[mapguide-commits] r6734 - in trunk/Tools/Maestro: Install Maestro.Editors Maestro.Editors/MapDefinition Maestro.Editors/MapDefinition/Live Maestro.MapViewer OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Tue Jun 5 07:52:06 PDT 2012
Author: jng
Date: 2012-06-05 07:52:05 -0700 (Tue, 05 Jun 2012)
New Revision: 6734
Added:
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.resx
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.resx
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.resx
trunk/Tools/Maestro/Install/Maestro.nsi
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.resx
trunk/Tools/Maestro/Maestro.MapViewer/Legend.Designer.cs
trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs
#2018: More Live Map Definition editor work:
- Add context menus and buttons to add new layer groups and layers
- Implement "Draw Order" view for layers and implement layer re-ordering
- Add a new CollectionChanged event for layer and group collection classes
- Add new files to NSIS installer
Modified: trunk/Tools/Maestro/Install/Maestro.nsi
--- trunk/Tools/Maestro/Install/Maestro.nsi 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Install/Maestro.nsi 2012-06-05 14:52:05 UTC (rev 6734)
@@ -38,11 +38,11 @@
# Globals
!ifndef SLN_CONFIG
- !define SLN_CONFIG "Release" #"Debug"
+ !define SLN_CONFIG "Release" #"Debug"
!endif
!ifndef CPU
- !define CPU "x86"
+ !define CPU "x86"
!endif
!echo "Building installer in configuration: ${SLN_CONFIG} (${CPU})"
@@ -50,7 +50,7 @@
!define SLN_DIR ".."
!define SLN_THIRDPARTY "${SLN_DIR}\Thirdparty"
!ifndef RELEASE_VERSION
- !define RELEASE_VERSION "Trunk"
+ !define RELEASE_VERSION "Trunk"
!endif
# Installer vars
@@ -162,65 +162,65 @@
# default section
Section
- ; Windows > Vista
- SetShellVarContext all
+ ; Windows > Vista
+ SetShellVarContext all
- ; Registry
- !if ${CPU} == "x64"
- SetRegView 64
- !else
- SetRegView 32
- !endif
+ ; Registry
+ !if ${CPU} == "x64"
+ SetRegView 64
+ !else
+ SetRegView 32
+ !endif
- # set installation dir
- SetOutPath $INSTDIR
- # directories / core addins
- File /r "${INST_OUTPUT_MAESTRO}\AddIns"
+ # set installation dir
+ SetOutPath $INSTDIR
+ # directories / core addins
+ File /r "${INST_OUTPUT_MAESTRO}\AddIns"
File /r "${INST_OUTPUT_MAESTRO}\Data"
File /r "${INST_OUTPUT_MAESTRO}\Schemas"
File /r "${INST_OUTPUT_MAESTRO}\UserDoc"
- # docs
- #File "${INST_OUTPUT_MAESTRO}\${HELP_USER}"
- #File "${INST_OUTPUT_MAESTRO}\${HELP_API}"
- File "${INST_OUTPUT_MAESTRO}\changelog.txt"
- File "${INST_OUTPUT_MAESTRO}\license.txt"
- # data/config files
+ # docs
+ #File "${INST_OUTPUT_MAESTRO}\${HELP_USER}"
+ #File "${INST_OUTPUT_MAESTRO}\${HELP_API}"
+ File "${INST_OUTPUT_MAESTRO}\changelog.txt"
+ File "${INST_OUTPUT_MAESTRO}\license.txt"
+ # data/config files
File "${INST_OUTPUT_MAESTRO}\LocalConfigure.exe.config"
File "${INST_OUTPUT_MAESTRO}\Maestro.exe.config"
File "${INST_OUTPUT_MAESTRO}\MaestroFsPreview.exe.config"
File "${INST_OUTPUT_MAESTRO}\MgCooker.exe.config"
File "${INST_OUTPUT_MAESTRO}\MgCookerCmd.exe.config"
File "${INST_OUTPUT_MAESTRO}\RtMapInspector.exe.config"
- File "${INST_OUTPUT_MAESTRO}\ConnectionProviders.xml"
+ File "${INST_OUTPUT_MAESTRO}\ConnectionProviders.xml"
File "${INST_OUTPUT_MAESTRO}\FsEditorMap.xml"
File "${INST_OUTPUT_MAESTRO}\OdbcDriverMap.xml"
- # libraries
- File "${INST_OUTPUT_MAESTRO}\Aga.Controls.dll"
+ # libraries
+ File "${INST_OUTPUT_MAESTRO}\Aga.Controls.dll"
File "${INST_OUTPUT_MAESTRO}\Ciloci.Flee.dll"
- File "${INST_OUTPUT_MAESTRO}\ICSharpCode.Core.dll"
- File "${INST_OUTPUT_MAESTRO}\ICSharpCode.Core.WinForms.dll"
+ File "${INST_OUTPUT_MAESTRO}\ICSharpCode.Core.dll"
+ File "${INST_OUTPUT_MAESTRO}\ICSharpCode.Core.WinForms.dll"
File "${INST_OUTPUT_MAESTRO}\ICSharpCode.SharpZipLib.dll"
File "${INST_OUTPUT_MAESTRO}\ICSharpCode.TextEditor.dll"
File "${INST_OUTPUT_MAESTRO}\IronPython.dll"
File "${INST_OUTPUT_MAESTRO}\IronPython.Modules.dll"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Base.dll"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Editors.dll"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Base.dll"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Editors.dll"
File "${INST_OUTPUT_MAESTRO}\Maestro.LiveMapEditor.exe"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Login.dll"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Login.dll"
File "${INST_OUTPUT_MAESTRO}\Maestro.MapViewer.dll"
File "${INST_OUTPUT_MAESTRO}\Maestro.Packaging.dll"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Shared.UI.dll"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Shared.UI.dll"
File "${INST_OUTPUT_MAESTRO}\Microsoft.Dynamic.dll"
File "${INST_OUTPUT_MAESTRO}\Microsoft.Scripting.dll"
File "${INST_OUTPUT_MAESTRO}\Microsoft.Scripting.Metadata.dll"
File "${INST_OUTPUT_MAESTRO}\NetTopologySuite.Merged.dll"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ExtendedObjectModels.dll"
- File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.dll"
- File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Http.dll"
+ File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.dll"
+ File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Http.dll"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Native32-2.2.0.dll"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0.dll"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0.dll"
@@ -245,15 +245,15 @@
File "${INST_OUTPUT_MAESTRO}\MaestroFsPreview.pdb"
File "${INST_OUTPUT_MAESTRO}\MgCooker.pdb"
File "${INST_OUTPUT_MAESTRO}\MgCookerCmd.pdb"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Base.pdb"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Editors.pdb"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Base.pdb"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Editors.pdb"
File "${INST_OUTPUT_MAESTRO}\Maestro.LiveMapEditor.pdb"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Login.pdb"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Login.pdb"
File "${INST_OUTPUT_MAESTRO}\Maestro.MapViewer.pdb"
File "${INST_OUTPUT_MAESTRO}\Maestro.Packaging.pdb"
- File "${INST_OUTPUT_MAESTRO}\Maestro.Shared.UI.pdb"
- File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.pdb"
- File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Http.pdb"
+ File "${INST_OUTPUT_MAESTRO}\Maestro.Shared.UI.pdb"
+ File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.pdb"
+ File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Http.pdb"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.MaestroAPI.Native32-2.2.0.pdb"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0.pdb"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0.pdb"
@@ -271,85 +271,86 @@
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.WebLayout-1.1.0.pdb"
File "${INST_OUTPUT_MAESTRO}\OSGeo.MapGuide.ObjectModels.WebLayout-2.4.0.pdb"
File "${INST_OUTPUT_MAESTRO}\RtMapInspector.pdb"
- # main executables
- File "${INST_OUTPUT_MAESTRO}\${EXE_MAESTRO}"
+ # main executables
+ File "${INST_OUTPUT_MAESTRO}\${EXE_MAESTRO}"
File "${INST_OUTPUT_MAESTRO}\LocalConfigure.exe"
- File "${INST_OUTPUT_MAESTRO}\MgCooker.exe"
+ File "${INST_OUTPUT_MAESTRO}\MgCooker.exe"
File "${INST_OUTPUT_MAESTRO}\MgCookerCmd.exe"
File "${INST_OUTPUT_MAESTRO}\MaestroFsPreview.exe"
File "${INST_OUTPUT_MAESTRO}\RtMapInspector.exe"
- # create uninstaller
- WriteUninstaller "$INSTDIR\uninstall.exe"
- # create Add/Remove Programs entry
- WriteRegStr HKLM "${REG_KEY_UNINSTALL}" \
- "DisplayName" "${INST_PRODUCT_NAME}"
- "UninstallString" "$INSTDIR\uninstall.exe"
- "URLInfoAbout" "${PROJECT_URL}"
- "DisplayVersion" "${RELEASE_VERSION}"
- # TODO: Add more useful information to Add/Remove programs
- # See: http://nsis.sourceforge.net/Add_uninstall_information_to_Add/Remove_Programs
- # create Maestro shortcuts. Use INST_PRODUCT_QUALIFIED so we can have x86 and x64 entries that don't clash
- CreateDirectory "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}"
- CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\${LNK_MAESTRO}.lnk" "$INSTDIR\${EXE_MAESTRO}"
- CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\MgCooker.lnk" "$INSTDIR\MgCooker.exe"
+ # create uninstaller
+ WriteUninstaller "$INSTDIR\uninstall.exe"
+ # create Add/Remove Programs entry
+ WriteRegStr HKLM "${REG_KEY_UNINSTALL}" \
+ "DisplayName" "${INST_PRODUCT_NAME}"
+ "UninstallString" "$INSTDIR\uninstall.exe"
+ "URLInfoAbout" "${PROJECT_URL}"
+ "DisplayVersion" "${RELEASE_VERSION}"
+ # TODO: Add more useful information to Add/Remove programs
+ # See: http://nsis.sourceforge.net/Add_uninstall_information_to_Add/Remove_Programs
+ # create Maestro shortcuts. Use INST_PRODUCT_QUALIFIED so we can have x86 and x64 entries that don't clash
+ CreateDirectory "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}"
+ CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\${LNK_MAESTRO}.lnk" "$INSTDIR\${EXE_MAESTRO}"
+ CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\MgCooker.lnk" "$INSTDIR\MgCooker.exe"
CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Maestro Feature Source Preview.lnk" "$INSTDIR\MaestroFsPreview.exe"
- #CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\User Documentation.lnk" "$INSTDIR\${HELP_USER}"
- #CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Core API Documentation.lnk" "$INSTDIR\${HELP_API}"
- CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Uninstall.lnk" "$INSTDIR\uninstall.exe"
- CreateShortCut "$DESKTOP\${LNK_MAESTRO}.lnk" "$INSTDIR\${EXE_MAESTRO}"
+ CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Live Map Definition Editor.lnk" "$INSTDIR\Maestro.LiveMapEditor.exe"
+ #CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\User Documentation.lnk" "$INSTDIR\${HELP_USER}"
+ #CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Core API Documentation.lnk" "$INSTDIR\${HELP_API}"
+ CreateShortCut "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}\Uninstall.lnk" "$INSTDIR\uninstall.exe"
+ CreateShortCut "$DESKTOP\${LNK_MAESTRO}.lnk" "$INSTDIR\${EXE_MAESTRO}"
SectionEnd
# uninstall section
Section "uninstall"
- ; Windows > Vista
+ ; Windows > Vista
- ; Registry
- SetRegView 64
- !else
- SetRegView 32
- !endif
+ ; Registry
+ SetRegView 64
+ !else
+ SetRegView 32
+ !endif
# remove uninstaller
- Delete "$INSTDIR\uninstall.exe"
- # remove desktop shortcut
- Delete "$DESKTOP\${LNK_MAESTRO}.lnk"
- # remove Add/Remove programs registry entry
- DeleteRegKey HKLM "${REG_KEY_UNINSTALL}"
- # remove installation directory
- RMDir /r "$INSTDIR"
- # remove shortcuts
- RMDir /r "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}"
+ Delete "$INSTDIR\uninstall.exe"
+ # remove desktop shortcut
+ Delete "$DESKTOP\${LNK_MAESTRO}.lnk"
+ # remove Add/Remove programs registry entry
+ DeleteRegKey HKLM "${REG_KEY_UNINSTALL}"
+ # remove installation directory
+ RMDir /r "$INSTDIR"
+ # remove shortcuts
+ RMDir /r "$SMPROGRAMS\${INST_PRODUCT_QUALIFIED}"
SectionEnd
Function .onInit
- ; Registry
- SetRegView 64
- !else
- SetRegView 32
- !endif
- !insertmacro MUI_LANGDLL_DISPLAY
+ ; Registry
+ SetRegView 64
+ !else
+ SetRegView 32
+ !endif
+ !insertmacro MUI_LANGDLL_DISPLAY
; Check for .NET Framework 4.0
ReadRegDWORD $0 HKLM "SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full" Install
@@ -363,7 +364,7 @@
FunctionEnd
Function LaunchLink
- ; TODO: Needs to launch under standard user. If installer was run under UAC elevated privileges, it will run under the
- ; user who elevated these privileges.
- ExecShell "" "$INSTDIR\${EXE_MAESTRO}"
+ ; TODO: Needs to launch under standard user. If installer was run under UAC elevated privileges, it will run under the
+ ; user who elevated these privileges.
+ ExecShell "" "$INSTDIR\${EXE_MAESTRO}"
FunctionEnd
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-06-05 14:52:05 UTC (rev 6734)
@@ -886,6 +886,24 @@
<Compile Include="MapDefinition\LiveMapDefinitionEditorCtrl.Designer.cs">
<DependentUpon>LiveMapDefinitionEditorCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="MapDefinition\LiveMapEditorDrawOrder.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="MapDefinition\LiveMapEditorDrawOrder.Designer.cs">
+ <DependentUpon>LiveMapEditorDrawOrder.cs</DependentUpon>
+ </Compile>
+ <Compile Include="MapDefinition\LiveMapEditorLegend.cs">
+ </Compile>
+ <Compile Include="MapDefinition\LiveMapEditorLegend.Designer.cs">
+ <DependentUpon>LiveMapEditorLegend.cs</DependentUpon>
+ </Compile>
+ <Compile Include="MapDefinition\Live\NewGroupDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MapDefinition\Live\NewGroupDialog.Designer.cs">
+ <DependentUpon>NewGroupDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="MapDefinition\ManualScaleEditor.cs">
</Compile>
@@ -1638,6 +1656,15 @@
<EmbeddedResource Include="MapDefinition\LiveMapDefinitionEditorCtrl.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\LiveMapEditorDrawOrder.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="MapDefinition\LiveMapEditorLegend.resx">
+ <EmbeddedResource Include="MapDefinition\Live\NewGroupDialog.resx">
<EmbeddedResource Include="MapDefinition\ManualScaleEditor.resx">
<DependentUpon>ManualScaleEditor.cs</DependentUpon>
</EmbeddedResource>
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.Designer.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,136 @@
+namespace Maestro.Editors.MapDefinition.Live
+ partial class NewGroupDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtName = new System.Windows.Forms.TextBox();
+ this.txtLegendLabel = new System.Windows.Forms.TextBox();
+ this.btnOK = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.lblDuplicateName = new System.Windows.Forms.Label();
+ this.SuspendLayout();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(9, 13);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(35, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Name";
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(9, 58);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(72, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "Legend Label";
+ // txtName
+ this.txtName.Location = new System.Drawing.Point(12, 29);
+ this.txtName.Name = "txtName";
+ this.txtName.Size = new System.Drawing.Size(325, 20);
+ this.txtName.TabIndex = 2;
+ this.txtName.TextChanged += new System.EventHandler(this.txtName_TextChanged);
+ // txtLegendLabel
+ this.txtLegendLabel.Location = new System.Drawing.Point(12, 74);
+ this.txtLegendLabel.Name = "txtLegendLabel";
+ this.txtLegendLabel.Size = new System.Drawing.Size(325, 20);
+ this.txtLegendLabel.TabIndex = 3;
+ this.txtLegendLabel.TextChanged += new System.EventHandler(this.txtLegendLabel_TextChanged);
+ // btnOK
+ this.btnOK.Enabled = false;
+ this.btnOK.Location = new System.Drawing.Point(181, 115);
+ this.btnOK.Name = "btnOK";
+ this.btnOK.Size = new System.Drawing.Size(75, 23);
+ this.btnOK.TabIndex = 4;
+ this.btnOK.Text = "OK";
+ this.btnOK.UseVisualStyleBackColor = true;
+ this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+ // btnCancel
+ this.btnCancel.Location = new System.Drawing.Point(262, 115);
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.Size = new System.Drawing.Size(75, 23);
+ this.btnCancel.TabIndex = 5;
+ this.btnCancel.Text = "Cancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // lblDuplicateName
+ this.lblDuplicateName.AutoSize = true;
+ this.lblDuplicateName.ForeColor = System.Drawing.Color.Red;
+ this.lblDuplicateName.Location = new System.Drawing.Point(12, 120);
+ this.lblDuplicateName.Name = "lblDuplicateName";
+ this.lblDuplicateName.Size = new System.Drawing.Size(104, 13);
+ this.lblDuplicateName.TabIndex = 6;
+ this.lblDuplicateName.Text = "Name already exists!";
+ this.lblDuplicateName.Visible = false;
+ // NewGroupDialog
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(349, 150);
+ this.ControlBox = false;
+ this.Controls.Add(this.lblDuplicateName);
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnOK);
+ this.Controls.Add(this.txtLegendLabel);
+ this.Controls.Add(this.txtName);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.label1);
+ this.Name = "NewGroupDialog";
+ this.Text = "New Group";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtName;
+ private System.Windows.Forms.TextBox txtLegendLabel;
+ private System.Windows.Forms.Button btnOK;
+ private System.Windows.Forms.Button btnCancel;
+ private System.Windows.Forms.Label lblDuplicateName;
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,73 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+ public partial class NewGroupDialog : Form
+ private RuntimeMap _map;
+ public NewGroupDialog(RuntimeMap map)
+ InitializeComponent();
+ _map = map;
+ public string GroupName { get { return txtName.Text; } }
+ public string GroupLabel { get { return txtLegendLabel.Text; } }
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ private void btnOK_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void txtName_TextChanged(object sender, EventArgs e)
+ string name = txtName.Text.Trim();
+ string label = txtLegendLabel.Text.Trim();
+ btnOK.Enabled = !string.IsNullOrEmpty(name) && !string.IsNullOrEmpty(label) && _map.Groups[name] == null;
+ lblDuplicateName.Visible = (_map.Groups[name] != null);
+ private void txtLegendLabel_TextChanged(object sender, EventArgs e)
+ btnOK.Enabled = !string.IsNullOrEmpty(name) && !string.IsNullOrEmpty(label);
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/Live/NewGroupDialog.resx 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.Designer.cs 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.Designer.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -28,22 +28,14 @@
/// </summary>
- this.components = new System.ComponentModel.Container();
this.splitContainer1 = new System.Windows.Forms.SplitContainer();
this.splitContainer2 = new System.Windows.Forms.SplitContainer();
this.tabLayersAndGroups = new System.Windows.Forms.TabControl();
this.TAB_LEGEND = new System.Windows.Forms.TabPage();
- this.legendCtrl = new Maestro.MapViewer.Legend();
- this.ctxLegend = new System.Windows.Forms.ContextMenuStrip(this.components);
- this.addNewGroupToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.addNewLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.grpContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
- this.addLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.removeThisGroupToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.layerContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
- this.removeThisLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.legendCtrl = new Maestro.Editors.MapDefinition.LiveMapEditorLegend();
this.viewer = new Maestro.MapViewer.MapViewer();
this.TAB_DRAW_ORDER = new System.Windows.Forms.TabPage();
+ this.drawOrderCtrl = new Maestro.Editors.MapDefinition.LiveMapEditorDrawOrder();
this.tabProperties = new System.Windows.Forms.TabControl();
this.TAB_PROPERTIES = new System.Windows.Forms.TabPage();
this.propGrid = new System.Windows.Forms.PropertyGrid();
@@ -63,9 +55,7 @@
this.splitContainer2.SuspendLayout();
this.tabLayersAndGroups.SuspendLayout();
this.TAB_LEGEND.SuspendLayout();
- this.ctxLegend.SuspendLayout();
- this.grpContextMenu.SuspendLayout();
- this.layerContextMenu.SuspendLayout();
+ this.TAB_DRAW_ORDER.SuspendLayout();
this.tabProperties.SuspendLayout();
this.TAB_PROPERTIES.SuspendLayout();
this.statusStrip.SuspendLayout();
@@ -132,77 +122,15 @@
// legendCtrl
- this.legendCtrl.ContextMenuStrip = this.ctxLegend;
this.legendCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
- this.legendCtrl.GroupContextMenu = this.grpContextMenu;
- this.legendCtrl.LayerContextMenu = this.layerContextMenu;
this.legendCtrl.Location = new System.Drawing.Point(3, 3);
this.legendCtrl.Name = "legendCtrl";
- this.legendCtrl.ShowTooltips = true;
this.legendCtrl.Size = new System.Drawing.Size(275, 135);
this.legendCtrl.TabIndex = 0;
- this.legendCtrl.ThemeCompressionLimit = 25;
this.legendCtrl.Viewer = this.viewer;
- this.legendCtrl.NodeSelected += new Maestro.MapViewer.NodeSelectionEventHandler(this.legendCtrl_NodeSelected);
+ this.legendCtrl.NodeDeleted += new Maestro.MapViewer.NodeEventHandler(this.legendCtrl_NodeDeleted);
+ this.legendCtrl.NodeSelected += new Maestro.MapViewer.NodeEventHandler(this.legendCtrl_NodeSelected);
- // ctxLegend
- this.ctxLegend.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.addNewGroupToolStripMenuItem,
- this.addNewLayerToolStripMenuItem});
- this.ctxLegend.Name = "ctxLegend";
- this.ctxLegend.Size = new System.Drawing.Size(160, 48);
- // addNewGroupToolStripMenuItem
- this.addNewGroupToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
- this.addNewGroupToolStripMenuItem.Name = "addNewGroupToolStripMenuItem";
- this.addNewGroupToolStripMenuItem.Size = new System.Drawing.Size(159, 22);
- this.addNewGroupToolStripMenuItem.Text = "Add New Group";
- // addNewLayerToolStripMenuItem
- this.addNewLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
- this.addNewLayerToolStripMenuItem.Name = "addNewLayerToolStripMenuItem";
- this.addNewLayerToolStripMenuItem.Size = new System.Drawing.Size(159, 22);
- this.addNewLayerToolStripMenuItem.Text = "Add New Layer";
- // grpContextMenu
- this.grpContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.addLayerToolStripMenuItem,
- this.removeThisGroupToolStripMenuItem});
- this.grpContextMenu.Name = "grpContextMenu";
- this.grpContextMenu.Size = new System.Drawing.Size(179, 48);
- // addLayerToolStripMenuItem
- this.addLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
- this.addLayerToolStripMenuItem.Name = "addLayerToolStripMenuItem";
- this.addLayerToolStripMenuItem.Size = new System.Drawing.Size(178, 22);
- this.addLayerToolStripMenuItem.Text = "Add Layer";
- // removeThisGroupToolStripMenuItem
- this.removeThisGroupToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
- this.removeThisGroupToolStripMenuItem.Name = "removeThisGroupToolStripMenuItem";
- this.removeThisGroupToolStripMenuItem.Size = new System.Drawing.Size(178, 22);
- this.removeThisGroupToolStripMenuItem.Text = "Remove This Group";
- // layerContextMenu
- this.layerContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
- this.removeThisLayerToolStripMenuItem});
- this.layerContextMenu.Name = "layerContextMenu";
- this.layerContextMenu.Size = new System.Drawing.Size(174, 26);
- // removeThisLayerToolStripMenuItem
- this.removeThisLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
- this.removeThisLayerToolStripMenuItem.Name = "removeThisLayerToolStripMenuItem";
- this.removeThisLayerToolStripMenuItem.Size = new System.Drawing.Size(173, 22);
- this.removeThisLayerToolStripMenuItem.Text = "Remove This Layer";
// viewer
this.viewer.Cursor = System.Windows.Forms.Cursors.Default;
@@ -219,14 +147,26 @@
// TAB_DRAW_ORDER
+ this.TAB_DRAW_ORDER.Controls.Add(this.drawOrderCtrl);
this.TAB_DRAW_ORDER.Location = new System.Drawing.Point(4, 22);
this.TAB_DRAW_ORDER.Name = "TAB_DRAW_ORDER";
this.TAB_DRAW_ORDER.Padding = new System.Windows.Forms.Padding(3);
- this.TAB_DRAW_ORDER.Size = new System.Drawing.Size(197, 141);
+ this.TAB_DRAW_ORDER.Size = new System.Drawing.Size(281, 141);
this.TAB_DRAW_ORDER.TabIndex = 1;
this.TAB_DRAW_ORDER.Text = "Draw Order";
this.TAB_DRAW_ORDER.UseVisualStyleBackColor = true;
+ // drawOrderCtrl
+ this.drawOrderCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.drawOrderCtrl.Location = new System.Drawing.Point(3, 3);
+ this.drawOrderCtrl.Name = "drawOrderCtrl";
+ this.drawOrderCtrl.Size = new System.Drawing.Size(275, 135);
+ this.drawOrderCtrl.TabIndex = 0;
+ this.drawOrderCtrl.Viewer = this.viewer;
+ this.drawOrderCtrl.LayerChanged += new Maestro.Editors.MapDefinition.LayerEventHandler(this.drawOrderCtrl_LayerChanged);
+ this.drawOrderCtrl.LayerDeleted += new Maestro.Editors.MapDefinition.LayerEventHandler(this.drawOrderCtrl_LayerDeleted);
// tabProperties
this.tabProperties.Controls.Add(this.TAB_PROPERTIES);
@@ -320,9 +260,7 @@
this.splitContainer2.ResumeLayout(false);
this.tabLayersAndGroups.ResumeLayout(false);
this.TAB_LEGEND.ResumeLayout(false);
- this.ctxLegend.ResumeLayout(false);
- this.grpContextMenu.ResumeLayout(false);
- this.layerContextMenu.ResumeLayout(false);
+ this.TAB_DRAW_ORDER.ResumeLayout(false);
this.tabProperties.ResumeLayout(false);
this.TAB_PROPERTIES.ResumeLayout(false);
this.statusStrip.ResumeLayout(false);
@@ -331,6 +269,8 @@
+ private Maestro.Editors.MapDefinition.LiveMapEditorDrawOrder drawOrderCtrl;
+ private Maestro.Editors.MapDefinition.LiveMapEditorLegend legendCtrl;
#endregion
@@ -340,20 +280,11 @@
private System.Windows.Forms.TabPage TAB_DRAW_ORDER;
private MapViewer.MapViewer viewer;
private MapViewer.DefaultToolbar toolbar;
- private MapViewer.Legend legendCtrl;
private System.Windows.Forms.StatusStrip statusStrip;
private System.Windows.Forms.ToolStripStatusLabel lblCoordinates;
private System.Windows.Forms.ToolStripStatusLabel lblSelected;
private System.Windows.Forms.ToolStripStatusLabel lblScale;
private MapViewer.MapStatusTracker mapStatusTracker;
- private System.Windows.Forms.ContextMenuStrip grpContextMenu;
- private System.Windows.Forms.ContextMenuStrip layerContextMenu;
- private System.Windows.Forms.ToolStripMenuItem addLayerToolStripMenuItem;
- private System.Windows.Forms.ToolStripMenuItem removeThisLayerToolStripMenuItem;
- private System.Windows.Forms.ToolStripMenuItem removeThisGroupToolStripMenuItem;
- private System.Windows.Forms.ContextMenuStrip ctxLegend;
- private System.Windows.Forms.ToolStripMenuItem addNewGroupToolStripMenuItem;
- private System.Windows.Forms.ToolStripMenuItem addNewLayerToolStripMenuItem;
private System.Windows.Forms.SplitContainer splitContainer2;
private System.Windows.Forms.TabControl tabProperties;
private System.Windows.Forms.TabPage TAB_PROPERTIES;
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.cs 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -95,5 +95,24 @@
return;
propGrid.SelectedObject = node.Tag;
+ private void drawOrderCtrl_LayerChanged(object sender, RuntimeMapLayer layer)
+ propGrid.SelectedObject = layer;
+ private void drawOrderCtrl_LayerDeleted(object sender, RuntimeMapLayer layer)
+ if (layer == propGrid.SelectedObject)
+ propGrid.SelectedObject = null;
+ private void legendCtrl_NodeDeleted(object sender, TreeNode node)
+ var layer = node.Tag as Maestro.MapViewer.Legend.LayerNodeMetadata;
+ //Nothing to edit for theme rule nodes
+ if (layer != null && layer == propGrid.SelectedObject)
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.resx 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapDefinitionEditorCtrl.resx 2012-06-05 14:52:05 UTC (rev 6734)
@@ -117,15 +117,6 @@
</resheader>
- <metadata name="ctxLegend.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>672, 17</value>
- </metadata>
- <metadata name="grpContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>366, 17</value>
- </metadata>
- <metadata name="layerContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>521, 17</value>
- </metadata>
<metadata name="toolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>17, 17</value>
</metadata>
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.Designer.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,124 @@
+ partial class LiveMapEditorDrawOrder
+ /// <summary>
+ /// Designer variable used to keep track of non-visual components.
+ /// </summary>
+ /// <summary>
+ /// Disposes resources used by the control.
+ /// </summary>
+ if (disposing) {
+ if (components != null) {
+ /// <summary>
+ /// This method is required for Windows Forms designer support.
+ /// Do not change the method contents inside the source code editor. The Forms designer might
+ /// not be able to load this method if it was changed manually.
+ /// </summary>
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnUp = new System.Windows.Forms.ToolStripButton();
+ this.btnDown = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnDelete = new System.Windows.Forms.ToolStripButton();
+ this.lstDrawOrder = new System.Windows.Forms.ListBox();
+ this.toolStrip1.SuspendLayout();
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnUp,
+ this.btnDown,
+ this.toolStripSeparator1,
+ this.btnDelete});
+ this.toolStrip1.Location = new System.Drawing.Point(0, 0);
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.Size = new System.Drawing.Size(241, 25);
+ this.toolStrip1.TabIndex = 0;
+ this.toolStrip1.Text = "toolStrip1";
+ // btnUp
+ this.btnUp.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnUp.Enabled = false;
+ this.btnUp.Image = global::Maestro.Editors.Properties.Resources.arrow_090;
+ this.btnUp.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnUp.Name = "btnUp";
+ this.btnUp.Size = new System.Drawing.Size(23, 22);
+ this.btnUp.Text = "Move Up";
+ this.btnUp.Click += new System.EventHandler(this.btnUp_Click);
+ // btnDown
+ this.btnDown.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDown.Enabled = false;
+ this.btnDown.Image = global::Maestro.Editors.Properties.Resources.arrow_270;
+ this.btnDown.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDown.Name = "btnDown";
+ this.btnDown.Size = new System.Drawing.Size(23, 22);
+ this.btnDown.Text = "Move Down";
+ this.btnDown.Click += new System.EventHandler(this.btnDown_Click);
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
+ // btnDelete
+ this.btnDelete.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnDelete.Enabled = false;
+ this.btnDelete.Image = global::Maestro.Editors.Properties.Resources.cross_script;
+ this.btnDelete.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnDelete.Name = "btnDelete";
+ this.btnDelete.Size = new System.Drawing.Size(23, 22);
+ this.btnDelete.Text = "Delete";
+ this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
+ // lstDrawOrder
+ this.lstDrawOrder.DisplayMember = "LegendLabel";
+ this.lstDrawOrder.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lstDrawOrder.FormattingEnabled = true;
+ this.lstDrawOrder.Location = new System.Drawing.Point(0, 25);
+ this.lstDrawOrder.Name = "lstDrawOrder";
+ this.lstDrawOrder.Size = new System.Drawing.Size(241, 380);
+ this.lstDrawOrder.TabIndex = 1;
+ this.lstDrawOrder.SelectedIndexChanged += new System.EventHandler(this.lstDrawOrder_SelectedIndexChanged);
+ // LiveMapEditorDrawOrder
+ this.Controls.Add(this.lstDrawOrder);
+ this.Controls.Add(this.toolStrip1);
+ this.Name = "LiveMapEditorDrawOrder";
+ this.Size = new System.Drawing.Size(241, 405);
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
+ private System.Windows.Forms.ToolStripButton btnDelete;
+ private System.Windows.Forms.ToolStripButton btnDown;
+ private System.Windows.Forms.ToolStripButton btnUp;
+ private System.Windows.Forms.ListBox lstDrawOrder;
+ private System.Windows.Forms.ToolStrip toolStrip1;
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,182 @@
+#endregion
+using System;
+using System.Linq;
+using Maestro.MapViewer;
+ /// <summary>
+ /// Description of LiveMapEditorDrawOrder.
+ /// </summary>
+ public partial class LiveMapEditorDrawOrder : UserControl
+ public LiveMapEditorDrawOrder()
+ private IMapViewer _viewer;
+ public IMapViewer Viewer
+ get { return _viewer; }
+ set
+ if (_viewer != value)
+ if (_viewer != null)
+ _viewer.MapLoaded -= OnMapLoaded;
+ UnbindMap();
+ _viewer = value;
+ _map = _viewer.GetMap();
+ BindMap();
+ _viewer.MapLoaded += OnMapLoaded;
+ void OnMapLoaded(object sender, EventArgs e)
+ BindMap();
+ private void OnMapLayersChanged(object sender, EventArgs e)
+ RefreshLayerList();
+ private void UnbindMap()
+ if (_map == null)
+ return;
+ _map.Layers.CollectionChanged -= OnMapLayersChanged;
+ private void BindMap()
+ if (_map == null)
+ return;
+ _map.Layers.CollectionChanged += OnMapLayersChanged;
+ private void RefreshLayerList()
+ try
+ bSuppressSelectedIndexChanged = true;
+ var item = lstDrawOrder.SelectedItem as RuntimeMapLayer;
+ lstDrawOrder.DataSource = _map.Layers.OrderBy(x => x.DisplayOrder).ToArray();
+ if (item != null)
+ var idx = lstDrawOrder.FindStringExact(item.LegendLabel);
+ if (idx >= 0)
+ lstDrawOrder.SelectedIndex = idx;
+ finally
+ bSuppressSelectedIndexChanged = false;
+ private bool bSuppressSelectedIndexChanged = false;
+ private void lstDrawOrder_SelectedIndexChanged(object sender, EventArgs e)
+ if (bSuppressSelectedIndexChanged)
+ return;
+ btnUp.Enabled = btnDown.Enabled = btnDelete.Enabled = false;
+ var layer = lstDrawOrder.SelectedItem as RuntimeMapLayer;
+ if (layer != null)
+ btnUp.Enabled = btnDown.Enabled = btnDelete.Enabled = true;
+ var h = this.LayerChanged;
+ if (h != null)
+ h(this, layer);
+ public event LayerEventHandler LayerChanged;
+ public event LayerEventHandler LayerDeleted;
+ private void btnUp_Click(object sender, EventArgs e)
+ if (_map == null)
+ return;
+ int idx = _map.Layers.IndexOf(layer);
+ if (idx > 0)
+ idx--;
+ else
+ return;
+ _map.Layers.SetNewIndex(idx, layer);
+ this.Viewer.RefreshMap();
+ private void btnDown_Click(object sender, EventArgs e)
+ if (_map == null)
+ return;
+ if (idx < _map.Layers.Count - 1)
+ idx++;
+ else
+ return;
+ private void btnDelete_Click(object sender, EventArgs e)
+ _map.Layers.Remove(layer);
+ public delegate void LayerEventHandler(object sender, RuntimeMapLayer layer);
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorDrawOrder.resx 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,123 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+</root>
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.Designer.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,196 @@
+ partial class LiveMapEditorLegend
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ if (disposing) {
+ /// <summary>
+ /// </summary>
+ this.components = new System.ComponentModel.Container();
+ this.btnAddLayer = new System.Windows.Forms.ToolStripButton();
+ this.btnAddGroup = new System.Windows.Forms.ToolStripButton();
+ this.ctxLegend = new System.Windows.Forms.ContextMenuStrip(this.components);
+ this.addNewGroupToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.addNewLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.grpContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
+ this.addLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.removeThisGroupToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.layerContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
+ this.removeThisLayerToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.legendCtrl = new Maestro.MapViewer.Legend();
+ this.ctxLegend.SuspendLayout();
+ this.grpContextMenu.SuspendLayout();
+ this.layerContextMenu.SuspendLayout();
+ // toolStrip1
+ this.btnAddLayer,
+ this.btnAddGroup,
+ this.toolStripSeparator1});
+ this.toolStrip1.Size = new System.Drawing.Size(275, 25);
+ // btnAddLayer
+ this.btnAddLayer.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.btnAddLayer.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnAddLayer.Name = "btnAddLayer";
+ this.btnAddLayer.Size = new System.Drawing.Size(80, 22);
+ this.btnAddLayer.Text = "Add Layer";
+ this.btnAddLayer.Click += new System.EventHandler(this.btnAddLayer_Click);
+ // btnAddGroup
+ this.btnAddGroup.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ this.btnAddGroup.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnAddGroup.Name = "btnAddGroup";
+ this.btnAddGroup.Size = new System.Drawing.Size(85, 22);
+ this.btnAddGroup.Text = "Add Group";
+ this.btnAddGroup.Click += new System.EventHandler(this.btnAddGroup_Click);
+ // ctxLegend
+ this.ctxLegend.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.addNewGroupToolStripMenuItem,
+ this.addNewLayerToolStripMenuItem});
+ this.ctxLegend.Name = "ctxLegend";
+ this.ctxLegend.Size = new System.Drawing.Size(160, 48);
+ this.ctxLegend.Click += new System.EventHandler(this.btnAddLayer_Click);
+ // addNewGroupToolStripMenuItem
+ this.addNewGroupToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.folder__plus;
+ this.addNewGroupToolStripMenuItem.Name = "addNewGroupToolStripMenuItem";
+ this.addNewGroupToolStripMenuItem.Size = new System.Drawing.Size(159, 22);
+ this.addNewGroupToolStripMenuItem.Text = "Add New Group";
+ this.addNewGroupToolStripMenuItem.Click += new System.EventHandler(this.btnAddGroup_Click);
+ // addNewLayerToolStripMenuItem
+ this.addNewLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.addNewLayerToolStripMenuItem.Name = "addNewLayerToolStripMenuItem";
+ this.addNewLayerToolStripMenuItem.Size = new System.Drawing.Size(159, 22);
+ this.addNewLayerToolStripMenuItem.Text = "Add New Layer";
+ // grpContextMenu
+ this.grpContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.addLayerToolStripMenuItem,
+ this.removeThisGroupToolStripMenuItem});
+ this.grpContextMenu.Name = "grpContextMenu";
+ this.grpContextMenu.Size = new System.Drawing.Size(179, 48);
+ // addLayerToolStripMenuItem
+ this.addLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__plus;
+ this.addLayerToolStripMenuItem.Name = "addLayerToolStripMenuItem";
+ this.addLayerToolStripMenuItem.Size = new System.Drawing.Size(178, 22);
+ this.addLayerToolStripMenuItem.Text = "Add Layer";
+ this.addLayerToolStripMenuItem.Click += new System.EventHandler(this.addLayerToolStripMenuItem_Click);
+ // removeThisGroupToolStripMenuItem
+ this.removeThisGroupToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.folder__minus;
+ this.removeThisGroupToolStripMenuItem.Name = "removeThisGroupToolStripMenuItem";
+ this.removeThisGroupToolStripMenuItem.Size = new System.Drawing.Size(178, 22);
+ this.removeThisGroupToolStripMenuItem.Text = "Remove This Group";
+ this.removeThisGroupToolStripMenuItem.Click += new System.EventHandler(this.removeThisGroupToolStripMenuItem_Click);
+ // layerContextMenu
+ this.layerContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.removeThisLayerToolStripMenuItem});
+ this.layerContextMenu.Name = "layerContextMenu";
+ this.layerContextMenu.Size = new System.Drawing.Size(174, 26);
+ // removeThisLayerToolStripMenuItem
+ this.removeThisLayerToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer__minus;
+ this.removeThisLayerToolStripMenuItem.Name = "removeThisLayerToolStripMenuItem";
+ this.removeThisLayerToolStripMenuItem.Size = new System.Drawing.Size(173, 22);
+ this.removeThisLayerToolStripMenuItem.Text = "Remove This Layer";
+ this.removeThisLayerToolStripMenuItem.Click += new System.EventHandler(this.removeThisLayerToolStripMenuItem_Click);
+ // legendCtrl
+ this.legendCtrl.ContextMenuStrip = this.ctxLegend;
+ this.legendCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.legendCtrl.GroupContextMenu = this.grpContextMenu;
+ this.legendCtrl.LayerContextMenu = this.layerContextMenu;
+ this.legendCtrl.Location = new System.Drawing.Point(0, 25);
+ this.legendCtrl.Name = "legendCtrl";
+ this.legendCtrl.SelectOnRightClick = true;
+ this.legendCtrl.ShowTooltips = true;
+ this.legendCtrl.Size = new System.Drawing.Size(275, 356);
+ this.legendCtrl.TabIndex = 1;
+ this.legendCtrl.ThemeCompressionLimit = 25;
+ this.legendCtrl.Viewer = null;
+ // LiveMapEditorLegend
+ this.Controls.Add(this.legendCtrl);
+ this.Name = "LiveMapEditorLegend";
+ this.Size = new System.Drawing.Size(275, 381);
+ this.ctxLegend.ResumeLayout(false);
+ this.grpContextMenu.ResumeLayout(false);
+ this.layerContextMenu.ResumeLayout(false);
+ private System.Windows.Forms.ToolStripButton btnAddGroup;
+ private System.Windows.Forms.ToolStripButton btnAddLayer;
+ private Maestro.MapViewer.Legend legendCtrl;
+ private System.Windows.Forms.ContextMenuStrip ctxLegend;
+ private System.Windows.Forms.ToolStripMenuItem addNewGroupToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem addNewLayerToolStripMenuItem;
+ private System.Windows.Forms.ContextMenuStrip grpContextMenu;
+ private System.Windows.Forms.ToolStripMenuItem addLayerToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem removeThisGroupToolStripMenuItem;
+ private System.Windows.Forms.ContextMenuStrip layerContextMenu;
+ private System.Windows.Forms.ToolStripMenuItem removeThisLayerToolStripMenuItem;
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,191 @@
+#endregion
+using System;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+ /// <summary>
+ /// Description of LiveMapEditorLegend.
+ /// </summary>
+ public partial class LiveMapEditorLegend : UserControl
+ public LiveMapEditorLegend()
+ legendCtrl.NodeSelected += new NodeEventHandler(OnInnerNodeSelected);
+ private void OnInnerNodeSelected(object sender, TreeNode e)
+ var h = this.NodeSelected;
+ if (h != null)
+ h(this, e);
+ public event NodeEventHandler NodeDeleted;
+ public event NodeEventHandler NodeSelected;
+ get { return legendCtrl.Viewer; }
+ set { legendCtrl.Viewer = value; }
+ private void btnAddGroup_Click(object sender, EventArgs e)
+ var map = this.Viewer.GetMap();
+ if (map != null)
+ var diag = new Live.NewGroupDialog(map);
+ if (diag.ShowDialog() == DialogResult.OK)
+ var mapSvc = (IMappingService)map.CurrentConnection.GetService((int)ServiceType.Mapping);
+ var group = mapSvc.CreateMapGroup(map, diag.GroupName);
+ group.LegendLabel = diag.GroupLabel;
+ group.Visible = true;
+ group.ShowInLegend = true;
+ map.Groups.Add(group);
+ legendCtrl.Viewer.RefreshMap();
+ private static string GenerateUniqueName(string prefix, RuntimeMapLayerCollection layers)
+ int counter = 0;
+ string name = prefix;
+ while (layers[name] != null)
+ counter++;
+ name = prefix + counter;
+ return name;
+ private void btnAddLayer_Click(object sender, EventArgs e)
+ if (map != null)
+ using (var picker = new ResourcePicker(map.CurrentConnection.ResourceService, ResourceTypes.LayerDefinition, ResourcePickerMode.OpenResource))
+ if (picker.ShowDialog() == DialogResult.OK)
+ var layer = mapSvc.CreateMapLayer(map, ((ILayerDefinition)map.CurrentConnection.ResourceService.GetResource(picker.ResourceID)));
+ layer.Name = GenerateUniqueName(ResourceIdentifier.GetName(picker.ResourceID), map.Layers);
+ layer.LegendLabel = ResourceIdentifier.GetName(picker.ResourceID);
+ layer.Visible = true;
+ layer.ShowInLegend = true;
+ map.Layers.Insert(0, layer);
+ private void addLayerToolStripMenuItem_Click(object sender, EventArgs e)
+ if (map != null)
+ var node = legendCtrl.SelectedNode;
+ if (node != null)
+ var grp = node.Tag as Legend.GroupNodeMetadata;
+ if (grp != null)
+ layer.Group = grp.Name;
+ private void removeThisGroupToolStripMenuItem_Click(object sender, EventArgs e)
+ if (map != null)
+ if (node != null)
+ if (grp != null)
+ var group = map.Groups[grp.Group];
+ if (group != null)
+ map.Groups.Remove(group);
+ private void removeThisLayerToolStripMenuItem_Click(object sender, EventArgs e)
+ if (map != null)
+ if (node != null)
+ var lyr = node.Tag as Legend.LayerNodeMetadata;
+ if (lyr != null && !lyr.IsThemeRule)
+ var layer = map.Layers[lyr.Name];
+ map.Layers.Remove(layer);
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorLegend.resx 2012-06-05 14:52:05 UTC (rev 6734)
@@ -0,0 +1,132 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </metadata>
+ <metadata name="ctxLegend.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>122, 17</value>
+ </metadata>
+ <metadata name="grpContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>229, 17</value>
+ </metadata>
+ <metadata name="layerContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>373, 17</value>
+ </metadata>
+</root>
Modified: trunk/Tools/Maestro/Maestro.MapViewer/Legend.Designer.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/Legend.Designer.cs 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.MapViewer/Legend.Designer.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -53,6 +53,7 @@
this.trvLegend.DrawNode += new System.Windows.Forms.DrawTreeNodeEventHandler(this.trvLegend_DrawNode);
this.trvLegend.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvLegend_AfterSelect);
this.trvLegend.NodeMouseClick += new System.Windows.Forms.TreeNodeMouseClickEventHandler(this.trvLegend_NodeMouseClick);
+ this.trvLegend.MouseDown += new System.Windows.Forms.MouseEventHandler(this.trvLegend_MouseDown);
// imgLegend
Modified: trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/Maestro.MapViewer/Legend.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -34,7 +34,7 @@
namespace Maestro.MapViewer
- public delegate void NodeSelectionEventHandler(object sender, TreeNode node);
+ public delegate void NodeEventHandler(object sender, TreeNode node);
public partial class Legend : UserControl
@@ -272,6 +272,8 @@
+ public TreeNode SelectedNode { get { return trvLegend.SelectedNode; } }
private static void ClearNodes(TreeNodeCollection nodes)
foreach (TreeNode node in nodes)
@@ -1010,7 +1012,7 @@
set { trvLegend.ShowNodeToolTips = value; }
- public event NodeSelectionEventHandler NodeSelected;
private void trvLegend_AfterSelect(object sender, TreeViewEventArgs e)
@@ -1018,5 +1020,15 @@
if (h != null)
h(this, e.Node);
+ public bool SelectOnRightClick { get; set; }
+ private void trvLegend_MouseDown(object sender, MouseEventArgs e)
+ if (e.Button == MouseButtons.Right && this.SelectOnRightClick)
+ trvLegend.SelectedNode = trvLegend.GetNodeAt(e.X, e.Y);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs 2012-06-05 12:12:43 UTC (rev 6733)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/Collections.cs 2012-06-05 14:52:05 UTC (rev 6734)
@@ -19,8 +19,11 @@
#endregion
using System;
using System.Text;
using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using System.Collections;
namespace OSGeo.MapGuide.MaestroAPI.Mapping
@@ -29,7 +32,7 @@
/// </summary>
/// <typeparam name="TKey">The type of the key.</typeparam>
/// <typeparam name="TVal">The type of the value.</typeparam>
- public abstract class KeyValueCollection<TKey, TVal> : IList<TVal> where TVal : class
+ public abstract class KeyValueCollection<TKey, TVal> : IList<TVal>, IList where TVal : class
/// <summary>
/// The internal list of value
@@ -96,6 +99,7 @@
_values.Insert(index, item);
_valuesByKey.Add(key, item);
OnItemAdded(item);
+ OnCollectionChanged();
/// <summary>
@@ -121,6 +125,7 @@
_valuesByKey.Remove(key);
OnItemRemoved(item);
@@ -149,10 +154,38 @@
if (_values[index] != null)
RemoveAt(index);
_values[index] = value;
/// <summary>
+ /// Sets the new index of the specified object. This object must already be present inside the collection
+ /// </summary>
+ /// <param name="newIndex"></param>
+ /// <param name="item"></param>
+ public void SetNewIndex(int newIndex, TVal item)
+ int idx = this.IndexOf(item);
+ if (idx >= 0)
+ bool bSuccess = false;
+ try
+ bSuppressCollectionChanged = true;
+ this.RemoveAt(idx);
+ this.Insert(newIndex, item);
+ bSuccess = true;
+ finally
+ bSuppressCollectionChanged = false;
+ if (bSuccess)
+ /// <summary>
/// Adds an item to the <see cref="T:System.Collections.Generic.ICollection`1"/>.
/// </summary>
/// <param name="item">The object to add to the <see cref="T:System.Collections.Generic.ICollection`1"/>.</param>
@@ -169,6 +202,7 @@
_values.Add(item);
OnItemAdded(item);
/// <summary>
@@ -179,24 +213,35 @@
/// </exception>
public virtual void Clear()
- //We don't call Clear() directly because we need to propagate removal of each
- //item back to the map
- var items = new List<TVal>(this);
- foreach (var item in items)
+ bool hasRemovedAnItem = false;
+ try
- Remove(item);
+ //We don't call Clear() directly because we need to propagate removal of each
+ //item back to the map
+ var items = new List<TVal>(this);
+ foreach (var item in items)
+ Remove(item);
+ hasRemovedAnItem = true;
+ //This shouldn't happen
+ if (_values.Count > 0)
+ System.Diagnostics.Trace.TraceWarning("Expected empty values collection!");
+ _values.Clear();
+ if (_valuesByKey.Count > 0)
+ _valuesByKey.Clear();
- //This shouldn't happen
- if (_values.Count > 0)
- System.Diagnostics.Trace.TraceWarning("Expected empty values collection!");
- _values.Clear();
+ finally {
+ if (hasRemovedAnItem)
- if (_valuesByKey.Count > 0)
- _valuesByKey.Clear();
/// <summary>
@@ -279,6 +324,7 @@
return ret;
return ret;
@@ -323,8 +369,32 @@
public TVal this[TKey key]
get { return _valuesByKey.ContainsKey(key) ? _valuesByKey[key] : null; }
- set { _valuesByKey[key] = value; }
+ set
+ _valuesByKey[key] = value;
+ /// <summary>
+ /// Raised when the collection has been modified
+ /// </summary>
+ public event EventHandler CollectionChanged;
+ private bool bSuppressCollectionChanged = false;
+ /// <summary>
+ /// Raises the <see cref="CollectionChanged" /> event
+ /// </summary>
+ protected virtual void OnCollectionChanged()
+ if (bSuppressCollectionChanged)
+ return;
+ var h = this.CollectionChanged;
+ if (h != null)
+ h(this, EventArgs.Empty);
/// <summary>
/// Called before an item is added
@@ -357,6 +427,86 @@
/// <param name="value">The value.</param>
/// <returns></returns>
protected abstract TKey SelectKey(TVal value);
+ int IList.Add(object value)
+ this.Add((TVal)value);
+ return this.Count - 1;
+ void IList.Clear()
+ this.Clear();
+ bool IList.Contains(object value)
+ return this.Contains((TVal)value);
+ int IList.IndexOf(object value)
+ return this.IndexOf((TVal)value);
+ void IList.Insert(int index, object value)
+ this.Insert(index, (TVal)value);
+ bool IList.IsFixedSize
+ get { return false; }
+ bool IList.IsReadOnly
+ void IList.Remove(object value)
+ this.Remove((TVal)value);
+ void IList.RemoveAt(int index)
+ this.RemoveAt(index);
+ object IList.this[int index]
+ get
+ return this[index];
+ set
+ this[index] = (TVal)value;
+ void ICollection.CopyTo(Array array, int index)
+ this.CopyTo((TVal[])array, index);
+ int ICollection.Count
+ get { return this.Count; }
+ bool ICollection.IsSynchronized
+ private readonly object _syncRoot = new object();
+ object ICollection.SyncRoot
+ get { return _syncRoot; }
/// <summary>
More information about the mapguide-commits
