[mapguide-commits] r6233 -
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers
svn_mapguide at osgeo.org
Thu Nov 17 07:01:03 EST 2011
Author: jng
Date: 2011-11-17 04:01:03 -0800 (Thu, 17 Nov 2011)
New Revision: 6233
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
Update PHP devguide samples to not use deprecated APIs
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2011-11-17 12:00:21 UTC (rev 6232)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2011-11-17 12:01:03 UTC (rev 6233)
@@ -49,12 +49,11 @@
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
- $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
// Open the map
- $map = new MgMap();
- $map->Open($resourceService, $mapName);
+ $map = new MgMap($siteConnection);
+ $map->Open($mapName);
@@ -133,10 +132,7 @@
// Save the map back to the session repository
- $sessionIdName = "Session:$sessionId//$mapName.Map";
- $sessionResourceID = new MgResourceIdentifier($sessionIdName);
- $sessionResourceID->Validate();
- $map->Save($resourceService, $sessionResourceID);
+ $map->Save();
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2011-11-17 12:00:21 UTC (rev 6232)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2011-11-17 12:01:03 UTC (rev 6233)
@@ -54,8 +54,8 @@
// Open the map
// Create a feature source with point data.
@@ -166,7 +166,7 @@
// Create a point type style.
$pointTypeStyle = $factory->
- CreatepointTypeStyle($pointRule);
+ CreatePointTypeStyle($pointRule);
// Create a scale range.
$minScale = '0';
@@ -200,10 +200,7 @@
+ $map->Save();
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2011-11-17 12:00:21 UTC (rev 6232)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2011-11-17 12:01:03 UTC (rev 6233)
@@ -55,8 +55,8 @@
// Open the map
@@ -122,10 +122,7 @@
+ $map->Save($sessionResourceID);
More information about the mapguide-commits
