[mapguide-commits] r7046 - trunk/Tools/Maestro/Maestro.Editors/WebLayout
svn_mapguide at osgeo.org
Tue Sep 25 06:55:10 PDT 2012
Author: jng
Date: 2012-09-25 06:55:10 -0700 (Tue, 25 Sep 2012)
New Revision: 7046
trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
#2112: Mono workarounds for the Web Layout editor
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs 2012-09-25 13:09:34 UTC (rev 7045)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs 2012-09-25 13:55:10 UTC (rev 7046)
@@ -38,14 +38,14 @@
public WebLayoutCommandsCtrl()
InitializeComponent();
- _commands = new BindingList<ICommand>();
+ _commands = new BindingList<CommandDecorator>();
grdCommands.DataSource = _commands;
private IWebLayout _wl;
private IEditorService _edsvc;
- private BindingList<ICommand> _commands;
+ private BindingList<CommandDecorator> _commands;
public override void Bind(IEditorService service)
@@ -56,7 +56,7 @@
//Populate command set
foreach (var cmd in _wl.CommandSet.Commands)
- _commands.Add(cmd);
+ _commands.Add(new CommandDecorator(cmd));
_commands.ListChanged += OnCommandSetListChanged;
@@ -79,7 +79,7 @@
case ListChangedType.ItemAdded:
- _wl.CommandSet.AddCommand(_commands[e.NewIndex]);
+ _wl.CommandSet.AddCommand(_commands[e.NewIndex].DecoratedInstance);
break;
@@ -137,7 +137,7 @@
btnExport.Enabled = customCmds.Length > 0;
- private void SetSelectedCommand(ICommand cmd)
+ private void SetSelectedCommand(CommandDecorator cmd)
grdCommands.ClearSelection();
foreach (DataGridViewRow row in grdCommands.Rows)
@@ -162,16 +162,18 @@
var cmd = _wl.CreateInvokeUrlCommand();
cmd.Description = cmd.Label = cmd.Tooltip = Strings.InvokeUrlCmdDescription;
- SetSelectedCommand(cmd);
+ var dec = new CommandDecorator(cmd);
+ _commands.Add(dec);
+ SetSelectedCommand(dec);
private void invokeScriptToolStripMenuItem_Click(object sender, EventArgs e)
var cmd = _wl.CreateInvokeScriptCommand();
cmd.Description = cmd.Label = cmd.Tooltip = Strings.InvokeScriptCmdDescription;
private void searchToolStripMenuItem_Click(object sender, EventArgs e)
@@ -184,8 +186,9 @@
var cmd = _wl.CreateSearchCommand();
cmd.Description = cmd.Label = cmd.Tooltip = Strings.SearchCmdDescription;
private void grdCommands_CellContentClick(object sender, DataGridViewCellEventArgs e)
@@ -199,11 +202,16 @@
var cmdCtrl = new CustomCommandPropertyCtrl();
cmdCtrl.Dock = DockStyle.Fill;
- cmdCtrl.Bind((ICommand)row.DataBoundItem, _edsvc);
- grpCommand.Controls.Add(cmdCtrl);
- EvaluateCommands();
+ //HACK: Mono workaround. It has problems with DataBoundItem
+ var dec = row.DataBoundItem as CommandDecorator;
+ if (dec != null)
+ ICommand cmd = dec.DecoratedInstance;
+ cmdCtrl.Bind(cmd, _edsvc);
+ grpCommand.Controls.Add(cmdCtrl);
+ EvaluateCommands();
@@ -225,57 +233,61 @@
if (grdCommands.SelectedRows.Count == 1)
- var iurl = grdCommands.SelectedRows[0].DataBoundItem as IInvokeUrlCommand;
- var iscr = grdCommands.SelectedRows[0].DataBoundItem as IInvokeScriptCommand;
- var srch = grdCommands.SelectedRows[0].DataBoundItem as ISearchCommand;
+ var cmd = grdCommands.SelectedRows[0].DataBoundItem as CommandDecorator;
+ if (cmd != null)
+ var iurl = cmd.DecoratedInstance as IInvokeUrlCommand;
+ var iscr = cmd.DecoratedInstance as IInvokeScriptCommand;
+ var srch = cmd.DecoratedInstance as ISearchCommand;
- WebLayoutRegion[] regions;
- if (iurl != null)
- if (_wl.IsCommandReferenced(iurl.Name, out regions))
+ WebLayoutRegion[] regions;
+ if (iurl != null)
- if (!Ask(Strings.DeleteCommand, string.Format(Strings.PromptDeleteCommand, GetAsString(regions, ", "))))
- return;
+ if (_wl.IsCommandReferenced(iurl.Name, out regions))
+ if (!Ask(Strings.DeleteCommand, string.Format(Strings.PromptDeleteCommand, GetAsString(regions, ", "))))
+ return;
- using (new WaitCursor(this))
- _wl.CommandSet.RemoveCommand(iurl);
- _commands.Remove(iurl);
- int deleted = _wl.RemoveAllReferences(iurl.Name);
- ClearCommandUI();
+ using (new WaitCursor(this))
+ _wl.CommandSet.RemoveCommand(iurl);
+ _commands.Remove(cmd);
+ int deleted = _wl.RemoveAllReferences(iurl.Name);
+ ClearCommandUI();
- else if (iscr != null)
- if (_wl.IsCommandReferenced(iscr.Name, out regions))
+ else if (iscr != null)
- return;
+ if (_wl.IsCommandReferenced(iscr.Name, out regions))
+ return;
- _wl.CommandSet.RemoveCommand(iscr);
- _commands.Remove(iscr);
- _wl.RemoveAllReferences(iscr.Name);
- ClearCommandUI();
+ _wl.CommandSet.RemoveCommand(iscr);
+ _wl.RemoveAllReferences(iscr.Name);
+ ClearCommandUI();
- else if (srch != null)
- if (_wl.IsCommandReferenced(srch.Name, out regions))
+ else if (srch != null)
- return;
+ if (_wl.IsCommandReferenced(srch.Name, out regions))
+ return;
- _wl.CommandSet.RemoveCommand(srch);
- _commands.Remove(srch);
- _wl.RemoveAllReferences(srch.Name);
- ClearCommandUI();
+ _wl.CommandSet.RemoveCommand(srch);
+ _wl.RemoveAllReferences(srch.Name);
+ ClearCommandUI();
@@ -305,7 +317,7 @@
List<string> selectedCmds = new List<string>();
foreach (DataGridViewRow row in grdCommands.SelectedRows)
- var cmd = (ICommand)row.DataBoundItem;
+ var cmd = ((CommandDecorator)row.DataBoundItem).DecoratedInstance;
var cmdType = cmd.GetType();
if (typeof(IInvokeScriptCommand).IsAssignableFrom(cmdType))
selectedCmds.Add(cmd.Name);
@@ -349,7 +361,7 @@
foreach (var imported in cmds)
ICommand cmd = _wl.GetCommandByName(imported.ImportedName);
if (imported.NameChanged)
sb.AppendLine(imported.ToString());
@@ -374,4 +386,139 @@
EvaluateCommands();
+ //HACK: Mono workaround for bugs due to binding to a BindingList of interfaces.
+ //So use a concrete decorator class that wraps the internal interface and bind to that
+ //instead
+ class CommandDecorator
+ private ICommand _cmd;
+ [Browsable(false)]
+ internal ICommand DecoratedInstance { get { return _cmd; } }
+ public CommandDecorator(ICommand cmd) { _cmd = cmd; }
+ public string Name
+ get
+ return _cmd.Name;
+ set
+ if (value != _cmd.Name)
+ _cmd.Name = value;
+ OnPropertyChanged("Name");
+ public string Label
+ get
+ return _cmd.Label;
+ set
+ if (value != _cmd.Label)
+ _cmd.Label = value;
+ OnPropertyChanged("Label");
+ public TargetViewerType TargetViewer
+ get
+ return _cmd.TargetViewer;
+ set
+ if (value != _cmd.TargetViewer)
+ _cmd.TargetViewer = value;
+ OnPropertyChanged("TargetViewer");
+ public string Tooltip
+ get
+ return _cmd.Tooltip;
+ set
+ if (value != _cmd.Tooltip)
+ _cmd.Tooltip = value;
+ OnPropertyChanged("Tooltip");
+ public string Description
+ get
+ return _cmd.Description;
+ set
+ if (value != _cmd.Description)
+ _cmd.Description = value;
+ OnPropertyChanged("Description");
+ public string ImageURL
+ get
+ return _cmd.ImageURL;
+ set
+ if (value != _cmd.ImageURL)
+ _cmd.ImageURL = value;
+ OnPropertyChanged("ImageURL");
+ public string DisabledImageURL
+ get
+ return _cmd.DisabledImageURL;
+ set
+ if (value != _cmd.DisabledImageURL)
+ _cmd.DisabledImageURL = value;
+ OnPropertyChanged("DisabledImageURL");
+ private void OnPropertyChanged(string propertyName)
+ var h = this.PropertyChanged;
+ if (h != null)
+ h(this, new PropertyChangedEventArgs(propertyName));
+ public event PropertyChangedEventHandler PropertyChanged;
More information about the mapguide-commits
