[mapguide-commits] r6493 -
	trunk/Tools/Maestro/Maestro.Editors/WebLayout
    svn_mapguide at osgeo.org
    Wed Feb  8 07:09:06 EST 2012
Author: jng
Date: 2012-02-08 04:09:06 -0800 (Wed, 08 Feb 2012)
New Revision: 6493
   trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
#1893: More Web Layout editor usability fixes.
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs	2012-02-08 11:45:14 UTC (rev 6492)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs	2012-02-08 12:09:06 UTC (rev 6493)
@@ -137,20 +137,41 @@
             btnExport.Enabled = customCmds.Length > 0;
+        private void SetSelectedCommand(ICommand cmd)
+            grdCommands.ClearSelection();
+            foreach (DataGridViewRow row in grdCommands.Rows)
+                if (row.DataBoundItem == cmd)
+                    //HACK: This is a long-winded way of simulating a programmatic
+                    //click of the cell that contains this databound item
+                    //See: http://social.msdn.microsoft.com/forums/en-US/winformsdatacontrols/thread/47e9c3ef-a8de-48c9-8e0d-4f3fdd34517e/
+                    grdCommands.FirstDisplayedScrollingRowIndex = row.Index;
+                    grdCommands.Refresh();
+                    grdCommands.CurrentCell = row.Cells[1];
+                    row.Selected = true;
+                    grdCommands_CellContentClick(this, new DataGridViewCellEventArgs(1, row.Index));
+                    break;
         private void invokeURLToolStripMenuItem_Click(object sender, EventArgs e)
             var cmd = _wl.CreateInvokeUrlCommand();
             cmd.Description = cmd.Label = cmd.Tooltip = Properties.Resources.InvokeUrlCmdDescription;
-            //_wl.CommandSet.AddCommand(cmd);
             _commands.Add(cmd);
+            SetSelectedCommand(cmd);
         private void invokeScriptToolStripMenuItem_Click(object sender, EventArgs e)
             var cmd = _wl.CreateInvokeScriptCommand();
             cmd.Description = cmd.Label = cmd.Tooltip = Properties.Resources.InvokeScriptCmdDescription;
             _commands.Add(cmd);
         private void searchToolStripMenuItem_Click(object sender, EventArgs e)
@@ -163,8 +184,8 @@
             var cmd = _wl.CreateSearchCommand();
             cmd.Description = cmd.Label = cmd.Tooltip = Properties.Resources.SearchCmdDescription;
             _commands.Add(cmd);
         private void grdCommands_CellContentClick(object sender, DataGridViewCellEventArgs e)
@@ -236,7 +257,7 @@
                     using (new WaitCursor(this))
                         _wl.CommandSet.RemoveCommand(iscr);
-                        _commands.Remove(iurl);
+                        _commands.Remove(iscr);
                         _wl.RemoveAllReferences(iscr.Name);
                         ClearCommandUI();
@@ -252,7 +273,7 @@
                         _wl.CommandSet.RemoveCommand(srch);
+                        _commands.Remove(srch);
                         _wl.RemoveAllReferences(srch.Name);
                         ClearCommandUI();
More information about the mapguide-commits
