[mapguide-commits] r6432 - in branches/maestro-4.0.x:
MaestroAPITests OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Mon Jan 16 08:34:47 EST 2012
Author: jng
Date: 2012-01-16 05:34:47 -0800 (Mon, 16 Jan 2012)
New Revision: 6432
branches/maestro-4.0.x/MaestroAPITests/RuntimeMapTests.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
#1916: Fix incorrect map extent serialization. Includes unit test
Modified: branches/maestro-4.0.x/MaestroAPITests/RuntimeMapTests.cs
--- branches/maestro-4.0.x/MaestroAPITests/RuntimeMapTests.cs 2012-01-16 09:26:03 UTC (rev 6431)
+++ branches/maestro-4.0.x/MaestroAPITests/RuntimeMapTests.cs 2012-01-16 13:34:47 UTC (rev 6432)
@@ -111,6 +111,26 @@
protected abstract IServerConnection CreateTestConnection();
+ public virtual void TestExtentSerialization()
+ var resSvc = _conn.ResourceService;
+ var mdf = resSvc.GetResource("Library://UnitTests/Maps/Sheboygan.MapDefinition") as IMapDefinition;
+ Assert.NotNull(mdf);
+ mdf.Extents = ObjectFactory.CreateEnvelope(1.0, 2.0, 3.0, 4.0);
+ var mapSvc = _conn.GetService((int)ServiceType.Mapping) as IMappingService;
+ Assert.NotNull(mapSvc);
+ var map = mapSvc.CreateMap("Session:" + _conn.SessionID + "//TestExtentSerialization.Map", mdf, 1.0);
+ map.Save();
+ var map2 = mapSvc.OpenMap("Session:" + _conn.SessionID + "//TestExtentSerialization.Map");
+ Assert.AreEqual(1.0, map2.DataExtent.MinX);
+ Assert.AreEqual(2.0, map2.DataExtent.MinY);
+ Assert.AreEqual(3.0, map2.DataExtent.MaxX);
+ Assert.AreEqual(4.0, map2.DataExtent.MaxY);
public virtual void TestCreate()
//Create a runtime map from its map definition, verify layer/group
@@ -1045,6 +1065,12 @@
return ConnectionUtil.CreateTestHttpConnection();
+ [Test]
+ public override void TestExtentSerialization()
+ base.TestExtentSerialization();
[Test]
public override void TestResourceEvents()
@@ -1131,6 +1157,12 @@
[Test]
+ [Test]
base.TestResourceEvents();
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-16 09:26:03 UTC (rev 6431)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-16 13:34:47 UTC (rev 6432)
@@ -684,8 +684,8 @@
s.Write(env.MinX);
s.Write(env.MinY);
+ s.Write(env.MaxX);
s.Write(env.MaxY);
- s.Write(env.MaxY);
private Dictionary<string, ChangeList> m_changeList;
More information about the mapguide-commits
