[mapguide-commits] r6804 - in trunk/Tools/Maestro: ExtendedModels/LayerDefinition-2.3.0 ExtendedModels/LayerDefinition-2.4.0 ExtendedModels/MapDefinition-2.3.0 ExtendedModels/MapDefinition-2.4.0 ExtendedModels/WatermarkDefinition-2.3.0 Maestro.AddIn.Local/Services Maestro.Base/Editor Maestro.Editors/WatermarkDefinition OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Mon Jun 25 06:26:33 PDT 2012
Author: jng
Date: 2012-06-25 06:26:33 -0700 (Mon, 25 Jun 2012)
New Revision: 6804
Added:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkCollectionUtil.cs
trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.3.0.csproj
trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.4.0.csproj
trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0.csproj
trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.4.0.csproj
trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0/WatermarkImpl.cs
trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkInterfaces.cs
#2036: Fix inability to add watermark instances to a Map Definition if originating from a different resource version (eg. A 2.3 watermark to a 2.4 Map Definition or vice versa). To fix this we removed the CreateInstance() API from IWatermarkDefinition. Instead we delegate watermark instance creation to a new internal WatermarkCollectionUtil utility class. This allows watermark instances to be detached from the WatermarkDefinition version allowing watermarks to be added from *any* Watermark Definition regardless of schema version. The existing Watermark Collection editor has been re-worked to work against this change of APIs
Modified: trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.3.0.csproj
--- trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.3.0.csproj 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.3.0.csproj 2012-06-25 13:26:33 UTC (rev 6804)
@@ -73,6 +73,9 @@
<Compile Include="..\..\OSGeo.MapGuide.MaestroAPI\ObjectModels\VectorLayerDefinitionImpl.cs">
<Link>VectorLayerDefinitionImpl.cs</Link>
</Compile>
+ <Compile Include="..\..\OSGeo.MapGuide.MaestroAPI\ObjectModels\WatermarkCollectionUtil.cs">
+ <Link>WatermarkCollectionUtil.cs</Link>
+ </Compile>
<Compile Include="..\..\Properties\GlobalAssemblyInfo.cs">
<Link>GlobalAssemblyInfo.cs</Link>
</Compile>
Modified: trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.4.0.csproj
--- trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.4.0.csproj 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/ExtendedModels/LayerDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.LayerDefinition-2.4.0.csproj 2012-06-25 13:26:33 UTC (rev 6804)
@@ -73,6 +73,9 @@
</Compile>
+ </Compile>
</Compile>
Modified: trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0.csproj
--- trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0.csproj 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.3.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.3.0.csproj 2012-06-25 13:26:33 UTC (rev 6804)
@@ -67,6 +67,9 @@
<Compile Include="..\..\OSGeo.MapGuide.MaestroAPI\ObjectModels\MapDefinition.cs">
<Link>MapDefinition.cs</Link>
</Compile>
+ </Compile>
</Compile>
Modified: trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.4.0.csproj
--- trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.4.0.csproj 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/ExtendedModels/MapDefinition-2.4.0/OSGeo.MapGuide.ObjectModels.MapDefinition-2.4.0.csproj 2012-06-25 13:26:33 UTC (rev 6804)
@@ -67,6 +67,9 @@
</Compile>
+ </Compile>
</Compile>
Modified: trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0/WatermarkImpl.cs
--- trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0/WatermarkImpl.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/ExtendedModels/WatermarkDefinition-2.3.0/WatermarkImpl.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -210,17 +210,6 @@
return this.Clone();
- public IWatermark CreateInstance()
- return new WatermarkType()
- ResourceId = this.ResourceID,
- Name = ResourceIdentifier.GetName(this.ResourceID),
- Usage = UsageType.All
public IXYPosition CreateXYPosition()
return new XYPositionType()
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -67,14 +67,13 @@
string resId = "Session:" + edSvc.SessionID + "//" + Guid.NewGuid() + "." + res.ResourceType.ToString();
edSvc.ResourceService.SetResourceXmlData(resId, ResourceTypeRegistry.Serialize(res));
- var wm = ((IWatermarkDefinition)res).CreateInstance();
- wm.ResourceId = resId;
var csFact = new MgCoordinateSystemFactory();
var arbXY = csFact.ConvertCoordinateSystemCodeToWkt("XY-M");
mapDef = ObjectFactory.CreateMapDefinition(conn, new Version(2, 3, 0), "Preview");
mapDef.CoordinateSystem = arbXY;
mapDef.SetExtents(-100000, -100000, 100000, 100000);
- ((IMapDefinition2)mapDef).AddWatermark(wm);
+ var wm = ((IMapDefinition2)mapDef).AddWatermark(((IWatermarkDefinition)res));
+ wm.ResourceId = resId;
var mapResId = new MgResourceIdentifier("Session:" + edSvc.SessionID + "//" + Guid.NewGuid() + "." + res.ResourceType.ToString());
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -183,7 +183,7 @@
IMapDefinition2 map = (IMapDefinition2)ObjectFactory.CreateMapDefinition(wmd.CurrentConnection, wmd.SupportedMapDefinitionVersion, "Watermark Definition Preview");
map.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]";
map.Extents = ObjectFactory.CreateEnvelope(-1000000, -1000000, 1000000, 1000000);
- map.AddWatermark(wmd.CreateInstance());
+ map.AddWatermark(wmd);
return GenerateMapPreviewUrl(map);
Modified: trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/Maestro.Editors/WatermarkDefinition/WatermarkCollectionEditorCtrl.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -64,13 +64,17 @@
LastSelectedFolder.FolderId = picker.SelectedFolder;
var wdf = (IWatermarkDefinition)_resSvc.GetResource(picker.ResourceID);
- var wm = wdf.CreateInstance();
+ //var wm = wdf.CreateInstance();
+ var wm = _watermarks.AddWatermark(wdf);
var diag = new WatermarkInstanceEditorDialog(_resSvc, wm);
if (diag.ShowDialog() == DialogResult.OK)
_list.Add(wm);
- _watermarks.AddWatermark(wm);
+ else //Undo
+ _watermarks.RemoveWatermark(wm);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2012-06-25 13:26:33 UTC (rev 6804)
@@ -251,6 +251,7 @@
<Compile Include="ObjectModels\IFdoSpatialContext.cs" />
<Compile Include="ObjectModels\NsDoc.cs" />
<Compile Include="ObjectModels\SymbolDefFactory.cs" />
+ <Compile Include="ObjectModels\WatermarkCollectionUtil.cs" />
<Compile Include="ObjectModels\WatermarkInterfaces.cs" />
<Compile Include="Resource\Comparison\BinaryData.cs" />
<Compile Include="Resource\Comparison\CharData.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -663,26 +663,14 @@
- void IWatermarkCollection.AddWatermark(OSGeo.MapGuide.ObjectModels.WatermarkDefinition.IWatermark watermark)
+ IWatermark IWatermarkCollection.AddWatermark(OSGeo.MapGuide.ObjectModels.WatermarkDefinition.IWatermarkDefinition watermark)
-#if MDF_240
- var wm = watermark as OSGeo.MapGuide.ObjectModels.WatermarkDefinition_2_4_0.WatermarkType;
-#else
- var wm = watermark as OSGeo.MapGuide.ObjectModels.WatermarkDefinition_2_3_0.WatermarkType;
-#endif
- if (wm != null)
- this.Watermarks.Add(wm);
+ return WatermarkCollectionUtil.AddWatermark(this.Watermarks, watermark);
void IWatermarkCollection.RemoveWatermark(OSGeo.MapGuide.ObjectModels.WatermarkDefinition.IWatermark watermark)
-#if MDF_240
-#else
-#endif
- if (wm != null)
- this.Watermarks.Remove(wm);
+ WatermarkCollectionUtil.RemoveWatermark(this.Watermarks, watermark);
int IWatermarkCollection.WatermarkCount
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -68,26 +68,14 @@
-#if LDF_240
-#else
-#endif
- if (wm != null)
-#if LDF_240
-#else
-#endif
- if (wm != null)
[XmlIgnore]
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkCollectionUtil.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkCollectionUtil.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkCollectionUtil.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -0,0 +1,52 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+using System.IO;
+using System.Xml.Serialization;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+namespace OSGeo.MapGuide.ObjectModels.WatermarkDefinition
+ internal class WatermarkCollectionUtil
+ public static IWatermark AddWatermark<T>(IList<T> collection, IWatermarkDefinition watermark) where T : class, IWatermark, new()
+ Check.NotNull(watermark, "watermark");
+ T impl = new T();
+ impl.ResourceId = watermark.ResourceID;
+ impl.Name = ResourceIdentifier.GetName(impl.ResourceId);
+ impl.Usage = UsageType.All;
+ collection.Add(impl);
+ return impl;
+ public static void RemoveWatermark<T>(IList<T> collection, IWatermark watermark) where T : class, IWatermark
+ T impl = watermark as T;
+ if (impl != null)
+ collection.Remove(impl);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkInterfaces.cs 2012-06-22 17:50:14 UTC (rev 6803)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/WatermarkInterfaces.cs 2012-06-25 13:26:33 UTC (rev 6804)
@@ -23,6 +23,7 @@
using System.ComponentModel;
using OSGeo.MapGuide.ObjectModels.SymbolDefinition;
+using OSGeo.MapGuide.ObjectModels.Common;
@@ -121,12 +122,6 @@
IPosition Position { get; set; }
/// <summary>
- /// Creates an new watermark instance from this definition
- /// </summary>
- /// <returns></returns>
- IWatermark CreateInstance();
- /// <summary>
/// Creates the XY position.
/// </summary>
@@ -288,8 +283,9 @@
/// <summary>
/// Adds a watermark
/// </summary>
- /// <param name="watermark"></param>
- void AddWatermark(IWatermark watermark);
+ /// <param name="watermarkDef">The watermark definition to add</param>
+ /// <returns>The added watermark instance.</returns>
+ IWatermark AddWatermark(IWatermarkDefinition watermarkDef);
/// <summary>
/// Removes the specified watermark
More information about the mapguide-commits
