[mapguide-commits] r5934 - in trunk/Tools/Maestro:
Maestro.Editors/FeatureSource/Preview
Maestro.Editors/Properties OSGeo.MapGuide.MaestroAPI/Schema
svn_mapguide at osgeo.org
Fri Jun 17 14:04:47 EDT 2011
Author: jng
Date: 2011-06-17 11:04:47 -0700 (Fri, 17 Jun 2011)
New Revision: 5934
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs
#1713: Show tooltip information for class and property nodes in Local Feature Source Preview
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs 2011-06-17 18:04:47 UTC (rev 5934)
@@ -38,8 +38,8 @@
this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
this.btnSql = new System.Windows.Forms.ToolStripButton();
this.btnStandard = new System.Windows.Forms.ToolStripButton();
+ this.btnClose = new System.Windows.Forms.ToolStripButton();
this.tabPreviews = new System.Windows.Forms.TabControl();
- this.btnClose = new System.Windows.Forms.ToolStripButton();
this.splitContainer1.Panel1.SuspendLayout();
this.splitContainer1.Panel2.SuspendLayout();
this.splitContainer1.SuspendLayout();
@@ -65,6 +65,7 @@
resources.ApplyResources(this.trvSchema, "trvSchema");
this.trvSchema.ImageList = this.schemaImageList;
this.trvSchema.Name = "trvSchema";
+ this.trvSchema.ShowNodeToolTips = true;
this.trvSchema.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvSchema_AfterSelect);
// schemaImageList
@@ -117,12 +118,6 @@
this.btnStandard.Name = "btnStandard";
this.btnStandard.Click += new System.EventHandler(this.btnStandard_Click);
- // tabPreviews
- resources.ApplyResources(this.tabPreviews, "tabPreviews");
- this.tabPreviews.Name = "tabPreviews";
- this.tabPreviews.SelectedIndex = 0;
// btnClose
this.btnClose.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
@@ -132,6 +127,12 @@
this.btnClose.Name = "btnClose";
this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
+ // tabPreviews
+ resources.ApplyResources(this.tabPreviews, "tabPreviews");
+ this.tabPreviews.Name = "tabPreviews";
+ this.tabPreviews.SelectedIndex = 0;
// LocalFeatureSourcePreviewCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.cs 2011-06-17 18:04:47 UTC (rev 5934)
@@ -118,6 +118,12 @@
classNode.Tag = cls;
classNode.ImageIndex = classNode.SelectedImageIndex = IDX_CLASS;
+ classNode.ToolTipText = string.Format(Properties.Resources.FsPreview_ClassNodeTooltip,
+ cls.Name,
+ cls.Description,
+ cls.DefaultGeometryPropertyName,
+ Environment.NewLine);
foreach (var prop in cls.Properties)
var propNode = new TreeNode(prop.Name);
@@ -125,11 +131,56 @@
propNode.Tag = prop;
if (prop.Type == PropertyDefinitionType.Geometry)
+ var g = (GeometricPropertyDefinition)prop;
propNode.ImageIndex = propNode.SelectedImageIndex = IDX_GEOMETRY;
- else if (prop.Type == PropertyDefinitionType.Data && cls.IdentityProperties.Contains((DataPropertyDefinition)prop))
- propNode.ImageIndex = propNode.SelectedImageIndex = IDX_IDENTITY;
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_GeometryPropertyNodeTooltip,
+ g.Name,
+ g.Description,
+ g.GeometryTypesToString(),
+ g.IsReadOnly,
+ g.HasElevation,
+ g.HasMeasure,
+ g.SpatialContextAssociation,
+ else if (prop.Type == PropertyDefinitionType.Data)
+ var d = (DataPropertyDefinition)prop;
+ if (cls.IdentityProperties.Contains((DataPropertyDefinition)prop))
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_IDENTITY;
+ else
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_PROP;
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_DataPropertyNodeTooltip,
+ d.Name,
+ d.Description,
+ d.DataType.ToString(),
+ d.IsNullable,
+ d.IsReadOnly,
+ d.Length,
+ d.Precision,
+ d.Scale,
+ else if (prop.Type == PropertyDefinitionType.Raster)
+ var r = (RasterPropertyDefinition)prop;
+ propNode.ImageIndex = propNode.SelectedImageIndex = IDX_RASTER;
+ propNode.ToolTipText = string.Format(Properties.Resources.FsPreview_RasterPropertyNodeTooltip,
+ r.Name,
+ r.Description,
+ r.IsNullable,
+ r.DefaultImageXSize,
+ r.DefaultImageYSize,
+ r.SpatialContextAssociation,
else
classNode.Nodes.Add(propNode);
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx 2011-06-17 18:04:47 UTC (rev 5934)
@@ -140,7 +140,7 @@
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAw
- DQAAAk1TRnQBSQFMAgEBBgEAASQBAAEkAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ DQAAAk1TRnQBSQFMAgEBBgEAASwBAAEsAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAASADAAEBAQABCAYAAQgYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-06-17 18:04:47 UTC (rev 5934)
@@ -869,6 +869,42 @@
/// <summary>
+ /// Looks up a localized string similar to Name: {0}{3}Description: {1}{3}Geometry Property: {2}.
+ /// </summary>
+ internal static string FsPreview_ClassNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_ClassNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{8}Description: {1}{8}Data Type: {2}{8}Nullable: {3}{8}Read Only: {4}{8}Length: {5}{8}Precision: {6}{8}Scale: {7}.
+ /// </summary>
+ internal static string FsPreview_DataPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_DataPropertyNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}.
+ /// </summary>
+ internal static string FsPreview_GeometryPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_GeometryPropertyNodeTooltip", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Name: {0}{6}Description: {1}{6}Nullable: {2}{6}Image X Size: {3}{6}Image Y Size: {4}{6}Spatial Context: {5}.
+ /// </summary>
+ internal static string FsPreview_RasterPropertyNodeTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_RasterPropertyNodeTooltip", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to SQL Server Spatial Feature Source.
/// </summary>
internal static string FsSqlServerSpatial {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-06-17 18:04:47 UTC (rev 5934)
@@ -1226,4 +1226,16 @@
<data name="ResourceDoesntExist" xml:space="preserve">
<value>Resource doesn't exist</value>
</data>
+ <data name="FsPreview_ClassNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{3}Description: {1}{3}Geometry Property: {2}</value>
+ </data>
+ <data name="FsPreview_DataPropertyNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{8}Description: {1}{8}Data Type: {2}{8}Nullable: {3}{8}Read Only: {4}{8}Length: {5}{8}Precision: {6}{8}Scale: {7}</value>
+ </data>
+ <data name="FsPreview_GeometryPropertyNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}</value>
+ </data>
+ <data name="FsPreview_RasterPropertyNodeTooltip" xml:space="preserve">
+ <value>Name: {0}{6}Description: {1}{6}Nullable: {2}{6}Image X Size: {3}{6}Image Y Size: {4}{6}Spatial Context: {5}</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs 2011-06-17 17:44:56 UTC (rev 5933)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/GeometricPropertyDefinition.cs 2011-06-17 18:04:47 UTC (rev 5934)
@@ -243,7 +243,7 @@
this.SpatialContextAssociation = (srs != null ? srs.Value : string.Empty);
- private string GeometryTypesToString()
+ public string GeometryTypesToString()
List<string> values = new List<string>();
var gts = GetIndividualGeometricTypes();
More information about the mapguide-commits
