[mapguide-commits] r5576 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Mar 1 08:27:46 EST 2011
Author: jng
Date: 2011-03-01 05:27:45 -0800 (Tue, 01 Mar 2011)
New Revision: 5576
   trunk/MgDev/Doc/devguide/source/analyzing_features.rst
   trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst
   trunk/MgDev/Doc/devguide/source/index.rst
   trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst
   trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst
   trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst
   trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst
   trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst
#1614: Flesh the outline of the remaining devguide content
Modified: trunk/MgDev/Doc/devguide/source/analyzing_features.rst
--- trunk/MgDev/Doc/devguide/source/analyzing_features.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/analyzing_features.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -10,6 +10,12 @@
 Representations of Geometry
+Geometry Objects
+Comparing Geometry Objects
 Coordinate Systems
@@ -19,6 +25,9 @@
 Temporary Feature Sources
+Inserting, Deleting and Updating Features
 Creating a Buffer
Modified: trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst
--- trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/digitizing_and_redlining.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -11,4 +11,13 @@
 Redlining
\ No newline at end of file
+Passing Coordinates
+Creating a Feature Source
+Create a Layer
Modified: trunk/MgDev/Doc/devguide/source/index.rst
--- trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/index.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -11,7 +11,7 @@
 .. toctree::
-   :maxdepth: 3
+   :maxdepth: 4
    introduction
Modified: trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst
--- trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -7,8 +7,38 @@
 Overview of Layers
+Basic Layer Properties
+Layer Groups
+Base Layer Groups
+Layer Style
+Layer Visibility
+Example: Actual Visibility
 Enumerating Map Layers
+Example
 Manipulating Layers
+Changing Basic Properties
+Example
+Changing Visibility
Modified: trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst
--- trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/mapguide_advanced.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -21,5 +21,8 @@
 Quering Data with Expressions and Filters
+Relationship to FDO
 The Geospatial Platform and MapGuide's role in it
Modified: trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst
--- trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/mapguide_ajax_viewer.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -10,7 +10,7 @@
 .. todo::
     Remove reference to DWF viewer. It is deprecated
-.. note::
+.. tip::
     The *Hello Viewer* sample, in the Developer's Guide samples, demonstrates
     concepts from this chapter.
Modified: trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst
--- trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -16,6 +16,15 @@
 Another Way to Create Layers
+Example: Creating a layer that users Area Rules
+Example: Using Line Rules
+Example: Using Point Rules
 Adding Layers to a Map
Modified: trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst
--- trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst	2011-03-01 13:01:11 UTC (rev 5575)
+++ trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst	2011-03-01 13:27:45 UTC (rev 5576)
@@ -10,5 +10,47 @@
 Querying Feature Data
+Feature Readers
+Selecting with the Web API
+Basic Filters
+Spatial Filters
+Example: Selection
 Active Selections
+Selecting with the Viewer
+Passing Viewer Information to the Web Server
+Additional Parameters to an Invoke URL Command
+Passing Parameters from an Invoke Script Command
+Passing Parameters from the Task Pane frame
+Working with the Active Selection
+Example: Listing Selected Parcels
+Setting the Active Selection with the Web API
+Example: Setting the Active Selection
More information about the mapguide-commits mailing list
