[mapguide-commits] r5575 - in trunk/MgDev/Doc/devguide/source: . images
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 1 08:01:11 EST 2011
Author: jng
Date: 2011-03-01 05:01:11 -0800 (Tue, 01 Mar 2011)
New Revision: 5575
Added:
   trunk/MgDev/Doc/devguide/source/images/ajaxviewer.png
   trunk/MgDev/Doc/devguide/source/images/frame_structure.png
   trunk/MgDev/Doc/devguide/source/introduction.rst
   trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst
#1614: Add "The MapGuide Viewer" chapter from original devguide (renamed "The MapGuide AJAX Viewer" to differentiate from the fusion-related topics planned) with some .net and java samples (some samples are still missing equivalent .net and java examples)
Added: trunk/MgDev/Doc/devguide/source/images/ajaxviewer.png
(Binary files differ)
Property changes on: trunk/MgDev/Doc/devguide/source/images/ajaxviewer.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/MgDev/Doc/devguide/source/images/frame_structure.png
Property changes on: trunk/MgDev/Doc/devguide/source/images/frame_structure.png
Modified: trunk/MgDev/Doc/devguide/source/introduction.rst
--- trunk/MgDev/Doc/devguide/source/introduction.rst	2011-03-01 12:05:09 UTC (rev 5574)
+++ trunk/MgDev/Doc/devguide/source/introduction.rst	2011-03-01 13:01:11 UTC (rev 5575)
@@ -189,7 +189,7 @@
 For example, the following section of code creates an ``MgMap`` named ``Sheboygan.Map``, based on ``Sheboygan.MapDefinition``.
-PHP
+**PHP**
 .. highlight:: php
 .. code-block:: php
@@ -201,7 +201,7 @@
     $mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." . MgResourceType::Map);
     $map->Save($resourceService, $mapId);
-.net (C#)
+**.net (C#)**
 .. highlight:: csharp
 .. code-block:: csharp
@@ -215,7 +215,7 @@
     MgResourceIdentifier mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." + MgResourceType.Map);
     map.Save(resourceService, mapId);
-Java
+**Java**
 .. highlight:: java
 .. code-block:: java
@@ -278,7 +278,7 @@
 performs some basic initialization and creates a session, then displays a Viewer
 page using the session identifier and the web layout.
-PHP
+**PHP**
 .. highlight:: php
 .. code-block:: php
@@ -314,14 +314,14 @@
     </body>
     </html>
-.net (C#)
+**.net (C#)**
     Code sample coming soon!
-Java
+**Java**
 .. highlight:: java
@@ -441,7 +441,7 @@
     This sample is very similar to the ``Hello Map`` sample in the Developer's Guide
     samples.
-PHP
+**PHP**
 .. highlight:: php
 .. code-block:: php
@@ -500,14 +500,14 @@
         </body>
     </html>
-.net (C#)
+**.net (C#)**
-Java
+**Java**
 .. highlight:: java
@@ -590,7 +590,7 @@
 instance of the necessary service type. The following example creates a resource
 service and a feature service:
-PHP
+**PHP**
 .. highlight:: php
 .. code-block:: php
@@ -601,7 +601,7 @@
     $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
     $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
-.net (C#)
+**.net (C#)**
@@ -614,7 +614,7 @@
     MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
     MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
-Java
+**Java**
 .. highlight:: java
Modified: trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst
--- trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst	2011-03-01 12:05:09 UTC (rev 5574)
+++ trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst	2011-03-01 13:01:11 UTC (rev 5575)
@@ -7,11 +7,467 @@
 Introduction
+.. todo::
+    Remove reference to DWF viewer. It is deprecated
+.. note::
+    The *Hello Viewer* sample, in the Developer's Guide samples, demonstrates
+    concepts from this chapter.
+The MapGuide Viewer is a browser-based method for displaying map data in a
+MapGuide application. It is a complete application, with support for standard
+mapping functionality like zooming, theming, and selecting features. There are
+two different versions of the Viewer:
+ * DWF Viewer, which runs only within Internet Explorer, and requires a browser plug-in
+ * AJAX Viewer, which runs within Internet Explorer, Mozilla Firefox, and Safari, without requiring a browser plug-in
+As much as possible, the two versions of the Viewer operate in the same way,
+so deciding which to use depends on the needs of the application. If all the end
+users of the application use Internet Explorer, the DWF Viewer my be an
+appropriate choice, but if some of them use a different browser the AJAX Viewer
+is a better choice.
+Most MapGuide applications use a Viewer, though it is possible to create
+applications that perform data analysis or manipulation but do not display
+using the Viewer. For example, a MapGuide application can be used as a back-end
+to another mapping application.
+The standard Viewer displays a map along with the following optional
+components surrounding the map:
+ * Tool bar
+ * Layers pane
+ * Properties pane
+ * Status bar
+ * Task bar
+ * Task list (normally hidden, but available as a drop-down from the task bar)
+ * Task pane
+ * Context (right-click) menu
+ * Zoom slider (AJAX Viewer only)
+**MapGuide Viewer**
+.. image:: images/ajaxviewer.png
+The tool bar, task list, task pane, and context menu can contain a combination
+of pre-defined and custom MapGuide commands.
+A *web layout* defines how the Viewer looks and operates for a map. One
+function of a web layout is to define which optional components display with
+the map. All of the optional components can be disabled, leaving just the
+map itself.
+The web layout also defines any custom functionality added to the web page
+through custom commands.
+Custom Commands
+Custom commands can be of two types:
+ * JavaScript commands
+ * Web Server Extensions pages, written in PHP, ASP.NET, or JSP
+JavaScript commands are defined in the web layout as commands of type
+Invoke Script. They are used primarily to interact with the Viewer, and can
+use the Viewer API.
+Web Server Extensions pages can be added to the web layout in two different
+ways. In one method, the web layout includes a home page. This home page
+is loaded in the task pane when the map first displays, and can be re-loaded
+by clicking the Home icon in the task bar. The home page can load other
+pages as needed.
+In addition, other task pages can be defined in the web layout as commands
+of type Invoke URL. These commands can be added to the tool bar, task list,
+or context menu. When a user selects one of these commands the
+corresponding URL is often loaded into the task pane, though it can also be
+loaded into a hidden frame so it is not visible.
+Because Web Server Extensions pages are created at the web tier before being
+passed to the Viewer, they can use both the Web Server Extensions API and
+the Viewer API.
 Understanding Viewer Frames
+The MapGuide Viewers use HTML frames to divide the viewer area. Refer to
+the diagram below for the locations of the following frames and frame sets:
+| Name                   | Description                                                  |
+|                        | Unnamed. Contains all the Viewer frames. This can be wrapped |
+|                        | by an outer frame so you can embed the Viewer in your own    |
+|                        | site.                                                        |
+| maparea                | Frame set containing the tool bar, map frame, form frame,    |
+|                        | andscript frame.                                             |
+| tbFrame                | Frame containing the tool bar. Add new commands to the tool  |
+|                        | bar by modifying the web layout.                             |
+| mapFrame               | Frame containing the map data. This includes the map display |
+|                        | and the layers and properties palettes.                      |
+| formFrame              | Hidden frame that can be used to generate HTTP POST requests |
+|                        | for sending data to the server.                              |
+| scriptFrame            | Hidden frame that can be used to load and execute pages      |
+|                        | out them being visible to the user. This is often used for   |
+|                        | executing client-side JavaScript.                            |
+| taskArea               | Frame set containing the task bar and the task frame.        |
+| taskBar                | Frame containing the task bar                                |
+| taskFrame              | Frame used to hold the task list frame and the task pane     |
+|                        | frame                                                        |
+| taskListFrame          | Frame used for displaying the task list. This is normally    |
+|                        | hidden, and is shown when a user clicks the task list button |
+|                        | in the task bar. Add new commands to the task list by        |
+|                        | modifying the web layout.                                    |
+| taskPaneFrame          | Frame used for displaying and executing MapGuide pages. A    |
+|                        | web layout has a default home page that displays in the task |
+|                        | pane when the layout loads. Custom commands of type Invoke   |
+|                        | URL also load in the task pane.                              |
+| sbFrame                | Frame containing the status bar.                             |
+.. image:: images/frame_structure.png
 MapGuide Viewer API
+The MapGuide Viewer API is a set of JavaScript functions used to interact with
+the Viewer. Many of the Viewer frames contain embedded JavaScript functions
+that can be called from other locations. For full details about the available
+functions, refer to the online *MapGuide Viewer API Reference*.
+To execute any of the Viewer API functions, call them from JavaScript
+embedded in a page. There are three common techniques for this:
+ * Define an Invoke Script command in the web layout. Use this technique when you want to call the Viewer API directly from the tool bar, task list, or context menu.
+ * Load a page into the hidden script frame and execute the script when the page loads. Use this technique when you want the Viewer to change as a result of an action in the MapGuide page, without reloading the page.
+ * Execute the JavaScript call from a page loaded in the task pane frame. The JavaScript can execute when the page first loads or as a result of user interaction.
+It is important to know the relationships between the frames. JavaScript
+executes in the context of a single frame, but it can call functions from other
+frames by locating them in the frame hierarchy. The following frames are
+children of the main Viewer frame:
+ * tbFrame
+ * mapFrame
+ * formFrame
+ * scriptFrame
+ * taskFrame
+The ``taskPaneFrame`` is a child of the taskFrame.
+Custom JavaScript code can execute in the context of the main frame, the
+script frame, or the task pane frame.
+JavaScript defined as an Invoke Script command executes in the context of
+the main frame. To execute functions in one of the other frames, identify the
+function with the frame name and function name. For example, the following
+calls the ``ZoomToView()`` function of the mapFrame from the main frame:
+.. highlight:: javascript
+.. code-block:: javascript
+    mapFrame.ZoomToView(xLoc, yLoc, newScale, true);
+JavaScript loaded into the ``scriptFrame`` must go up 1 level in the hierarchy
+using parent. For example:
+    parent.mapFrame.ZoomToView(xLoc, yLoc, newScale, true);
+JavaScript loaded into the ``taskPaneFrame`` must go up 2 levels in the hierarchy
+using ``parent.parent``. For example:
+    parent.parent.mapFrame.ZoomToView(xLoc, yLoc, newScale, true);
+Many Viewer API calls will generate requests to the site server, either to refresh
+data in the Viewer or to notify the site server of a change in Viewer state.
+These requests are generated automatically.
+Calling the Viewer API with an Invoke Script Command
+Use this technique when you want to call the API directly from the tool bar,
+task list, or context menu.
+For example, you may want to create a tool bar button that zooms and
+positions the map to show a particular location. In the web layout, create a
+command of type Invoke Script. Enter the API call as the script to invoke:
+    ZoomToView(-87.7116768, 43.7766789973, 5000, true);
+Add the button to the tool bar. When a user clicks the button, the map view
+repositions to the location.
+Commands of type Invoke Script always execute in the context of the main
+frame. This means that all main frame functions are available. To execute a
+function in another frame, use the frame name as part of the function name.
+For example, ``formFrame.Submit()``.
+Calling the Viewer API from the Script Frame
+Use this technique when you want the Viewer API calls to be made as a result
+of an action in the calling page, but you do not want to reload the page. For
+example, you may have a page that generates a list of locations and you would
+like the user to be able to jump directly to any location, while leaving the list
+still available in the task pane.
+In this case, your page can load another page in the hidden script frame, using
+``target="scriptFrame"`` as part of the ``<a>`` tag. This requires creating a separate
+page to load in the script frame and passing the necessary parameters when
+the page loads.
+The Hello Viewer sample application contains a file named ``gotopoint.php``
+that is designed to run in the script frame. The ``<body>`` element is empty, so
+the page does not produce any output. Instead, it emits a JavaScript function
+to execute when the page loads. This function calls the ``ZoomToView()`` function
+in the Viewer API. The essential parts of ``gotopoint.php`` are:
+**PHP (gotopoint.php)**
+.. highlight:: php
+.. code-block:: php
+    <script language="javascript">
+    function OnPageLoad()
+        parent.ZoomToView(
+            <?= $_GET['X'] ?>,
+            <?= $_GET['Y'] ?>,
+            <?= $_GET['Scale'] ?>,
+            true);
+    </script>
+    <body onLoad="OnPageLoad()">
+    </body>
+**.net (gotopoint.aspx)**
+.. highlight:: csharp
+.. code-block:: csharp
+    Code sample coming soon!
+**Java (gotopoint.jsp)**
+To execute ``gotopoint.php`` from the task frame, insert code similar to the
+following:
+**PHP**
+.. highlight:: php
+    $xLocation = -87.7116768; // Or calculate values
+    $yLocation = 43.7766789973;
+    $mapScale = 2000;
+    echo "<p><a href=\"gotopoint.php?" .
+    "X=$xLocation&Y=$yLocation&Scale=$mapScale\"" .
+    "target=\"scriptFrame\">Click to position map</a></p>";
+**.net**
+**Java**
+.. note::
+    This technique is also appropriate for calling the Web API without reloading the task pane. See the Modifying Maps and Layers sample for an example.
+Calling the Viewer API from the Task Pane
+Use this technique when you want the Viewer API calls to be made when the
+page loads or as a result of an ``onclick`` event. For example, if you have a task
+in the task list that zooms the map to a pre-defined location, then you do not
+need any user input. The Viewer should zoom as soon as the page loads.
+The map frame contains a JavaScript function to center the map to a given
+coordinate at a given map scale. To call this function from a page loading in the task pane,
+create a function that will be executed when the ``onLoad`` event occurs. The following is a simple
+example. If you add this to the task list and select the task, the displayed map will reposition to the given location.
+.. highlight:: html
+.. code-block:: html
+    <html>
+    <head>
+    <title>Viewer Sample Application - Zoom</title>
+    </head>
+            parent.parent.ZoomToView(-87.7116768, 43.7766789973, 5000, true);
+    </script>
+    <h1>Zooming...</h1>
+    </body>
+    </html>
+Use a similar technique to call custom JavaScript based on an action in the
+task pane, like clicking a link.
+Extending Map Initialization Functionality
+.. todo::
+    There are initialization code samples in the wiki that are useful here
+At times, it may be necessary to perform some initialization functions when
+the map first loads. To accomplish this, a page loaded into the task pane can
+hook into the standard map initialization process.
+For example, when a browser first connects to a MapGuide site, it specifies a
+web layout. The site uses this layout to determine which Viewer components
+to enable and which map to display in the map area. At the time that the task
+pane first loads, the map name is not yet known. It may be required for some
+operations, though.
+The Hello Viewer Sample
+The Hello Viewer sample, installed with the Developer's Guide samples, shows
+simple examples of using the Viewer API from different parts of a web layout.
+The tool bar for the sample contains a custom Invoke Script command that
+calls the ``ZoomToView()`` function of the ``mapFrame``. This is executed in the context
+of the main frame, so the function is available using
+    mapFrame.ZoomToView()
+The task pane loads a page that shows two other ways of calling ``ZoomToView()``.
+One way loads a custom page into the hidden ``scriptFrame``. The page reads
+``GET`` parameters and passes them to the JavaScript function call. This is executed
+in the context of the ``scriptFrame``, so ``ZoomToView()`` is available using
+    parent.mapFrame.ZoomToView()
+Another way calls ``ZoomToView()`` directly when a link is clicked, using the
+JavaScript ``onclick`` event. This is executed in the context of the ``taskPaneFrame``,
+so ``ZoomToView()`` is available using
+    parent.parent.mapFrame.ZoomToView()
+The Developer's Guide samples also demonstrate a more advanced method
+for using JavaScript in a Viewer. The file *index.php* includes an external
+JavaScript file that solves 2 problems:
+ * When a map is first loading, the task pane displays before the map has been fully initialized. This can cause problems if users click any links in the task pane that depend on the map being available.
+ * The first time the Viewer loads a page into the task pane, it passes ``SESSION`` and ``WEBLAYOUT`` as ``GET`` parameters. The map name is not known until after the web layout has loaded. When a user clicks the Home button, the Viewer reloads the home page in the task pane, but passes ``SESSION`` and ``MAPNAME`` as ``GET`` parameters instead. In some cases, it may be useful for the home page to have the map name when it first loads.
+To deal with these problems, the Hello Viewer sample loads ``pageLoadFunctions.js``, which attaches a function
+to the ``window.onload`` event of the page in the task pane. This function does the following:
+ * Replaces the ``OnMapLoaded()`` function of the main frame. This function is called after the map has been fully initialized. The new version performs some initialization (see below), then calls the original ``OnMapLoaded()``.
+ * Saves the contents of the task pane page and replaces it with the text "Loading...".
+ * After the map is fully initialized, it calls the new version of ``OnMapLoaded()``. At this point, the map name is known, and is available from the ``mapFrame.GetMapName()`` function. The new version of ``OnMapLoaded()`` restores the contents of the task pane page, then it searches all ``<a>`` elements, replacing "``MAPNAME=unknown``" with the correct map name in the ``href`` attributes.
+See the Hello Viewer sample for links to view *index.php* and *pageLoadFuctions.js*.
 Embedding a Viewer in Your Own Page
\ No newline at end of file
+The simplest way to incorporate a MapGuide Viewer into your own site is to
+create a frame set that contains a frame for your own page layout and a frame
+for the Viewer. The Developer's Guide samples use this technique. The main
+page for the samples, *main.php*, creates a frame set where the top frame in the
+set contains a site-specific page header, and the bottom frame in the set
+contains the embedded Viewer. The following code contains the important
+parts of *main.php*.
+**PHP**
+.. highlight:: php
+    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN"
+    "http://www.w3.org/TR/html4/frameset.dtd">
+    <?php
+    require_once('common/common.php');
+    try
+        // Initialize the web extensions,
+        MgInitializeWebTier ($webconfigFilePath);
+        // Connect to the site server and create a session
+        $userInfo = new MgUserInformation("Author", "author");
+        $site = new MgSite();
+        $site->Open($userInfo);
+    catch (MgException $e)
+        echo "Could not connect to the MapGuide site server.";
+        die();
+    try
+        $sessionId = $site->CreateSession();
+        // Define some constants
+        $webLayout = "Library://Samples/Layouts/SamplesPHP.WebLayout";
+        $title = "Samples";
+        echo "ERROR: " . $e->GetMessage("eng") . "\n";
+        echo $e->GetStackTrace("eng") . "\n";
+    <html>
+        <head>
+            <title><?= $title ?></title>
+        </head>
+        <frameset rows="110,*">
+            <frame src="common/Title.php?TitleText=<?= $title ?>" name="TitleFrame" scrolling="NO" noresize />
+            <frame src="/mapguide/mapviewerajax/?SESSION=<?= $sessionId ?>&WEBLAYOUT=<?= $webLayout ?>" name="ViewerFrame" />
+        </frameset>
+    </html>
More information about the mapguide-commits mailing list
