[mapguide-commits] r7066 - in trunk/Tools/Maestro/Maestro.Base: . UI/Packaging
svn_mapguide at osgeo.org
Wed Oct 3 07:07:01 PDT 2012
Author: jng
Date: 2012-10-03 07:07:01 -0700 (Wed, 03 Oct 2012)
New Revision: 7066
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/UI/Packaging/CreatePackageDialog.cs
#2133: Unique-ify the list of resource ids that are inputted into the Create Package dialog. Also make the "Compile Full Dependency List" command available on multiple selected resources.
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-10-03 14:05:15 UTC (rev 7065)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2012-10-03 14:07:01 UTC (rev 7066)
@@ -636,6 +636,9 @@
class="Maestro.Base.Commands.CutCommand" />
</Condition>
<MenuItem type="Separator" />
+ <MenuItem id="CompileDependencyList"
+ label="${res:SiteExplorer_SelectedItem_CompileDependencyList}"
+ class="Maestro.Base.Commands.SiteExplorer.CompileFullDependencyListCommand" />
<MenuItem id="CopyMoveMultipleToServer"
icon="server__arrow"
label="${res:SiteExplorer_CopyMoveToServer}"
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Packaging/CreatePackageDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Packaging/CreatePackageDialog.cs 2012-10-03 14:05:15 UTC (rev 7065)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Packaging/CreatePackageDialog.cs 2012-10-03 14:07:01 UTC (rev 7066)
@@ -80,7 +80,11 @@
public string[] ResourceIds
- get { return txtResourceIdList.Lines.ToArray(); }
+ get
+ var ids = new HashSet<string>(txtResourceIdList.Lines);
+ return ids.ToArray();
public string FolderToPackage
More information about the mapguide-commits
