[mapguide-commits] r7047 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Tue Sep 25 07:25:21 PDT 2012
Author: jng
Date: 2012-09-25 07:25:20 -0700 (Tue, 25 Sep 2012)
New Revision: 7047
trunk/Tools/Maestro/Maestro/changelog.txt
beta 4 changelog update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2012-09-25 13:55:10 UTC (rev 7046)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2012-09-25 14:25:20 UTC (rev 7047)
@@ -1,5 +1,19 @@
-- New specialized error dialog for XML content errors, that shows the offending XML contnent.
+5.0 Beta 4
+- New "address bar" for Resource IDs, allowing for quick navigation and identiifcation of Resource IDs.
+- Layer Definition editor improvements:
+ - Add support for "exploding" themes into individual filtered sub-layers.
+ - Theme generation now considers active layer filter when generating rules
+ - Use GETLEGENDIMAGE for layer style previews
+- Symbol Definitions can now be previewed (via the GETLEGENDIMAGE API)
+- Resource IDs references in the Resource Properties Dialog can now be copied to the clipboard
+- New specialized error dialog for XML content errors, that shows the offending XML contnent.
- Streamlined localizable strings
+- Add context menu and shortcuts for common operations in Generic XML editor
+- RuntimeMap viewer improvements (ported from mg-desktop):
+ - Delayed tooltip queries
+ - Mouse interaction suppression when viewer is busy
- Live Map Definition Editor improvements
- Add a repository browser view. Layers selected can be added to the current map
- Move to a 3 pane interface (ala. AJAX viewer)
@@ -14,7 +28,8 @@
- Missing label in new fusion templates
- Fusion editor improvements
- Can view widget info in the Generic Widget XML editor
-- Theme generation now considers active layer filter when generating rules
+- Fix: Mono workaround for Web Layout editor
+- Fix: Mono workaround for .net 4.0 generated code involving SplitContainers
- Fix: Dirty state not properly raised for certain Web Layout properties
- Fix: Node color incorrectly set in Site Explorer for re-activated editors
- Fix: Updating a dynamic group name in a Map Definition did not update child groups
@@ -23,7 +38,10 @@
- Fix: Restore missing checkbox for toggling Tiled Layer Group visibility in a Map Definition
- Fix: Duplicating vector scale ranges not creating true clones
- Fix: Prevent Map Definition groups from being dragged and dropped into its child groups/layers
+- Fix: Renaming a Map Definition group did not update any child groups.
- Fix: Allow tiled layers to be moved between different tiled layer groups
+- Fix: Thread culture not transferred to background workers, resulting in english resources being returned if the background worker is doing localized resource lookups.
+- Fix: Cannot add top-level aliased raster files to a Composite Raster Feature Source
5.0 Beta 3
More information about the mapguide-commits
