[mapguide-commits] r6506 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Mon Feb 13 08:50:41 EST 2012
Author: jng
Date: 2012-02-13 05:50:41 -0800 (Mon, 13 Feb 2012)
New Revision: 6506
trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.resx
#1952: Support validation result filtering by category
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.cs 2012-02-13 13:18:01 UTC (rev 6505)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.cs 2012-02-13 13:50:41 UTC (rev 6506)
@@ -22,6 +22,7 @@
using System.ComponentModel;
using System.Data;
using System.Drawing;
+using System.Linq;
using System.Text;
using System.Windows.Forms;
using OSGeo.MapGuide.MaestroAPI;
@@ -47,14 +48,43 @@
public ValidationResultsDialog(List<KeyValuePair<string, ValidationIssue[]>> issues)
: this()
- listView1.Items.Clear();
m_issues = issues;
+ PopulateIssues();
- foreach (KeyValuePair<string, ValidationIssue[]> e in issues)
+ private void PopulateIssues()
+ listView1.Items.Clear();
+ foreach (KeyValuePair<string, ValidationIssue[]> e in m_issues)
- foreach (ValidationIssue issue in e.Value)
+ IEnumerable<ValidationIssue> items = null;
+ if (chkErrors.Checked)
+ if (items == null)
+ items = e.Value.Where(x => x.Status == ValidationStatus.Error);
+ else
+ items = items.Concat(e.Value.Where(x => x.Status == ValidationStatus.Error));
+ if (chkWarnings.Checked)
+ items = e.Value.Where(x => x.Status == ValidationStatus.Warning);
+ else
+ items = items.Concat(e.Value.Where(x => x.Status == ValidationStatus.Warning));
+ if (chkNotices.Checked)
+ items = e.Value.Where(x => x.Status == ValidationStatus.Information);
+ else
+ items = items.Concat(e.Value.Where(x => x.Status == ValidationStatus.Information));
+ continue;
+ foreach (ValidationIssue issue in items)
if (issue == null || issue.Resource == null || string.IsNullOrEmpty(issue.Message) || string.IsNullOrEmpty(issue.Resource.ResourceID))
continue;
@@ -119,5 +149,10 @@
MessageBox.Show(this, string.Format(Properties.Resources.ValidationFailedError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ private void OnResultFilterCheckedChanged(object sender, EventArgs e)
+ PopulateIssues();
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.designer.cs 2012-02-13 13:18:01 UTC (rev 6505)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.designer.cs 2012-02-13 13:50:41 UTC (rev 6506)
@@ -34,15 +34,21 @@
this.SaveReportBtn = new System.Windows.Forms.Button();
this.CancelBtn = new System.Windows.Forms.Button();
this.listView1 = new System.Windows.Forms.ListView();
- this.columnHeader1 = new System.Windows.Forms.ColumnHeader();
- this.columnHeader2 = new System.Windows.Forms.ColumnHeader();
+ this.columnHeader1 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
+ this.columnHeader2 = ((System.Windows.Forms.ColumnHeader)(new System.Windows.Forms.ColumnHeader()));
this.imageList1 = new System.Windows.Forms.ImageList(this.components);
this.saveFileDialog = new System.Windows.Forms.SaveFileDialog();
+ this.chkErrors = new System.Windows.Forms.CheckBox();
+ this.chkWarnings = new System.Windows.Forms.CheckBox();
+ this.chkNotices = new System.Windows.Forms.CheckBox();
this.panel1.SuspendLayout();
this.SuspendLayout();
// panel1
+ this.panel1.Controls.Add(this.chkNotices);
+ this.panel1.Controls.Add(this.chkWarnings);
+ this.panel1.Controls.Add(this.chkErrors);
this.panel1.Controls.Add(this.SaveReportBtn);
this.panel1.Controls.Add(this.CancelBtn);
resources.ApplyResources(this.panel1, "panel1");
@@ -96,6 +102,33 @@
this.saveFileDialog.DefaultExt = "txt";
resources.ApplyResources(this.saveFileDialog, "saveFileDialog");
+ // chkErrors
+ resources.ApplyResources(this.chkErrors, "chkErrors");
+ this.chkErrors.Checked = true;
+ this.chkErrors.CheckState = System.Windows.Forms.CheckState.Checked;
+ this.chkErrors.Name = "chkErrors";
+ this.chkErrors.UseVisualStyleBackColor = true;
+ this.chkErrors.CheckedChanged += new System.EventHandler(this.OnResultFilterCheckedChanged);
+ // chkWarnings
+ resources.ApplyResources(this.chkWarnings, "chkWarnings");
+ this.chkWarnings.Checked = true;
+ this.chkWarnings.CheckState = System.Windows.Forms.CheckState.Checked;
+ this.chkWarnings.Name = "chkWarnings";
+ this.chkWarnings.UseVisualStyleBackColor = true;
+ this.chkWarnings.CheckedChanged += new System.EventHandler(this.OnResultFilterCheckedChanged);
+ // chkNotices
+ resources.ApplyResources(this.chkNotices, "chkNotices");
+ this.chkNotices.Checked = true;
+ this.chkNotices.CheckState = System.Windows.Forms.CheckState.Checked;
+ this.chkNotices.Name = "chkNotices";
+ this.chkNotices.UseVisualStyleBackColor = true;
+ this.chkNotices.CheckedChanged += new System.EventHandler(this.OnResultFilterCheckedChanged);
// ValidationResultsDialog
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -106,6 +139,7 @@
this.Name = "ValidationResultsDialog";
this.ShowIcon = false;
this.panel1.ResumeLayout(false);
+ this.panel1.PerformLayout();
this.ResumeLayout(false);
@@ -120,5 +154,8 @@
private System.Windows.Forms.ImageList imageList1;
private System.Windows.Forms.Button SaveReportBtn;
private System.Windows.Forms.SaveFileDialog saveFileDialog;
+ private System.Windows.Forms.CheckBox chkNotices;
+ private System.Windows.Forms.CheckBox chkWarnings;
+ private System.Windows.Forms.CheckBox chkErrors;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.resx 2012-02-13 13:18:01 UTC (rev 6505)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ValidationResultsDialog.resx 2012-02-13 13:50:41 UTC (rev 6506)
@@ -112,23 +112,113 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="chkNotices.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="chkNotices.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="chkNotices.Location" type="System.Drawing.Point, System.Drawing">
+ <value>245, 12</value>
+ </data>
+ <data name="chkNotices.Size" type="System.Drawing.Size, System.Drawing">
+ <value>62, 17</value>
+ </data>
+ <data name="chkNotices.TabIndex" type="System.Int32, mscorlib">
+ <value>4</value>
+ </data>
+ <data name="chkNotices.Text" xml:space="preserve">
+ <value>Notices</value>
+ </data>
+ <data name=">>chkNotices.Name" xml:space="preserve">
+ <value>chkNotices</value>
+ </data>
+ <data name=">>chkNotices.Type" xml:space="preserve">
+ <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>chkNotices.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>chkNotices.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="chkWarnings.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="chkWarnings.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkWarnings.Location" type="System.Drawing.Point, System.Drawing">
+ <value>168, 12</value>
+ </data>
+ <data name="chkWarnings.Size" type="System.Drawing.Size, System.Drawing">
+ <value>71, 17</value>
+ </data>
+ <data name="chkWarnings.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="chkWarnings.Text" xml:space="preserve">
+ <value>Warnings</value>
+ </data>
+ <data name=">>chkWarnings.Name" xml:space="preserve">
+ <value>chkWarnings</value>
+ </data>
+ <data name=">>chkWarnings.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkWarnings.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkWarnings.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="chkErrors.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="chkErrors.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="chkErrors.Location" type="System.Drawing.Point, System.Drawing">
+ <value>109, 12</value>
+ </data>
+ <data name="chkErrors.Size" type="System.Drawing.Size, System.Drawing">
+ <value>53, 17</value>
+ </data>
+ <data name="chkErrors.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="chkErrors.Text" xml:space="preserve">
+ <value>Errors</value>
+ </data>
+ <data name=">>chkErrors.Name" xml:space="preserve">
+ <value>chkErrors</value>
+ </data>
+ <data name=">>chkErrors.Type" xml:space="preserve">
+ </data>
+ <data name=">>chkErrors.Parent" xml:space="preserve">
+ </data>
+ <data name=">>chkErrors.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<data name="SaveReportBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="SaveReportBtn.Location" type="System.Drawing.Point, System.Drawing">
<value>12, 8</value>
</data>
<data name="SaveReportBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>91, 23</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="SaveReportBtn.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
</data>
@@ -139,13 +229,13 @@
<value>SaveReportBtn</value>
</data>
<data name=">>SaveReportBtn.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>SaveReportBtn.Parent" xml:space="preserve">
</data>
<data name=">>SaveReportBtn.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>3</value>
</data>
<data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Right</value>
@@ -166,13 +256,13 @@
<value>CancelBtn</value>
</data>
<data name=">>CancelBtn.Type" xml:space="preserve">
</data>
<data name=">>CancelBtn.Parent" xml:space="preserve">
</data>
<data name=">>CancelBtn.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>4</value>
</data>
<data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Bottom</value>
@@ -190,7 +280,7 @@
</data>
<data name=">>panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>panel1.Parent" xml:space="preserve">
<value>$this</value>
@@ -219,78 +309,77 @@
<data name="listView1.Size" type="System.Drawing.Size, System.Drawing">
<value>595, 232</value>
</data>
- <metadata name="imageList1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="imageList1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>146, 17</value>
</metadata>
<data name="imageList1.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
<value>
- AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj00LjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADI
- DgAAAk1TRnQBSQFMAgEBAwEAARwBAAEcAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAC8
+ DgAAAk1TRnQBSQFMAgEBAwEAASQBAAEkAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
AwABEAMAAQEBAAEgBgABEC4AAwwBEAMVAR0kAAMQARUDEQEXAxEBFwMRARcDEQEXAxEBFwMRARcDEQEX
- AxEBFwMRARcDEQEXAxUBHRwAAwkBDAMWAR8DFgEfAxYBHwMWAR8DFgEfZAADEgEYAX0BMwEgAfcBxAFF
- ASwB/wHNAUkBLwH/Ac4BSQEvAf8BygFIAS4B/wGkATkBJAH/AUgCRwGGFAABVQFJAUwBzQEAAbsB6wH/
- AQABvQHsAf8BAAHBAe4B/wEAAcQB8AH/AQABxQHwAf8BAAHFAfAB/wEAAcUB8AH/AQABxQHwAf8BAAHF
- AfAB/wEAAcMB7wH/AQABvwHtAf8BAAG7AesB/wEEAZcBvgH/FAABVAJNAasBKAE6AbYB/wEqAT0BwAH/
- ASsBPwHGAf8BKwE/AccB/wEqAT4BwwH/ASkBPAG7Af8BIQEoAYEB/1wAAUoCSAGKAcYBRgEtAf8B1wFM
- ATEB/wHjAVABNAH/AekBUgE1Af8B6gFSATUB/wHmAVEBNAH/Ad0BTgEyAf8BzwFJAS8B/wF/ASsBJAH8
- EAABBgGCAaMB/wEAAbwB7AH/AQABxQHwAf8BAAHLAfMB/wEAAc4B9QH/AQAB0AH2Af8BAAHQAfYB/wEA
- AdAB9gH/AQAB0AH2Af8BAAHPAfYB/wEAAc0B9AH/AQAByAHyAf8BAAHAAe4B/wEAAbsB6wH/AxIBGAwA
- AVQCTQGrASoBPgHBAf8BLQFCAdAB/wEvAUUB2QH/ATABRwHeAf8BMAFHAd8B/wEwAUYB3AH/AS4BRAHV
- Af8BKwFAAcgB/wEiASoBhAH/VAABOwI6AWMBygFHAS4B/wHfAU8BMwH/Ae8BVAE3Af8B+wHxAe8B/wH9
- AvkB/wHhAWUBTgH/AfwBWQE6Af8B9QFWATgB/wHnAVEBNQH/AdMBSwEwAf8BfwErASQB/AwAAT4CPQFr
- AQABvwHtAf8BAAHJAfIB/wEAAdAB9gH/AQAB1AH5Af8BAAHUAfcB/wGFAdwB6wH/AYEB2wHqAf8BAAHQ
- AfMB/wEAAdYB+gH/AQAB0gH4Af8BAAHNAfQB/wEAAcMB7wH/AQcBgAGdAf8MAAFUAk0BqwEqAT4BwwH/
- AS8BRAHWAf8BMgFJAeQB/wEzAUsB7AH/ATQBTAHvAf8BNAFNAfAB/wE0AUwB7gH/ATIBSgHmAf8BMAFH
- Ad0B/wEsAUEBzAH/ASIBKgGEAf9QAAG3AUABKQH/Ad0BTgEyAf8B8gFVATcB/wH+AVwBPgn/AeMBiQF3
- Af8B6AGbAY0C/wFgAUIB/wH5AVgBOQH/AecBUQE1Af8BzwFJAS8B/wFIAkcBhgwAARABjgGuAf8BOwHW
- AfUB/wFBAd0B+QH/ATcB4AH7Af8BHAHNAekJ/wEqAcoB4wH/AQAB2QH7Af8BAAHUAfkB/wEAAc0B9QH/
- AQABwwHvAf8DLwFJCAABUAJLAZ8BKQE9Ab0B/wEuAUQB1QH/ATIBSgHmAf8BqgGzAesB/wGcAaYB6QH/
- ATcBUAH6Af8BNwFQAfsB/wFXAWkB4AH/AeUB6AH4Af8BMwFKAegB/wEwAUcB3QH/ASsBQAHIAf8BIQEo
- AYEB/0gAAUcCRQGBAdEBSgEwAf8B6wFSATYB/wH+AVoBPAL/AWYBSQH/AewBsQGlBf8B8wHMAcQB/wHh
- AXABWQH/AfwBaAFMAv8BYAFCAf8B9QFWATgB/wHdAU4BMgH/AaQBOQEkAf8MAAE9AjwBaAFJAdYB9QH/
- AVAB3gH5Af8BVgHkAfsB/wFdAegB/QH/AXIB2QHpAf8BgQHeAesB/wEJAdsB+wH/AQAB2AH7Af8BAAHT
- AfgB/wEAAcoB8wH/AQcBgQGeAf8MAAEiASoBgwH/ASwBQAHKAf8BMQFIAeAB/wGIAZQB4gn/AZwBpwHs
- Af8BWAFrAeQJ/wHeAeEB9wH/ATIBSgHoAf8BLgFEAdUB/wEpATwBuwH/AxYBH0QAAYEBJwEhAfsB2gFN
- ATIB/wH0AVUBNwL/AWQBSAL/AXMBWAH/AewBbgFVCf8B+AF0AVkC/wF1AVoC/wFtAVIB/wH8AVkBOgH/
- AeYBUQE0Af8BygFIAS4B/xAAAS4BlgGwAf8BXgHeAfgB/wFlAeUB+wH/AWwB6QH9Cf8BgQHoAfkB/wFW
- AeQB+wH/AQABzwH2Af8BAAHFAfAB/wMuAUcMAAEjASwBiQH/ATYBSwHUAf8BRAFaAekB/wFQAWUB9QH/
- AdcB2wH3Ef8B9wH4Af0B/wE0AU0B8AH/ATQBTAHuAf8BMAFGAdwB/wEqAT4BwwH/AxYBH0QAAZ4BNgEj
- Af8B3wFPATMB/wH3AWUBSQL/AXcBXgH/AfgBgAFlAf8B7AF6AWMB/wH8AfMB8QX/AeYBiwF5Av8BgQFo
- Av8BewFjAf8B/gFwAVYB/wHqAVIBNQH/Ac4BSQEvAf8DFQEdDAADPAFmAW0B3gH3Af8BdAHlAfoB/wF7
- AeoB/An/AY8B6gH5Af8BlgHtAfwB/wFbAd0B9wH/AQcBgQGeAf8QAAEvATcBjwH/AUoBXAHbAf8BUwFn
- Ae0B/wFcAXEB+AH/AWQBdwH8Af8B3wHiAfkJ/wH8Af0B/gH/AYUBlAH5Af8BcQGDAfwB/wE0AU0B8AH/
- ATABRwHfAf8BKwE/AccB/wMWAR9EAAGXATQBIQH/Ad4BTwEzAf8B+AGAAWUC/wGFAW8B/wH+AY0BdwH/
- AfUB2AHSAf8B5wGbAY0F/wH5AecB5AL/AY4BeAL/AYkBcwH/Af4BgQFoAf8B7QF0AV0B/wHNAUkBLwH/
- AwwBEBAAAT4BmgGxAf8BgwHmAfkB/wGKAesB/An/AZ4B7AH5Af8BpAHuAfsB/wGqAewB+gH/Ay0BRhAA
- ATQBOwGQAf8BVAFmAdwB/wFeAXEB7QH/AWcBegH4Af8BhgGTAeoR/wHJAc8B9AH/AZkBpgH8Af8BoAGr
- AfcB/wFWAWkB5AH/ASsBPwHGAf8DFgEfRAABYgFEAUAB1QHcAWYBTwH/AfUBjQF6Av8BkwGBAv8BmwGI
- Af8B/gGeAYoB/wHtAbEBpgH/AfwB9gH0Af8B7wG8AbIC/wGdAYoC/wGXAYQB/wH7AY8BewH/AewBigF3
- Af8BxAFFASwB/xQAAzsBZQGSAeYB+QH/AZkB7AH7Cf8BrAHuAfkB/wGyAe8B+wH/AUIBjgGiAf8UAAE5
- AT8BjwH/AV4BbgHaAf8BaQF6AesB/wGJAZUB5gn/AfoB+wH+Af8B5AHnAfoJ/wHTAdcB9QH/AawBtQH3
- Af8BsQG5AfEB/wFhAW8BzwH/AxYBH0QAAx8BLQHUAWkBVAH/AfEBngGOAf8B/AGiAZEC/wGnAZcC/wGr
- AZsC/wGtAZ0B/wHvAbYBqwH/Af4B/QH8Af8B8QGlAZcB/wH+AaQBkwH/AfYBnwGPAf8B6QGbAYwB/wF9
- ATMBIAH3GAABTgGdAbIB/wGnAe0B+wn/AbkB7wH5Af8BvgHwAfsB/wMtAUUUAAEwATMBeAH/AWkBdwHW
- Af8BdAGDAecB/wF8AYoB6QH/A/4B/wL7Af4B/wGVAaIB+QH/AZ0BqQH9Af8B6QHrAfoF/wG2Ab0B8AH/
- AbcBvwH1Af8BvAHDAfAB/wHBAcYB6gH/AwkBDEgAAYIBMQEdAfkB7AGuAaIB/wH1AbEBpAH/AfwBtAGm
- Av8BtgGpAv8BuAGrAf8B9wHdAdkF/wH1AdUBzwH/AfkBsgGlAf8B8AGwAaMB/wHeAZgBigH/AxIBGBgA
- AzsBZAG0Ae0B+gn/AcUB8AH6Af8BRwGPAaIB/xgAAwgBCwFXAV8BqgH/AYEBiwHhAf8BiAGWAe0B/wGQ
- AZwB7QH/AZkBpAH0Af8BoQGtAfsB/wGoAbMB+wH/Aa8BuQH6Af8BuQHAAfEB/wG8AcMB9wH/AcEByAHz
- Af8BxwHMAe4B/wFUAk0Bq08AAQEBvgF3AWkB/wHwAcEBtwH/AfYBwgG5Af8B+gHEAboB/wH8AcQBugH/
- AfsBxAG6Af8B8gHGAb0B/wH2AcIBuQH/AfMBwgG4Af8B7AG+AbUB/wFKAkgBiiAAAVsBnwGyAf8BxgHx
- AfsB/wHLAfIB/AH/AdAB8wH8Af8DLAFEHAADCAELAWYBbQGwAf8BkwGeAeYB/wGcAacB7gH/AaUBrwHz
- Af8BrAG2AfYB/wGzAbwB9wH/AboBwgH3Af8BwAHHAfUB/wHGAcwB8wH/AcsB0AHwAf8BVAJNAatXAAEB
- AYoBQQE6AfkB8gHQAckB/wH0AdEBygH/AfYB0gHKAf8B9gHSAcoB/wH1AdEBygH/AfMB0AHKAf8B1AGe
- AZMB/wE7AjoBYyQAAzsBZAHRAfIB+wH/AdUB9AH8Af8BTQGQAaMB/yQAAwgBCwF0AXkBswH/AacBrwHn
- Af8BrwG3Ae0B/wG2Ab4B8AH/Ab0BxAHyAf8BxAHKAfIB/wHKAc8B8QH/Ac8B0wHwAf8BVAJNAatgAAMf
- AS0BYgFEAUAB1QGpAWsBYAH/AbQBewFwAf8BigFGATMB+wFHAkUBgTAAAVIBSAFMAdwBTwGRAaQB/wMW
- AR4oAAMIAQsBSAFJAYEB/wFrAW0BnwH/AW4BcQGiAf8BcgF0AaQB/wF1AXYBpAH/AXMBdAGgAf8BUAJL
- AZ//AFEAAUIBTQE+BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIA
- AfABDwGAAQEB8AEPAgAB4AEHAYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEB
- AcABAwGAAwABgAEBAeABAwGAAwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEB
- AfgBDwGAAwABwAEBAfgBHwGAAQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHw
- AQ8CAAb/AgAL
+ AxEBFwMRARcDEQEXAxUBHRwAAwkBDAMWAR8DFgEfAxYBHwMWAR8DFgEfZAADEgEYAXoBNQEkAfcBxAFE
+ ASsB/wHNAUgBLgH/Ac4BSAEuAf8BygFHAS0B/wGkATgBIwH/A0gBhhQAAVcCUAHNAQABuwHrAf8BAAG9
+ AewB/wEAAcEB7gH/AQABxAHwAf8BAAHFAfAB/wEAAcUB8AH/AQABxQHwAf8BAAHFAfAB/wEAAcUB8AH/
+ AQABwwHvAf8BAAG/Ae0B/wEAAbsB6wH/AQMBlwG+Af8UAAFUAlEBqwEnATkBtgH/ASkBPAHAAf8BKgE+
+ AcYB/wEqAT4BxwH/ASkBPQHDAf8BKAE7AbsB/wEgAScBgQH/XAABSgJJAYoBxgFFASwB/wHXAUsBMAH/
+ AeMBTwEzAf8B6QFRATQB/wHqAVEBNAH/AeYBUAEzAf8B3QFNATEB/wHPAUgBLgH/AX4BKwElAfwQAAEF
+ AYIBowH/AQABvAHsAf8BAAHFAfAB/wEAAcsB8wH/AQABzgH1Af8BAAHQAfYB/wEAAdAB9gH/AQAB0AH2
+ Af8BAAHQAfYB/wEAAc8B9gH/AQABzQH0Af8BAAHIAfIB/wEAAcAB7gH/AQABuwHrAf8DEgEYDAABVAJR
+ AasBKQE9AcEB/wEsAUEB0AH/AS4BRAHZAf8BLwFGAd4B/wEvAUYB3wH/AS8BRQHcAf8BLQFDAdUB/wEq
+ AT8ByAH/ASEBKQGEAf9UAAM7AWMBygFGAS0B/wHfAU4BMgH/Ae8BUwE2Af8B+wHxAe8B/wH9AvkB/wHh
+ AWQBTQH/AfwBWAE5Af8B9QFVATcB/wHnAVABNAH/AdMBSgEvAf8BfgErASUB/AwAAz4BawEAAb8B7QH/
+ AQAByQHyAf8BAAHQAfYB/wEAAdQB+QH/AQAB1AH3Af8BhQHcAesB/wGBAdsB6gH/AQAB0AHzAf8BAAHW
+ AfoB/wEAAdIB+AH/AQABzQH0Af8BAAHDAe8B/wEGAYABnQH/DAABVAJRAasBKQE9AcMB/wEuAUMB1gH/
+ ATEBSAHkAf8BMgFKAewB/wEzAUsB7wH/ATMBTAHwAf8BMwFLAe4B/wExAUkB5gH/AS8BRgHdAf8BKwFA
+ AcwB/wEhASkBhAH/UAABtwE/ASgB/wHdAU0BMQH/AfIBVAE2Af8B/gFbAT0J/wHjAYkBdgH/AegBmwGN
+ Av8BXwFBAf8B+QFXATgB/wHnAVABNAH/Ac8BSAEuAf8DSAGGDAABDwGOAa4B/wE6AdYB9QH/AUAB3QH5
+ Af8BNgHgAfsB/wEbAc0B6Qn/ASkBygHjAf8BAAHZAfsB/wEAAdQB+QH/AQABzQH1Af8BAAHDAe8B/wMv
+ AUkIAAFQAk4BnwEoATwBvQH/AS0BQwHVAf8BMQFJAeYB/wGqAbMB6wH/AZwBpgHpAf8BNgFPAfoB/wE2
+ AU8B+wH/AVYBaAHgAf8B5QHoAfgB/wEyAUkB6AH/AS8BRgHdAf8BKgE/AcgB/wEgAScBgQH/SAABRwJG
+ AYEB0QFJAS8B/wHrAVEBNQH/Af4BWQE7Av8BZQFIAf8B7AGxAaUF/wHzAcwBxAH/AeEBbwFYAf8B/AFn
+ AUsC/wFfAUEB/wH1AVUBNwH/Ad0BTQExAf8BpAE4ASMB/wwAAT0CPAFoAUgB1gH1Af8BTwHeAfkB/wFV
+ AeQB+wH/AVwB6AH9Af8BcQHZAekB/wGBAd4B6wH/AQgB2wH7Af8BAAHYAfsB/wEAAdMB+AH/AQABygHz
+ Af8BBgGBAZ4B/wwAASEBKQGDAf8BKwE/AcoB/wEwAUcB4AH/AYgBlAHiCf8BnAGnAewB/wFXAWoB5An/
+ Ad4B4QH3Af8BMQFJAegB/wEtAUMB1QH/ASgBOwG7Af8DFgEfRAABgAEnASEB+wHaAUwBMQH/AfQBVAE2
+ Av8BYwFHAv8BcgFXAf8B7AFtAVQJ/wH4AXMBWAL/AXQBWQL/AWwBUQH/AfwBWAE5Af8B5gFQATMB/wHK
+ AUcBLQH/EAABLQGWAbAB/wFdAd4B+AH/AWQB5QH7Af8BawHpAf0J/wGBAegB+QH/AVUB5AH7Af8BAAHP
+ AfYB/wEAAcUB8AH/Ay4BRwwAASIBKwGJAf8BNQFKAdQB/wFDAVkB6QH/AU8BZAH1Af8B1wHbAfcR/wH3
+ AfgB/QH/ATMBTAHwAf8BMwFLAe4B/wEvAUUB3AH/ASkBPQHDAf8DFgEfRAABngE1ASIB/wHfAU4BMgH/
+ AfcBZAFIAv8BdgFdAf8B+AGAAWQB/wHsAXkBYgH/AfwB8wHxBf8B5gGLAXgC/wGBAWcC/wF6AWIB/wH+
+ AW8BVQH/AeoBUQE0Af8BzgFIAS4B/wMVAR0MAAM8AWYBbAHeAfcB/wFzAeUB+gH/AXoB6gH8Cf8BjwHq
+ AfkB/wGWAe0B/AH/AVoB3QH3Af8BBgGBAZ4B/xAAAS4BNgGPAf8BSQFbAdsB/wFSAWYB7QH/AVsBcAH4
+ Af8BYwF2AfwB/wHfAeIB+Qn/AfwB/QH+Af8BhQGUAfkB/wFwAYMB/AH/ATMBTAHwAf8BLwFGAd8B/wEq
+ AT4BxwH/AxYBH0QAAZcBMwEgAf8B3gFOATIB/wH4AYABZAL/AYUBbgH/Af4BjQF2Af8B9QHYAdIB/wHn
+ AZsBjQX/AfkB5wHkAv8BjgF3Av8BiQFyAf8B/gGBAWcB/wHtAXMBXAH/Ac0BSAEuAf8DDAEQEAABPQGa
+ AbEB/wGDAeYB+QH/AYoB6wH8Cf8BngHsAfkB/wGkAe4B+wH/AaoB7AH6Af8DLQFGEAABMwE6AZAB/wFT
+ AWUB3AH/AV0BcAHtAf8BZgF5AfgB/wGGAZMB6hH/AckBzwH0Af8BmQGmAfwB/wGgAasB9wH/AVUBaAHk
+ Af8BKgE+AcYB/wMWAR9EAAFhAUwBSQHVAdwBZQFOAf8B9QGNAXkC/wGTAYEC/wGbAYgB/wH+AZ4BigH/
+ Ae0BsQGmAf8B/AH2AfQB/wHvAbwBsgL/AZ0BigL/AZcBhAH/AfsBjwF6Af8B7AGKAXYB/wHEAUQBKwH/
+ FAADOwFlAZIB5gH5Af8BmQHsAfsJ/wGsAe4B+QH/AbIB7wH7Af8BQQGOAaIB/xQAATgBPgGPAf8BXQFt
+ AdoB/wFoAXkB6wH/AYkBlQHmCf8B+gH7Af4B/wHkAecB+gn/AdMB1wH1Af8BrAG1AfcB/wGxAbkB8QH/
+ AWABbgHPAf8DFgEfRAADHwEtAdQBaAFTAf8B8QGeAY4B/wH8AaIBkQL/AacBlwL/AasBmwL/Aa0BnQH/
+ Ae8BtgGrAf8B/gH9AfwB/wHxAaUBlwH/Af4BpAGTAf8B9gGfAY8B/wHpAZsBjAH/AXoBNQEkAfcYAAFN
+ AZ0BsgH/AacB7QH7Cf8BuQHvAfkB/wG+AfAB+wH/Ay0BRRQAAS8BMgF3Af8BaAF2AdYB/wFzAYMB5wH/
+ AXsBigHpAf8D/gH/AvsB/gH/AZUBogH5Af8BnQGpAf0B/wHpAesB+gX/AbYBvQHwAf8BtwG/AfUB/wG8
+ AcMB8AH/AcEBxgHqAf8DCQEMSAABgQEzAR8B+QHsAa4BogH/AfUBsQGkAf8B/AG0AaYC/wG2AakC/wG4
+ AasB/wH3Ad0B2QX/AfUB1QHPAf8B+QGyAaUB/wHwAbABowH/Ad4BmAGKAf8DEgEYGAADOwFkAbQB7QH6
+ Cf8BxQHwAfoB/wFGAY8BogH/GAADCAELAVYBXgGqAf8BgQGLAeEB/wGIAZYB7QH/AZABnAHtAf8BmQGk
+ AfQB/wGhAa0B+wH/AagBswH7Af8BrwG5AfoB/wG5AcAB8QH/AbwBwwH3Af8BwQHIAfMB/wHHAcwB7gH/
+ AVQCUQGrTwABAQG+AXYBaAH/AfABwQG3Af8B9gHCAbkB/wH6AcQBugH/AfwBxAG6Af8B+wHEAboB/wHy
+ AcYBvQH/AfYBwgG5Af8B8wHCAbgB/wHsAb4BtQH/AUoCSQGKIAABWgGfAbIB/wHGAfEB+wH/AcsB8gH8
+ Af8B0AHzAfwB/wMsAUQcAAMIAQsBZQFsAbAB/wGTAZ4B5gH/AZwBpwHuAf8BpQGvAfMB/wGsAbYB9gH/
+ AbMBvAH3Af8BugHCAfcB/wHAAccB9QH/AcYBzAHzAf8BywHQAfAB/wFUAlEBq1cAAQEBiQFBATwB+QHy
+ AdAByQH/AfQB0QHKAf8B9gHSAcoB/wH2AdIBygH/AfUB0QHKAf8B8wHQAcoB/wHUAZ4BkwH/AzsBYyQA
+ AzsBZAHRAfIB+wH/AdUB9AH8Af8BTAGQAaMB/yQAAwgBCwFzAXgBswH/AacBrwHnAf8BrwG3Ae0B/wG2
+ Ab4B8AH/Ab0BxAHyAf8BxAHKAfIB/wHKAc8B8QH/Ac8B0wHwAf8BVAJRAatgAAMfAS0BYQFMAUkB1QGp
+ AWoBXwH/AbQBegFvAf8BiQFGATIB+wFHAkYBgTAAAVUBTQFRAdwBTgGRAaQB/wMWAR4oAAMIAQsBRwFI
+ AYEB/wFqAWwBnwH/AW0BcAGiAf8BcQFzAaQB/wF0AXUBpAH/AXIBcwGgAf8BUAJOAZ//AFEAAUIBTQE+
+ BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIAAfABDwGAAQEB8AEP
+ AgAB4AEHAYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEBAcABAwGAAwABgAEB
+ AeABAwGAAwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEBAfgBDwGAAwABwAEB
+ AfgBHwGAAQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHwAQ8CAAb/AgAL
</value>
</data>
<data name="listView1.TabIndex" type="System.Int32, mscorlib">
@@ -300,7 +389,7 @@
<value>listView1</value>
</data>
<data name=">>listView1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>listView1.Parent" xml:space="preserve">
@@ -308,7 +397,7 @@
<data name=">>listView1.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="saveFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <metadata name="saveFileDialog.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
<data name="saveFileDialog.Filter" xml:space="preserve">
@@ -317,7 +406,7 @@
<data name="saveFileDialog.Title" xml:space="preserve">
<value>Select the filename to write the report to</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
@@ -333,30 +422,30 @@
<value>columnHeader1</value>
</data>
<data name=">>columnHeader1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>columnHeader2.Name" xml:space="preserve">
<value>columnHeader2</value>
</data>
<data name=">>columnHeader2.Type" xml:space="preserve">
</data>
<data name=">>imageList1.Name" xml:space="preserve">
<value>imageList1</value>
</data>
<data name=">>imageList1.Type" xml:space="preserve">
- <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>saveFileDialog.Name" xml:space="preserve">
<value>saveFileDialog</value>
</data>
<data name=">>saveFileDialog.Type" xml:space="preserve">
- <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>ValidationResultsDialog</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
</root>
More information about the mapguide-commits
