[mapguide-commits] r6861 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Fri Jul 6 06:47:49 PDT 2012
Author: jng
Date: 2012-07-06 06:47:48 -0700 (Fri, 06 Jul 2012)
New Revision: 6861
branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
#2058: Instead of allowing selectability toggling on all layers, only allow it for layers initially marked as selectable in the Map Definition and dynamically added layers
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-07-06 13:25:04 UTC (rev 6860)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegend.cs 2012-07-06 13:47:48 UTC (rev 6861)
@@ -51,16 +51,33 @@
InitializeComponent();
+ private Dictionary<string, bool> _initialLayerSelectabilityState = new Dictionary<string, bool>();
internal void Init(MgMapViewerProvider provider)
_provider = provider;
_map = _provider.GetMap();
+ InitInitialSelectabilityStates();
_resSvc = (MgResourceService)_provider.CreateService(MgServiceType.ResourceService);
_selectableIcon = Properties.Resources.lc_select;
_unselectableIcon = Properties.Resources.lc_unselect;
RefreshLegend();
+ private void InitInitialSelectabilityStates()
+ if (_map != null)
+ _initialLayerSelectabilityState.Clear();
+ var layers = _map.GetLayers();
+ for (int i = 0; i < layers.GetCount(); i++)
+ var layer = layers.GetItem(i);
+ _initialLayerSelectabilityState[layer.GetObjectId()] = layer.Selectable;
private Dictionary<string, MgLayerBase> _layers = new Dictionary<string, MgLayerBase>();
private Dictionary<string, MgLayerGroup> _groups = new Dictionary<string, MgLayerGroup>();
private Dictionary<string, string> _layerDefinitionContents = new Dictionary<string, string>();
@@ -287,7 +304,9 @@
if (fsId.EndsWith("DrawingSource"))
node.SelectedImageKey = node.ImageKey = IMG_DWF;
- node.Tag = new LayerNodeMetadata(layer);
+ //If not in the dictionary, assume it is a dynamically added layer
+ bool bInitiallySelectable = _initialLayerSelectabilityState.ContainsKey(layer.GetObjectId()) ? _initialLayerSelectabilityState[layer.GetObjectId()] : layer.Selectable;
+ node.Tag = new LayerNodeMetadata(layer, bInitiallySelectable);
node.ToolTipText = string.Format(Properties.Resources.DrawingLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceId);
else
@@ -343,7 +362,9 @@
imgLegend.Images.Add(id, img);
node.SelectedImageKey = node.ImageKey = id;
ThemeIcon = img
@@ -447,7 +468,7 @@
TreeNode node = new TreeNode();
node.Text = (count + " other styles");
node.ImageKey = node.SelectedImageKey = IMG_OTHER;
- node.Tag = new LayerNodeMetadata(null) {
+ node.Tag = new LayerNodeMetadata(null, false) {
IsBaseLayer = false,
ThemeIcon = Properties.Resources.icon_etc,
IsThemeRule = true
@@ -458,12 +479,12 @@
private TreeNode CreateThemeRuleNode(MgResourceIdentifier layerDefId, double viewScale, string labelText, int geomType, int categoryIndex)
MgByteReader icon = _provider.GenerateLegendImage(layerDefId,
- viewScale,
- 16,
- 16,
- "PNG",
- geomType,
- categoryIndex);
+ viewScale,
+ 16,
+ 16,
+ "PNG",
+ geomType,
+ categoryIndex);
node.Text = labelText;
if (icon != null)
@@ -473,7 +494,7 @@
byte[] b = new byte[icon.GetLength()];
icon.Read(b, b.Length);
- var tag = new LayerNodeMetadata(null)
+ var tag = new LayerNodeMetadata(null, false)
IsThemeRule = true
@@ -535,12 +556,12 @@
class LayerNodeMetadata : LegendNodeMetadata
- public LayerNodeMetadata(MgLayerBase layer)
+ public LayerNodeMetadata(MgLayerBase layer, bool bInitiallySelectable)
base.IsGroup = false;
this.Layer = layer;
this.IsSelectable = (layer != null) ? layer.Selectable : false;
- this.DrawSelectabilityIcon = (layer != null);
+ this.DrawSelectabilityIcon = (layer != null && bInitiallySelectable);
this.IsThemeRule = false;
More information about the mapguide-commits
