[mapguide-commits] r7067 - in branches/2.4/MgDev/Desktop: MapViewer MgAppLayout
svn_mapguide at osgeo.org
Wed Oct 3 07:52:58 PDT 2012
Author: jng
Date: 2012-10-03 07:52:57 -0700 (Wed, 03 Oct 2012)
New Revision: 7067
Added:
branches/2.4/MgDev/Desktop/MapViewer/MgSearchComponent.cs
branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.Designer.cs
branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.cs
branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.resx
branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
branches/2.4/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs
branches/2.4/MgDev/Desktop/MapViewer/Strings.Designer.cs
branches/2.4/MgDev/Desktop/MapViewer/Strings.resx
branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout
branches/2.4/MgDev/Desktop/MgAppLayout/SheboyganTiled.AppLayout
mg-desktop: This submission includes the following changes:
- #2116: Implement support for pre-defined search commands. Like the AJAX/Fusion implementation, this is a very simple type of search.
- Update MgQueryResultsDialog to allow for unbounded search results (ie. A limit of -1 means spin through the entire reader)
Modified: branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj
--- branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MapViewer/MapViewer.csproj 2012-10-03 14:52:57 UTC (rev 7067)
@@ -168,6 +168,15 @@
<Compile Include="MgLayerSelectionHandler.cs">
<SubType>Component</SubType>
</Compile>
+ <Compile Include="MgSearchComponent.cs">
+ <SubType>Component</SubType>
+ </Compile>
+ <Compile Include="MgSearchControlImpl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="MgSearchControlImpl.Designer.cs">
+ <DependentUpon>MgSearchControlImpl.cs</DependentUpon>
+ </Compile>
<Compile Include="MgTaskPane.cs">
</Compile>
@@ -245,6 +254,9 @@
<EmbeddedResource Include="MgQueryResultsDialog.resx">
<DependentUpon>MgQueryResultsDialog.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="MgSearchControlImpl.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="MgTaskPane.resx">
<DependentUpon>MgTaskPane.cs</DependentUpon>
</EmbeddedResource>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgQueryResultsDialog.cs 2012-10-03 14:52:57 UTC (rev 7067)
@@ -79,7 +79,7 @@
bgGridLoader.ReportProgress(-1, new InitGridAction() { ColumnNames = propNames.ToArray() });
int read = 0;
- while (reader.ReadNext() && read < _limit)
+ while (reader.ReadNext())
object[] values = new object[propCount];
for (int i = 0; i < propCount; i++)
@@ -157,6 +157,8 @@
bgGridLoader.ReportProgress(-1, new AddRow() { Values = values });
read++;
+ if ((_limit > 0 && read >= _limit))
+ break;
finally
Added: branches/2.4/MgDev/Desktop/MapViewer/MgSearchComponent.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgSearchComponent.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgSearchComponent.cs 2012-10-03 14:52:57 UTC (rev 7067)
@@ -0,0 +1,45 @@
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace OSGeo.MapGuide.Viewer
+ public class MgSearchComponent : MgViewerComponent
+ /// <summary>
+ /// Gets or sets the layer name this component will search on
+ /// </summary>
+ [MgComponentProperty]
+ public string LayerName { get; set; }
+ /// <summary>
+ /// Gets or sets the filter this component will apply as part of the search
+ /// </summary>
+ public string Filter { get; set; }
+ /// <summary>
+ /// Gets or sets the prompt for the user interface
+ /// </summary>
+ public string Prompt { get; set; }
+ /// <summary>
+ /// Gets or sets the Task Pane / Window title
+ /// </summary>
+ public string Title { get; set; }
+ public MgSearchComponent()
+ this.Icon = Properties.Resources.search;
+ this.Label = this.ToolTipText = this.Title = Strings.TitleSearch;
+ this.Prompt = Strings.TextEnterSearchCriteria;
+ protected override MgControlView CreateControlView()
+ return new MgSearchControlImpl(this.Viewer, this.Title, this.LayerName, this.Prompt, this.Filter);
Added: branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.Designer.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.Designer.cs 2012-10-03 14:52:57 UTC (rev 7067)
@@ -0,0 +1,73 @@
+ partial class MgSearchControlImpl
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(MgSearchControlImpl));
+ this.lblPrompt = new System.Windows.Forms.Label();
+ this.txtSearch = new System.Windows.Forms.TextBox();
+ this.btnSearch = new System.Windows.Forms.Button();
+ this.SuspendLayout();
+ // lblPrompt
+ resources.ApplyResources(this.lblPrompt, "lblPrompt");
+ this.lblPrompt.Name = "lblPrompt";
+ // txtSearch
+ resources.ApplyResources(this.txtSearch, "txtSearch");
+ this.txtSearch.Name = "txtSearch";
+ // btnSearch
+ resources.ApplyResources(this.btnSearch, "btnSearch");
+ this.btnSearch.Name = "btnSearch";
+ this.btnSearch.UseVisualStyleBackColor = true;
+ this.btnSearch.Click += new System.EventHandler(this.btnSearch_Click);
+ // MgSearchControlImpl
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.btnSearch);
+ this.Controls.Add(this.txtSearch);
+ this.Controls.Add(this.lblPrompt);
+ this.Name = "MgSearchControlImpl";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label lblPrompt;
+ private System.Windows.Forms.TextBox txtSearch;
+ private System.Windows.Forms.Button btnSearch;
Added: branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.cs 2012-10-03 14:52:57 UTC (rev 7067)
@@ -0,0 +1,51 @@
+using System;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+ public partial class MgSearchControlImpl : MgControlView
+ private MgSearchControlImpl()
+ InitializeComponent();
+ private IMapViewer _viewer;
+ private string _filter;
+ private MgLayerBase _layer;
+ public MgSearchControlImpl(IMapViewer viewer, string title, string layerName, string prompt, string filter)
+ : this()
+ _viewer = viewer;
+ this.Title = title;
+ lblPrompt.Text = prompt;
+ _filter = filter;
+ if (!_filter.Contains("$USER_VARIABLE")) //NOXLATE
+ throw new InvalidOperationException(Strings.ErrorSearchFilterMissingPlaceholder);
+ var map = viewer.GetMap();
+ var layers = map.GetLayers();
+ var lidx = layers.IndexOf(layerName);
+ if (lidx < 0)
+ throw new InvalidOperationException(string.Format(Strings.ErrorInvalidSearchLayer, layerName));
+ _layer = layers.GetItem(lidx);
+ private void btnSearch_Click(object sender, EventArgs e)
+ var query = new MgFeatureQueryOptions();
+ query.SetFilter(_filter.Replace("$USER_VARIABLE", txtSearch.Text)); //NOXLATE
+ var reader = _layer.SelectFeatures(query);
+ new MgQueryResultsDialog(_viewer, _layer, reader, -1).Show();
Added: branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.resx
--- branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.resx (rev 0)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgSearchControlImpl.resx 2012-10-03 14:52:57 UTC (rev 7067)
@@ -0,0 +1,210 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="lblPrompt.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="lblPrompt.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 21</value>
+ </data>
+ <data name="lblPrompt.Size" type="System.Drawing.Size, System.Drawing">
+ <value>184, 45</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="lblPrompt.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>lblPrompt.Name" xml:space="preserve">
+ <value>lblPrompt</value>
+ </data>
+ <data name=">>lblPrompt.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lblPrompt.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>lblPrompt.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="txtSearch.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="txtSearch.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 81</value>
+ </data>
+ <data name="txtSearch.Size" type="System.Drawing.Size, System.Drawing">
+ <value>181, 20</value>
+ </data>
+ <data name="txtSearch.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>txtSearch.Name" xml:space="preserve">
+ <value>txtSearch</value>
+ </data>
+ <data name=">>txtSearch.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtSearch.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtSearch.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnSearch.Location" type="System.Drawing.Point, System.Drawing">
+ <value>16, 108</value>
+ </data>
+ <data name="btnSearch.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnSearch.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnSearch.Text" xml:space="preserve">
+ <value>Search</value>
+ </data>
+ <data name=">>btnSearch.Name" xml:space="preserve">
+ <value>btnSearch</value>
+ </data>
+ <data name=">>btnSearch.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnSearch.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnSearch.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+ <value>215, 144</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>MgSearchControlImpl</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>OSGeo.MapGuide.Viewer.MgControlView, OSGeo.MapGuide.Viewer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f</value>
+ </data>
+</root>
\ No newline at end of file
Modified: branches/2.4/MgDev/Desktop/MapViewer/Strings.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/Strings.Designer.cs 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MapViewer/Strings.Designer.cs 2012-10-03 14:52:57 UTC (rev 7067)
@@ -178,6 +178,15 @@
/// <summary>
+ /// Looks up a localized string similar to Invalid search layer. Layer {0} not found on map.
+ /// </summary>
+ internal static string ErrorInvalidSearchLayer {
+ get {
+ return ResourceManager.GetString("ErrorInvalidSearchLayer", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Layer metadata not fully initialized.
/// </summary>
internal static string ErrorLayerMetadataNotFullyInitialized {
@@ -214,6 +223,15 @@
/// <summary>
+ /// Looks up a localized string similar to The search filter is missing the required $USER_VARIABLE placeholder.
+ /// </summary>
+ internal static string ErrorSearchFilterMissingPlaceholder {
+ get {
+ return ResourceManager.GetString("ErrorSearchFilterMissingPlaceholder", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to The stream is not rewindable.
/// </summary>
internal static string ErrorStreamNotRewindable {
@@ -511,6 +529,15 @@
/// <summary>
+ /// Looks up a localized string similar to Enter Search Criteria.
+ /// </summary>
+ internal static string TextEnterSearchCriteria {
+ get {
+ return ResourceManager.GetString("TextEnterSearchCriteria", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Exit.
/// </summary>
internal static string TextExitApplication {
@@ -817,6 +844,15 @@
/// <summary>
+ /// Looks up a localized string similar to Search.
+ /// </summary>
+ internal static string TitleSearch {
+ get {
+ return ResourceManager.GetString("TitleSearch", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to About the Task Pane.
/// </summary>
internal static string TitleTaskPaneAbout {
Modified: branches/2.4/MgDev/Desktop/MapViewer/Strings.resx
--- branches/2.4/MgDev/Desktop/MapViewer/Strings.resx 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MapViewer/Strings.resx 2012-10-03 14:52:57 UTC (rev 7067)
@@ -390,4 +390,16 @@
<data name="SetLanguage" xml:space="preserve">
<value>Set Language</value>
</data>
+ <data name="ErrorSearchFilterMissingPlaceholder" xml:space="preserve">
+ <value>The search filter is missing the required $USER_VARIABLE placeholder</value>
+ </data>
+ <data name="ErrorInvalidSearchLayer" xml:space="preserve">
+ <value>Invalid search layer. Layer {0} not found on map</value>
+ </data>
+ <data name="TextEnterSearchCriteria" xml:space="preserve">
+ <value>Enter Search Criteria</value>
+ </data>
+ <data name="TitleSearch" xml:space="preserve">
+ </data>
</root>
Modified: branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout
--- branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout 2012-10-03 14:52:57 UTC (rev 7067)
@@ -1,6 +1,6 @@
<?xml version="1.0"?>
<AppLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
- <Title>MapGuide Desktop App Layout Example</Title>
+ <Title>MapGuide Desktop App Layout Example (Untiled)</Title>
<Icon>app.ico</Icon>
<Settings>
<NameValue>
@@ -92,6 +92,11 @@
</ItemBase>
<ItemBase xsi:type="SeparatorItem" />
<ItemBase xsi:type="CommandItem">
+ <ComponentID>SearchParcelsByName</ComponentID>
+ <ShowLabel>false</ShowLabel>
+ </ItemBase>
+ <ItemBase xsi:type="SeparatorItem" />
+ <ItemBase xsi:type="CommandItem">
<ComponentID>ViewerOptions</ComponentID>
</ItemBase>
@@ -185,6 +190,11 @@
</ItemBase>
+ </ItemBase>
</ItemBase>
@@ -248,6 +258,11 @@
<ComponentID>Theme</ComponentID>
</ItemBase>
+ </ItemBase>
</Items>
</ItemBase>
@@ -277,6 +292,11 @@
</ItemBase>
+ </ItemBase>
</Items>
</TaskMenu>
</TaskPane>
@@ -404,6 +424,40 @@
<ClassName>OSGeo.MapGuide.Viewer.MgSelectComponent</ClassName>
</ComponentDefinition>
<ComponentDefinition>
+ <ClassName>OSGeo.MapGuide.Viewer.MgSearchComponent</ClassName>
+ <Properties>
+ <NameValue>
+ <Name>Label</Name>
+ <Value>Search Parcels by Owner</Value>
+ </NameValue>
+ <NameValue>
+ <Name>Title</Name>
+ </NameValue>
+ <NameValue>
+ <Name>LayerName</Name>
+ <Value>Parcels</Value>
+ </NameValue>
+ <NameValue>
+ <Name>Prompt</Name>
+ <Value>Enter the owner's name (eg. Schmitt)</Value>
+ </NameValue>
+ <NameValue>
+ <Name>Filter</Name>
+ <Value>RNAME LIKE '$USER_VARIABLE%'</Value>
+ </NameValue>
+ <NameValue>
+ <Name>Target</Name>
+ <Value>enum:OSGeo.MapGuide.Viewer.MgViewerTarget:TaskPane</Value>
+ </NameValue>
+ <NameValue>
+ <Name>TaskPane</Name>
+ <Value>taskpane:</Value>
+ </NameValue>
+ </Properties>
+ </ComponentDefinition>
+ <ComponentDefinition>
<ClassName>OSGeo.MapGuide.Viewer.MgThemeComponent</ClassName>
<Properties>
Modified: branches/2.4/MgDev/Desktop/MgAppLayout/SheboyganTiled.AppLayout
--- branches/2.4/MgDev/Desktop/MgAppLayout/SheboyganTiled.AppLayout 2012-10-03 14:07:01 UTC (rev 7066)
+++ branches/2.4/MgDev/Desktop/MgAppLayout/SheboyganTiled.AppLayout 2012-10-03 14:52:57 UTC (rev 7067)
@@ -1,6 +1,6 @@
+ <Title>MapGuide Desktop App Layout Example (Tiled Map)</Title>
<Settings>
<NameValue>
@@ -92,6 +92,11 @@
</ItemBase>
+ </ItemBase>
</ItemBase>
</ItemBase>
+ </ItemBase>
</ItemBase>
</ItemBase>
+ </ItemBase>
</Items>
</ItemBase>
</ItemBase>
+ </ItemBase>
</Items>
</TaskMenu>
</TaskPane>
+ <Properties>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ </Properties>
<Properties>
More information about the mapguide-commits
