[mapguide-commits] r6860 - in branches/2.4/MgDev/Desktop: MgDesktop/Services UnitTest
svn_mapguide at osgeo.org
Fri Jul 6 06:25:04 PDT 2012
Author: jng
Date: 2012-07-06 06:25:04 -0700 (Fri, 06 Jul 2012)
New Revision: 6860
branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
branches/2.4/MgDev/Desktop/UnitTest/TestResourceService.cpp
#2056: Add extra checks on the XML root elements to at least ensuring some part of the XML content is correct with respect to the type of the resource identifier. Ideally we want content model validation (which I haven't figured out yet with Xerces), but SetResource() now at least only accepts XML content and will do some basic checks based on the type of resource which is better than before where any arbitrary content could be passed in.
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp 2012-07-06 07:07:04 UTC (rev 6859)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp 2012-07-06 13:25:04 UTC (rev 6860)
@@ -303,15 +303,44 @@
std::string xml;
sink->ToStringUtf8(xml);
- XercesDOMParser parser;
- parser.setExternalSchemaLocation(m_schemaPath.c_str());
+ XercesDOMParser parser;
parser.setValidationScheme(XercesDOMParser::Val_Always);
+ parser.cacheGrammarFromParse(true);
DefaultHandler handler;
parser.setErrorHandler(&handler);
try
MemBufInputSource source((const XMLByte*)xml.c_str(), xml.size(), "MgdResourceService.Class", false);
parser.parse(source);
+ DOMDocument* doc = parser.getDocument();
+ CHECKNULL(doc, L"MgdResourceService::SetResource");
+ STRING resType = resource->GetResourceType();
+ DOMElement* docEl = doc->getDocumentElement();
+ CHECKNULL(docEl, L"MgdResourceService::SetResource");
+ STRING docElName = docEl->getNodeName();
+ //Now make sure it's the right type of XML document
+ //Everything except SymbolDefinitions will have the same root element name as the resource type
+ if (resType != MgResourceType::SymbolDefinition)
+ if (resType != docElName)
+ MgStringCollection args;
+ args.Add(docElName);
+ throw new MgInvalidResourceTypeException(L"MgdResourceService::SetResource", __LINE__, __WFILE__, &args, L"", NULL);
+ else
+ if (docElName != L"SimpleSymbolDefinition" && docElName != L"CompoundSymbolDefinition")
catch (const SAXParseException& e)
Modified: branches/2.4/MgDev/Desktop/UnitTest/TestResourceService.cpp
--- branches/2.4/MgDev/Desktop/UnitTest/TestResourceService.cpp 2012-07-06 07:07:04 UTC (rev 6859)
+++ branches/2.4/MgDev/Desktop/UnitTest/TestResourceService.cpp 2012-07-06 13:25:04 UTC (rev 6860)
@@ -442,16 +442,55 @@
std::string notXml = "Not XML content";
std::string malformedXml = "<Foo></Bar>";
+ std::string fsXml = "<FeatureSource></FeatureSource>";
+ std::string unkXml = "<Unknown></Unknown>";
+ std::string fsIncompleteXml = "<FeatureSource xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" xsi:noNamespaceSchemaLocation=\"FeatureSource-1.0.0.xsd\"></FeatureSource>";
+ std::string simpleSymXml = "<SimpleSymbolDefinition></SimpleSymbolDefinition>";
+ std::string compoundSymXml = "<CompoundSymbolDefinition></CompoundSymbolDefinition>";
Ptr<MgByteSource> bs1 = new MgByteSource((BYTE_ARRAY_IN)notXml.c_str(), (INT32)notXml.length());
Ptr<MgByteSource> bs2 = new MgByteSource((BYTE_ARRAY_IN)malformedXml.c_str(), (INT32)malformedXml.length());
+ Ptr<MgByteSource> bs3 = new MgByteSource((BYTE_ARRAY_IN)fsXml.c_str(), (INT32)fsXml.length());
+ Ptr<MgByteSource> bs4 = new MgByteSource((BYTE_ARRAY_IN)unkXml.c_str(), (INT32)unkXml.length());
+ Ptr<MgByteSource> bs5 = new MgByteSource((BYTE_ARRAY_IN)fsIncompleteXml.c_str(), (INT32)fsIncompleteXml.length());
+ Ptr<MgByteSource> bs6 = new MgByteSource((BYTE_ARRAY_IN)simpleSymXml.c_str(), (INT32)simpleSymXml.length());
+ Ptr<MgByteSource> bs7 = new MgByteSource((BYTE_ARRAY_IN)compoundSymXml.c_str(), (INT32)compoundSymXml.length());
Ptr<MgByteReader> r1 = bs1->GetReader();
Ptr<MgByteReader> r2 = bs2->GetReader();
+ Ptr<MgByteReader> r3 = bs3->GetReader();
+ Ptr<MgByteReader> r4 = bs4->GetReader();
+ Ptr<MgByteReader> r5 = bs5->GetReader();
+ Ptr<MgByteReader> r6 = bs6->GetReader();
+ Ptr<MgByteReader> r7 = bs7->GetReader();
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.FeatureSource");
+ Ptr<MgResourceIdentifier> ldfId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.LayerDefinition");
+ Ptr<MgResourceIdentifier> mdfId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.MapDefinition");
+ Ptr<MgResourceIdentifier> pltId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.PrintLayout");
+ Ptr<MgResourceIdentifier> symId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.SymbolDefinition");
+ Ptr<MgResourceIdentifier> slbId = new MgResourceIdentifier(L"Library://UnitTests/NotGettingSaved.SymbolLibrary");
+ Ptr<MgResourceIdentifier> ssId = new MgResourceIdentifier(L"Library://UnitTests/GettingSavedSimple.SymbolDefinition");
+ Ptr<MgResourceIdentifier> csId = new MgResourceIdentifier(L"Library://UnitTests/GettingSavedCompound.SymbolDefinition");
+ //TODO: We can get xerces to vet the content as being XML, but can't figure out how to get xerces
+ //to validate the content model. Until we figure that out, the relevant assertions are commented
+ //out. Still at this stage it's better than letting any arbitrary content get through these calls.
CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r1, NULL), MgXmlParserException*);
CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r2, NULL), MgXmlParserException*);
+ //CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r3, NULL), MgXmlParserException*);
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(ldfId, r3, NULL), MgInvalidResourceTypeException*);
+ r3->Rewind();
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(mdfId, r3, NULL), MgInvalidResourceTypeException*);
+ r3->Rewind();
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(pltId, r3, NULL), MgInvalidResourceTypeException*);
+ r3->Rewind();
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(symId, r3, NULL), MgInvalidResourceTypeException*);
+ r3->Rewind();
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(slbId, r3, NULL), MgInvalidResourceTypeException*);
+ CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r4, NULL), MgInvalidResourceTypeException*);
+ //CPPUNIT_ASSERT_THROW_MG(pService->SetResource(resId, r5, NULL), MgXmlParserException*);
+ pService->SetResource(ssId, r6, NULL);
+ pService->SetResource(csId, r7, NULL);
catch(MgException* e)
More information about the mapguide-commits
