlFNtWeMwbYbztzcfOXkiRPFZ555pvbqqydPFYrFs1NTU2eGh4cp6Cnw6V+q
+ 4gvQrzj33kJaIYCLT4x8TOghxmIEIUwIUQDRNWvW9A8MDGzJZrMb2pLJdZ/4xCfW7dh+VfuqVava0ul0
+ JBKxDH+BEgaAB7HsDuqNOup1G7VaDbV6A/V6Ha6rPPrvhSlgGAYikcD/EPyNRiMwTUtKdxn92Gg4hUKh
+ dvbs2dKRw4eXX3rpxZlyuTy2WCiMTIyPn52cmpqDGpqjan74I8450EN26Tj+CvDfRFohgDeXhEYgyEB8
+ qL9AkEHT38svu2xjZ1fXukw6vTaeSKzeuXPnJdu3bW+75JJL2rLZbDyRSFimYQTzYUTMf7D4hcdh2zbs
+ YJhP/HUcF66jHHfcD5aXZoVcSiQ04iC878JBJ1R4y7LIXxORiCXH+lUTqMEGx7G9cnm5kZ+frwyfGS4f
+ e+WV2uDgqblKpTJZLJXG5ufnx4aGhs5BSW0BegHuVn/Ddj0N3vnIhe2+E2mFAN5aoloB9RXQACNBBlRL
+ oB9ro7/f4ep0Oj2QTCb7YrFY/xVXbuvaunVrfGDVQDKX64y1tSWjsVjUNE1TBtYpahBJfGPqNwPkFsfk
+ Kp8IOLTtj/Uv/i95nX/OthterVZ3iqVSfW5utjp67lxlcHCwcfbsmVK1VpupVCozpVJpan5+fnJkZGQS
+ PlCd0MdGs7pPj9OAnVa2/Qrw36a0QgBvXwr7CighUL9BK2Kgf03DMCJr167t78zl+lKpVHcikeiOxWKd
+ 8Xi8c/369b0bN26yBgYGIrnOrmh7eyaaTCSsWCxuRqOWaVoRWKbJDIMxMZtOjK/7wp9J7cDzPHjcj19w
+ XZd7rsNt2/Eatu1Vq1WnXC7bi4uL9tzsXH1sbLRx5swZPjU1Odew7cV6rbZQqVTy5XJ5Pr+wMDs2NjbD
+ OaeAFZLehQI1/UuBboeuF4Bfse3f4bRCAO9MakUGrQjBep0PvdYEYHR0dKQ7c7mOVDrdkUgkMrFoNBON
+ RlOWZbVZltVmmmbCNM24YRhRwzCijLEIY8wCY6bgAD/eh7ucc8fzPMfjvOF5XsNz3ZrrulXbcSqObVca
+ jUa5Xq8vVavV0tLSUnFhYaFQKBaXoYPTJX8piMNSP/y5EOBXQP8upRUCeOcTJQNKCiaazYYwQYS/0w/N
+ wwg9o9WHlocmHvre6qPtyIRm0LeS+uHvYXWegp4+YwX072JaIYB3N4VBeT5SoMQQJotWf+knnHcrEmiV
+ zgd6CvxWBHC+v26L61uBfQX072FaIYD3NrWS1GFSCEv4Cx0/n/Rn5HmtEid/L6QFhDWBsMp+vmOt8ltJ
+ 74O0QgDvr0SBeiFyaPVbzAMyQnmE822VeIu/4rtH/rbSDi4E8nC+K+l9llYI4P2fWoH4fEQRPt/q/vOl
+ VmANg7gVsFuRx0r6gKQVAvjgp/MB/EKOv/OlMPhbnVsB+EpaSStpJa2klbSSVtJKWkkraSWtpJW0klbS
+ Byz9/0gOIT47YbVtAAAAAElFTkSuQmCCKAAAADAAAABgAAAAAQAgAAAAAACAJQAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAQAAAAIAAAAEAAAABwAAAAkAAAAKAAAADAAAAAwAAAAMAAAACgAAAAkAAAAH
+ AAAABAAAAAIAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAFAAAACgAAABAAAAAWAAAAGwAAAB8AAAAiAAAAJQAAACYAAAAl
+ AAAAIwAAAB8AAAAbAAAAFgAAABAAAAAKAAAABQAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAABwAAAA0AAAAWAAAAIAAAACsAAAA0AAAAPAAAAEMAAABI
+ AAAATAAAAE0AAABMAAAASAAAAEMAAAA8AAAANAAAACsAAAAgAAAAFgAAAA0AAAAHAAAAAgAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAUAAAANAAAAGEBAQUZUVFV8XV1epmVlZsh0dHXp
+ dHR193NzdP9zc3T/c3N0/3R0dfl1dXbtYmJj0FZWVrVFRUaXKSkpcQAAAE4AAABCAAAANAAAACUAAAAY
+ AAAADAAAAAUAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAACDg4OCNaWltrZ2dot3Jyc+eCgoTh
+ ra2z99PT1P/m5ub/9fX1//7+/v/+/v7//v7+//f39//n5uf/1NTV/7y8vv9/f5b0b2948V5eYMtBQUKV
+ FBQUYAAAAEYAAAA0AAAAIgAAABMAAAAIAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM0NDQUYGBhZ3BwcdGCgoLc
+ s7O16/Pz9v7n5/P/4eHy/8nJ5f+nqNX/kJDH/4B/vf98fLz/goPB/46PyP+hoNX/vLvk/9PT8//g4Pb/
+ 7e3y/aSkvPZ3eIruaWlr30FBQpYMDAxaAAAAQQAAACwAAAAZAAAACwAAAAMAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABF5eXzxvb3C0
+ hISF2dXV1vj29fn93d3t/7a12/95err/KSmP/w8PiP8PD5L/EBCg/w8Pq/8PD7P/Dw+0/xAQr/8SEaT/
+ ExOa/xUVkv9WVbf/oKDh/9LS9P/v7/n+v7/S+Xh4ie1gYGLNKyssegAAAEoAAAAzAAAAHQAAAAwAAAAD
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD
+ Z2doWHZ2d9y7u7vk+/v8/tra7P+Tk8n/QUGb/xIRif8PD5n/DQ2e/w0Nov8MDKb/DAyq/wsLrv8LC7P/
+ Cwu4/wsLvP8LC8L/Dw/G/w8Pyf8TE8f/Fhar/xgYm/9bXMn/vb3x//j4/f+mprv0cHBz6zw8PZEAAABQ
+ AAAANgAAAB4AAAAMAAAAAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAJra2xshISF1ePj4/Tl5fD/eHi8/w0OgP8ODor/DQ2W/w0Nmv8NDZz/DAyd/wwMof8LC6X/
+ Cwup/woKrP8KCrH/CQm3/wkJu/8ICMD/DAzH/wwMzP8PD87/EBDT/xIS0f8XF7X/Gxuf/3p63v/d3fj/
+ 1dXk/HZ2f+pFRUWeAAAAUQAAADYAAAAcAAAACgAAAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAW5ub2uSkpLT+Pj4/M/P5v87O5z/Dg6E/w0NkP8MDJT/DAyX/wwMmP8MDJr/
+ Cwue/wsLoP8KCqT/Cgqo/wkJrP8JCbH/CAi1/wgIuv8HB77/CgjD/wwLyf8MDs7/DQ3S/w8P1v8QENr/
+ ExPS/xkZqv9FRcP/xcX0//Pz+P58fInqRUVFngAAAE8AAAAxAAAAGAAAAAgAAAABAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcHBxaZOTlNH+/v7/wMDd/xgYif8MDIn/DQ2T/w0Nk/8MDJP/
+ DAyW/wwMmP8LC5r/Cwue/wsLoP8KCqT/Cgqo/wkJrP8JCbD/CAi0/wgIuf8ICLz/BwfC/woKxv8MDMv/
+ DQ3P/w0N1v8ODtf/Dw/b/xIS3P8XF7j/KSmx/7a28f/9/f7/fX2F6ERERZsAAABIAAAAKQAAABEAAAAE
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABycnNTiIiI0Pn5+fzDw9z/DAyE/wsLjf8MDJP/
+ DAyT/wwMk/8MDJX/DAyV/wwMmf8LC5r/Cwue/wsLoP8LC6P/Cgqo/woKq/8JCa3/CQmy/wgIt/8ICLr/
+ Bwe//wgIw/8LC8j/CgvN/wsL0f8NDdb/Dw7Z/w8P3P8REd3/FRW//yEhr/+5ufH/9PT4/nV1eOg6OjqH
+ AAAAPQAAAB8AAAAKAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHNzdC94eHna5ubm8tfX5v8XGIv/
+ CguP/wsLlv8MDJb/DAyT/wwMlf8MDJX/DAyY/wwMmf8LC5r/Cwue/wsLn/8LC6P/Cgqm/woKqf8JCaz/
+ CQmx/wgItP8ICLn/CAi8/wcHwP8ICMX/CwvJ/wsLzv8MDNH/DQ3W/w4O2P8QD9r/EBDa/xUVuv8sLbr/
+ zc30/87O2/lubm/oJiYmZwAAADAAAAAUAAAABQAAAAAAAAAAAAAAAAAAAAAAAAAAc3N0CXV1dq3Gxsbf
+ 8PD1/zw8nv8KCo7/CwuZ/wwMmP8MDJf/DAyV/wwMlf8MDJX/DQ2Q/wsLhf8KCor/Cwue/wsLn/8LC6P/
+ Cgqk/woKqf8JCaz/CQmw/wkJsv8ICLf/CAi7/wcHvv8HB8P/Bwe//wcHv/8JCbb/DQ3S/w0M1v8NDdf/
+ Dw/Y/xAQ2f8VFa//U1PP/+jo+P+Xl6XvWlpbuAcHB0MAAAAgAAAACgAAAAEAAAAAAAAAAAAAAAAAAAAA
+ c3N0UYqKi9L+/v79gIC9/wkJi/8KCpz/Cwub/wwMmf8MDJn/DAyY/wwMkv8aGpr/aWmu/xkZcv8MDH//
+ CgqO/wsLoP8LC6H/Cgqk/woKp/8KCqn/CQmt/wkJsf8ICLT/CAi4/wgIvP8ICLr/UVHJ/0xMvP8ICJz/
+ BQW2/wwM0f8MDNH/Dg7V/w8P1f8REdH/GRml/5WV5P/y8vb+dHR16jc3N3cAAAAuAAAAEgAAAAQAAAAA
+ AAAAAAAAAABzc3QRdXV2xdfX2One3uz/CAiH/woKmv8KCp7/Cwue/wsLnv8LC5v/DAyW/yAgnv+goLz/
+ 29vO/8HB0f8eHXP/DAx//woKjv8LC6H/Cgqk/woKp/8KCqn/CQms/wkJsP8JCbL/CAi3/wkJsv9mZsj/
+ +/vx////+P90dMX/CQmY/wUFs/8NDc//CwvQ/w0M0f8OD9L/EhK+/ywss//Z2fT/paWy82FhYsMNDQ1A
+ AAAAGwAAAAcAAAAAAAAAAAAAAABzc3RUjIyM0f39/f1jZLD/CQiT/woKoP8KCqL/Cwug/wsLn/8LC5r/
+ Hh6k/6aow//IyLz/urq3/+Tk4f/FxdT/Hx91/wsLgf8KCpH/Cwuj/woKpv8KCqn/CQms/wkJrf8JCbH/
+ CQmv/2Zmw//s7OP/9/fx////+/////v/dnbE/wkJlv8HB7H/CgzL/wsKzf8MDM3/Dw/J/xYWpf+tren/
+ 8PD0/nR0dek5OTlvAAAAJAAAAAwAAAABAAAAAAAAAABzc3SixMTE4ODg7/8JCoj/CQmg/wkJov8KCqT/
+ Cwuj/wsLn/8aGqT/paXJ/8/Pw/++vr3/vLy9/7e3t//l5eH/xMTU/x8fdf8LC4X/CQmS/woKpv8KCqf/
+ Cgqp/wkJrP8KCqv/YGC7/9vb1f/l5eH/5ubn/+3t7f/+/vr////4/2Vlw/8ICLn/BgjH/wgJyP8KCsj/
+ DQ3I/xAQuf9tbMz/39/y/4+PlexWVlakAAAALgAAABIAAAADAAAAAHNzdCZ3d3jf9/f3+6Cg0f8gIJr/
+ ERKm/wkJpv8KCqb/Cgqk/wsLn/84OLT/1dXQ/87Oxv/BwcL/vr6+/7y8vP+3t7f/5eXh/8jI1f8kJHj/
+ CwuF/wkJlP8KCqb/Cgqo/woKp/9eXrf/09LH/9XV0P/V1dX/3t7e/+bm5//s7Oz////+/6+t5P8ICLf/
+ BwfC/wcHw/8HB8T/CgvE/wwMv/89P7b/vLzo/8LEzPlra2zeFxcXQQAAABcAAAAFAAAAAHNzdF6Tk5TR
+ +fn7/0REpv8wMK3/JSax/wkJq/8KCqn/Cgqo/woKpv8KCqT/bGzG/9XVzf/Jycb/wsLD/8DAwP+8vLz/
+ ubm2/+Tk4f/JydX/IyN5/wsLhv8JCZT/Cgqk/19esv/ExLv/xsbB/8bGx//Nzc3/1dXV/9vb3f/09Oz/
+ 1tbs/yoqv/8ICLv/Bwe+/wcHvv8HB77/CAi//woKvf8cHK3/hYXX/+bm6/12dnfqPDw9ZwAAABwAAAAH
+ AAAAAHNzdIeysrPa39/y/zQ0ov81NbT/MDC1/ycntP8JCaz/Cgqp/woKqP8KCqb/Cgqk/3Fxx//Z2c7/
+ ysrF/8LCw/++vr7/vLy8/7i4uP/k5OH/yMjV/yIief8LC4X/WVmy/7+/tv+6urf/u7u7/8DAwP/Gxsb/
+ ysrK/+rq3f/T1ef/KCi7/wkJsv8ICLj/CAi4/wgIuf8ICLr/CQi7/woKu/8NDbD/Vle//+jo8v6YmJnx
+ VFRVkQAAACAAAAAJAAAAAHNzdK/Pz8/pv7/k/zk5qf81Nbf/MjK4/zQ0uP8kJbb/CQms/woKq/8KCqn/
+ Cgqm/woKpv93d8r/29vO/8vLxv/Dw8P/wMDA/729vf+4uLj/5eXg/8DA1f9vb63/tra1/7e3sv+0tLb/
+ t7e3/7u7u/+8vLz/29vQ/8/P4f8xMbr/CQms/wkJsv8JCbT/CAi0/wgItf8ICLf/CAi3/wkJt/8MDLT/
+ NTas/9TV7f+0tLb2cHBxvgAAACEAAAAKAAAAAHNzdNLm5ub2mJjT/z9Asf82Nrn/NDS8/zMzvf82Nrz/
+ JCO2/wkJrf8KCqv/Cgqr/woKp/8KCqj/fHzL/9ra0P/Kysb/wsLE/8DAwP+9vb3/ubm6/+Pj4P/Dw7v/
+ t7ez/7OztP+ysrL/tLS0/7OztP/Pz8T/ysrb/zIyuP8KCqn/CQmv/wkJr/8JCbD/CQmx/wkJsf8JCbL/
+ CQmy/woKsv8MDLH/Ghqd/8fJ6//U1NX+fX1+3QAAACIAAAAKAAAAAHNzdO739/f9cXHC/0RFt/84OLz/
+ NTW+/zQ0vv8zM73/Nja8/yUlt/8JCbD/CQms/wkJrP8KCqn/Cgqo/39/zv/a2s//zMzG/8LCxP/BwcH/
+ vr6+/7q6uf+5ubb/tbW1/7S0tP+0tLT/r6+v/8rKwP/Jydr/MDC4/woKpv8KCqv/CQms/wkJrP8JCaz/
+ CQmt/wkJrf8JCa//CQmv/woKr/8MDK3/ERGZ/7y95f/k4+P/cXFy4AAAACEAAAAKAAAAAHNzdP7+/v7/
+ T0+1/0tLvf84OL3/NjbA/zU1wP80NL//NDO+/zU1vf8uLrr/Dg6x/wkJrf8JCaz/Cgqp/woKqf99fc//
+ 2NjQ/8vLx//ExMX/wcHB/76+vv+7u7v/uLi4/7W1tf+ysrL/yMjB/8jI2v81Nbj/Cwuh/woKqP8KCqn/
+ Cgqp/woKqf8KCqv/Cgqr/woKq/8KCqv/Cgqr/woKrP8MDKr/Dw+a/6+t3v/m5uf/cnJz5AAAACAAAAAJ
+ AAAAAHNzdP7+/v7/Ozuv/1BQwv87O8H/ODjF/zc3xP81NcL/NTXA/zI0v/81Nb7/MzO9/xsbtf8JCa//
+ CQms/woKqf8KCqn/cnLJ/9TUz//Kysj/xcXF/8LCwv++vr7/vLy8/7i4uP/GxsH/w8PW/ysrmv8KCo//
+ Cgqm/woKp/8KCqf/Cgqn/woKp/8KCqf/Cgqn/woKqP8KCqj/Cgqn/woKp/8MDKf/Dg6a/6mp2v/m5+j/
+ cnJz4wAAABwAAAAIAAAAAHNzdP7+/v7/Tk65/1VVxP89PcL/OjrH/zo6yP83OcX/NTfD/zU1wv80NMD/
+ NTW//zg4v/8oKLn/ERGz/wkJrf8KCqb/bWzI/9ra1f/Pz87/ycnJ/8bGxv/CwsL/vr6+/7u7u//n5+T/
+ x8fX/x4eef8LC4b/CQmU/woKpP8KCqT/Cgqk/woKpP8KCqT/Cgqk/woKpP8KCqT/Cgqk/wsLpP8NDKT/
+ EA+X/6ur2v/m5eb/dnZ25QAAABgAAAAGAAAAAHNzdPL5+fn9cnLJ/1paxf9CQsX/OzzI/zo6yf86Osj/
+ ODrI/zk5xf81NcP/NjbB/zQ0wP85OcD/MDC9/xgXsf+Dg9T/5eXf/9ra1f/T09P/zc3N/8rKyv/Hx8f/
+ wsLC/76+vv+6urv/5+fk/8nJ1v8kJHr/CwuF/wkJkv8KCqT/Cgqk/woKpP8KCqT/Cwuj/wsLo/8LC6H/
+ Cwuh/wsLof8NDKL/ExGT/7m44P/e2938b29w1AAAABMAAAADAAAAAHNzdNfp6er3nJza/1tbxf9JScb/
+ Pj7J/z08y/88PMz/OjvK/zo6yP84OMb/OTnF/zg4w/8xMcH/KCi5/5+e3f/39+3/7Ozm/97e3v/Y2Nj/
+ 09PT/83Nzf/Jycn/x8fH/8LCwv/AwMD/u7u7/+jo5P/Kytb/IyN6/wsLhv8JCZL/Cgqk/wsLo/8LC6P/
+ Cwuh/wsLoP8LC6D/Cwug/wsLoP8MDaD/ISCa/8bF4//Nzc/6bGxtvwAAAA0AAAABAAAAAHNzdLLS0tLp
+ xcXr/1paxP9VVcn/QUDL/z8+zv89Ps7/PTzM/zw8yv86Osj/PDzJ/zU0xv8mJrv/mpri//399v/x8e//
+ 6+vr/+Xl5f/i4uL/2dna/93d2P/e3tT/y8vJ/8bGxv/CwsL/vr6+/7q6u//p6eT/yMjV/x4ed/8LC4b/
+ CQmS/wsLo/8LC6D/Cwug/wsLoP8LC5//Cwue/wsLn/8MDZ3/MjGf/9HS5v6ys7TsamprpQAAAAgAAAAA
+ AAAAAHNzdIizs7Pa5OT2/1NTw/9lZdD/QkHL/0FB0f9BQdL/Pj7Q/z8/zv8+Psz/ODjK/y0twf+dnen/
+ //////7++v/z8/P/7+/v/+zs7P/l5eX/7+/o/9fX7f+kpNz/19fW/9LSzv/Jycr/xMTE/8HBwf+7u7v/
+ 6enm/8fH1f8hIXf/CwuF/wkJkv8LC6D/Cwuf/wsLn/8LC57/Cwue/wsMnf8NDZr/UU+u/+jp7f6ZmZrh
+ aWlqfAAAAAQAAAAAAAAAAHNzdF2SkpPR+fn9/1hYxv92dtT/TEzN/0ND0f9BQdP/QUHU/0JC0v87O9D/
+ LCzF/5yc6/////////////z8/f/4+Pj/9PT0/+7u7v/39+7/6unz/1xcz/8hIbX/mprZ/+Tk2v/W1tT/
+ zc3N/8nJyf/Gxsb/wMDB/+zs5//Jydj/ISF5/wsLhv8KCpH/Cwug/wsLn/8LC57/Cwuf/wwMnf8PD5b/
+ goHD//Ly8/6AgIHfZWVmSQAAAAEAAAAAAAAAAHNzdCp3d3jc+vr6/Kqq4/9ubtD/YWHT/0VF0v9CRNb/
+ Q0PV/0FB1P84OM//nZ3y///////////////////////+/v7/+Pj4////+f/u7vr/ZGLV/yUluP8wML3/
+ Kyu9/52d2v/k5Nr/19fT/87O0P/MzMz/ycnJ/8LCwv/s7ej/zMvZ/ywsfP8bG4//JiWn/yIipf8jIqP/
+ Hx+j/x4dof86OqP/w8Lb/+Df3/dzc3TeWFhZGgAAAAAAAAAAAAAAAAAAAABzc3Sqy8vL4Obm9/9bW8r/
+ f3/a/0xM0f9ISNb/R0fa/zg20/9xcej//////////////////////////////////////+7u//9lY9j/
+ JSW+/zo6xf85OcL/MTG//y0tvv+Zmdv/5OTa/9fX0//Pz9H/zMzM/8nJyf/CwsL/8fHp/7i41v8jI6T/
+ KCiq/ysqqf8pKKj/Jian/ycnpf9oZ7b/4eLo/qurrOFubm+NAAAAAgAAAAAAAAAAAAAAAAAAAABzc3Rb
+ kJCQzv39//yUlNz/fX7X/2lo1/9KSdX/SUnb/0FB2P9YWOH/5ef/////////////////////////////
+ 6ur//19f2v8uLsT/PDzK/z09yf87O8f/OjrF/zMzwf8vL8D/mprd/+Pj2//X19T/zs7Q/8zMzv/MzMf/
+ 39/a/4yM1f8lJa3/Kyuv/yoqrf8qKqz/KSmq/ywro/+pqc//+vn5/YKCg9ltbW5JAAAAAAAAAAAAAAAA
+ AAAAAAAAAABzc3QUdnZ3yNzc3Ork5Pf/YGDN/5SU4f9XV9X/SkrY/0xM3f88PNn/ZGTn/+np////////
+ ///////////q6v//Y2Hd/y8vyf9CQs//PkDL/z8/y/89Pcn/PD3H/zs7x/81NcP/MC6//5WV2//j493/
+ 2dnU/9XV0P/m5t//mprg/ygos/8vL7P/MDC0/y4usf8rK67/Kyqr/y0tmf/g4Oz/zs7O6HR0db1ra2wO
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAc3N0XZGRkc7+/v/9ra3m/3t71/9/f97/TEzV/0xK2/9KTN//
+ ODjX/2Rk5//m5v///////+fn//9gYOD/MjLM/0RE0/9CQtL/Q0HR/0BBzv8+Psz/PT3J/z4+yf8+Psj/
+ NzXD/zAwwf+Tk93/5eXe/+zs5v+eneT/Kiq4/y8vt/8zM7n/MzO3/zExs/8tLrH/LS6l/6yt1P/9/f3+
+ hoaH1HJyc00AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAc3N0DHZ2d7DKysvd8vL7/35+2P+MjN7/
+ c3Pc/0xM1/9NTd3/TU3g/z4+2/9iYun/p6X3/2Vl5v86OtT/R0jZ/0ZG1/9ERNX/RETT/0JD0/9BQdL/
+ QEDN/0E/zf8/P8v/Pz/K/zk5xv82NsX/f3/b/39/3P8yMr//MjO9/zg4v/82Nrz/MzO5/zExt/8vL6v/
+ fH29//Ly9//BwcHddXV2pnNzdAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHNzdDh7e3zT
+ 6urq8d7e9f9oaNP/lZXh/21t3P9NTdn/TU3f/09P4P9FRN3/OjrZ/0RE3P9MTN3/SUnc/0hG2/9IR9n/
+ RkbX/0ZG1f9DQ9P/Q0PR/0ND0f9AQc7/QEDL/0JCzP89Pcn/MS/F/zAwwf87O8T/PDzD/zg5wf84OL3/
+ NTS7/y8wsP9hYrT/39/u/+jo6PJ5eXrYc3N0MQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAABzc3Rcjo6Py/r6+vza2vT/Y2PR/5aW4v91dd7/T0/Y/01N3v9OTuH/T03j/05N4P9MTN//
+ S0ve/0tL3f9JSdv/SEjb/0hI2f9GRtf/RkbV/0VF0/9DQ9H/Q0PR/0NDz/9BQc3/QkLL/0BAyv8+Psf/
+ PDzF/zo6wf83OL7/MDGv/1lZs//R0ej/+fn5/IqKis9zc3RTAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAc3N0c5+foMz+/v7/2tr0/2tr1P+RkeH/h4fi/1tb2v9OTt3/
+ Tk7g/01O4f9MTuH/TU3f/0xM4P9LS97/S0vd/0lJ3P9ISdv/R0jX/0lJ1v9HR9X/RUXT/0VF0/9ERND/
+ QkLN/0BBy/89Pcf/OzvE/zo6wP8yMrD/UVGz/9LS6v/+/v7/nZ2ezHNzdHIAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHNzdHOenp/M+vr6/Ofn9/+AgNr/
+ gYHb/6Gh6P9yc9//VFTa/09P2/9OTt//Tk7g/05M4f9MTd//TU3f/01M3f9KTNz/S0va/0lJ2v9JSdf/
+ SEjU/0ZG0v9FQ9D/QkLM/z8/yP89PcT/OTm7/zU1r/9iY7z/3t7w//r6+vyfn5/Mc3N0cwAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABzc3Ry
+ jo6PzOvr6/L19f3/sLDo/2dn0/+NjeD/lpbl/3Jy3f9ZWdn/Tk7Z/01N2/9MTNv/TEzc/01N3P9MTNv/
+ S0rZ/0lJ1/9HR9T/RUXS/0NFzf9BQcn/QEDF/z4+v/86Orb/NTWu/52d1v/z8/r/6urq8Y6Oj8tzc3Rz
+ AAAAAAAAAAAAAAAAc3N0W3t7fNTLy8ze/v7//eXl+P+VleD/Z2fT/4KC3P+VleP/gYHf/2ts2v9cXNb/
+ UlHU/0xM0/9ISNH/R0jP/0dHzv9HR8z/R0fJ/0VFxv9ERML/QUG8/zo6tf+Bgc3/4ODz//7+//3Kysvd
+ e3t81HNzdFwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHNzdDd2dnewkZGRzt7e3ur9/f/95+f4/66u6P9gYNH/
+ ZGTR/3Fx1P95edj/eXnY/3V11/9tbdT/ZmbR/1tbzP9RUcf/SEjC/0JCvv9NTcD/o6Pe/+Tk9f/9/f78
+ 3t7e6ZGRkc52dnewc3N0NwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABzc3QMc3N0XXZ2d8uQkJDP
+ y8vL4fr6+vz6+v3/5eX3/8fH7v+goOP/enrW/1dXzP9FRcT/VFTI/3V10v+bm97/wsLr/+Pj9v/5+f3/
+ +fn5/MrKyuGQkJDPdnZ3y3NzdF1zc3QMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAHNzdBVzc3Rac3N0qXd3eNySkpPRtbW22tXV1evr6+v4+fn5/f7+/v/+/v7//v7+//n5+f3r6+v4
+ 1dXV67W1ttqSkpPRd3d43HNzdKlzc3Rac3N0FQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHNzdCpzc3Rdc3N0i3NzdLVzc3TYc3N08nNzdP5zc3T+
+ c3N0/nNzdPJzc3TYc3N0tXNzdItzc3Rdc3N0KgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP//gAD//wAA//4AAD//AAD/+AAA
+ D/8AAP/gAAAD/wAA/8AAAAH/AAD/gAAAAP8AAP8AAAAAfwAA/gAAAAA/AAD8AAAAAB8AAPgAAAAADwAA
+ +AAAAAAPAADwAAAAAAcAAOAAAAAABwAAwAAAAAADAADAAAAAAAMAAIAAAAAAAwAAgAAAAAABAACAAAAA
+ AAEAAAAAAAAAAQAAAAAAAAABAAAAAAAAAAEAAAAAAAAAAQAAAAAAAAABAAAAAAAAAAEAAAAAAAAAAQAA
+ AAAAAAABAAAAAAAAAAEAAAAAAAAAAQAAAAAAAAABAAAAAAAAAAMAAAAAAAAAAwAAAAAAAAADAAAAAAAA
+ AAcAAIAAAAAABwAAgAAAAAAPAACAAAAAAA8AAMAAAAAAHwAAwAAAAAAfAADgAAAAAD8AAPAAAAAAfwAA
+ +AAAAAD/AAD8AAAAAf8AAP4AAAAD/wAA/wAAAAf/AAD/gAAAD/8AAP/AAAAf/wAA//AAAH//AAD//gAD
+ //8AACgAAAAgAAAAQAAAAAEAIAAAAAAAgBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprJWpqa2BqamuUamprwGpqa+Fqamv4ampr+Gpqa+FqamvA
+ amprlGpqa2BqamslAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprQHV1dp54eHnxn5+f9sDAwP3a2tr/7e3u//v7+//7+/v/
+ 7e3u/9ra2v/AwMD9n5+f9nh4efF1dXaeamprQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprInx8fJiIiInwvb29/Onp6/7Z2en+tbXd/ouLzf5ZWrf/
+ Nzmo/ysspP9KSbH/cXHB/6Gi1//T0+j/6urr/r6+v/yIiInwfHx8mGpqayIAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGpqa0ODg4PYt7e4+uzs7/7AwN//eXfE/yIhoP8SEpv/
+ EBCk/wwMqP8KCqz/Cgq0/woKuf8NDb7/Dw+x/xERpv9WVrj/rq3c/+zs7/63t7j6g4OD2Gpqa0MAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABqamtOh4eI6tPT0/7Kyuj/REOw/xcXmf8REZz/
+ DAyY/wsLm/8LC6D/Cgqm/wkJrP8JCbL/CAi6/wcHv/8LCcj/DQ3O/xERzP8QEK//Skmy/8/P6//T09P+
+ h4eI6mpqa04AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprQ4eHiOrh4eH/qKja/yMjoP8VFZz/
+ DQ2S/wwMlf8MDJn/Cwue/wsLoP8KCqb/CQms/wkJsv8ICLj/CAi8/wgIw/8MDMn/DAzQ/w0N1v8TE8//
+ IiKp/6+v3v/h4eH/h4eI6mpqa0MAAAAAAAAAAAAAAAAAAAAAAAAAAGpqayKDg4PY09PT/qio2f8gIKT/
+ ExOb/wwMkv8MDJX/DAyX/wwMmf8LC57/Cwug/woKpP8KCqn/CQmw/wgItP8ICLv/BwfA/woKxv8JCcz/
+ DAzT/w0N2P8TE9P/Ghqo/66t3v/U1NT+g4OD2GpqayIAAAAAAAAAAAAAAAAAAAAAfHx8mLe3uPrKyuj/
+ JSSj/xMTn/8MDJf/DAyV/wwMlf8MDJH/DAyV/wsLnv8LC6D/Cgqk/woKqP8JCa3/CQmy/wgIuP8ICLz/
+ BwfA/wgIvP8HB8X/DAzT/w0N1/8SEtH/ICCn/83N6/+4uLn6fHx8mAAAAAAAAAAAAAAAAGpqa0CIiInw
+ 7Ozv/kVFsf8WFqT/Cwub/wwMmf8MDJb/MzOi/7m50P85Opv/DAyV/wsLof8KCqT/Cgqn/woKq/8JCbD/
+ CAi0/wgIt/8vL8L/rq7i/0tLv/8HB77/CwvR/wwM0/8UE8z/SEix/+zs7/6IiInwamprQAAAAAAAAAAA
+ dXV2nr+/v/2bm9X/HBym/wwMof8LC5//Cwua/zU1p/+1tb7/5ubf/+3t7/88PJz/DAyX/woKpP8KCqb/
+ Cgqp/wkJrf8JCbD/Jia1/87O3v////v/7u7x/0hIuv8ICLz/CgrN/wsLzv8REav/vsDg/7/Av/11dXae
+ AAAAAGpqayV4eHnx4+Pl/kZGsv8UFKj/Cgqk/wsLoP8hIan/vb3K/9DQyP/FxcX/4+Ph/+3t7/8+Pp7/
+ DAyY/woKpv8KCqj/Cgqp/ysrsP/AwM3/6uri/+vr6//+/vj/7e3u/ygovf8HB8T/CAnH/w8PxP+HiMv/
+ 6+vs/nl5evFqamslamprYJ2enfbW1+T/Ojqz/xISrf8KCqj/Cgqk/xMTqv+rq8//1tbL/8rKyv/Gxsb/
+ 5OTg/+7u7/8/P6D/DAyZ/woKpv8oKKv/srK//9jYzv/W1tj/4ODg//b17f/R0e3/HhzA/wcHvv8HB7//
+ BwfA/yEgqv/T1en+n6Cg9mpqa2BqamuUvb29+7q73P86Obf/Ly+4/wkJrf8KCqn/Cgqm/xUVrP+trc//
+ 1tbL/8vLyv/Gxsb/5OTh/+7u7/84OKH/IiKi/6yruP/IyMD/x8fI/83Nzf/h4dn/yMrh/yQkvP8ICLT/
+ CAi5/wgIuv8ICLv/Dw6r/6Gi1f7AwMD8amprlGpqa8DZ2Nf+mZnR/zg4u/82Nrz/LCy3/wkJrf8KCqn/
+ Cgqk/xwcr/+xsc//1tbL/8zMy//Hx8f/5OTh/+zs7v+srLf/wsK8/76+v//AwMD/z8/G/8HB1f8nJ7j/
+ CQms/wkJsv8JCbL/CQm0/wgItP8ODrX/bm6//9nZ2f5qamvAampr4evq6/99fMf/ODi//zQ0vv81Nr7/
+ Kiq4/wkJsP8JCaz/Cgqo/xwcsf+ystD/19fM/8vLy//Hx8j/yMjD/8bGw/+/v8H/vb29/8XFvP+4uM7/
+ KSm1/woKqP8JCaz/CQmt/wkJr/8JCa//CQmv/wwMsP9HR6//7Ozt/2pqa+Fqamv4+fn5/2Zmwf84OMT/
+ NTXC/zQ0wP81Nb7/MDC8/xMTtP8JCa3/Cgqo/x4es/+qqtD/09PN/8zMzP/IyMj/w8PD/8LCwf/ExL//
+ srLL/ysrtP8KCqT/Cgqo/woKqP8KCqn/Cgqp/woKqf8KCqn/Cwup/zExpv/6+vr/ampr+Gpqa/j7+/v/
+ WVm+/zs7yv86Osj/NzfE/zU1wv82NsD/Nja+/yMjuP8JCbH/Cgqn/0lJvv/W1tT/09PR/83Nzf/IyMj/
+ xMTD/+3t7f9fX7P/DAyY/woKp/8KCqb/Cgqm/woKpv8KCqT/Cgqm/woKpP8LC6T/LS2m//v7+/9qamv4
+ ampr4e3t7v9/gMv/QEHM/zw8yv86Osj/ODrI/zg4xP82NsL/OTnA/yEjt/9KSsL/y8ve/+Dg3P/W1tb/
+ 0tLT/83Nzv/Jycn/4uLh//Hx8v9CQqP/DAyZ/woKpP8KCqT/Cgqk/wsLo/8LC6P/Cwuh/w4Oof9EQ7D/
+ 7e3u/2pqa+FqamvA2tra/5yb1f5JSc3/Pj3Q/zw9zv88PMr/OjrI/zs5x/8oKL3/XFzM/+Xl7f/09O3/
+ 5eXm/97e3v/c3Nn/2dnT/83Nzf/IyMj/5eXh//Hx8/8/P6D/DAyZ/woKpP8LC6H/Cwug/wsLoP8LC5//
+ ExOi/2trwP/a2tr/amprwGpqa5TAwMD9vbrh/lZVz/9BQdT/Pz/S/z8/zv89Pcz/LCrD/15e0//r6/b/
+ ///6//Hx8f/t7e7/8PDp/9LS5v+9vdb/2trT/8/Pz//Jycr/5eXi//Hx8/86OqD/DAyY/wsLo/8LC5//
+ Cwue/wsLnv8cHKT/nJzT/8HBwf1qamuUamprYJ+fn/ba2er/a2vP/0RE1/9BQ9b/QkLT/zQ0zf9kZNv/
+ 7+/////////8/Pz/9vb2//z89P/i4fD/UFDM/0BAwf/Dw9v/4eHY/9TU1f/Pz8//6Ojl//Ly9P9AQKL/
+ DAyZ/w8Pov8PD6D/Dw+d/zAvqf/R0ej+oKCg9mpqa2BqamsleHh58enp6/6np9r/YGDb/0VH2/88PNb/
+ WFfe//Ly////////////////////////6Oj4/1tb1P8oKL3/Kiu9/0lJxf/Dw9v/5OTa/9XV1f/OztD/
+ 6Ojl//T09P9JSa//ISGm/yoqpv8sK6n/VVe4/+rq7P54eHnxamprJQAAAAB1dXaevr6+/cnK5v96edv/
+ TEzf/0FB2/9XV+D/6ur//////////////////+jn//9bW9f/Li7G/z4+yf86OsX/LC7B/0pJyP/Cwt3/
+ 4+Pa/9XV1P/a2tP/ysvZ/0dHu/8lJa3/LCus/zMyrv+lpNj/v7+//XV1dp4AAAAAAAAAAGpqa0CIiInw
+ 7Ozv/paW1v97e+P/TUvg/0FB2/9fX+b/5+f////////p6f//Wlrc/zMzyv9CQs//QEDL/z09yf89Psj/
+ MDDC/0hIyf/AwN3/7O7e/9DQ4P9VVMf/KCiz/zIytP80NLH/VFO3/+zs7/6IiInwamprQAAAAAAAAAAA
+ AAAAAHx8fJi3t7j60NDs/4+P2/9oaOP/Tk7i/z5A2/9lZen/srL3/2Vl5P85O9L/RkbX/0ND1P9DQ9H/
+ QkLP/0BAy/8/P8r/MzPE/05Oy/+enuL/XFvP/ykquv82Nrz/OTi4/z8+sf/Ly+n/t7e4+nx8fJgAAAAA
+ AAAAAAAAAAAAAAAAamprIoODg9jT09P+tbXi/56e5P9nZuL/TlDm/0ZG4P89Pdr/RETc/0tL3P9ISNv/
+ SEfZ/0ZG1f9EQ9P/Q0PR/0JCz/9BQ83/OjrI/zEvxf81NcP/PDzD/z09vv9AP7X/rKzc/9PT0/6Dg4PY
+ amprIgAAAAAAAAAAAAAAAAAAAAAAAAAAamprQ4eHiOrh4eH/tbXi/6em5P94d+X/UVHl/09P5P9OTuL/
+ TU3g/0xM3v9LS9z/SUnb/0hI1/9HR9X/RUXT/0VF0f9DQ8//QkLM/z8/y/9DQ8L/RkW2/62t3P/h4eH/
+ h4eI6mpqa0MAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprToeHiOrT09P+0NDs/6qp3/+iouz/
+ ZWXj/1FR5v9PT+T/T03k/01N4P9NTd//TU3c/0xJ2/9KStj/R0nW/0dH1P9JScv/S0vD/46O0P/NzOj/
+ 09PT/oeHiOpqamtOAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAamprQ4ODg9i3t7j6
+ 7Ozv/sPC5f+truH/np3o/29v4P9cXOH/VFLi/1BR4f9PT9//T0/b/1FQ1v9RUc//X1/I/6Gh0/7HyOD+
+ 5OTn/re3uPqDg4PYamprQwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ amprInx8fJiIiInwv7+//evr7P7Y2ev+vb3k/qin3P+Wldf/iIbU/399zv+Mi9L/oaLZ/8C+4f7Z2er+
+ 6urs/r+/v/2IiInwfHx8mGpqayIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAGpqa0B1dXaeeHh58Z+fn/bAwMD92tra/+3t7v/7+/v/+/v7/+3t7v/a2tr/
+ wMDA/Z+fn/Z4eHnxdXV2nmpqa0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABqamslamprYGpqa5RqamvAampr4Wpqa/hqamv4
+ ampr4Wpqa8BqamuUamprYGpqayUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ /8AD//8AAP/8AAA/+AAAH/AAAA/gAAAHwAAAA8AAAAOAAAABgAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAGAAAABwAAAA8AAAAPgAAAH8AAAD/gAAB/8AAA/
+ /wAA///AA/8oAAAAGAAAADAAAAABACAAAAAAAGAJAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAGxrbDhsa2x4bGtsrmxrbNhsa2z1bGts9WxrbNhsa2yubGtseGxrbDgAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABsa2w9bGtsmHh3eNijo6PY
+ zMzM6+jo6Pn5+fn/+fn5/+jo6PnMzMzro6Oj2Hh3eNhsa2yYbGtsPQAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAGxrbGp2dXbQuLi52uzs8vrExOb/f3/I/0pKsf8pKaL/KSmi/05Os/+MjM7/
+ 09Pt//Dw9Pq5ubnZdnV20GxrbGoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbGtseY+Oj8Tc3OLv
+ tLTf/z08rv8PD6b/CQmq/wQErv8CArP/AgK//wQEyf8HB8X/Dg62/1BRtv/NzOr/5OTm7Y+Oj8Rsa2x5
+ AAAAAAAAAAAAAAAAAAAAAAAAAABsa2xqj46PxOvr9PR0dMX/FRWn/wkIof8BAZz/AACh/wAAp/8AALH/
+ AAC8/wAAxf8AAND/AwPb/wgI2f8UErj/lpbU//f3+vGPjo/EbGtsagAAAAAAAAAAAAAAAGxrbD12dXbQ
+ 2trh8HFxw/8VFar/BASc/wAAl/8AAJn/AACj/wAAp/8AAK7/AAC4/wAAwf8AAMv/AADQ/wAA3v8HB+P/
+ EBC8/5aW0//j4+XtdnV20GxrbD0AAAAAAAAAAGxrbJi2tbjbqKjZ/xoZqv8EBKL/AACZ/xQUnv8gIH7/
+ AACL/wAAp/8AAKz/AAC1/wAAvP8AAMP/MDDP/w8Pof8AANr/BQXe/xQStf/MzOr/ubm52WxrbJgAAAAA
+ bGtsOHh3eNjm5u/8QkGz/wgIqv8AAKL/GBil/39/vP/09PT/MDCC/wAAjv8AAKz/AACx/wAAtf9GRsf/
+ 9PT1/7Gx5P8QEJv/AADW/wcHz/9OTbX/8PD0+nh3eNhsa2w4bGtseKOjo9i5ueL/JSSz/wEBq/8AAKX/
+ ZGTE/+np1P/a2tT/9fX1/zExhP8AAJH/AACt/z4+uP/i4t3/8/Ps//f39v+NjeP/AADG/wEBzv8RD7b/
+ 09Ps/6Ojo9hsa2x4bGtsrszMzOuCgc3/Ly++/wkJtv8AAKv/EhK0/7e31f/f39P/2trU//X19f8vL4b/
+ KiqK/8/Pzv/d3dj/9PTu/9PU7/8cG8b/AADB/wAAxP8IB7z/iorN/8zMzOtsa2yubGts2Ojo6PlhYMH/
+ MTHE/ysrw/8HCLf/AACr/w4OtP+6utb/4ODU/9ra1f/z8/L/19fY/9bW0v/n5+L/xMTe/xQUuv8AALT/
+ AAC5/wAAuv8FBb3/UFC0/+jo6Plsa2zYbGts9fn5+f9RULz/MS/K/y4wyf8qKsT/DAy7/wAAr/8SErX/
+ sbHV/9vb1v/a2tr/19fW/+fn5P+6utf/Fxe3/wAArP8AALD/AACx/wAAsf8CArP/LCyl//n5+f9sa2z1
+ bGts9fn5+f9WVr//NTXT/zIyzv8xMcz/MTHJ/xwdwf8AALD/Y2PL/+fn3//f39//3d3d//b29v9GRpD/
+ AACP/wAArP8AAKz/AACr/wAAqv8DA6v/LCyk//n5+f9sa2z1bGts2Ojo6Plubcj/PDzW/zY21v80NdP/
+ MjHO/yAgxf9vcNj/8PD0//Dw7v/r6+b/4eHc/9XV0//z8/T/NDSG/wAAj/8AAKr/AACm/wAApv8GBqr/
+ UFC1/+jo6Plsa2zYbGtsrszMzOuNjNT/RkbY/zs73v86Otj/JCPP/3l55f/9/fz/+vr5//X18f/R0e7/
+ xMPe/+Pj3P/b29f/9PT0/zMzhv8AAI3/AACk/wAAo/8SEqz/hobM/8zMzOtsa2yubGtseKOjo9i8u+X/
+ VFPS/z5A4/8yMt7/g4Pv//n5+P/9/f3/+vr6/+jo//8wMMr/MTHF/9DQ5P/p6eH/4eHc//Ly8f88PIz/
+ Cwun/xQUqP8pKa//xsbn/6Ojo9hsa2x4bGtsOHh3eNjk5O79dHPQ/0tL5f81NeX/rq7///r6+f/6+vn/
+ 5eX//zg40v8qKs3/JyjK/zY2yf/OzuX/7e3e/+zt3v91ds//Gxuy/ykptP9RULn/7e3y+nh3eNhsa2w4
+ AAAAAGxrbJivrrfgsbHi/19e1f9KSev/Pj/q/7i4///g4P//QEDa/zEx2P89Pdn/OzvV/ykqzv85Ocv/
+ trfk/4aG2/8mJsH/LS29/zY1tf+4uOH/t7e522xrbJgAAAAAAAAAAGxrbD12dXbQ0tHe9I+O1/9fXtv/
+ Skzu/0RE7f9HR+v/Pj/l/0VF5f9AQOH/Pz7b/z4+2f80NNT/OjjV/zExzv80NMn/PDq8/4KCy//c3OLv
+ dnV20GxrbD0AAAAAAAAAAAAAAABsa2xqjo6PxOPj8fiRkdj/ZWPa/1JS7P9ISO//Skru/0lI6/9GRuj/
+ RkXj/0RC4f9AQd3/OzrY/z4+0P9DQr7/goHM/+3t9fSPjo/EbGtsagAAAAAAAAAAAAAAAAAAAAAAAAAA
+ bGtseY+Oj8TS0d/0tbTk/3x81f9jYt3/V1fo/1JQ7f9MTOz/S0rp/0tL4/9LS9n/TUzK/2NixP+yst//
+ 29rh8I+Oj8Rsa2x5AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGxrbGp2dXbQr6634OXl7/3Bwej/
+ l5ba/3590f9pacv/ZmXI/3Nzy/+OjdT/v7/l/+fn7/y2tbjbdnV20GxrbGoAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAABsa2w9bGtsmHh3eNijo6PYzMzM6+jo6Pn5+fn/+fn5/+jo6PnMzMzr
+ o6Oj2Hh3eNhsa2yYbGtsPQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAGxrbDhsa2x4bGtsrmxrbNhsa2z1bGts9WxrbNhsa2yubGtseGxrbDgAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAA/gB/APgAHwDwAA8A4AAHAMAAAwCAAAEAgAABAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAACAAAEAgAABAMAAAwDgAAcA8AAPAPgAHwD+AH8AKAAAABAAAAAgAAAA
+ AQAgAAAAAABABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABycXJGcnFyjXJxcsdycXLw
+ cnFy8HJxcsdycXKNcnFyRgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHJxciBycXKMh4WF9aWhoP++ubf/
+ 0MnI/9DJyP++ubf/paGg/4eFhfVycXKMcnFyIAAAAAAAAAAAAAAAAHJxciBycXKjm5eX/7SvvP+Ef8T/
+ UlDD/ywswP8sLML/UlDF/4SByP+0r73/m5eX/3JxcqNycXIgAAAAAAAAAABycXKMm5eX/6Kevv8sKq3/
+ AQGr/wAAnf8AAK//AAC4/wAAwf8CApn/Kymn/6Kezf+bl5f/cnFyjAAAAABycXJGh4WF9bawvf9ZV7L/
+ gIDQ/7u76P8AAHn/AACf/wAAs/8EBKH/19fs/4WFy/8mJaH/tK+9/4eFhfVycXJGcnFyjaWhoP+IhMX/
+ Pz/C/6ur1v///+z/x8fX/wAAef8AAJb/0tLc////8v+2tu7/BgaI/4WBx/+loaD/cnFyjXJxcse+ubf/
+ ZGLH/wICq/8hIb3/q6vU////6f+9vdH/vb3P//f32v+2tuP/HByc/wICuv9SUML/vrm3/3JxcsdycXLw
+ 0MnI/1FQyv8DA7T/AACq/0REvv+dndP/+Pjm//X15f+oqNz/FhaX/wAAqf8CAq3/LS29/9DJyP9ycXLw
+ cnFy8NDJyP9YV87/MDDK/wEBuf8FBbb/kJDa//T04f/29uj/kZHU/wAAe/8AAJ3/AgKy/y4uvP/Qycj/
+ cnFy8HJxcse+ubf/fXrT/xYVyf80NNH/nZ3n////+f/4+PD/5eTc//r65f+MjM//AQF8/wIClP9aV8D/
+ vrm3/3JxcsdycXKNpaGg/6ah0v9ubub/oKDp////////////bGzc/2Bgzf/39eP////w/4+P0P80NIn/
+ jIjF/6WhoP9ycXKNcnFyRoeFhfW8tsH/e3rm/93d9///////goLn/wkJxv8ICcP/cnLW////5v/Z2eT/
+ aGfV/7awvf+HhYX1cnFyRgAAAABycXKMm5eX/6+r0P9tbOT/jY3x/x4f1/85Od3/NjbX/xkazP9ub9v/
+ YF7Z/6qlyP+bl5f/cnFyjAAAAAAAAAAAcnFyIHJxcqObl5f/vLbC/6yn1f+Ihdj/aGbW/2Jg0f9zcc3/
+ lJDK/7eyvv+bl5f/cnFyo3JxciAAAAAAAAAAAAAAAABycXIgcnFyjIeFhfWloaD/vrm3/9DJyP/Qycj/
+ vrm3/6WhoP+HhYX1cnFyjHJxciAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABycXJGcnFyjXJxcsdycXLw
+ cnFy8HJxcsdycXKNcnFyRgAAAAAAAAAAAAAAAAAAAADwDwAAwAMAAIABAACAAQAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAACAAQAAgAEAAMADAADwDwAA
+</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Error</value>
+ </data>
+ <data name=">>saveFileDialog.Name" xml:space="preserve">
+ <value>saveFileDialog</value>
+ </data>
+ <data name=">>saveFileDialog.Type" xml:space="preserve">
+ <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ErrorDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2011-06-17 17:44:56 UTC (rev 5933)
@@ -52,6 +52,12 @@
</Compile>
<Compile Include="ComboBoxBinder.cs" />
<Compile Include="DialogFactory.cs" />
+ <Compile Include="ErrorDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="ErrorDialog.Designer.cs">
+ <DependentUpon>ErrorDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="NumericBinder.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="Properties\Resources.Designer.cs">
@@ -74,6 +80,9 @@
<DependentUpon>CollapsiblePanel.cs</DependentUpon>
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="ErrorDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="Properties\Resources.resx">
<Generator>ResXFileCodeGenerator</Generator>
<LastGenOutput>Resources.Designer.cs</LastGenOutput>
@@ -95,6 +104,9 @@
<ItemGroup>
<None Include="Resources\chevron.png" />
</ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\ErrorLogTemplate.txt" />
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs 2011-06-17 17:44:56 UTC (rev 5933)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.3053
+// Runtime Version:2.0.50727.4952
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -74,6 +74,32 @@
+ /// <summary>
+ /// Looks up a localized string similar to Maestro Error Report
+ ///Version: {0}
+ ///Date: {1}
+ ///Message: {2}
+ ///Details: {3}.
+ /// </summary>
+ internal static string ErrorLogTemplate {
+ get {
+ return ResourceManager.GetString("ErrorLogTemplate", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to File saved.
+ /// </summary>
+ internal static string FileSaved {
+ get {
+ return ResourceManager.GetString("FileSaved", resourceCulture);
internal static System.Drawing.Bitmap minus_white {
get {
object obj = ResourceManager.GetObject("minus-white", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx 2011-06-17 17:00:11 UTC (rev 5932)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx 2011-06-17 17:44:56 UTC (rev 5933)
@@ -130,4 +130,10 @@
<data name="chevron" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\chevron.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="ErrorLogTemplate" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\ErrorLogTemplate.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
+ <data name="FileSaved" xml:space="preserve">
+ <value>File saved</value>
+ </data>
</root>
Added: trunk/Tools/Maestro/Maestro.Shared.UI/Resources/ErrorLogTemplate.txt
--- trunk/Tools/Maestro/Maestro.Shared.UI/Resources/ErrorLogTemplate.txt (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Resources/ErrorLogTemplate.txt 2011-06-17 17:44:56 UTC (rev 5933)
@@ -0,0 +1,9 @@
+Maestro Error Report
+Version: {0}
+Date: {1}
+Message: {2}
+Details: {3}
More information about the mapguide-commits
