[mapguide-commits] r6494 - in trunk/Tools/Maestro:
Maestro.Editors/FeatureSource/Providers
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Wed Feb 8 07:56:55 EST 2012
Author: jng
Date: 2012-02-08 04:56:55 -0800 (Wed, 08 Feb 2012)
New Revision: 6494
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/GenericCtrl.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
#1925: Avoid unnecessary flagging of dirty state in the Generic FS editor when testing a connection. We do this by creating a clone of the currently edited feature source object with all change listeners detached to not accidentally trigger the dirty state. This submission also fixes a defect where a new feature source object is not initialized with default connection property values where applicable.
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/GenericCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/GenericCtrl.cs 2012-02-08 12:09:06 UTC (rev 6493)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/GenericCtrl.cs 2012-02-08 12:56:55 UTC (rev 6494)
@@ -101,22 +101,26 @@
nameCell.Value = p.Name;
nameCell.ToolTipText = p.LocalizedName;
+ var currentValue = _fs.GetConnectionProperty(p.Name);
DataGridViewCell valueCell = null;
if (p.Enumerable)
valueCell = new DataGridViewTextBoxCell();
valueCell.Tag = p;
- valueCell.Value = _fs.GetConnectionProperty(p.Name);
+ valueCell.Value = currentValue;
else
valueCell.Tag = p;
- if (!string.IsNullOrEmpty(p.DefaultValue))
+ if (string.IsNullOrEmpty(currentValue) && !string.IsNullOrEmpty(p.DefaultValue))
valueCell.Value = p.DefaultValue;
+ _fs.SetConnectionProperty(p.Name, p.DefaultValue);
row.Cells.Add(nameCell);
row.Cells.Add(valueCell);
@@ -182,15 +186,20 @@
private void btnTest_Click(object sender, EventArgs e)
txtTestResult.Text = string.Empty;
+ var param = GetConnectionParameters();
- var param = GetConnectionParameters();
+ var cloneFs = (IFeatureSource)_fs.Clone();
+ _service.ResourceService.SaveResourceAs(cloneFs, "Session:" + _service.SessionID + "//" + Guid.NewGuid().ToString() + ".FeatureSource");
+ cloneFs.ClearConnectionProperties();
foreach (var key in param.AllKeys)
- _fs.SetConnectionProperty(key, param[key]);
+ cloneFs.SetConnectionProperty(key, param[key]);
- _service.ResourceService.SaveResource(_fs);
- string msg = _service.FeatureService.TestConnection(_fs.ResourceID);
+ _service.ResourceService.SaveResource(cloneFs);
+ string msg = _service.FeatureService.TestConnection(cloneFs.ResourceID);
if (string.IsNullOrEmpty(msg))
msg = Properties.Resources.TestConnectionNoErrors;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2012-02-08 12:09:06 UTC (rev 6493)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2012-02-08 12:56:55 UTC (rev 6494)
@@ -25,6 +25,7 @@
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.ObjectModels.Common;
using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using System.ComponentModel;
#pragma warning disable 1591, 0114, 0108
@@ -86,7 +87,9 @@
object ICloneable.Clone()
- return this.Clone();
+ var fs = this.Clone();
+ fs.DetachChangeListeners();
+ return fs;
[XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")]
@@ -155,6 +158,19 @@
OnPropertyChanged("Parameter");
+ protected void DetachChangeListeners()
+ var handler = this.PropertyChanged;
+ if (handler != null)
+ foreach (var h in handler.GetInvocationList())
+ this.PropertyChanged -= (PropertyChangedEventHandler)h;
+ handler = null;
[XmlIgnore]
public string ConnectionString
More information about the mapguide-commits
