[mapguide-commits] r6735 - in trunk/Tools/Maestro: Maestro.Base/Editor Maestro.Editors/Generic
svn_mapguide at osgeo.org
Wed Jun 6 04:38:16 PDT 2012
Author: jng
Date: 2012-06-06 04:38:16 -0700 (Wed, 06 Jun 2012)
New Revision: 6735
trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
#2016: Fix trailing characters due to faulty formatting logic. Since we've moved to the ICSharpCode.TextEditor component, we can probably remove this function in the future.
Also fix a threading issue with XML validation (probably due to the introduction of the ICSharpCode.TextEditor component)
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs 2012-06-05 14:52:05 UTC (rev 6734)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs 2012-06-06 11:38:16 UTC (rev 6735)
@@ -78,36 +78,44 @@
string[] warnings;
string[] errors;
- ValidateXml(out errors, out warnings);
- var issues = new List<ValidationIssue>();
- foreach (string err in errors)
+ Func<ValidationIssue[]> validator = () =>
- issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Error, ValidationStatusCode.Error_General_ValidationError, err));
- foreach (string warn in warnings)
- issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Warning, ValidationStatusCode.Warning_General_ValidationWarning, warn));
+ ValidateXml(out errors, out warnings);
+ var issues = new List<ValidationIssue>();
+ foreach (string err in errors)
+ issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Error, ValidationStatusCode.Error_General_ValidationError, err));
+ foreach (string warn in warnings)
+ issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Warning, ValidationStatusCode.Warning_General_ValidationWarning, warn));
- //Put through ValidationResultSet to weed out redundant messages
- var set = new ValidationResultSet(issues);
+ //Put through ValidationResultSet to weed out redundant messages
+ var set = new ValidationResultSet(issues);
- try
- var res = ResourceTypeRegistry.Deserialize(editor.XmlContent);
- var context = new ResourceValidationContext(_edSvc.ResourceService, _edSvc.FeatureService);
- //We don't care about dependents, we just want to validate *this* resource
- var resIssues = ResourceValidatorSet.Validate(context, res, false);
- set.AddIssues(resIssues);
- catch
- //This can fail because the XML may be for something that Maestro does not offer a strongly-typed class for yet.
- //So the XML may be legit, just not for this version of Maestro that is doing the validating
+ try
+ var res = ResourceTypeRegistry.Deserialize(editor.XmlContent);
+ var context = new ResourceValidationContext(_edSvc.ResourceService, _edSvc.FeatureService);
+ //We don't care about dependents, we just want to validate *this* resource
+ var resIssues = ResourceValidatorSet.Validate(context, res, false);
+ set.AddIssues(resIssues);
+ catch
+ //This can fail because the XML may be for something that Maestro does not offer a strongly-typed class for yet.
+ //So the XML may be legit, just not for this version of Maestro that is doing the validating
- //Only care about errors. Warnings and other types should not derail us from saving
- return set.GetAllIssues(ValidationStatus.Error);
+ //Only care about errors. Warnings and other types should not derail us from saving
+ return set.GetAllIssues(ValidationStatus.Error);
+ if (this.InvokeRequired)
+ return (ValidationIssue[])this.Invoke(validator);
+ else
+ return validator();
public override string GetXmlContent()
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs 2012-06-05 14:52:05 UTC (rev 6734)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditorCtrl.cs 2012-06-06 11:38:16 UTC (rev 6735)
@@ -148,7 +148,7 @@
set
_origText = null;
- txtXmlContent.Text = value; FormatText();
+ txtXmlContent.Text = value; //FormatText();
More information about the mapguide-commits
