[mapguide-commits] r6433 - in trunk/Tools/Maestro: MaestroAPITests
OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Mon Jan 16 08:36:41 EST 2012
Author: jng
Date: 2012-01-16 05:36:41 -0800 (Mon, 16 Jan 2012)
New Revision: 6433
Added:
trunk/Tools/Maestro/MaestroAPITests/LocalNativePerformanceTests.cs
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
#1916: Fix incorrect map extent serialization. Includes unit test. Also add performance test for #1914
Added: trunk/Tools/Maestro/MaestroAPITests/LocalNativePerformanceTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/LocalNativePerformanceTests.cs (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/LocalNativePerformanceTests.cs 2012-01-16 13:36:41 UTC (rev 6433)
@@ -0,0 +1,42 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using NUnit.Framework;
+using System.Diagnostics;
+namespace MaestroAPITests
+ [TestFixture(Ignore = TestControl.IgnoreLocalNativePerformanceTests)]
+ public class LocalNativePerformanceTests
+ [Test]
+ public void TestCase1914()
+ var conn = LocalNativeConnectionUtil.CreateTestConnection();
+ var sw = new Stopwatch();
+ sw.Start();
+ conn.ResourceService.ResourceExists("Library://UnitTests/Data/Parcels.FeatureSource");
+ sw.Stop();
+ Trace.TraceInformation("ResourceExists() executed in {0}ms", sw.ElapsedMilliseconds);
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2012-01-16 13:34:47 UTC (rev 6432)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2012-01-16 13:36:41 UTC (rev 6433)
@@ -111,6 +111,26 @@
protected abstract IServerConnection CreateTestConnection();
+ public virtual void TestExtentSerialization()
+ var resSvc = _conn.ResourceService;
+ var mdf = resSvc.GetResource("Library://UnitTests/Maps/Sheboygan.MapDefinition") as IMapDefinition;
+ Assert.NotNull(mdf);
+ mdf.Extents = ObjectFactory.CreateEnvelope(1.0, 2.0, 3.0, 4.0);
+ var mapSvc = _conn.GetService((int)ServiceType.Mapping) as IMappingService;
+ Assert.NotNull(mapSvc);
+ var map = mapSvc.CreateMap("Session:" + _conn.SessionID + "//TestExtentSerialization.Map", mdf, 1.0);
+ map.Save();
+ var map2 = mapSvc.OpenMap("Session:" + _conn.SessionID + "//TestExtentSerialization.Map");
+ Assert.AreEqual(1.0, map2.DataExtent.MinX);
+ Assert.AreEqual(2.0, map2.DataExtent.MinY);
+ Assert.AreEqual(3.0, map2.DataExtent.MaxX);
+ Assert.AreEqual(4.0, map2.DataExtent.MaxY);
public virtual void TestCreate()
//Create a runtime map from its map definition, verify layer/group
@@ -1074,6 +1094,12 @@
return ConnectionUtil.CreateTestHttpConnection();
+ [Test]
+ public override void TestExtentSerialization()
+ base.TestExtentSerialization();
[Test]
public override void TestResourceEvents()
@@ -1157,6 +1183,12 @@
[Test]
+ [Test]
base.TestResourceEvents();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-16 13:34:47 UTC (rev 6432)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-01-16 13:36:41 UTC (rev 6433)
@@ -685,8 +685,8 @@
s.Write(env.MinX);
s.Write(env.MinY);
+ s.Write(env.MaxX);
s.Write(env.MaxY);
- s.Write(env.MaxY);
private Dictionary<string, ChangeList> m_changeList;
More information about the mapguide-commits
