[mapguide-commits] r7119 - in trunk/Tools/Maestro/SDK/Samples: . DrawMap DrawMap/Properties DwfInspector DwfInspector/Properties QueryFeatureSource QueryFeatureSource/Properties SchemaViewer SchemaViewer/Properties StandaloneWebLayoutEditor StandaloneWebLayoutEditor/Properties
svn_mapguide at osgeo.org
Tue Oct 16 04:09:52 PDT 2012
Author: jng
Date: 2012-10-16 04:09:52 -0700 (Tue, 16 Oct 2012)
New Revision: 7119
Added:
trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config
trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config
trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
trunk/Tools/Maestro/SDK/Samples/Samples.sln
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/MyResourceEditorService.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
#2138: Update SDK samples to VS2010
Property changes on: trunk/Tools/Maestro/SDK/Samples
___________________________________________________________________
Modified: svn:ignore
- Samples.suo
+ Samples.suo
Samples.sln.docstates.suo
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/DrawMap.csproj 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,5 +1,5 @@
<?xml version="1.0" encoding="utf-8"?>
-<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
@@ -10,8 +10,29 @@
<AppDesignerFolder>Properties</AppDesignerFolder>
<RootNamespace>DrawMap</RootNamespace>
<AssemblyName>DrawMap</AssemblyName>
- <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
<FileAlignment>512</FileAlignment>
+ <FileUpgradeFlags>
+ </FileUpgradeFlags>
+ <UpgradeBackupLocation>
+ </UpgradeBackupLocation>
+ <OldToolsVersion>3.5</OldToolsVersion>
+ <TargetFrameworkProfile />
+ <PublishUrl>publish\</PublishUrl>
+ <Install>true</Install>
+ <InstallFrom>Disk</InstallFrom>
+ <UpdateEnabled>false</UpdateEnabled>
+ <UpdateMode>Foreground</UpdateMode>
+ <UpdateInterval>7</UpdateInterval>
+ <UpdateIntervalUnits>Days</UpdateIntervalUnits>
+ <UpdatePeriodically>false</UpdatePeriodically>
+ <UpdateRequired>false</UpdateRequired>
+ <MapFileExtensions>true</MapFileExtensions>
+ <ApplicationRevision>0</ApplicationRevision>
+ <ApplicationVersion>1.0.0.%2a</ApplicationVersion>
+ <IsWebBootstrapper>false</IsWebBootstrapper>
+ <UseApplicationTrust>false</UseApplicationTrust>
+ <BootstrapperEnabled>true</BootstrapperEnabled>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<DebugSymbols>true</DebugSymbols>
@@ -74,7 +95,9 @@
<Compile Include="Properties\Resources.Designer.cs">
<AutoGen>True</AutoGen>
<DependentUpon>Resources.resx</DependentUpon>
+ <DesignTime>True</DesignTime>
</Compile>
+ <None Include="app.config" />
<None Include="Properties\Settings.settings">
<Generator>SettingsSingleFileGenerator</Generator>
<LastGenOutput>Settings.Designer.cs</LastGenOutput>
@@ -95,6 +118,23 @@
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
</ItemGroup>
+ <ItemGroup>
+ <BootstrapperPackage Include="Microsoft.Net.Client.3.5">
+ <Visible>False</Visible>
+ <ProductName>.NET Framework 3.5 SP1 Client Profile</ProductName>
+ <Install>false</Install>
+ </BootstrapperPackage>
+ <BootstrapperPackage Include="Microsoft.Net.Framework.3.5.SP1">
+ <ProductName>.NET Framework 3.5 SP1</ProductName>
+ <BootstrapperPackage Include="Microsoft.Windows.Installer.3.1">
+ <ProductName>Windows Installer 3.1</ProductName>
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Resources.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,17 +1,17 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4952
+// Runtime Version:4.0.30319.17929
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
-namespace DrawMap.Properties
+namespace DrawMap.Properties {
+ using System;
/// <summary>
/// A strongly-typed resource class, for looking up localized strings, etc.
/// </summary>
@@ -19,51 +19,43 @@
// class via a tool like ResGen or Visual Studio.
// To add or remove a member, edit your .ResX file then rerun ResGen
// with the /str option, or rebuild your VS project.
- [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
[global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
[global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
- internal class Resources
+ internal class Resources {
private static global::System.Resources.ResourceManager resourceMan;
private static global::System.Globalization.CultureInfo resourceCulture;
[global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
- internal Resources()
+ internal Resources() {
/// <summary>
/// Returns the cached ResourceManager instance used by this class.
/// </summary>
[global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
- internal static global::System.Resources.ResourceManager ResourceManager
- get
- if ((resourceMan == null))
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DrawMap.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// Overrides the current thread's CurrentUICulture property for all
/// resource lookups using this strongly typed resource class.
/// </summary>
- internal static global::System.Globalization.CultureInfo Culture
- get
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
return resourceCulture;
- set
+ set {
resourceCulture = value;
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Properties/Settings.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,28 +1,24 @@
// <auto-generated>
- [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
- internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "10.0.0.0")]
+ internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase {
private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
- public static Settings Default
- get
+ public static Settings Default {
+ get {
return defaultInstance;
Added: trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/app.config 2012-10-16 11:09:52 UTC (rev 7119)
@@ -0,0 +1,3 @@
+<?xml version="1.0"?>
+<configuration>
+<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/></startup></configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/DwfInspector.csproj 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,5 +1,5 @@
<PropertyGroup>
@@ -10,8 +10,29 @@
<RootNamespace>DwfInspector</RootNamespace>
<AssemblyName>DwfInspector</AssemblyName>
</PropertyGroup>
@@ -77,7 +98,9 @@
</Compile>
@@ -104,6 +127,23 @@
</Content>
</ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Resources.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,17 +1,17 @@
// <auto-generated>
-namespace DwfInspector.Properties
+namespace DwfInspector.Properties {
+ using System;
/// <summary>
/// </summary>
@@ -19,51 +19,43 @@
/// <summary>
/// </summary>
- get
+ get {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("DwfInspector.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// </summary>
- get
+ get {
- set
+ set {
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Properties/Settings.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,28 +1,24 @@
// <auto-generated>
- get
+ get {
Added: trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/app.config 2012-10-16 11:09:52 UTC (rev 7119)
@@ -0,0 +1,3 @@
+<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Resources.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,17 +1,17 @@
// <auto-generated>
-namespace QueryFeatureSource.Properties
+namespace QueryFeatureSource.Properties {
+ using System;
/// <summary>
/// </summary>
@@ -19,51 +19,43 @@
/// <summary>
/// </summary>
- get
+ get {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("QueryFeatureSource.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// </summary>
- get
+ get {
- set
+ set {
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Properties/Settings.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,28 +1,24 @@
// <auto-generated>
- get
+ get {
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/QueryFeatureSource.csproj 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,5 +1,5 @@
<PropertyGroup>
@@ -10,8 +10,29 @@
<RootNamespace>QueryFeatureSource</RootNamespace>
<AssemblyName>QueryFeatureSource</AssemblyName>
</PropertyGroup>
@@ -74,7 +95,9 @@
</Compile>
@@ -95,6 +118,23 @@
</Content>
</ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
Added: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/app.config 2012-10-16 11:09:52 UTC (rev 7119)
@@ -0,0 +1,3 @@
+<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/Samples.sln
--- trunk/Tools/Maestro/SDK/Samples/Samples.sln 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/Samples.sln 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
+Microsoft Visual Studio Solution File, Format Version 11.00
+# Visual Studio 2010
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "DrawMap", "DrawMap\DrawMap.csproj", "{30EA9CAC-7DFA-4434-87F4-0AB226F2D305}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "QueryFeatureSource", "QueryFeatureSource\QueryFeatureSource.csproj", "{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}"
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,17 +1,17 @@
// <auto-generated>
-namespace SchemaViewer.Properties
+namespace SchemaViewer.Properties {
+ using System;
/// <summary>
/// </summary>
@@ -19,51 +19,43 @@
/// <summary>
/// </summary>
- get
+ get {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("SchemaViewer.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// </summary>
- get
+ get {
- set
+ set {
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,28 +1,24 @@
// <auto-generated>
- get
+ get {
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,5 +1,5 @@
<PropertyGroup>
@@ -10,8 +10,29 @@
<RootNamespace>SchemaViewer</RootNamespace>
<AssemblyName>SchemaViewer</AssemblyName>
</PropertyGroup>
@@ -74,7 +95,9 @@
</Compile>
@@ -95,6 +118,23 @@
</Content>
</ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/app.config 2012-10-16 11:09:52 UTC (rev 7119)
@@ -0,0 +1,3 @@
+<configuration>
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/MyResourceEditorService.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/MyResourceEditorService.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/MyResourceEditorService.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -82,5 +82,10 @@
throw new NotImplementedException();
+ public override void RunProcess(string processName, params string[] args)
+ throw new NotImplementedException();
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Resources.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,17 +1,17 @@
// <auto-generated>
-// Runtime Version:2.0.50727.4959
-namespace StandaloneWebLayoutEditor.Properties
+namespace StandaloneWebLayoutEditor.Properties {
+ using System;
/// <summary>
/// </summary>
@@ -19,51 +19,43 @@
/// <summary>
/// </summary>
- get
+ get {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("StandaloneWebLayoutEditor.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// </summary>
- get
+ get {
- set
+ set {
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Properties/Settings.Designer.cs 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,28 +1,24 @@
// <auto-generated>
- get
+ get {
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj 2012-10-16 10:47:59 UTC (rev 7118)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/StandaloneWebLayoutEditor.csproj 2012-10-16 11:09:52 UTC (rev 7119)
@@ -1,5 +1,5 @@
<PropertyGroup>
@@ -10,8 +10,29 @@
<RootNamespace>StandaloneWebLayoutEditor</RootNamespace>
<AssemblyName>StandaloneWebLayoutEditor</AssemblyName>
</PropertyGroup>
@@ -75,7 +96,9 @@
</Compile>
@@ -96,6 +119,23 @@
</Content>
</ItemGroup>
+ <ItemGroup>
+ </ItemGroup>
Added: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/app.config 2012-10-16 11:09:52 UTC (rev 7119)
@@ -0,0 +1,3 @@
+<configuration>
More information about the mapguide-commits
