[mapguide-commits] r6232 - in
trunk/MgDev/Doc/samples/dotnetsamples: . analyzing_features
common modifying_maps_and_layers
svn_mapguide at osgeo.org
Thu Nov 17 07:00:21 EST 2011
Author: jng
Date: 2011-11-17 04:00:21 -0800 (Thu, 17 Nov 2011)
New Revision: 6232
Added:
trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/
trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferlayerdefinition.xml
trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/parcelmarker.xml
trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/change_layers_via_dom.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_line_layer_definition.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx
trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx
Devguide: Implement the modifying_maps_and_layers section of the samples for asp.net
Added: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferlayerdefinition.xml
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferlayerdefinition.xml (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/bufferlayerdefinition.xml 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,31 @@
+<?xml version="1.0" encoding="UTF-8"?>
+ <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
+ <VectorLayerDefinition>
+ <ResourceId></ResourceId>
+ <FeatureName>BufferClass</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Geometry>BufferGeometry</Geometry>
+ <VectorScaleRange>
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel>Buffer</LegendLabel>
+ <AreaSymbolization2D>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>22AA00AA</ForegroundColor>
+ <BackgroundColor>FF000000</BackgroundColor>
+ </Fill>
+ <Stroke>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>0</Thickness>
+ <Color>FF666666</Color>
+ <Unit>Inches</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ </Stroke>
+ </AreaSymbolization2D>
+ </AreaRule>
+ </AreaTypeStyle>
+ </VectorScaleRange>
+ </VectorLayerDefinition>
+ </LayerDefinition>
Added: trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/parcelmarker.xml
--- trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/parcelmarker.xml (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/analyzing_features/parcelmarker.xml 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,42 @@
+<LayerDefinition version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd">
+ <FeatureName>ParcelMarkerClass</FeatureName>
+ <Geometry>ParcelLocation</Geometry>
+ <MinScale>0</MinScale>
+ <MaxScale>10000</MaxScale>
+ <PointTypeStyle>
+ <DisplayAsText>false</DisplayAsText>
+ <AllowOverpost>false</AllowOverpost>
+ <PointRule>
+ <LegendLabel></LegendLabel>
+ <PointSymbolization2D>
+ <Mark>
+ <SizeX>.1</SizeX>
+ <SizeY>.1</SizeY>
+ <Rotation>0</Rotation>
+ <Shape>X</Shape>
+ <Fill>
+ <ForegroundColor>FFFF0000</ForegroundColor>
+ <BackgroundColor>ff000000</BackgroundColor>
+ </Fill>
+ <Edge>
+ <Thickness>0.0</Thickness>
+ <Color>ff000000</Color>
+ <Unit>Centimeters</Unit>
+ </Edge>
+ </Mark>
+ </PointSymbolization2D>
+ </PointRule>
+ </PointTypeStyle>
+</LayerDefinition>
Modified: trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx 2011-11-17 06:31:01 UTC (rev 6231)
+++ trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -32,6 +32,11 @@
get { return Path.Combine(RootDirectory, "Server"); }
+ public static string SchemaDirectory
+ get { return Path.Combine(MapGuideServerDirectory, "Schema"); }
public static string WebExtensionsDirectory
get { return Path.Combine(RootDirectory, "Web"); }
@@ -48,4 +53,36 @@
+public class TemplateUtil
+ public static String Substitute(String templ, params String[] vals)
+ StringBuilder res = new StringBuilder();
+ int index = 0, val = 0;
+ bool found;
+ do
+ found = false;
+ int i = templ.IndexOf('%', index);
+ if(i != -1)
+ found = true;
+ res.Append(templ.Substring(index, i - index));
+ if(i < templ.Length - 1)
+ if(templ[i+1] == '%')
+ res.Append('%');
+ else if(templ[i+1] == 's')
+ res.Append(vals[val ++]);
+ else
+ res.Append('@'); //add a character illegal in jscript so we know the template was incorrect
+ index = i + 2;
+ } while(found);
+ res.Append(templ.Substring(index));
+ return res.ToString();
</script>
Added: trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,141 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+ Copyright (C) 2004-2011 by Autodesk, Inc.
+ This library is free software; you can redistribute it and/or
+ modify it under the terms of version 2.1 of the GNU Lesser
+ General Public License as published by the Free Software Foundation.
+ This library is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ Lesser General Public License for more details.
+ You should have received a copy of the GNU Lesser General Public
+ License along with this library; if not, write to the Free Software
+ Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+<%@ Page language="c#" %>
+<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.Xml" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
+<!-- #Include File="common.aspx" -->
+<script runat="server">
+String sessionId;
+String mapName;
+</script>
+<html>
+ <head>
+ <title>Map Info</title>
+ <style type="text/css">
+ body, html { margin: 0; padding: 0 }
+ body { font-family: Verdana; font-size: 0.6em; }
+ </style>
+ </head>
+ <body>
+ // Initialize
+ MapGuideApi.MgInitializeWebTier(Constants.WebConfigPath);
+ sessionId = Request.Params["SESSION"];
+ mapName = Request.Params["MAPNAME"];
+ MgUserInformation userInfo = new MgUserInformation(sessionId);
+ MgSiteConnection siteConnection = new MgSiteConnection();
+ siteConnection.Open(userInfo);
+ MgMap map = new MgMap(siteConnection);
+ map.Open(mapName);
+ <p>Map Name: <%= map.GetName() %></p>
+ <p>Object Id: <%= map.GetObjectId() %></p>
+ <p>Map Definition: <%= map.GetMapDefinition().ToString() %></p>
+ <hr />
+ <p>Display DPI: <%= map.GetDisplayDpi() %></p>
+ <p>Display Height: <%= map.GetDisplayHeight() %></p>
+ <p>Display Width: <%= map.GetDisplayWidth() %></p>
+ <hr />
+ <p>View Center: (<%= map.GetViewCenter().GetCoordinate().GetX() %>, <%= map.GetViewCenter().GetCoordinate().GetY() %>)</p>
+ <p>View Scale: <%= map.GetViewScale() %></p>
+ <hr />
+ MgEnvelope dataExtents = map.GetDataExtent();
+ MgCoordinate ll = dataExtents.GetLowerLeftCoordinate();
+ MgCoordinate ur = dataExtents.GetUpperRightCoordinate();
+ <h3>Data Extents</h3>
+ <p>Lower Left: (<%= ll.GetX() %>, <%= ll.GetY() %>)</p>
+ <p>Upper Left: (<%= ur.GetX() %>, <%= ur.GetY() %>)</p>
+ <hr />
+ MgLayerCollection layers = map.GetLayers();
+ <h3>Layers (<%= layers.GetCount() %>)</h3>
+ <table border="1">
+ <tr>
+ <th>Name</th>
+ <th>Group</th>
+ <th>Label</th>
+ <th>Legend Visible</th>
+ <th>Potential Visible</th>
+ <th>Actual Visible</th>
+ <th>Expand In Legend</th>
+ <th>Layer Type</th>
+ <th>Layer Definition</th>
+ <th>Feature Source Id</th>
+ <th>Needs Refresh</th>
+ </tr>
+ for (int i = 0; i < layers.GetCount(); i++) {
+ MgLayerBase layer = layers.GetItem(i);
+ MgLayerGroup group = layer.GetGroup();
+ <tr>
+ <td><%= layer.GetName() %></td>
+ <td><%= group == null ? "" : group.Name %></td>
+ <td><%= layer.GetLegendLabel() %></td>
+ <td><%= layer.GetDisplayInLegend() %></td>
+ <td><%= layer.GetVisible() %></td>
+ <td><%= layer.IsVisible() %></td>
+ <td><%= layer.GetExpandInLegend() %></td>
+ <td><%= layer.GetLayerType() %></td>
+ <td><%= layer.GetLayerDefinition().ToString() %></td>
+ <td><%= layer.GetFeatureSourceId() %></td>
+ <td><%= layer.NeedsRefresh() %></td>
+ </tr>
+ </table>
+ <hr />
+ MgLayerGroupCollection layerGroups = map.GetLayerGroups();
+ <h3>Layer Groups (<%= layerGroups.GetCount() %>)</h3>
+ <tr>
+ <th>Name</th>
+ <th>Group</th>
+ <th>Label</th>
+ <th>Group Type</th>
+ </tr>
+ for (int i = 0; i < layerGroups.GetCount(); i++) {
+ MgLayerGroup group = layerGroups.GetItem(i);
+ MgLayerGroup parent = group.GetGroup();
+ <tr>
+ <td><%= group.GetName() %></td>
+ <td><%= parent == null ? "" : parent.Name %></td>
+ <td><%= group.GetLegendLabel() %></td>
+ <td><%= group.GetDisplayInLegend() %></td>
+ <td><%= group.GetVisible() %></td>
+ <td><%= group.IsVisible() %></td>
+ <td><%= group.GetExpandInLegend() %></td>
+ <td><%= group.GetLayerGroupType() %></td>
+ </tr>
+ </table>
+ </body>
+</html>
\ No newline at end of file
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,57 @@
+<LayerDefinition xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.3.0.xsd">
+ <ResourceId>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</ResourceId>
+ <FeatureName>SHP_Schema:Parcels</FeatureName>
+ <PropertyMapping>
+ <Name>NAME</Name>
+ <Value>NAME</Value>
+ </PropertyMapping>
+ <PropertyMapping>
+ <Name>ID</Name>
+ <Value>ID</Value>
+ <PropertyMapping>
+ <Name>YRBUILT</Name>
+ <Value>YRBUILT</Value>
+ <Geometry>SHPGEOM</Geometry>
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel>Built after 1950</LegendLabel>
+ <Filter>YRBUILT > 1950</Filter>
+ <Label>
+ <Unit>Points</Unit>
+ <SizeX>0.3</SizeX>
+ <SizeY>10</SizeY>
+ <Text>YRBUILT</Text>
+ <FontName>Arial</FontName>
+ <ForegroundColor>FF000000</ForegroundColor>
+ <BackgroundColor>FFFFFFFF</BackgroundColor>
+ <BackgroundStyle>Transparent</BackgroundStyle>
+ <HorizontalAlignment>'Center'</HorizontalAlignment>
+ <VerticalAlignment>'Baseline'</VerticalAlignment>
+ </Label>
+ <Fill>
+ <ForegroundColor>FFFFFF00</ForegroundColor>
+ </Fill>
+ <Stroke>
+ <Color>FF000000</Color>
+ </Stroke>
+ </AreaRule>
+ </AreaTypeStyle>
+</LayerDefinition>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/change_layers_via_dom.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/change_layers_via_dom.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/change_layers_via_dom.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,152 @@
+<%@ Page language="c#" debug="true" %>
+<%@ Import Namespace="System.IO" %>
+String sessionId;
+String mapName;
+</script>
+<!-- #Include File="../common/common.aspx" -->
+<!-- #Include File="layer_functions.aspx" -->
+<html>
+<head>
+ <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
+ <meta http-equiv="content-script-type" content="text/javascript">
+ <meta http-equiv="content-style-type" content="text/css">
+ <link href="../styles/globalStyles.css" rel="stylesheet" type="text/css">
+ <link href="../styles/otherStyles.css" rel="stylesheet" type="text/css">
+ <script language="javascript" type="text/javascript">
+ function OnPageLoad()
+ parent.mapFrame.Refresh();
+ parent.mapFrame.ZoomToScale(9999);
+ </script>
+</head>
+<body onLoad="OnPageLoad()">
+try
+ // Initialize
+ MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+ // Open the map
+ // Load a layer from XML, and use the DOM to change it
+ // Load the prototype layer definition into
+ // a PHP DOM object.
+ XmlDocument domDocument = new XmlDocument();
+ String layerDefPath = Server.MapPath("RecentlyBuilt.LayerDefinition");
+ if (!File.Exists(layerDefPath))
+ Response.Write("The layer definition 'RecentlyBuilt.LayerDefinition' could not be found.<BR>\n");
+ return;
+ domDocument.Load(layerDefPath);
+ // Get a list of all the <AreaRule><Filter> elements in
+ // the XML.
+ XmlNodeList nodes = domDocument.SelectNodes("//AreaRule/Filter");
+ // Find the correct node and change it
+ foreach (XmlNode node in nodes)
+ if (node.InnerText == "YRBUILT > 1950")
+ node.InnerText = "YRBUILT > 1980";
+ // Get a list of all the <LegendLabel> elements in the
+ // XML.
+ nodes = domDocument.SelectNodes("//LegendLabel");
+ if (node.InnerText == "Built after 1950")
+ node.InnerText = "Built after 1980";
+ // Add the layer to the map
+ MgLayer newLayer = LayerFunctions.AddLayerDefinitionToMap(domDocument, "RecentlyBuilt", "Built after 1980", sessionId, resourceService, map);
+ LayerFunctions.AddLayerToGroup(newLayer, "Analysis", "Analysis", map);
+ // Turn off the "Square Footage" themed layer (if it
+ // exists) so it does not hide this layer.
+ MgLayerCollection layerCollection = map.GetLayers();
+ if (layerCollection.Contains("SquareFootage"))
+ MgLayerBase squareFootageLayer = layerCollection.GetItem("SquareFootage");
+ squareFootageLayer.SetVisible(false);
+ // Turn on the visibility of this layer.
+ // (If the layer does not already exist in the map, it will be visible by default when it is added.
+ // But if the user has already run this script, he or she may have set the layer to be invisible.)
+ layerCollection = map.GetLayers();
+ if (layerCollection.Contains("RecentlyBuilt"))
+ MgLayerBase recentlyBuiltLayer = layerCollection.GetItem("RecentlyBuilt");
+ recentlyBuiltLayer.SetVisible(true);
+ // Save the map back to the session repository
+ map.Save();
+catch (MgException e)
+ Response.Write("<script language=\"javascript\" type=\"text/javascript\"> \n");
+ String message = e.GetExceptionMessage().Replace("\n", " ");
+ Response.Write(" alert(\" " + message + " \"); \n");
+ Response.Write("</script> \n");
+</body>
+</html>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_line_layer_definition.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_line_layer_definition.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_line_layer_definition.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,129 @@
+String sessionId;
+String mapName;
+</script>
+<html>
+<head>
+ parent.mapFrame.ZoomToScale(40000);
+ </script>
+</head>
+try
+ // Initialize
+ // Open the map
+ // Create a new layer
+ LayerDefinitionFactory factory = new LayerDefinitionFactory(this.Server);
+ // Create a line rule.
+ String legendLabel = "";
+ String filter = "";
+ String color = "FF0000FF";
+ String lineRule = factory.CreateLineRule(legendLabel, filter, color);
+ // Create a line type style.
+ String lineTypeStyle = factory.CreateLineTypeStyle(lineRule);
+ // Create a scale range.
+ String minScale = "0";
+ String maxScale = "1000000000000";
+ String lineScaleRange = factory.CreateScaleRange(minScale, maxScale, lineTypeStyle);
+ // Create the layer definiton.
+ String featureClass = "Library://Samples/Sheboygan/Data/HydrographicLines.FeatureSource";
+ String featureName = "SHP_Schema:HydrographicLines";
+ String geometry = "SHPGEOM";
+ String layerDefinition = factory.CreateLayerDefinition(featureClass, featureName, geometry, lineScaleRange);
+ XmlDocument doc = new XmlDocument();
+ doc.LoadXml(layerDefinition);
+ MgLayer newLayer = LayerFunctions.AddLayerDefinitionToMap(doc, "Hydro", "Hydro", sessionId, resourceService, map);
+ if (layerCollection.Contains("Hydro"))
+ MgLayerBase squareFootageLayer =layerCollection.GetItem("Hydro");
+ squareFootageLayer.SetVisible(true);
+ map.Save();
+ Response.Write(" alert(\" " +e.GetExceptionMessage() + " \"); \n");
+</body>
+</html>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,229 @@
+String sessionId;
+String mapName;
+MgPropertyCollection MakePoint(String name, double x, double y)
+ MgPropertyCollection propertyCollection = new MgPropertyCollection();
+ MgStringProperty nameProperty = new MgStringProperty("NAME", name);
+ propertyCollection.Add(nameProperty);
+ MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
+ MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
+ MgGeometry geometry = wktReaderWriter.Read("POINT XY (" + x + " " + y + ")");
+ MgByteReader geometryByteReader = agfReaderWriter.Write(geometry);
+ MgGeometryProperty geometryProperty = new MgGeometryProperty("GEOM", geometryByteReader);
+ propertyCollection.Add(geometryProperty);
+ return propertyCollection;
+</script>
+<html>
+<head>
+ </script>
+</head>
+try
+ // Initialize
+ MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+ // Open the map
+ // Create a feature source with point data.
+ // (The Sheboygan sample data does not contain such data,
+ // so we"ll create it.)
+ // Create a feature class definition for the new feature source
+ MgClassDefinition classDefinition = new MgClassDefinition();
+ classDefinition.SetName("Points");
+ classDefinition.SetDescription("Feature class with point data.");
+ classDefinition.SetDefaultGeometryPropertyName("GEOM");
+ // Create an identify property
+ MgDataPropertyDefinition identityProperty = new MgDataPropertyDefinition("KEY");
+ identityProperty.SetDataType(MgPropertyType.Int32);
+ identityProperty.SetAutoGeneration(true);
+ identityProperty.SetReadOnly(true);
+ // Add the identity property to the class definition
+ classDefinition.GetIdentityProperties().Add(identityProperty);
+ classDefinition.GetProperties().Add(identityProperty);
+ // Create a name property
+ MgDataPropertyDefinition nameProperty = new MgDataPropertyDefinition("NAME");
+ nameProperty.SetDataType(MgPropertyType.String);
+ // Add the name property to the class definition
+ classDefinition.GetProperties().Add(nameProperty);
+ // Create a geometry property
+ MgGeometricPropertyDefinition geometryProperty = new MgGeometricPropertyDefinition("GEOM");
+ geometryProperty.SetGeometryTypes(MgFeatureGeometricType.Point);
+ // Add the geometry property to the class definition
+ classDefinition.GetProperties().Add(geometryProperty);
+ // Create a feature schema
+ MgFeatureSchema featureSchema = new MgFeatureSchema("PointSchema", "Point schema");
+ // Add the feature schema to the class definition
+ featureSchema.GetClasses().Add(classDefinition);
+ // Create the feature source
+ String featureSourceName = "Library://Samples/DevGuide/Data/points.FeatureSource";
+ MgResourceIdentifier resourceIdentifier = new MgResourceIdentifier(featureSourceName);
+ //wkt = "LOCALCS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ String wkt = map.GetMapSRS();
+ //sdfParams = new MgCreateSdfParams("ArbitraryXY", wkt, featureSchema);
+ MgCreateSdfParams sdfParams = new MgCreateSdfParams("LatLong", wkt, featureSchema);
+ featureService.CreateFeatureSource(resourceIdentifier, sdfParams);
+ // We need to add some data to the sdf before using it. The spatial context
+ // reader must have an extent.
+ MgBatchPropertyCollection batchPropertyCollection = new MgBatchPropertyCollection();
+ MgGeometryFactory geometryFactory = new MgGeometryFactory();
+ // Make four points
+ batchPropertyCollection.Add(MakePoint("Point A", -87.727, 43.748));
+ batchPropertyCollection.Add(MakePoint("Point B", -87.728, 43.730));
+ batchPropertyCollection.Add(MakePoint("Point C", -87.726, 43.750));
+ batchPropertyCollection.Add(MakePoint("Point D", -87.728, 43.750));
+ // Add the batch property collection to the feature source
+ MgInsertFeatures cmd = new MgInsertFeatures("Points", batchPropertyCollection);
+ MgFeatureCommandCollection featureCommandCollection = new MgFeatureCommandCollection();
+ featureCommandCollection.Add(cmd);
+ // Execute the "add" commands
+ featureService.UpdateFeatures(resourceIdentifier, featureCommandCollection, false);
+ // Create a mark symbol
+ String resourceId = "Library://Samples/Sheboygan/Symbols/BasicSymbols.SymbolLibrary";
+ String symbolName = "PushPin";
+ String width = "24"; // unit = points
+ String height = "24"; // unit = points
+ String color = "FFFF0000";
+ String markSymbol = factory.CreateMarkSymbol(resourceId, symbolName, width, height, color);
+ // Create a text symbol
+ String text = "ID";
+ String fontHeight="12";
+ String foregroundColor = "FF000000";
+ String textSymbol = factory.CreateTextSymbol(text, fontHeight, foregroundColor);
+ // Create a point rule.
+ String legendLabel = "trees";
+ String pointRule = factory.CreatePointRule(legendLabel, filter, textSymbol, markSymbol);
+ // Create a point type style.
+ String pointTypeStyle = factory.CreatePointTypeStyle(pointRule);
+ String pointScaleRange = factory.CreateScaleRange(minScale, maxScale, pointTypeStyle);
+ String featureName = "PointSchema:Points";
+ String geometry = "GEOM";
+ String layerDefinition = factory.CreateLayerDefinition(featureSourceName, featureName, geometry, pointScaleRange);
+ MgLayer newLayer = LayerFunctions.AddLayerDefinitionToMap(doc, "Points", "Points of Interest", sessionId, resourceService, map);
+ if (layerCollection.Contains("Points"))
+ MgLayerBase pointsLayer =layerCollection.GetItem("Points");
+ pointsLayer.SetVisible(true);
+ map.Save();
+ Response.Write(" alert(\" " + e.GetExceptionMessage() + " \"); \n");
+</body>
+</html>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,141 @@
+String sessionId;
+String mapName;
+</script>
+<html>
+<head>
+ </script>
+</head>
+try
+ // Initialize
+ // Open the map
+ /// Create three area rules for three different
+ // scale ranges.
+ String areaRule1 = factory.CreateAreaRule( "1 to 800",
+ "SQFT >= 1 AND SQFT < 800", "FFFFFF00");
+ String areaRule2 = factory.CreateAreaRule( "800 to 1600",
+ "SQFT >= 800 AND SQFT < 1600", "FFFFBF20");
+ String areaRule3 = factory.CreateAreaRule("1600 to 2400",
+ "SQFT >= 1600 AND SQFT < 2400", "FFFF8040");
+ // Create an area type style.
+ String areaTypeStyle = factory.CreateAreaTypeStyle(areaRule1 + areaRule2 + areaRule3);
+ String maxScale = "10000";
+ String areaScaleRange = factory.CreateScaleRange(minScale, maxScale, areaTypeStyle);
+ String featureClass = "Library://Samples/Sheboygan/Data/Parcels.FeatureSource";
+ String featureName = "SHP_Schema:Parcels";
+ String layerDefinition = factory.CreateLayerDefinition(featureClass, featureName, geometry, areaScaleRange);
+ MgLayer newLayer = LayerFunctions.AddLayerDefinitionToMap(doc, "SquareFootage", "Square Footage", sessionId, resourceService, map);
+ // Turn off the "Recently Built" themed layer (if it exists) so it does not hide this layer.
+ MgLayerBase recentlyBuiltLayer =layerCollection.GetItem("RecentlyBuilt");
+ recentlyBuiltLayer.SetVisible(false);
+ MgLayerBase squareFootageLayer =layerCollection.GetItem("SquareFootage");
+ map.Save();
+ Response.Write( "<script language=\"javascript\" type=\"text/javascript\"> \n");
+ Response.Write( " alert(\" " + e.GetExceptionMessage() + " \"); \n");
+ Response.Write( "</script> \n");
+</body>
+</html>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,225 @@
+<script language="C#" runat="server">
+public class LayerFunctions
+ // Adds the layer definition (XML) to the map.
+ // Returns the layer.
+ public static MgLayer AddLayerDefinitionToMap(XmlDocument domDocument, String layerName, String layerLegendLabel, String sessionId, MgResourceService resourceService, MgMap map)
+ // TODO: Should probably validate this XML content
+ using (MemoryStream ms = new MemoryStream())
+ domDocument.Save(ms);
+ ms.Position = 0L;
+ // Save the new layer definition to the session repository
+ MgByteSource byteSource = new MgByteSource(ms.GetBuffer(), (int)ms.Length);
+ byteSource.SetMimeType(MgMimeType.Xml);
+ MgResourceIdentifier resourceID = new MgResourceIdentifier("Session:" + sessionId + "//" + layerName + ".LayerDefinition");
+ resourceService.SetResource(resourceID, byteSource.GetReader(), null);
+ MgLayer newLayer = AddLayerResourceToMap(resourceID, resourceService, layerName, layerLegendLabel, map);
+ return newLayer;
+ // Adds a layer to a layer group. If necessary, it creates the layer group.
+ public static void AddLayerToGroup(MgLayer layer, String layerGroupName, String layerGroupLegendLabel, MgMap map)
+ // Get the layer group
+ MgLayerGroupCollection layerGroupCollection = map.GetLayerGroups();
+ MgLayerGroup layerGroup = null;
+ if (layerGroupCollection.Contains(layerGroupName))
+ layerGroup = layerGroupCollection.GetItem(layerGroupName);
+ else
+ // It does not exist, so create it
+ layerGroup = new MgLayerGroup(layerGroupName);
+ layerGroup.SetVisible(true);
+ layerGroup.SetDisplayInLegend(true);
+ layerGroup.SetLegendLabel(layerGroupLegendLabel);
+ layerGroupCollection.Add(layerGroup);
+ // Add the layer to the group
+ layer.SetGroup(layerGroup);
+ // Adds a layer defition (which can be stored either in the Library or a session
+ // repository) to the map.
+ public static MgLayer AddLayerResourceToMap(MgResourceIdentifier layerResourceID, MgResourceService resourceService, String layerName, String layerLegendLabel, MgMap map)
+ MgLayer newLayer = new MgLayer(layerResourceID, resourceService);
+ // Add the new layer to the map's layer collection
+ newLayer.SetName(layerName);
+ newLayer.SetVisible(true);
+ newLayer.SetLegendLabel(layerLegendLabel);
+ newLayer.SetDisplayInLegend(true);
+ if (!layerCollection.Contains(layerName) )
+ // Insert the new layer at position 0 so it is at the top
+ // of the drawing order
+ layerCollection.Insert(0, newLayer);
+ return newLayer;
+public class LayerDefinitionFactory
+ private HttpServerUtility _server;
+ public LayerDefinitionFactory(HttpServerUtility server)
+ _server = server;
+ HttpServerUtility Server { get { return _server; } }
+ //Creates Area Rule
+ //Parameters:
+ //foreGroundColor - color code for the foreground color
+ //legendLabel - string for the legend label
+ //filterText - filter string
+ //textSymbol - use textsymbol.templ to create it
+ public String CreateAreaRule(String legendLabel, String filterText, String foreGroundColor)
+ String areaRule = File.ReadAllText(Server.MapPath("../../viewerfiles/arearule.templ"));
+ areaRule = TemplateUtil.Substitute(areaRule, legendLabel, filterText, foreGroundColor);
+ return areaRule;
+ //Creates AreaTypeStyle.
+ //Parameters:
+ //areaRules - call CreateAreaRule to create area rules
+ public String CreateAreaTypeStyle(String areaRules)
+ String style = File.ReadAllText(Server.MapPath("../../viewerfiles/areatypestyle.templ"));
+ style = TemplateUtil.Substitute(style, areaRules);
+ return style;
+ //Creates line rule
+ //Parameters:
+ //color - color code for the line
+ //filter - filter string
+ public String CreateLineRule(String legendLabel, String filter, String color)
+ String lineRule = File.ReadAllText(Server.MapPath("../../viewerfiles/linerule.templ"));
+ lineRule = TemplateUtil.Substitute(lineRule, legendLabel, filter, color);
+ return lineRule;
+ //Creates LineTypeStyle
+ //Parameters:
+ //lineRules - call CreateLineRule to create line rules
+ public String CreateLineTypeStyle(String lineRules)
+ String lineStyle = File.ReadAllText(Server.MapPath("../../viewerfiles/linetypestyle.templ"));
+ lineStyle = TemplateUtil.Substitute(lineStyle, lineRules);
+ return lineStyle;
+ //Creates mark symbol
+ //Parameters:
+ //resourceId - resource identifier for the resource to be used
+ //symbolName - the name of the symbol
+ //width - the width of the symbol
+ //height - the height of the symbol
+ //color - color code for the symbol color
+ public String CreateMarkSymbol(String resourceId, String symbolName, String width, String height, String color)
+ String markSymbol = File.ReadAllText(Server.MapPath("../../viewerfiles/marksymbol.templ"));
+ markSymbol = TemplateUtil.Substitute(markSymbol, width, height, resourceId, symbolName, color);
+ return markSymbol;
+ //Creates text symbol
+ //Parameters:
+ //text - string for the text
+ //fontHeight - the height for the font
+ //TODO:Can we pass it as a integer (ex. 10) or string (ex"10")
+ //foregroundColor - color code for the foreground color
+ public String CreateTextSymbol(String text, String fontHeight, String foregroundColor)
+ String textSymbol = File.ReadAllText(Server.MapPath("../../viewerfiles/textsymbol.templ"));
+ textSymbol = TemplateUtil.Substitute(textSymbol, fontHeight, fontHeight, text, foregroundColor);
+ return textSymbol;
+ //Creates a point rule
+ //Parameters:
+ //pointSym - point symbolization. Use CreateMarkSymbol to create it
+ //legendlabel - string for the legend label
+ //filter - string for the filter
+ //label - use CreateTextSymbol to create it
+ public String CreatePointRule(String legendLabel, String filter, String label, String pointSym)
+ String pointRule = File.ReadAllText(Server.MapPath("../../viewerfiles/pointrule.templ"));
+ pointRule = TemplateUtil.Substitute(pointRule, legendLabel, filter, label, pointSym);
+ return pointRule;
+ //Creates PointTypeStyle
+ //Parameters:
+ //pointRule - use CreatePointRule to define rules
+ public String CreatePointTypeStyle(String pointRule)
+ String pointTypeStyle = File.ReadAllText(Server.MapPath("../../viewerfiles/pointtypestyle.templ"));
+ pointTypeStyle = TemplateUtil.Substitute(pointTypeStyle, pointRule);
+ return pointTypeStyle;
+ //Creates ScaleRange
+ //Parameterss
+ //minScale - minimum scale
+ //maxScale - maximum scale
+ //typeStyle - use one CreateAreaTypeStyle, CreateLineTypeStyle, or CreatePointTypeStyle
+ public String CreateScaleRange(String minScale, String maxScale, String typeStyle)
+ String scaleRange = File.ReadAllText(Server.MapPath("../../viewerfiles/scalerange.templ"));
+ scaleRange = TemplateUtil.Substitute(scaleRange, minScale, maxScale, typeStyle);
+ return scaleRange;
+ //Creates a layer definition
+ //resourceId - resource identifier for the new layer
+ //featureClass - the name of the feature class
+ //geometry - the name of the geometry
+ //featureClassRange - use CreateScaleRange to define it.
+ public String CreateLayerDefinition(String resourceId, String featureClass, String geometry, String featureClassRange)
+ String layerDef = File.ReadAllText(Server.MapPath("../../viewerfiles/layerdefinition.templ"));
+ layerDef = TemplateUtil.Substitute(layerDef, resourceId, featureClass, geometry, featureClassRange);
+ return layerDef;
+</script>
Added: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/task_pane.aspx 2011-11-17 12:00:21 UTC (rev 6232)
@@ -0,0 +1,90 @@
+String sessionId;
+String mapName;
+String fullPath;
+</script>
+<html>
+ <head>
+ </head>
+ <body class="AppFrame">
+ <h1 class="AppHeading">Modifying Maps & Layers</h1>
+ <p>The following links all load in the hidden script frame, leaving this task pane visible.</p>
+ <ul>
+ <li><a href="change_layers_via_dom.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="scriptFrame">
+ Change Layers via DOM</a>
+ <br>Show buildings built after 1980.
+ <br>
+ fullPath = Server.MapPath("change_layers_via_dom.aspx");
+ <a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >View source</a>
+ </li>
+ <li><a href="create_new_squarefootage_layer_definition.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="scriptFrame">
+ Create Square Footage Layer</a>
+ <br>Show a map themed by areas.
+ <br>
+ fullPath = Server.MapPath("create_new_squarefootage_layer_definition.aspx");
+ </li>
+ <li><a href="create_new_line_layer_definition.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="scriptFrame">
+ Create Hydro Line Layer</a>
+ <br>Show a map themed by lines.
+ <br>
+ fullPath = Server.MapPath("create_new_line_layer_definition.aspx");
+ </li>
+ <li><a href="create_new_point_layer_definition.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" target="scriptFrame">
+ Create Points of Interest Layer</a>
+ <br>Show a map themed by points.
+ <br>
+ fullPath = Server.MapPath("create_new_point_layer_definition.aspx");
+ String fullPath2 = Server.MapPath("RecentlyBuilt.LayerDefinition");
+ String fullPath3 = Server.MapPath("layer_functions.aspx");
+ </li>
+ </ul>
+ <p>View source for support files:</p>
+ <ul>
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath2 %>">RecentlyBuilt.LayerDefinition</a></li>
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath3 %>">layer_functions.aspx</a></li>
+ </ul>
+ <p>Map Debugging:</p>
+ <a target="_blank" href="../common/mapinfo.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>">Map Information</a>
+ </body>
+</html>
More information about the mapguide-commits
