[mapguide-commits] r5574 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 1 07:05:09 EST 2011
Author: jng
Date: 2011-03-01 04:05:09 -0800 (Tue, 01 Mar 2011)
New Revision: 5574
   trunk/MgDev/Doc/devguide/source/conf.py
   trunk/MgDev/Doc/devguide/source/index.rst
   trunk/MgDev/Doc/devguide/source/introduction.rst
#1614: Add introduction chapter from original devguide with some .net and java samples (some samples are still missing equivalent .net and java examples)
Modified: trunk/MgDev/Doc/devguide/source/conf.py
--- trunk/MgDev/Doc/devguide/source/conf.py	2011-03-01 10:51:07 UTC (rev 5573)
+++ trunk/MgDev/Doc/devguide/source/conf.py	2011-03-01 12:05:09 UTC (rev 5574)
@@ -13,6 +13,10 @@
 import sys, os
+from sphinx.highlighting import lexers
+from pygments.lexers.web import PhpLexer
+lexers['php'] = PhpLexer(startinline=True)
 # If extensions (or modules to document with autodoc) are in another directory,
 # add these directories to sys.path here. If the directory is relative to the
 # documentation root, use os.path.abspath to make it absolute, like shown here.
Modified: trunk/MgDev/Doc/devguide/source/index.rst
--- trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 10:51:07 UTC (rev 5573)
+++ trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 12:05:09 UTC (rev 5574)
@@ -11,7 +11,7 @@
 .. toctree::
-   :maxdepth: 2
+   :maxdepth: 3
    introduction
    mapguide_ajax_viewer
Modified: trunk/MgDev/Doc/devguide/source/introduction.rst
--- trunk/MgDev/Doc/devguide/source/introduction.rst	2011-03-01 10:51:07 UTC (rev 5573)
+++ trunk/MgDev/Doc/devguide/source/introduction.rst	2011-03-01 12:05:09 UTC (rev 5574)
@@ -1,29 +1,628 @@
 .. index::
    single: introduction
 Introduction
 What This Guide Covers
+.. todo::
+    Update Web Studio references to MapGuide Maestro
+This guide describes how to use the MapGuide Open Source Web API and Viewer
+API.
+It assumes you have read the MapGuide Getting Started guide and are familiar
+with using Autodesk MapGuide or MapGuide Open Source Web Studio. Most
+examples also assume that you have installed the sample data and sample
+applications supplied with MapGuide.
+This guide provides a high-level overview of the APIs. More detailed information
+is provided in the on-line MapGuide Web API Reference and MapGuide Viewer API
+Reference.
 Essential Concepts
+.. todo::
+Refer to the MapGuide Getting Started guide for details about the MapGuide
+architecture and components. It is important to understand the relationship
+between a MapGuide Viewer, a MapGuide Web application, and the MapGuide
+site. It is also important to understand resources and repositories.
+Web applications reside on the Web Server. They are normally executed by
+requests from a MapGuide Viewer. They can in turn communicate with the
+MapGuide site and send data back to the Viewer.
+When you define a web layout, using Autodesk MapGuide or some other
+method, you also define toolbar and menu commands. These can be standard
+pre-defined Viewer commands like pan, zoom, and refresh, or they can be
+custom commands. Custom commands are a way of extending MapGuide to interact with your mapping data.
+The custom commands are HTML pages, generated on the server using PHP, ASP.NET, or Java (JSP). These languages
+can use the Web API to retrieve, manipulate, and update mapping data.
+The current version of MapGuide Open Source Web Studio does not create or
+edit web layouts. It is possible, however, to create and edit web layouts using
+the Mapagent HTML pages at
+http://ServerAddress/mapguide/mapagent/index.html. Get an existing web
+layout, such as the web layout supplied with the sample applications, using
+the GetResourceContent and GetResourceHeader links. Edit the XML in a text
+editor, then save to the site repository using the SetResource link.
+Many custom commands run in the task area, a section of the Viewer that is
+designed for user input/output. For more details about the task area and how
+it integrates with the rest of the Viewer, see The MapGuide Viewer on page
+15.
 Preparing to Run the Examples
+.. todo::
+MapGuide includes a set of sample applications. Some of them correspond
+directly to chapters in this Developer's Guide. These samples are designed to
+show one or two key concepts at a time.
+Other sample applications are more full-featured. These are designed to show
+some of the capabilities of MapGuide. They are not discussed in detail in this
+guide, but they do build upon the basic concepts.
+The sample applications are available on the installation CD. See the manual
+Installing Sample Data and Viewer Sample Application for details.
+Complete examples are available from http://mapguide.osgeo.org/downloads.html.
+There are two required components: the source code and a package file for
+creating the web layouts. The Sheboygan sample data must also be installed.
+.. note::
+   The Web API supports .NET, Java, and PHP. For simplicity, the examples in
+   this guide use PHP. However, many of the sample applications are available in all
+   development languages.
+   To run the examples on a Linux installation, change any Windows-specific
+   file paths to corresponding Linux paths.
+This guide includes many code snippets. In most cases, the snippets are
+incomplete, lacking initialization and error-checking. For more complete
+versions, refer to the sample applications.
+The sample applications also include links to the MapGuide documentation,
+but the links only work if the documentation files are visible to the web server.
+By default, the installation program installs the documentation in the
+...\WebServerExtensions\Help folder. If you copy or move the Help folder to
+...\WebServerExtensions\www\Help the documentation will be available directly
+from the main page of the sample applications.
 Application Development
+.. todo::
+    It seems Autodesk themselves were lost for words here. Talk about: Firebug, Visual Studio / Visual Web Developer, error and trace log monitoring
+Hints for debugging, etc.
+Making script frame visible to catch errors there
+Use Firefox because of DOM Inspector, Error console, Venckman,
+Reading Apache log for PHP errors. Is there an equivalent for IIS? Other sources
+of log information?
 Resources and Repositories
+.. todo::
+    Update with newer resource types
+A MapGuide repository is a database that stores and manages the data for the
+site. The repository stores all data except data that is stored in external
+databases. Data stored in a repository is a resource.
+Types of data stored in the repository:
+ * Feature data from SHP and SDF files
+ * Drawing data from DWF files
+ * Map symbols
+ * Layer definitions
+ * Map definitions
+ * Web layouts
+ * Connections to feature sources, including database credentials
+Library and Session
+Persistent data that is available to all users is stored in the Library repository.
+In addition, each session has its own repository, which stores the run-time
+map state. It can also be used to store other data, like temporary layers that
+apply only to an individual session. For example, a temporary layer might be
+used to overlay map symbols indicating places of interest.
+Data in a session repository is destroyed when the session ends.
+A resource identifier for a resource in the Library will always begin with
+``Library://``. For example:
+``Library://Samples/Layouts/SamplesPhp.WebLayout``
+A resource identifier for a session resource will always begin with ``Session:``,
+followed by the session id. For example:
+``Session:70ea89fe-0000-1000-8000-005056c00008_en//layer.LayerDefinition``
+Maps
+A map (``MgMap`` object) is created from a map definition resource. The map definition contains
+basic information about the map, including things like:
+ * the coordinate system used in the map
+ * the initial map extents
+ * references to the layer definitions for layers in the map
+When the ``MgMap`` object is created, it is initialized with data from the map
+definition. As a user interacts with the map, the ``MgMap`` may change, but the
+map definition does not.
+The map is saved in the session repository so it is available to all pages in the
+same session. You cannot save a map in the library repository.
+Map creation is handled by the Viewers. When a Viewer first loads, it creates
+a map in the session repository.
+The map name is taken from the map
+definition name. For example, if a web layout references a map definition
+named ``Sheboygan.MapDefinition``, then the Viewer will create a map named
+``Sheboygan.Map``.
+If your application does not use a Viewer, you can create the map and store
+it in the repository yourself. To do this, your page must
+ * Create an ``MgMap`` object.
+ * Initialize the ``MgMap`` object from a map definition.
+ * Assign a name to the ``MgMap`` object.
+ * Save the map in the session repository.
+For example, the following section of code creates an ``MgMap`` named ``Sheboygan.Map``, based on ``Sheboygan.MapDefinition``.
+PHP
+.. highlight:: php
+.. code-block:: php
+    $mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+    $map = new MgMap();
+    $mapName = $mapDefId->GetName();
+    $map->Create($resourceService, $mapDefId, $mapName);
+    $mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." . MgResourceType::Map);
+    $map->Save($resourceService, $mapId);
+.net (C#)
+.. highlight:: csharp
+.. code-block:: csharp
+    //Note: This code fragment assumes you have imported the OSGeo.MapGuide namespace
+    MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+    MgMap map = new MgMap();
+    String mapName = mapDefId.GetName();
+    map.Create(resourceService, mapDefId, mapName);
+    MgResourceIdentifier mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." + MgResourceType.Map);
+    map.Save(resourceService, mapId);
+Java
+.. highlight:: java
+.. code-block:: java
+    //Note: This code fragment assumes you have imported the org.osgeo.mapguide package
 Hello, Map - Displaying a Web Layout
+.. todo::
+   Remove references to DWF viewer. It is deprecated
+A web layout describes how the map looks when it is displayed in a web
+browser. Using Studio or some other method to edit the web layout resource,
+you can create and customize the layout, changing how it looks in a browser
+and what features are enabled.
+Displaying the web layout requires a compatible web browser and a MapGuide
+Viewer. There are two Viewers, depending on the needs of your site. The DWF
+Viewer runs as a control within the Internet Explorer browser. It requires that
+users install the Autodesk DWF Viewer.
+The AJAX Viewer does not require installing any additional software. It runs
+using most browsers, including Internet Explorer, Mozilla Firefox, and Safari.
+The simplest way to display a web layout is to pass its resource identifier as a
+GET parameter to the Viewer URL. For example, the following will display a
+web layout using the AJAX Viewer running on localhost:
+``http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSamples%2fLayouts%2fSample.WebLayout``
+**Authentication**
+All MapGuide sites require authentication with user id and password. If
+authentication succeeds, MapGuide creates a session, identified by a unique
+session id. This keeps the state consistent between the viewer and the server
+across multiple HTTP requests. Subsequent access to the site requires the
+session id instead of the user id. By default, the Viewer handles authentication
+itself, and it prompts for user id and password when it first loads. There are
+situations, though, where it is better to authenticate before loading the Viewer
+page.
+One common example is a site offering read-only access to visitors. For this
+situation, the default MapGuide installation includes a user ``Anonymous``
+with an empty password.
+To perform authentication before the Viewer loads, embed the Viewer in
+another page using a ``<frame>`` or ``<iframe>`` element. The outer page can do
+any necessary authentication, create a session, then pass the web layout and
+session id to the Viewer frame.
+The following example displays a web layout using the AJAX Viewer. It
+performs some basic initialization and creates a session, then displays a Viewer
+page using the session identifier and the web layout.
+PHP
+.. highlight:: php
+    <?php
+    $installDir =
+       'C:\\Program Files\\OSGeo\\MapGuide\\';
+    $extensionsDir = $installDir . 'Web\\www\\';
+    $viewerDir = $installDir . 'mapviewerphp\\';
+    include $viewerDir . 'constants.php';
+    MgInitializeWebTier($extensionsDir . 'webconfig.ini');
+    $site = new MgSite();
+    $site->Open(new MgUserInformation("Anonymous", ""));
+    $sessionId = $site->CreateSession();
+    $webLayout = "Library://Samples/Layouts/SamplesPhp.WebLayout";
+    <html>
+    <head>
+    <title>Simple Sample Application</title>
+    </head>
+    <body marginheight="0" marginwidth="0">
+    <iframe id="viewerFrame" width="100%" height="100%" frameborder=0
+    scrolling="no"
+    src="/mapguide/mapviewerajax/?SESSION=<?= $sessionId ?>&
+    WEBLAYOUT=<?= $webLayout ?>"></iframe>
+    </body>
+    </html>
+.net (C#)
+    Code sample coming soon!
+Java
 Hello, Map 2 - Adding a Custom Command
+Web layouts can include custom commands added to the toolbar, context
+menu, task list, or task pane area of the Viewer. These custom commands
+make up the MapGuide application.
+This next sample MapGuide page displays some basic information about a
+map. It does not do any complicated processing. Its purpose is to illustrate
+the steps required to create a MapGuide page and have it connect to a Viewer
+on one side and the MapGuide site on the other.
+Web Layouts and MapGuide Server Pages
+.. todo::
+A *MapGuide Server Page* is any PHP, ASP.NET, or JSP page that makes use of the
+MapGuide Web API. These pages are typically invoked by the MapGuide
+Viewer or browser and when processed result in HTML pages that are loaded
+into a MapGuide Viewer or browser frame. This is the form that will be used
+for most examples in this guide. It is possible, however, to create pages that
+do not return HTML or interact with the Viewer at all. These can be used for
+creating web services as a back-end to another mapping client or for batch
+processing of your data.
+Creating a MapGuide page requires initial setup, to make the proper
+connections between the Viewer, the page, and the MapGuide site. Much of
+this can be done using . Refer to the *MapGuide Studio Help* for details.
+One part of the initial setup is creating a web layout, which defines the
+appearance and available functions for the Viewer. When you define a web
+layout, you assign it a resource name that describes its location in the
+repository. The full resource name looks something like this:
+When you open the web layout using a browser with either the AJAX Viewer
+or the DWF Viewer, the resource name is passed as part of the Viewer URL.
+Special characters in the resource name are URL-encoded, so the full URL
+would look something like this, (with line breaks removed):
+``http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganPhp.WebLayout``
+Part of the web layout defines commands and the toolbars and menus that
+contain the commands. These commands can be built-in commands, or they
+can be URLs to custom pages. The web layout also includes a URL to a home
+task that displays in the task pane. The home task can open other pages.
+To create a new page and make it available as a command from the task list,
+do the following:
+ * Edit the web layout using Studio or Maestro
+ * Add a command to the web layout.
+ * Set the command type to Invoke URL.
+ * Set the URL of the command to the URL of your page
+ * Add the command to the Task Bar Menu.
+.. note::
+    Custom pages are loaded by the Viewer page, so a relative URL for a custom
+    page must start at the Viewer directory, then go up one level to reach the ``mapguide``
+    directory. For example, a custom page located at ``www/mapguide/samplesphp/index.php``
+    would use the following relative URL in the web layout
+    ``../samplesphp/index.php``
+It is also possible to add custom commands to the toolbar and the context
+menu using the same technique.
+For most of the examples in this guide, however, the pages will be links from
+a home page loaded in the task pane frame.
+.. note::
+    Installing the package that comes with the Developer's Guide samples
+    creates a web layout automatically. The home task page of this layout contains
+    links to examples that correspond to chapters in the Developer's Guide.
+MapGuide Page Flow
+Most MapGuide pages follow a similar processing flow. First, they create a
+connection with the site server using an existing session id. Then they open
+connections to any needed site services. The exact services required depend
+on the page function. For example, a page that deals with map feature data
+requires a feature service connection.
+Once the site connection and any other service connections are open, the
+page can use MapGuide Web API calls to retrieve and process data. Output
+goes to the task pane or back to the Viewer. See The MapGuide Viewer on
+page 15 for details about sending data to the Viewer.
+.. note::
+    MapGuide pages written in PHP require one additional step because PHP
+    does not support enumerations compiled into extensions. To deal with this
+    limitation, PHP Web Extension pages must include constants.php, which is in
+    the mapviewerphp folder. This is not required for ASP.NET or JSP pages.
+Example Code
+The following sample illustrates basic page structure. It is designed to be called
+as a task from a Viewer. It connects to a MapGuide server and displays the
+map name and spatial reference system for the map currently being displayed
+in the Viewer.
+.. note::
+    This sample is very similar to the ``Hello Map`` sample in the Developer's Guide
+    samples.
+PHP
+.. highlight:: php
+    <html>
+        <head><title>Hello, map</title></head>
+        <body>
+            <p>
+            <?php
+            // Define some common locations
+            $installDir ='C:\\Program Files\\OSGeo\\MapGuide\\';
+            $extensionsDir = $installDir . 'WebServerExtensions\www\\';
+            $viewerDir = $extensionsDir . 'mapviewerphp\\';
+            // constants.php is required to set some enumerations
+            // for PHP. The same step is not required for .NET
+            // or Java applications.
+            try
+                // Get the session information passed from the viewer.
+                $args = ($_SERVER['REQUEST_METHOD'] == "POST")
+                ? $_POST : $_GET;
+                $mgSessionId = $args['SESSION']
+                $mgMapName = $args['MAPNAME']
+                // Basic initialization needs to be done every time.
+                MgInitializeWebTier("$extensionsDir\webconfig.ini");
+                // Get the user information using the session id,
+                // and set up a connection to the site server.
+                $userInfo = new MgUserInformation($mgSessionId);
+                $siteConnection = new MgSiteConnection();
+                $siteConnection->Open($userInfo);
+                // Get an instance of the required service(s).
+                $resourceService = $siteConnection->
+                CreateService(MgServiceType::ResourceService);
+                // Display the spatial reference system used for the map.
+                $map->Open($resourceService, $mgMapName);
+                $srs = $map->GetMapSRS();
+                echo 'Map <strong>' . $map->GetName() .
+                '</strong> uses this reference system: <br />' . $srs;
+            catch (MgException $e)
+                echo "ERROR: " . $e->GetMessage() . "<br />";
+                echo $e->GetStackTrace() . "<br />";
+            </p>
+        </body>
+    </html>
+.net (C#)
+Java
+How This Page Works
+This example page performs the following operations:
+**1. Get session information.**
+When you first go to the URL containing the web layout, the Viewer
+initiates a new session. It prompts for a user id and password, and uses
+these to validate with the site server. If the user id and password are valid,
+the site server creates a session and sends the session id back to the viewer.
+The Viewer passes the session information every time it sends a request
+to a MapGuide page. The pages use this information to re-establish a
+session.
+**2. Perform basic initialization.**
+The webconfig.ini file contains parameters required to connect to the site
+server, including the IP address and port numbers to use for
+communication. ``MgInitializeWebTier()`` reads the file and gets the
+necessary values to find the site server and create a connection.
+**3. Get user information.**
+The site server saves the user credentials along with other session
+information. These credentials must be supplied when the user first
+connects to the site. At that time, the Viewer authenticates the user and
+creates a new session using the credentials. Using the session ID, other
+pages can get an encrypted copy of the user credentials that can be used
+for authentication.
+**4. Create a site connection.**
+Any MapGuide pages require a connection to a site server, which manages
+the repository and site services.
+**5. Create a connection to a resource service.**
+Access to resources is handled by a resource service. In this case, the page
+needs a resource service in order to retrieve information about the map
+resource. You may need to create connections to other services, depending on the
+needs of your application.
+**6. Retrieve map details.**
+The map name is also passed by the viewer to the MapGuide page. Use
+this name to open a particular map resource with the resource service.
+Once the map is open you can get other information. This example
+displays the spatial reference system used by the map, but you can also
+get more complex information about the layers that make up the map.
+.. note::
+    The ``MgInitializeWebTier`` function always needs to be called before you create a site connection and
+    create service connections.
+    However, this function does not need to be called if you are only using the
+    Geometry and Coordinate System components of the MapGuide API
 Understanding Services
\ No newline at end of file
+The MapGuide site performs many different functions. These can be all done
+by a single server, or you may balance the load across multiple servers. Some
+essential functions must execute on the site server, while other functions may
+execute on support servers.
+A service performs a particular set of related functions. For example, a resource
+service manages data in the repository, a feature service provides access to
+feature data sources, and a mapping service provides visualization and plotting
+functions.
+Before a page can use a service, it must open a site connection and create an
+instance of the necessary service type. The following example creates a resource
+service and a feature service:
+PHP
+.. highlight:: php
+    $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
+    $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
+.net (C#)
+    MgUserInformation userInfo = new MgUserInformation(mgSessionId);
+    MgSiteConnection siteConnection = new MgSiteConnection();
+    siteConnection.Open(userInfo);
+    MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+    MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+Java
More information about the mapguide-commits mailing list
