[mapguide-commits] r5582 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 2 06:08:18 EST 2011
Author: jng
Date: 2011-03-02 03:08:18 -0800 (Wed, 02 Mar 2011)
New Revision: 5582
   trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst
#1614: Commit current work on devguide chapter "Working with feature data"
Modified: trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst
--- trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst	2011-03-02 07:10:46 UTC (rev 5581)
+++ trunk/MgDev/Doc/devguide/source/working_with_feature_data.rst	2011-03-02 11:08:18 UTC (rev 5582)
@@ -4,27 +4,392 @@
 Working With Feature Data
-Overivew of Features
+Overview of Features
+.. note::
+    The Working With Feature Data sample, in the Developer's Guide samples,
+    demonstrates concepts from this chapter.
+Understanding features is fundamental to being able to use the MapGuide Web
+API. Nearly every application will need to interact with feature data in one form
+or another.
+*Features* are map objects representing items like roads (polylines), lakes
+(polygons), or locations (points).
+A *feature source* is a resource that contains a set of related features, stored in a
+file or database. Some common feature source types are SDF files, SHP files, or
+data in a spatial database.
+For example, you may have a feature source that contains data for roads. Feature
+sources can be stored in the library repository or in a session repository. A feature
+source identifier describes a complete path in the repository. For example,
+``Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource``
+Within a single feature source there may be one or more *feature classes*. A feature
+class describes a subset of the features in the feature source. In many cases, there
+is one feature class for each feature source. For example, there may be a Roads
+feature class in the RoadCenterLines feature source.
+A feature class contains one or more features. Each feature has a geometry that
+defines the spatial representation of the feature. Features will also generally
+have one or more properties that provide additional information. For example,
+a feature class containing road data may have properties for the road name
+and the number of lanes. Feature properties can be of different types, like
+strings, integers, and floating point numbers. Possible types are defined in the
+class ``MgPropertyType``.
+In some cases, a feature property will be another feature. For example, a Roads
+feature might have a Sidewalk feature as one of its properties.
+A map layer may contain the features from a feature class. The features are
+rendered using the feature geometry.
+The Web API Feature Service provides functions for querying and updating
+feature data.
 Querying Feature Data
+In order to work with feature data, you must first select the features you are
+interested in. This can be done with the Viewer or through Web API calls.
 Feature Readers
+.. todo::
+    Update page number reference with section link
+A *feature reader*, represented by an ``MgFeatureReader`` object, is used to iterate
+through a list of features. Typically, the feature reader is created by selecting
+features from a feature source.
+To create a feature reader, use the ``MgFeatureService::SelectFeatures()``
+method. See Selecting with the Web API on page 39 for details about selection.
+To process the features in a feature reader, use the
+``MgFeatureReader::ReadNext()`` method. You must call this method before
+being able to read the first feature. Continue calling the method to process
+the rest of the features.
+The ``MgFeatureReader::GetPropertyCount()`` method returns the number of
+properties available for the current feature. When you know the name and
+type of the feature property, call one of the ``MgFeatureReader::GetPropertyType()``
+methods (where PropertyType represents one of the available types) to retrieve the value.
+Otherwise, call ``MgFeatureReader::GetPropertyName()`` and
+``MgFeatureReader::GetPropertyType()`` before retrieving the value.
+.. note::
+    You should always call ``Close()`` on your ``MgFeatureReader`` objects (or any object derived from ``MgReader`` for that matter)
+    as memory leaks can happen because of unclosed reader objects. Another common pitfall is the ``Close()`` call not being called because
+    the code before it threw an exception. For .net and Java, you can use the a ``try...finally`` block
+    to ensure your reader will always be closed regardless of whether exceptions have been thrown or not.
+.. note::
+    Always check if the property whose value you are trying to retrive is null using the ``IsNull()`` method before attempting to access the property value.
+    Attempting to access a null property value will cause the reader to throw a ``MgNullPropertyValueException``
+Selections can be created programatically with the Web API. This is done by
+querying data in a feature source, creating a feature reader that contains the
+features, then converting the feature reader to a selection (``MgSelection`` object).
+To create a feature reader, apply a selection filter to a feature class in the feature
+source. A selection filter can be a basic filter, a spatial filter, or a combination
+of the two. The filter is stored in an ``MgFeatureQueryOptions`` object.
+Basic filters are used to select features based on the values of feature properties.
+For example, you could use a basic filter to select all roads that have four or
+more lanes.
+Spatial filters are used to select features based on their geometry. For example,
+you could use a spatial filter to select all roads that intersect a certain area.
 Basic Filters
+Basic filters perform logical tests of feature properties. You can construct
+complex queries by combining expressions. Expressions use the comparison
+operators below:
+| Operator   | Meaning                                  |
+| =          | Equality                                 |
+| <>         | Not Equal                                |
+| <          | Less Than                                |
+| <=         | Less Than or Equal To                    |
+| >          | Greater Than                             |
+| >=         | Greater Than or Equal To                 |
+| ``LIKE``   | Used for string comparisons. The "%"     |
+|            | wildcard represents any sequence of 0 or |
+|            | more characters. The "_" wildcard        |
+|            | represents any single character. For     |
+|            | example, ``LIKE 'SCHMITT%'`` will begin  |
+|            | search for any names beginning with      |
+|            | ``SCHMITT``                              |
+The comparison operators can be used with numeric or string properties,
+except for the ``LIKE`` operator, which can only be used with string properties.
+Combine or modify expressions with the standard boolean operators ``AND``, ``OR``,
+and ``NOT``.
+**Examples**
+These examples assume that the feature class you are querying has an integer
+property named year and a string property named owner. To select all features
+newer than 2001, create a filter like this:
+**PHP**
+.. highlight:: php
+.. code-block:: php
+    $queryOptions = new MgFeatureQueryOptions();
+    $queryOptions->SetFilter('year > 2001');
+**.net (C#)**
+.. highlight:: csharp
+.. code-block:: csharp
+    MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
+    queryOptions.SetFilter("year > 2001");
+**Java**
+.. highlight:: java
+.. code-block:: java
+To select all features built between 2001 and 2004, create a filter like this:
+**PHP**
+.. highlight:: php
+    $queryOptions->SetFilter('year >= 2001 and year <= 2004');
+**.net (C#)**
+    queryOptions.SetFilter("year >= 2001 and year <= 2004");
+**Java**
+To select all features owned by Davis or Davies, create a filter like this:
+**PHP**
+.. highlight:: php
+    $queryOptions->SetFilter("owner LIKE 'Davi%s'");
+**.net (C#)**
+    queryOptions.SetFilter("owner LIKE 'Davi%s'");
+**Java**
 Spatial Filters
+.. todo::
+With spatial filters, you can do comparisons using geometric properties. For
+example, you can select all features that are inside an area on the map, or that
+intersect an area.
+.. note::
+    For more information about geometry, see Representation of Geometry on page 73.
+There are two ways of using spatial filters:
+ * Create a separate spatial filter to apply to the feature source, using the
+   ``MgFeatureQueryOptions::SetSpatialFilter()`` method.
+ * Include spatial properties in a basic filter created with the ``MgFeatureQueryOptions::SetFilter()`` method.
+The ``MgFeatureQueryOptions::SetSpatialFilter()`` method requires an
+``MgGeometry`` object to define the geometry and a spatial operation to compare
+the feature property and the geometry. The spatial operations are defined in
+class ``MgFeatureSpatialOperations``.
+To include spatial properties in a basic filter, define the geometry using WKT
+format. Use the ``GEOMFROMTEXT()`` function in the basic filter, along with one
+of the following spatial operations:
+ * CONTAINS
+ * COVEREDBY
+ * CROSSES
+ * DISJOINT
+ * EQUALS
+ * INTERSECTS
+ * OVERLAPS
+ * TOUCHES
+ * WITHIN
+ * INSIDE
+.. note::
+    Not all spatial operations can be used on all features. It depends on the
+    capabilities of the FDO provider that supplies the data. This restriction applies to
+    separate spatial filters and spatial properties that are used in a basic filter.
+**Creating Geometry Objects from Features**
+You may want to use an existing feature as part of a spatial query. To retrieve
+the feature's geometry and convert it into an appropriate format for a query,
+perform the following steps:
+ * Create a query that will select the feature.
+ * Query the feature class containing the feature using the
+   ``MgFeatureService::SelectFeatures()`` method.
+ * Obtain the feature from the query using the ``MgFeatureReader::ReadNext()``
+   method.
+ * Get the geometry data from the feature using the
+   ``MgFeatureReader::GetGeometry()`` method. This data is in AGF binary
+   format.
+ * Convert the AGF data to an ``MgGeometry`` object using the
+   ``MgAgfReaderWriter::Read()`` method.
+For example, the following sequence creates an ``MgGeometry`` object representing
+the boundaries of District 1 in the Sheboygan sample data.
+**PHP**
+.. highlight:: php
+    $districtQuery = new MgFeatureQueryOptions();
+    $districtQuery->SetFilter("Autogenerated_SDF_ID = 1");
+    $layer = $map->GetLayers()->GetItem('Districts');
+    $featureReader = $layer->SelectFeatures($districtQuery);
+    $featureReader->ReadNext();
+    $districtGeometryData = $featureReader->GetGeometry('Data');
+    $agfReaderWriter = new MgAgfReaderWriter();
+    $districtGeometry = $agfReaderWriter->Read($districtGeometryData);
+**.net (C#)**
+    //This code fragment assumes you have imported the OSGeo.MapGuide namespace
+    MgFeatureQueryOptions districtQuery = new MgFeatureQueryOptions();
+    districtQuery.SetFilter("Autogenerated_SDF_ID = 1");
+    MgLayer layer = (MgLayer)map.GetLayers().GetItem("Districts");
+    MgFeatureReader featureReader = layer.SelectFeatures(districtQuery);
+    featureReader.ReadNext();
+    MgByteReader districtGeometryData = featureReader.GetGeometry("Data");
+    MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
+    MgGeometry districtGeometry = agfReaderWriter.Read(districtGeometryData);
+**Java**
+    //This code fragment assumes you have imported the org.osgeo.mapguide namespace
+To convert an ``MgGeometry`` object into its WKT representation, use the ``MgWktReaderWriter::Write()`` method, as in the following example:
+**PHP**
+.. highlight:: php
+    $wktReaderWriter = new MgWktReaderWriter();
+    $districtWkt = $wktReaderWriter->Write($districtGeometry);
+**.net (C#)**
+    MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
+    String districtWkt = wktReaderWriter.Write(districtGeometry);
+**Java**
+**Examples**
 Example: Selection
+**PHP**
+.. highlight:: php
+**.net (C#)**
+**Java**
 Active Selections
More information about the mapguide-commits mailing list
