[mapguide-commits] r6805 - in trunk/Tools/Maestro/Maestro.Editors: . Properties Resources
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 25 06:35:33 PDT 2012
Author: jng
Date: 2012-06-25 06:35:33 -0700 (Mon, 25 Jun 2012)
New Revision: 6805
Added:
   trunk/Tools/Maestro/Maestro.Editors/Resources/water.png
   trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs
Update watermark resource icon in the Resource Picker
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2012-06-25 13:26:33 UTC (rev 6804)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2012-06-25 13:35:33 UTC (rev 6805)
@@ -2319,6 +2319,7 @@
     <Content Include="OdbcDriverMap.xml">
       <CopyToOutputDirectory>Always</CopyToOutputDirectory>
     </Content>
+    <None Include="Resources\water.png" />
     <None Include="Resources\magnifier-left.png" />
     <None Include="Resources\icon_maptip_disabled.gif" />
     <None Include="Resources\icon_maptip.gif" />
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2012-06-25 13:26:33 UTC (rev 6804)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs	2012-06-25 13:35:33 UTC (rev 6805)
@@ -3532,6 +3532,13 @@
+        internal static System.Drawing.Bitmap water {
+            get {
+                object obj = ResourceManager.GetObject("water", resourceCulture);
+                return ((System.Drawing.Bitmap)(obj));
         /// <summary>
         ///   Looks up a localized string similar to A widget named {0} already exists.
         /// </summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2012-06-25 13:26:33 UTC (rev 6804)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx	2012-06-25 13:35:33 UTC (rev 6805)
@@ -5701,4 +5701,7 @@
   <data name="TextLoading" xml:space="preserve">
     <value>Loading</value>
   </data>
+  <data name="water" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\water.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs
--- trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs	2012-06-25 13:26:33 UTC (rev 6804)
+++ trunk/Tools/Maestro/Maestro.Editors/RepositoryIcons.cs	2012-06-25 13:35:33 UTC (rev 6805)
@@ -155,7 +155,7 @@
             imgList.Images.Add(Properties.Resources.blueprints);
             imgList.Images.Add(Properties.Resources.applications_stack);
             imgList.Images.Add(Properties.Resources.marker);
-            imgList.Images.Add(Properties.Resources.edit);
+            imgList.Images.Add(Properties.Resources.water);
             imgList.Images.Add(Properties.Resources.script__arrow);
             imgList.Images.Add(Properties.Resources.server);
             imgList.Images.Add(Properties.Resources.folder_horizontal);
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/water.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/water.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
More information about the mapguide-commits mailing list
