[mapguide-commits] r5936 - in trunk/Tools/Maestro:
ExtendedModels/WatermarkDefinition-2.3.0
OSGeo.MapGuide.MaestroAPI/ObjectModels SDK
svn_mapguide at osgeo.org
Mon Jun 20 08:41:46 EDT 2011
Author: jng
Date: 2011-06-20 05:41:46 -0700 (Mon, 20 Jun 2011)
New Revision: 5936
Removed:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkImpl.cs
trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0/
trunk/Tools/Maestro/SDK/SDK.sln
Sync up SDK.sln
Property changes on: trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0
___________________________________________________________________
Added: svn:ignore
+ obj
Deleted: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkImpl.cs 2011-06-20 05:06:01 UTC (rev 5935)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkImpl.cs 2011-06-20 12:41:46 UTC (rev 5936)
@@ -1,260 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2011, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using System;
-using System.Collections.Generic;
-using System.Text;
-using OSGeo.MapGuide.ObjectModels.WatermarkDefinition;
-using System.Xml.Serialization;
-using OSGeo.MapGuide.MaestroAPI;
-using OSGeo.MapGuide.MaestroAPI.Resource;
-namespace OSGeo.MapGuide.ObjectModels.WatermarkDefinition_2_3_0
- partial class WatermarkDefinition : IWatermarkDefinition
- private static readonly Version RES_VERSION = new Version(2, 3, 0);
- [XmlIgnore]
- public ResourceTypes ResourceType
- get
- return ResourceTypes.WatermarkDefinition;
- [XmlIgnore]
- public Version ResourceVersion
- get
- return RES_VERSION;
- [XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")]
- public string ValidatingSchema
- get { return "WatermarkDefinition-2.3.0.xsd"; }
- set { }
- [XmlIgnore]
- public bool IsStronglyTyped
- get { return true; }
- [XmlIgnore]
- object IWatermarkDefinition.Content
- get
- throw new NotImplementedException();
- set
- [XmlIgnore]
- IWatermarkAppearance IWatermarkDefinition.Appearance
- get
- return this.Appearance;
- set
- this.Appearance = (WatermarkAppearanceType)value;
- [XmlIgnore]
- IPosition IWatermarkDefinition.Position
- get
- if (this.Position != null)
- return this.Position.Item;
- return null;
- set
- if (value != null)
- if (this.Position == null)
- this.Position = new WatermarkDefinitionTypePosition();
- this.Position.Item = (PositionType)value;
- [XmlIgnore]
- OSGeo.MapGuide.MaestroAPI.IServerConnection OSGeo.MapGuide.MaestroAPI.Resource.IResource.CurrentConnection
- get;
- set;
- private string _resId;
- [XmlIgnore]
- public string ResourceID
- get
- return _resId;
- set
- if (!ResourceIdentifier.Validate(value))
- throw new InvalidOperationException("Not a valid resource identifier"); //LOCALIZE
- var res = new ResourceIdentifier(value);
- if (res.Extension != ResourceTypes.WatermarkDefinition.ToString())
- throw new InvalidOperationException("Invalid resource identifier for this type of object: " + res.Extension); //LOCALIZE
- _resId = value;
- this.OnPropertyChanged("ResourceID");
- object ICloneable.Clone()
- return this.Clone();
- partial class WatermarkType : IWatermark
- [XmlIgnore]
- IWatermarkAppearance IWatermark.AppearanceOverride
- get
- return this.AppearanceOverride;
- set
- this.AppearanceOverride = (WatermarkAppearanceType)value;
- [XmlIgnore]
- IPosition IWatermark.PositionOverride
- get
- return this.PositionOverride.Item;
- set
- this.PositionOverride.Item = (PositionType)value;
- partial class WatermarkAppearanceType : IWatermarkAppearance { }
- partial class WatermarkTypePositionOverride { }
- partial class XYPositionType : IXYPosition
- [XmlIgnore]
- public override OSGeo.MapGuide.ObjectModels.WatermarkDefinition.PositionType Type
- get { return OSGeo.MapGuide.ObjectModels.WatermarkDefinition.PositionType.XY; }
- [XmlIgnore]
- IHorizontalPosition IXYPosition.XPosition
- get
- return this.XPosition;
- set
- this.XPosition = (HorizontalPositionType)value;
- [XmlIgnore]
- IVerticalPosition IXYPosition.YPosition
- get
- return this.YPosition;
- set
- this.YPosition = (VerticalPositionType)value;
- abstract partial class PositionType : IPosition
- [XmlIgnore]
- public abstract OSGeo.MapGuide.ObjectModels.WatermarkDefinition.PositionType Type { get; }
- partial class TilePositionType : ITilePosition
- [XmlIgnore]
- get { return OSGeo.MapGuide.ObjectModels.WatermarkDefinition.PositionType.Tile; ; }
- [XmlIgnore]
- IHorizontalPosition ITilePosition.HorizontalPosition
- get
- return this.HorizontalPosition;
- set
- this.HorizontalPosition = (HorizontalPositionType)value;
- [XmlIgnore]
- IVerticalPosition ITilePosition.VerticalPosition
- get
- return this.VerticalPosition;
- set
- this.VerticalPosition = (VerticalPositionType)value;
- partial class VerticalPositionType : IVerticalPosition { }
- partial class HorizontalPositionType : IHorizontalPosition { }
Modified: trunk/Tools/Maestro/SDK/SDK.sln
--- trunk/Tools/Maestro/SDK/SDK.sln 2011-06-20 05:06:01 UTC (rev 5935)
+++ trunk/Tools/Maestro/SDK/SDK.sln 2011-06-20 12:41:46 UTC (rev 5936)
@@ -1,6 +1,6 @@
Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual C# Express 2008
+# Visual Studio 2008
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI", "..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj", "{80FA3158-8B5F-48D1-A393-0378AFE48A7E}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI.Http", "..\OSGeo.MapGuide.MaestroAPI.Http\OSGeo.MapGuide.MaestroAPI.Http.csproj", "{6EF1E775-444B-4E5F-87FB-D687C43A68D7}"
@@ -39,6 +39,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0", "..\ExtendedModels\MapDefinition-2.3.0\OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0.csproj", "{C8DB3E77-3AF4-471D-A214-69DBEB32750E}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.ObjectModels.WatermarkDefinition-2.3.0", "..\ExtendedModels\WatermarkDefinition-2.3.0\OSGeo.MapGuide.ObjectModels.WatermarkDefinition-2.3.0.csproj", "{F84E21EE-360C-46EC-BD01-E66F8D9F5B3E}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -121,6 +123,10 @@
{C8DB3E77-3AF4-471D-A214-69DBEB32750E}.Debug|Any CPU.Build.0 = Debug|Any CPU
{C8DB3E77-3AF4-471D-A214-69DBEB32750E}.Release|Any CPU.ActiveCfg = Release|Any CPU
{C8DB3E77-3AF4-471D-A214-69DBEB32750E}.Release|Any CPU.Build.0 = Release|Any CPU
+ {F84E21EE-360C-46EC-BD01-E66F8D9F5B3E}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {F84E21EE-360C-46EC-BD01-E66F8D9F5B3E}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {F84E21EE-360C-46EC-BD01-E66F8D9F5B3E}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {F84E21EE-360C-46EC-BD01-E66F8D9F5B3E}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
More information about the mapguide-commits
