[mapguide-commits] r6505 - in trunk/Tools/Maestro:
Maestro.Editors/LayerDefinition/Vector
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Mon Feb 13 08:18:01 EST 2012
Author: jng
Date: 2012-02-13 05:18:01 -0800 (Mon, 13 Feb 2012)
New Revision: 6505
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
#1953: Remove empty Url/Tooltip/Filter elements if set to an empty string in the editor
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.Designer.cs 2012-02-13 13:17:15 UTC (rev 6504)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.Designer.cs 2012-02-13 13:18:01 UTC (rev 6505)
@@ -172,6 +172,7 @@
resources.ApplyResources(this.txtTooltip, "txtTooltip");
this.txtTooltip.Name = "txtTooltip";
+ this.txtTooltip.TextChanged += new System.EventHandler(this.txtTooltip_TextChanged);
// txtHyperlink
@@ -183,6 +184,7 @@
resources.ApplyResources(this.txtFilter, "txtFilter");
this.txtFilter.Name = "txtFilter";
+ this.txtFilter.TextChanged += new System.EventHandler(this.txtFilter_TextChanged);
// label6
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2012-02-13 13:17:15 UTC (rev 6504)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2012-02-13 13:18:01 UTC (rev 6505)
@@ -68,13 +68,15 @@
TextBoxBinder.BindText(txtFeatureClass, _vl, "FeatureName");
TextBoxBinder.BindText(txtGeometry, _vl, "Geometry");
- TextBoxBinder.BindText(txtFilter, _vl, "Filter");
+ //TextBoxBinder.BindText(txtFilter, _vl, "Filter");
+ txtFilter.Text = _vl.Filter;
//Loose bind this one because 2.4 changes this behaviour making it
//unsuitable for databinding via TextBoxBinder
txtHyperlink.Text = _vl.Url;
- TextBoxBinder.BindText(txtTooltip, _vl, "ToolTip");
+ //TextBoxBinder.BindText(txtTooltip, _vl, "ToolTip");
+ txtTooltip.Text = _vl.ToolTip;
//This is not the root object so no change listeners have been subscribed
_vl.PropertyChanged += OnVectorLayerPropertyChanged;
@@ -318,9 +320,34 @@
if (_init)
return;
- _vl.Url = txtHyperlink.Text;
+ if (string.IsNullOrEmpty(txtHyperlink.Text))
+ _vl.Url = null;
+ else
+ _vl.Url = txtHyperlink.Text;
+ private void txtFilter_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ if (string.IsNullOrEmpty(txtFilter.Text))
+ _vl.Filter = null;
+ else
+ _vl.Filter = txtFilter.Text;
+ private void txtTooltip_TextChanged(object sender, EventArgs e)
+ if (_init)
+ return;
+ if (string.IsNullOrEmpty(txtTooltip.Text))
+ _vl.ToolTip = null;
+ else
+ _vl.ToolTip = txtTooltip.Text;
private void btnGoToFeatureSource_Click(object sender, EventArgs e)
_edsvc.OpenResource(txtFeatureSource.Text);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx 2012-02-13 13:17:15 UTC (rev 6504)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx 2012-02-13 13:18:01 UTC (rev 6505)
@@ -411,21 +411,6 @@
<data name="grpFeatureClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
- <data name="btnBrowseGeometry.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Right</value>
- </data>
- <data name="btnBrowseGeometry.Location" type="System.Drawing.Point, System.Drawing">
- <value>377, 42</value>
- </data>
- <data name="btnBrowseGeometry.Size" type="System.Drawing.Size, System.Drawing">
- <value>30, 23</value>
- </data>
- <data name="btnBrowseGeometry.TabIndex" type="System.Int32, mscorlib">
- <value>12</value>
- </data>
- <data name="btnBrowseGeometry.Text" xml:space="preserve">
- <value>...</value>
- </data>
<data name=">>btnBrowseGeometry.Name" xml:space="preserve">
<value>btnBrowseGeometry</value>
</data>
@@ -438,21 +423,6 @@
<data name=">>btnBrowseGeometry.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="label3.AutoSize" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
- <value>15, 47</value>
- </data>
- <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
- <value>94, 13</value>
- </data>
- <data name="label3.TabIndex" type="System.Int32, mscorlib">
- <value>1</value>
- </data>
- <data name="label3.Text" xml:space="preserve">
- <value>Geometry Property</value>
- </data>
<data name=">>label3.Name" xml:space="preserve">
<value>label3</value>
</data>
@@ -465,21 +435,6 @@
<data name=">>label3.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="btnBrowseSchema.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- </data>
- <data name="btnBrowseSchema.Location" type="System.Drawing.Point, System.Drawing">
- <value>377, 17</value>
- </data>
- <data name="btnBrowseSchema.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="btnBrowseSchema.TabIndex" type="System.Int32, mscorlib">
- <value>11</value>
- </data>
- <data name="btnBrowseSchema.Text" xml:space="preserve">
- </data>
<data name=">>btnBrowseSchema.Name" xml:space="preserve">
<value>btnBrowseSchema</value>
</data>
@@ -492,21 +447,6 @@
<data name=">>btnBrowseSchema.ZOrder" xml:space="preserve">
<value>2</value>
</data>
- <data name="label2.AutoSize" type="System.Boolean, mscorlib">
- </data>
- <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
- <value>15, 22</value>
- </data>
- <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
- <value>71, 13</value>
- </data>
- <data name="label2.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
- </data>
- <data name="label2.Text" xml:space="preserve">
- <value>Feature Class</value>
- </data>
<data name=">>label2.Name" xml:space="preserve">
<value>label2</value>
</data>
@@ -519,18 +459,6 @@
<data name=">>label2.ZOrder" xml:space="preserve">
<value>3</value>
</data>
- <data name="txtGeometry.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Left, Right</value>
- </data>
- <data name="txtGeometry.Location" type="System.Drawing.Point, System.Drawing">
- <value>121, 44</value>
- </data>
- <data name="txtGeometry.Size" type="System.Drawing.Size, System.Drawing">
- <value>250, 20</value>
- </data>
- <data name="txtGeometry.TabIndex" type="System.Int32, mscorlib">
- <value>10</value>
- </data>
<data name=">>txtGeometry.Name" xml:space="preserve">
<value>txtGeometry</value>
</data>
@@ -543,18 +471,6 @@
<data name=">>txtGeometry.ZOrder" xml:space="preserve">
<value>4</value>
</data>
- <data name="txtFeatureClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- </data>
- <data name="txtFeatureClass.Location" type="System.Drawing.Point, System.Drawing">
- <value>121, 19</value>
- </data>
- <data name="txtFeatureClass.Size" type="System.Drawing.Size, System.Drawing">
- </data>
- <data name="txtFeatureClass.TabIndex" type="System.Int32, mscorlib">
- <value>9</value>
- </data>
<data name=">>txtFeatureClass.Name" xml:space="preserve">
<value>txtFeatureClass</value>
</data>
@@ -684,6 +600,162 @@
<data name=">>contentPanel.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <data name="btnBrowseGeometry.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Right</value>
+ </data>
+ <data name="btnBrowseGeometry.Location" type="System.Drawing.Point, System.Drawing">
+ <value>377, 42</value>
+ </data>
+ <data name="btnBrowseGeometry.Size" type="System.Drawing.Size, System.Drawing">
+ <value>30, 23</value>
+ </data>
+ <data name="btnBrowseGeometry.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name="btnBrowseGeometry.Text" xml:space="preserve">
+ <value>...</value>
+ </data>
+ <data name=">>btnBrowseGeometry.Name" xml:space="preserve">
+ <value>btnBrowseGeometry</value>
+ </data>
+ <data name=">>btnBrowseGeometry.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnBrowseGeometry.Parent" xml:space="preserve">
+ <value>grpFeatureClass</value>
+ </data>
+ <data name=">>btnBrowseGeometry.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 47</value>
+ </data>
+ <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>94, 13</value>
+ </data>
+ <data name="label3.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="label3.Text" xml:space="preserve">
+ <value>Geometry Property</value>
+ </data>
+ <data name=">>label3.Name" xml:space="preserve">
+ <value>label3</value>
+ </data>
+ <data name=">>label3.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label3.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnBrowseSchema.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="btnBrowseSchema.Location" type="System.Drawing.Point, System.Drawing">
+ <value>377, 17</value>
+ </data>
+ <data name="btnBrowseSchema.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnBrowseSchema.TabIndex" type="System.Int32, mscorlib">
+ <value>11</value>
+ </data>
+ <data name="btnBrowseSchema.Text" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowseSchema.Name" xml:space="preserve">
+ <value>btnBrowseSchema</value>
+ </data>
+ <data name=">>btnBrowseSchema.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowseSchema.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnBrowseSchema.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>15, 22</value>
+ </data>
+ <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+ <value>71, 13</value>
+ </data>
+ <data name="label2.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label2.Text" xml:space="preserve">
+ <value>Feature Class</value>
+ </data>
+ <data name=">>label2.Name" xml:space="preserve">
+ <value>label2</value>
+ </data>
+ <data name=">>label2.Type" xml:space="preserve">
+ </data>
+ <data name=">>label2.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label2.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="txtGeometry.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtGeometry.Location" type="System.Drawing.Point, System.Drawing">
+ <value>121, 44</value>
+ </data>
+ <data name="txtGeometry.Size" type="System.Drawing.Size, System.Drawing">
+ <value>250, 20</value>
+ </data>
+ <data name="txtGeometry.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name=">>txtGeometry.Name" xml:space="preserve">
+ <value>txtGeometry</value>
+ </data>
+ <data name=">>txtGeometry.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtGeometry.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtGeometry.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="txtFeatureClass.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtFeatureClass.Location" type="System.Drawing.Point, System.Drawing">
+ <value>121, 19</value>
+ </data>
+ <data name="txtFeatureClass.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="txtFeatureClass.TabIndex" type="System.Int32, mscorlib">
+ <value>9</value>
+ </data>
+ <data name=">>txtFeatureClass.Name" xml:space="preserve">
+ <value>txtFeatureClass</value>
+ </data>
+ <data name=">>txtFeatureClass.Type" xml:space="preserve">
+ </data>
+ <data name=">>txtFeatureClass.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtFeatureClass.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-02-13 13:17:15 UTC (rev 6504)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-02-13 13:18:01 UTC (rev 6505)
@@ -1718,9 +1718,20 @@
set
- if (this.urlDataField == null)
- this.urlDataField = new URLDataType();
- this.urlDataField.Content = value;
+ if (!string.IsNullOrEmpty(value))
+ if (this.urlDataField == null)
+ this.urlDataField = new URLDataType();
+ this.urlDataField.Content = value;
+ OnPropertyChanged("Url");
+ else
+ //NOTE: None of the other URLData properties seem to be used atm
+ //hence why we are nulling this
+ this.urlDataField = null;
#else
get { return this.Url; }
More information about the mapguide-commits
