[mapguide-commits] r6581 - trunk/Installer/scripts
svn_mapguide at osgeo.org
Fri Apr 20 09:27:16 EDT 2012
Author: jng
Date: 2012-04-20 06:27:15 -0700 (Fri, 20 Apr 2012)
New Revision: 6581
trunk/Installer/scripts/build.sh
trunk/Installer/scripts/setvars.sh
Parameterise the svn root and the relative path so that we have full flexiblity when it comes to our SVN source
Modified: trunk/Installer/scripts/build.sh
--- trunk/Installer/scripts/build.sh 2012-04-19 16:56:15 UTC (rev 6580)
+++ trunk/Installer/scripts/build.sh 2012-04-20 13:27:15 UTC (rev 6581)
@@ -11,16 +11,16 @@
sudo rm -rf ${MGSOURCE}
sudo rm -rf ${INSTALLROOT}
-REVISION=`svn info ${SVNROOT}/mapguide/trunk/MgDev | perl revnum.pl`
+REVISION=`svn info ${SVNROOT}${SVNRELPATH} | perl revnum.pl`
echo ${REVISION} > revnum.txt
echo "Exporting svn revision ${REVISION}"
if [ ${LOCALSVN} = 1 ]
then
echo "Making local SVN copy to ${MGSOURCE}"
- cp -R ${SVNROOT}/mapguide/trunk/MgDev ${MGSOURCE}
+ cp -R ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
else
echo "Performing fresh SVN export to ${MGSOURCE}"
- svn export -q -r ${REVISION} ${SVNROOT}/mapguide/trunk/MgDev ${MGSOURCE}
+ svn export -q -r ${REVISION} ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
fi
echo "Building Revision ${BUILDNUM}.${REVISION}"
cd ${MGSOURCE}
Modified: trunk/Installer/scripts/setvars.sh
--- trunk/Installer/scripts/setvars.sh 2012-04-19 16:56:15 UTC (rev 6580)
+++ trunk/Installer/scripts/setvars.sh 2012-04-20 13:27:15 UTC (rev 6581)
@@ -12,8 +12,10 @@
# Use LOCALSVN=1 if you want to build from an existing copy instead of building
# from an export
export LOCALSVN=1
-export SVNROOT=/home/user
+export SVNROOT=/home/jackie
+export SVNRELPATH=/mg-2.4/MgDev
#export SVNROOT="svn://svn.bld.mgproto.net"
#export SVNROOT="http://svn.osgeo.org"
+#export SVNRELPATH=/mapguide/trunk/MgDev
export MY_MAKE_OPTS="-j 4"
export UBUNTU=1
More information about the mapguide-commits
