[mapguide-commits] r5937 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Wed Jun 22 08:18:32 EDT 2011
Author: jng
Date: 2011-06-22 05:18:32 -0700 (Wed, 22 Jun 2011)
New Revision: 5937
trunk/Tools/Maestro/Maestro.Base/UI/OutboundRequestViewer.cs
#1725: Disable listening for outbound requests if Outbound Requests UI is not visible.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/OutboundRequestViewer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/OutboundRequestViewer.cs 2011-06-20 12:41:46 UTC (rev 5936)
+++ trunk/Tools/Maestro/Maestro.Base/UI/OutboundRequestViewer.cs 2011-06-22 12:18:32 UTC (rev 5937)
@@ -28,6 +28,7 @@
using System.IO;
using ICSharpCode.Core;
using Maestro.Base.Services;
+using Maestro.Base.UI.Preferences;
namespace Maestro.Base.UI
@@ -38,17 +39,22 @@
InitializeComponent();
this.Title = this.Description = Properties.Resources.Content_OutboundRequests;
- var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
- connMgr.ConnectionAdded += (s, args) =>
+ //This is okay because changing the value requires a restart, so it will either be listening
+ //or not and that will remain in effect for the duration of the application running.
+ if (PropertyService.Get(ConfigProperties.ShowOutboundRequests, ConfigProperties.DefaultShowOutboundRequests))
- var conn = connMgr.GetConnection(args);
- conn.RequestDispatched += OnRequestDispatched;
- connMgr.ConnectionRemoving += (s, ce) =>
- var conn = connMgr.GetConnection(ce.ConnectionName);
- conn.RequestDispatched -= OnRequestDispatched;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ connMgr.ConnectionAdded += (s, args) =>
+ var conn = connMgr.GetConnection(args);
+ conn.RequestDispatched += OnRequestDispatched;
+ connMgr.ConnectionRemoving += (s, ce) =>
+ var conn = connMgr.GetConnection(ce.ConnectionName);
+ conn.RequestDispatched -= OnRequestDispatched;
protected override void OnLoad(EventArgs e)
More information about the mapguide-commits
