[mapguide-commits] r7120 - in trunk/Tools/Maestro/SDK/SamplesWeb: . SamplesWeb SamplesWeb/Tasks
svn_mapguide at osgeo.org
Tue Oct 16 04:27:11 PDT 2012
Author: jng
Date: 2012-10-16 04:27:09 -0700 (Tue, 16 Oct 2012)
New Revision: 7120
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb.sln
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
#2138: Update SDK web samples to VS2010. Also fix the "Add Tracks Layer" example
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs 2012-10-16 11:09:52 UTC (rev 7119)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Global.asax.cs 2012-10-16 11:27:09 UTC (rev 7120)
@@ -26,20 +26,11 @@
using System.Web.SessionState;
using OSGeo.MapGuide.ObjectModels;
-using Ldf110 = OSGeo.MapGuide.ObjectModels.LayerDefinition_1_1_0;
-using Ldf120 = OSGeo.MapGuide.ObjectModels.LayerDefinition_1_2_0;
-using Ldf130 = OSGeo.MapGuide.ObjectModels.LayerDefinition_1_3_0;
-using Lp110 = OSGeo.MapGuide.ObjectModels.LoadProcedure_1_1_0;
-using Lp220 = OSGeo.MapGuide.ObjectModels.LoadProcedure_2_2_0;
-using WL110 = OSGeo.MapGuide.ObjectModels.WebLayout_1_1_0;
-using Sym110 = OSGeo.MapGuide.ObjectModels.SymbolDefinition_1_1_0;
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
using OSGeo.MapGuide.MaestroAPI.Resource.Validation;
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ExtendedObjectModels;
namespace SamplesWeb
@@ -54,65 +45,10 @@
//This is our application's entry point, so we do this here.
+ //The ModelSetup utility class can auto-magically do this for us
//This is only necessary if you want to create resources newer than version 1.0.0
- //Layer Definition 1.1.0
- ResourceValidatorSet.RegisterValidator(new Ldf110.LayerDefinitionValidator());
- ResourceTypeRegistry.RegisterResource(
- new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.1.0"),
- new ResourceSerializationCallback(Ldf110.LdfEntryPoint.Serialize),
- new ResourceDeserializationCallback(Ldf110.LdfEntryPoint.Deserialize));
- ObjectFactory.RegisterLayerFactoryMethod(new Version(1, 1, 0), new LayerCreatorFunc(Ldf110.LdfEntryPoint.CreateDefault));
- //Layer Definition 1.2.0
- ResourceValidatorSet.RegisterValidator(new Ldf120.LayerDefinitionValidator());
- new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.2.0"),
- new ResourceSerializationCallback(Ldf120.LdfEntryPoint.Serialize),
- new ResourceDeserializationCallback(Ldf120.LdfEntryPoint.Deserialize));
- ObjectFactory.RegisterLayerFactoryMethod(new Version(1, 2, 0), new LayerCreatorFunc(Ldf120.LdfEntryPoint.CreateDefault));
- //Layer Definition 1.3.0
- ResourceValidatorSet.RegisterValidator(new Ldf130.LayerDefinitionValidator());
- new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.3.0"),
- new ResourceSerializationCallback(Ldf130.LdfEntryPoint.Serialize),
- new ResourceDeserializationCallback(Ldf130.LdfEntryPoint.Deserialize));
- ObjectFactory.RegisterLayerFactoryMethod(new Version(1, 3, 0), new LayerCreatorFunc(Ldf130.LdfEntryPoint.CreateDefault));
- //Load Procedure 1.1.0
- ResourceValidatorSet.RegisterValidator(new Lp110.LoadProcedureValidator());
- new ResourceTypeDescriptor(ResourceTypes.LoadProcedure, "1.1.0"),
- new ResourceSerializationCallback(Lp110.LoadProcEntryPoint.Serialize),
- new ResourceDeserializationCallback(Lp110.LoadProcEntryPoint.Deserialize));
- //Load Procedure 1.1.0 schema offers nothing new for the ones we want to support, so nothing to register
- //with the ObjectFactory
- //Load Procedure 2.2.0
- ResourceValidatorSet.RegisterValidator(new Lp220.LoadProcedureValidator());
- new ResourceTypeDescriptor(ResourceTypes.LoadProcedure, "2.2.0"),
- new ResourceSerializationCallback(Lp220.LoadProcEntryPoint.Serialize),
- new ResourceDeserializationCallback(Lp220.LoadProcEntryPoint.Deserialize));
- ObjectFactory.RegisterLoadProcedureFactoryMethod(LoadType.Sqlite, new LoadProcCreatorFunc(Lp220.LoadProcEntryPoint.CreateDefaultSqlite));
- //Web Layout 1.1.0
- ResourceValidatorSet.RegisterValidator(new WL110.WebLayoutValidator());
- new ResourceTypeDescriptor(ResourceTypes.WebLayout, "1.1.0"),
- new ResourceSerializationCallback(WL110.WebLayoutEntryPoint.Serialize),
- new ResourceDeserializationCallback(WL110.WebLayoutEntryPoint.Deserialize));
- ObjectFactory.RegisterWebLayoutFactoryMethod(new Version(1, 1, 0), new WebLayoutCreatorFunc(WL110.WebLayoutEntryPoint.CreateDefault));
- //Symbol Definition 1.1.0
- new ResourceTypeDescriptor(ResourceTypes.SymbolDefinition, "1.1.0"),
- new ResourceSerializationCallback(Sym110.SymbolDefEntryPoint.Serialize),
- new ResourceDeserializationCallback(Sym110.SymbolDefEntryPoint.Deserialize));
- ObjectFactory.RegisterCompoundSymbolFactoryMethod(new Version(1, 1, 0), new CompoundSymbolDefCreatorFunc(Sym110.SymbolDefEntryPoint.CreateDefaultCompound));
- ObjectFactory.RegisterSimpleSymbolFactoryMethod(new Version(1, 1, 0), new SimpleSymbolDefCreatorFunc(Sym110.SymbolDefEntryPoint.CreateDefaultSimple));
+ ModelSetup.Initialize();
protected void Session_Start(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2012-10-16 11:09:52 UTC (rev 7119)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2012-10-16 11:27:09 UTC (rev 7120)
@@ -1,4 +1,6 @@
-<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
@@ -10,7 +12,14 @@
<AppDesignerFolder>Properties</AppDesignerFolder>
<RootNamespace>SamplesWeb</RootNamespace>
<AssemblyName>SamplesWeb</AssemblyName>
- <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+ <FileUpgradeFlags>
+ </FileUpgradeFlags>
+ <UpgradeBackupLocation>
+ </UpgradeBackupLocation>
+ <OldToolsVersion>3.5</OldToolsVersion>
+ <TargetFrameworkProfile />
+ <UseIISExpress>false</UseIISExpress>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<DebugSymbols>true</DebugSymbols>
@@ -30,47 +39,28 @@
<WarningLevel>4</WarningLevel>
</PropertyGroup>
<ItemGroup>
+ <Reference Include="OSGeo.MapGuide.ExtendedObjectModels">
+ <HintPath>..\..\bin\OSGeo.MapGuide.ExtendedObjectModels.dll</HintPath>
+ </Reference>
<Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
<SpecificVersion>False</SpecificVersion>
<HintPath>..\..\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
</Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <SpecificVersion>False</SpecificVersion>
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.1.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.2.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.LayerDefinition-1.3.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.LayerDefinition-1.3.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.LoadProcedure-1.1.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.LoadProcedure-1.1.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.LoadProcedure-2.2.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.LoadProcedure-2.2.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.SymbolDefinition-1.1.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.SymbolDefinition-1.1.0.dll</HintPath>
- </Reference>
- <Reference Include="OSGeo.MapGuide.ObjectModels.WebLayout-1.1.0, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
- <HintPath>..\..\bin\OSGeo.MapGuide.ObjectModels.WebLayout-1.1.0.dll</HintPath>
- </Reference>
<Reference Include="System" />
<Reference Include="System.Data" />
+ <Reference Include="System.Data.DataSetExtensions" />
<Reference Include="System.Drawing" />
<Reference Include="System.Web" />
+ <Reference Include="System.Web.ApplicationServices" />
+ <Reference Include="System.Web.DynamicData" />
+ <Reference Include="System.Web.Entity" />
+ <Reference Include="System.Web.Extensions" />
<Reference Include="System.Xml" />
<Reference Include="System.Configuration" />
<Reference Include="System.Web.Services" />
<Reference Include="System.EnterpriseServices" />
<Reference Include="System.Web.Mobile" />
+ <Reference Include="System.Xml.Linq" />
</ItemGroup>
<ItemGroup>
<Content Include="..\..\bin\ConnectionProviders.xml">
@@ -191,8 +181,13 @@
<Folder Include="App_Data\" />
<Folder Include="bin\" />
</ItemGroup>
+ <PropertyGroup>
+ <VisualStudioVersion Condition="'$(VisualStudioVersion)' == ''">10.0</VisualStudioVersion>
+ <VSToolsPath Condition="'$(VSToolsPath)' == ''">$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v$(VisualStudioVersion)</VSToolsPath>
+ </PropertyGroup>
<Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
- <Import Project="$(MSBuildExtensionsPath)\Microsoft\VisualStudio\v9.0\WebApplications\Microsoft.WebApplication.targets" />
+ <Import Project="$(VSToolsPath)\WebApplications\Microsoft.WebApplication.targets" Condition="'$(VSToolsPath)' != ''" />
+ <Import Project="$(MSBuildExtensionsPath32)\Microsoft\VisualStudio\v10.0\WebApplications\Microsoft.WebApplication.targets" Condition="false" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
<Target Name="BeforeBuild">
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs 2012-10-16 11:09:52 UTC (rev 7119)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs 2012-10-16 11:27:09 UTC (rev 7120)
@@ -84,6 +84,7 @@
RuntimeMapLayer layer = mpSvc.CreateMapLayer(rtMap, layerDef);
layer.Group = groupName;
+ layer.Name = "Tracks";
layer.LegendLabel = "Tracks";
layer.ShowInLegend = true;
layer.ExpandInLegend = true;
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2012-10-16 11:09:52 UTC (rev 7119)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2012-10-16 11:27:09 UTC (rev 7120)
@@ -1,25 +1,24 @@
<?xml version="1.0"?>
<configuration>
- <appSettings>
- <add key="MapAgentUrl" value="http://localhost/mapguide/mapagent/mapagent.fcgi"/>
- </appSettings>
- <connectionStrings/>
- <system.web>
+ <appSettings>
+ <add key="MapAgentUrl" value="http://localhost/mapguide/mapagent/mapagent.fcgi"/>
+ </appSettings>
+ <connectionStrings/>
+ <system.web>
Set compilation debug="true" to insert debugging
symbols into the compiled page. Because this
affects performance, set this value to true only
during development.
- <compilation debug="true">
- </compilation>
+ <compilation debug="true" targetFramework="4.0"/>
The <authentication> section enables configuration
of the security authentication mode used by
ASP.NET to identify an incoming user.
- <authentication mode="Windows"/>
+ <authentication mode="Windows"/>
The <customErrors> section enables configuration
of what to do if/when an unhandled error occurs
during the execution of a request. Specifically,
@@ -31,5 +30,6 @@
<error statusCode="404" redirect="FileNotFound.htm" />
</customErrors>
- </system.web>
-</configuration>
+ <pages controlRenderingCompatibilityVersion="3.5" clientIDMode="AutoID"/>
+ </system.web>
+</configuration>
\ No newline at end of file
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb.sln
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb.sln 2012-10-16 11:09:52 UTC (rev 7119)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb.sln 2012-10-16 11:27:09 UTC (rev 7120)
@@ -1,6 +1,6 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
+Microsoft Visual Studio Solution File, Format Version 11.00
+# Visual Studio 2010
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SamplesWeb", "SamplesWeb\SamplesWeb.csproj", "{28A017F3-28C9-4C0F-BD7F-160DC4D1EB44}"
EndProject
Global
More information about the mapguide-commits
