[mapguide-commits] r6582 - trunk/Installer/scripts
svn_mapguide at osgeo.org
Fri Apr 20 13:26:54 EDT 2012
Author: jng
Date: 2012-04-20 10:26:54 -0700 (Fri, 20 Apr 2012)
New Revision: 6582
trunk/Installer/scripts/build.sh
trunk/Installer/scripts/setvars.sh
Build script modifications to allow for build directory preservation
Modified: trunk/Installer/scripts/build.sh
--- trunk/Installer/scripts/build.sh 2012-04-20 13:27:15 UTC (rev 6581)
+++ trunk/Installer/scripts/build.sh 2012-04-20 17:26:54 UTC (rev 6582)
@@ -8,19 +8,27 @@
exit
fi
-sudo rm -rf ${MGSOURCE}
+if [ ${PRESERVE_BUILD_ROOT} != 1 ]
+then
+ sudo rm -rf ${MGSOURCE}
+else
+ echo "Preserving existing build dir"
+fi
sudo rm -rf ${INSTALLROOT}
REVISION=`svn info ${SVNROOT}${SVNRELPATH} | perl revnum.pl`
echo ${REVISION} > revnum.txt
-echo "Exporting svn revision ${REVISION}"
-if [ ${LOCALSVN} = 1 ]
+if [ ${PRESERVE_BUILD_ROOT} != 1 ];
then
- echo "Making local SVN copy to ${MGSOURCE}"
- cp -R ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
-else
- echo "Performing fresh SVN export to ${MGSOURCE}"
- svn export -q -r ${REVISION} ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
+ echo "Exporting svn revision ${REVISION}"
+ if [ ${LOCALSVN} = 1 ]
+ then
+ echo "Making local SVN copy to ${MGSOURCE}"
+ cp -R ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
+ else
+ echo "Performing fresh SVN export to ${MGSOURCE}"
+ svn export -q -r ${REVISION} ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
+ fi
fi
echo "Building Revision ${BUILDNUM}.${REVISION}"
cd ${MGSOURCE}
Modified: trunk/Installer/scripts/setvars.sh
--- trunk/Installer/scripts/setvars.sh 2012-04-20 13:27:15 UTC (rev 6581)
+++ trunk/Installer/scripts/setvars.sh 2012-04-20 17:26:54 UTC (rev 6582)
@@ -12,10 +12,19 @@
# Use LOCALSVN=1 if you want to build from an existing copy instead of building
# from an export
export LOCALSVN=1
-export SVNROOT=/home/jackie
-export SVNRELPATH=/mg-2.4/MgDev
+export SVNROOT=/home/user
+export SVNRELPATH=/mapguide/trunk/MgDev
#export SVNROOT="svn://svn.bld.mgproto.net"
#export SVNROOT="http://svn.osgeo.org"
#export SVNRELPATH=/mapguide/trunk/MgDev
export MY_MAKE_OPTS="-j 4"
export UBUNTU=1
+export PRESERVE_BUILD_ROOT=1
+echo "******************************************************************"
+echo " MapGuide will be installed to: ${INSTALLROOT}"
+echo " SVN Source is: ${SVNROOT}${SVNRELPATH}"
+echo " Make Options: ${MY_MAKE_OPTS}"
+echo " Is Ubuntu?: ${UBUNTU}"
+echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
More information about the mapguide-commits
