[mapguide-commits] r7664 - in trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI: Mapping Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jul 6 09:46:47 PDT 2013
Author: jng
Date: 2013-07-06 09:46:47 -0700 (Sat, 06 Jul 2013)
New Revision: 7664
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/ITileService.cs
#1319: API doc cleanup
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2013-07-04 15:23:22 UTC (rev 7663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2013-07-06 16:46:47 UTC (rev 7664)
@@ -1621,7 +1621,7 @@
         /// <param name="selection"></param>
         /// <param name="format"></param>
         /// <param name="selectionColor"></param>
-        /// <param name="behaviour"></param>
+        /// <param name="behaviour">A bitmask for the rendering behaviour (1 = Render Selection, 2 = Render Layers, 4 = Keep Selection, 8 = Render Base Layers)</param>
         /// <returns></returns>
         public System.IO.Stream RenderDynamicOverlay(MapSelection selection, string format, Color selectionColor, int behaviour)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs	2013-07-04 15:23:22 UTC (rev 7663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IFeatureService.cs	2013-07-06 16:46:47 UTC (rev 7664)
@@ -93,112 +93,116 @@
         /// <summary>
         /// Executes a SQL query
         /// </summary>
-        /// <param name="featureSourceID"></param>
-        /// <param name="sql"></param>
-        /// <returns></returns>
+        /// <remarks>
+        /// No validation is done on the SQL query string. The calling application should validate the SQL string to ensure
+        /// that it does not contain any malicious operations.
+        /// </remarks>
+        /// <param name="featureSourceID">The Feature Source ID</param>
+        /// <param name="sql">The SQL query string</param>
+        /// <returns>A <see cref="T:OSGeo.MapGuide.MaestroAPI.Feature.IReader"/> containing the results of the query</returns>
         IReader ExecuteSqlQuery(string featureSourceID, string sql);
         /// <summary>
         /// Executes a feature query on the specified feature source
         /// </summary>
-        /// <param name="resourceID"></param>
-        /// <param name="className"></param>
-        /// <param name="filter"></param>
+        /// <param name="resourceID">The Feature Source ID</param>
+        /// <param name="className">The feature class name</param>
+        /// <param name="filter">The FDO filter string that determines what features will be returned</param>
+        /// <returns>A <see cref="T:OSGeo.MapGuide.MaestroAPI.Feature.IFeatureReader"/> containing the results of the query</returns>
         IFeatureReader QueryFeatureSource(string resourceID, string className, string filter);
         /// <summary>
         /// </summary>
         IFeatureReader QueryFeatureSource(string resourceID, string className);
         /// <summary>
         /// </summary>
-        /// <param name="propertyNames"></param>
+        /// <param name="propertyNames">A list of properties that are to be returned in the query result</param>
         IFeatureReader QueryFeatureSource(string resourceID, string className, string filter, string[] propertyNames);
         /// <summary>
         /// </summary>
-        /// <param name="schema"></param>
-        /// <param name="query"></param>
-        /// <param name="columns"></param>
-        /// <param name="computedProperties"></param>
-        IFeatureReader QueryFeatureSource(string resourceID, string schema, string query, string[] columns, NameValueCollection computedProperties);
+        /// <param name="computedProperties">A list of name/value pairs that contain the alias (name) for an FDO expression (value)</param>
+        IFeatureReader QueryFeatureSource(string resourceID, string className, string filter, string[] propertyNames, NameValueCollection computedProperties);
         /// <summary>
         /// Executes an aggregate query on the specified feature source
         /// </summary>
-        IReader AggregateQueryFeatureSource(string resourceID, string schema, string filter);
+        IReader AggregateQueryFeatureSource(string resourceID, string className, string filter);
         /// <summary>
         /// </summary>
-        IReader AggregateQueryFeatureSource(string resourceID, string schema, string filter, string[] columns);
+        /// <param name="propertyNames">An array of property names to include in the result</param>
+        IReader AggregateQueryFeatureSource(string resourceID, string className, string filter, string[] propertyNames);
         /// <summary>
         /// </summary>
-        /// <param name="aggregateFunctions"></param>
-        IReader AggregateQueryFeatureSource(string resourceID, string schema, string filter, NameValueCollection aggregateFunctions);
+        /// <param name="aggregateFunctions">A list of name/value pairs that contain the alias (name) for an FDO aggregate expression (value)</param>
+        IReader AggregateQueryFeatureSource(string resourceID, string className, string filter, NameValueCollection aggregateFunctions);
         /// <summary>
         /// Gets the geometric extent of the specified feature source
         /// </summary>
-        /// <param name="geometry"></param>
+        /// <param name="geometryPropertyName">The geometry property to get the geometric extent of</param>
-        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry);
+        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string className, string geometryPropertyName);
         /// <summary>
         /// </summary>
-        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, string filter);
+        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string className, string geometryPropertyName, string filter);
         /// <summary>
         /// </summary>
-        /// <param name="allowFallbackToContextInformation"></param>
+        /// <param name="allowFallbackToContextInformation">If true, the geometric extent of the feature class's spatial context will be used in the event that computing the extents fails</param>
         /// <exception cref="T:OSGeo.MapGuide.MaestroAPI.Exceptions.NullExtentException">Thrown if the geometric extent is null</exception>
-        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string schema, string geometry, bool allowFallbackToContextInformation);
+        ObjCommon.IEnvelope GetSpatialExtent(string resourceID, string className, string geometryPropertyName, bool allowFallbackToContextInformation);
         /// <summary>
         /// Describes the specified feature source
         /// </summary>
         /// <remarks>
         /// If you only need to list schemas and class names, use the respective <see cref="M:OSGeo.MapGuide.MaestroAPI.Services.IFeatureService.GetSchemas" /> and
         /// <see cref="M:OSGeo.MapGuide.MaestroAPI.Services.IFeatureService.GetClassNames" /> methods. Using this API will have a noticeable performance impact on
@@ -210,8 +214,8 @@
         /// <summary>
         /// </summary>
+        /// <param name="schema">The name of the schema to describe</param>
         /// <remarks>
@@ -237,7 +241,7 @@
         /// <summary>
         /// Gets the specified class definition
         /// </summary>
         /// <param name="className">The feature class name. You can pass a qualified class name to be explicit about which class definition you are after</param>
         ClassDefinition GetClassDefinition(string resourceID, string className);
@@ -245,15 +249,15 @@
         /// <summary>
         /// Get the spatial context information for the specified feature source
         /// </summary>
-        /// <param name="activeOnly"></param>
+        /// <param name="activeOnly">If true, will only return the active spatial context</param>
         ObjCommon.FdoSpatialContextList GetSpatialContextInfo(string resourceID, bool activeOnly);
         /// <summary>
         /// Gets the names of the identity properties from a feature
         /// </summary>
-        /// <param name="resourceID">The resourceID for the FeatureSource</param>
         /// <param name="classname">The classname of the feature, including schema</param>
         /// <returns>A string array with the found identities</returns>
         string[] GetIdentityProperties(string resourceID, string classname);
@@ -261,36 +265,36 @@
         /// <summary>
         /// Enumerates all the data stores and if they are FDO enabled for the specified provider and partial connection string
         /// </summary>
-        /// <param name="providerName"></param>
-        /// <param name="partialConnString"></param>
+        /// <param name="providerName">The FDO provider name</param>
+        /// <param name="partialConnString">The partial connection string. Certain providers require a partial conection string in order to be able to enumerate data stores</param>
         OSGeo.MapGuide.ObjectModels.Common.DataStoreList EnumerateDataStores(string providerName, string partialConnString);
         /// <summary>
         /// Gets an array of schema names from the specified feature source
         /// </summary>
-        /// <param name="resourceId"></param>
-        string[] GetSchemas(string resourceId);
+        string[] GetSchemas(string resourceID);
         /// <summary>
         /// Gets an array of qualified feature class names from the specified feature source
         /// </summary>
-        /// <param name="resourceId">The feature source id</param>
+        /// <param name="resourceID">The feature source id</param>
         /// <param name="schemaName">
         /// The name of the schema whose class names are to be returned. If null, class names from all schemas in the feature source
         /// are returned
         /// </param>
-        string[] GetClassNames(string resourceId, string schemaName);
+        string[] GetClassNames(string resourceID, string schemaName);
         /// <summary>
         /// Gets the long transactions for the specified feature source
         /// </summary>
         /// <param name="activeOnly">If true, will only return active long transactions</param>
-        ILongTransactionList GetLongTransactions(string resourceId, bool activeOnly);
+        ILongTransactionList GetLongTransactions(string resourceID, bool activeOnly);
         /// <summary>
         /// Gets the schema mappings for the given FDO provider. These mappings form the basis for a custom configuration document
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs	2013-07-04 15:23:22 UTC (rev 7663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs	2013-07-06 16:46:47 UTC (rev 7664)
@@ -94,6 +94,25 @@
         /// <summary>
         /// Creates a new runtime map instance from an existing map definition.
         /// </summary>
+        /// <remarks>
+        /// Calculation of meters-per-unit may differ between implementations. This may have an adverse
+        /// effect on things such as rendering and measuring depending on the underlying implementation
+        /// If you are certain of the meters-per-unit value required, use the overloaded method that
+        /// accepts a metersPerUnit parameter.
+        /// </remarks>
+        /// <example>
+        /// This example shows how to create a new runtime map instance
+        /// <code>
+        /// <![CDATA[
+        /// IServerConnection conn;
+        /// IMappingService mappingSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+        /// IMapDefinition mapDef = (IMapDefinition)conn.ResourceService.GetResource("Library://Path/To/My.MapDefinition");
+        /// RuntimeMap map = mappingSvc.CreateMap(mapDef);
+        /// </code>
+        /// </example>
         /// <param name="mapDef"></param>
         RuntimeMap CreateMap(IMapDefinition mapDef);
@@ -102,6 +121,19 @@
         /// Creates a new runtime map instance from an existing map definition. Meters per unit
         /// is calculated from the Coordinate System WKT of the map definition.
         /// </summary>
+        /// <example>
+        /// <code>
+        /// <![CDATA[
+        /// double metersPerUnit = 1.0;
+        /// RuntimeMap map = mappingSvc.CreateMap(mapDef, metersPerUnit);
+        /// </code>
+        /// </example>
         /// <param name="metersPerUnit"></param>
@@ -118,6 +150,20 @@
         /// </remarks>
+        /// <example>
+        /// <code>
+        /// <![CDATA[
+        /// string mapName = "MyMap";
+        /// string rtMapId = "Session:" + conn.SessionID + "//" + mapName + ".Map";
+        /// string baseMapDefId = "Library://Path/To/My.MapDefinition";
+        /// RuntimeMap map = mappingSvc.CreateMap(rtMapId, baseMapDefId);
+        /// </code>
+        /// </example>
         /// <param name="runtimeMapResourceId"></param>
         /// <param name="baseMapDefinitionId"></param>
@@ -126,6 +172,21 @@
         /// <summary>
         /// </summary>
+        /// <example>
+        /// <code>
+        /// <![CDATA[
+        /// </code>
+        /// </example>
@@ -143,6 +204,20 @@
         /// </remarks>
+        /// <example>
+        /// <code>
+        /// <![CDATA[
+        /// IMapDefinition mdf = (IMapDefinition)conn.ResourceService.GetResource("Library://Path/To/My.MapDefinition");
+        /// RuntimeMap map = mappingSvc.CreateMap(rtMapId, mdf);
+        /// </code>
+        /// </example>
         /// <param name="mdf"></param>
@@ -151,6 +226,21 @@
         /// <summary>
         /// </summary>
+        /// <example>
+        /// <code>
+        /// <![CDATA[
+        /// RuntimeMap map = mappingSvc.CreateMap(rtMapId, mdf, metersPerUnit);
+        /// </code>
+        /// </example>
@@ -160,6 +250,19 @@
         /// <summary>
         /// Opens an existing runtime map instance
         /// </summary>
+        /// <example>
+        /// This example shows how to open a RuntimeMap instance from a resource id
+        /// <code>
+        /// <![CDATA[
+        /// RuntimeMap map = mappingSvc.OpenMap(rtMapId);
+        /// </code>
+        /// </example>
         RuntimeMap OpenMap(string runtimeMapResourceId);
@@ -188,15 +291,38 @@
         /// <summary>
         /// Renders a dynamic overlay image of the map
         /// </summary>
+        /// <remarks>
+        /// The render base layers bitmask behaviour (8) is only supported from MapGuide Open Source 2.5 onwards
+        /// </remarks>
+        /// <example>
+        /// This example shows how to create a render a dynamic overlay image from a map and load it into a System.Drawing.Image
+        /// <code>
+        /// <![CDATA[
+        /// string format = "PNG";
+        /// Color selectionColor = Color.Blue;
+        /// int behaviour = 1 | 2 | 4;
+        /// using(Stream stream = mappingSvc.RenderDynamicOverlay(map, map.Selection, format, selectionColor, behaviour))
+        ///     Image img = Image.FromStream(stream);
+        /// </code>
+        /// </example>
         /// <param name="map">The runtime map instance</param>
         /// <param name="selection">The map selection</param>
         /// <param name="format">The image format</param>
         /// <param name="selectionColor">The color of the selection</param>
-        /// <param name="behaviour">The rendering behaviour</param>
         /// <exception cref="T:System.NotSupportedException">Thrown if the service is too old to be able to support this API</exception>
         System.IO.Stream RenderDynamicOverlay(RuntimeMap map, MapSelection selection, string format, Color selectionColor, int behaviour);
         /// <summary>
         /// Renders the runtime map.
         /// </summary>
@@ -303,7 +429,7 @@
         System.Drawing.Image GetLegendImage(double scale, string layerdefinition, int themeIndex, int type);
         /// <summary>
-        ///Renders a minature bitmap of the layers style
+        /// Renders a minature bitmap of the layers style
         /// </summary>
         /// <param name="scale">The scale for the bitmap to match</param>
         /// <param name="layerdefinition">The layer definition resource id</param>
@@ -316,14 +442,17 @@
         System.Drawing.Image GetLegendImage(double scale, string layerdefinition, int themeIndex, int type, int width, int height, string format);
         /// <summary>
-        /// Identifies features that meet the specified spatial selection criteria. These features can be persisted as selected features in a map. QueryMapFeatures returns an XML document describing the set of selected features. If a single feature is selected, the XML contains the tooltip, hyperlink, and properties of the feature.
+        /// Identifies features that meet the specified spatial selection criteria. These features can be persisted as selected features in a map.
+        /// This operation is generally used to implement selection/tooltip functionality for a client-side map viewer.
+        /// QueryMapFeatures returns an XML document describing the set of selected features.
+        /// If a single feature is selected, the XML contains the tooltip, hyperlink, and properties of the feature.
         /// </summary>
-        /// <param name="map"></param>
-        /// <param name="maxFeatures"></param>
-        /// <param name="wkt"></param>
-        /// <param name="persist"></param>
-        /// <param name="selectionVariant"></param>
-        /// <param name="extraOptions"></param>
+        /// <param name="map">The RuntimeMap instance</param>
+        /// <param name="maxFeatures">The maximum number of features to return</param>
+        /// <param name="wkt">The WKT of the filter geometry, specifying the selection area</param>
+        /// <param name="persist">Indicates whether the selection should be persisted as part of the map</param>
+        /// <param name="selectionVariant">The spatial operator to use against the selection geometry</param>
+        /// <param name="extraOptions">Extra options for controlling selection criteria</param>
         string QueryMapFeatures(RuntimeMap map, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs	2013-07-04 15:23:22 UTC (rev 7663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs	2013-07-06 16:46:47 UTC (rev 7664)
@@ -180,19 +180,19 @@
         /// Sets the resource data of a specified resource
         /// </summary>
         /// <remarks>For the HTTP implementation of this API, the input stream must be seekable</remarks>
-        /// <param name="resourceid"></param>
-        /// <param name="dataname"></param>
-        /// <param name="datatype"></param>
+        /// <param name="resourceID"></param>
+        /// <param name="dataName"></param>
+        /// <param name="dataType"></param>
         /// <param name="stream"></param>
         /// <param name="callback"></param>
-        void SetResourceData(string resourceid, string dataname, ObjCommon.ResourceDataType datatype, System.IO.Stream stream, Utility.StreamCopyProgressDelegate callback);
+        void SetResourceData(string resourceID, string dataName, ObjCommon.ResourceDataType dataType, System.IO.Stream stream, Utility.StreamCopyProgressDelegate callback);
         /// <summary>
         /// Sets the raw XML data of the specified resource
         /// </summary>
-        void SetResourceXmlData(string resourceid, System.IO.Stream stream);
+        void SetResourceXmlData(string resourceID, System.IO.Stream stream);
         /// <summary>
         /// Sets the header for the specified folder
@@ -211,9 +211,9 @@
         /// <summary>
         /// Updates the repository
         /// </summary>
         /// <param name="header"></param>
-        void UpdateRepository(string resourceId, ObjCommon.ResourceFolderHeaderType header);
+        void UpdateRepository(string resourceID, ObjCommon.ResourceFolderHeaderType header);
         /// <summary>
         /// Deletes the specified attached resource data
@@ -238,54 +238,54 @@
         /// <summary>
         /// Gets a listing of all resources dependent on the specified resource
         /// </summary>
-        ObjCommon.ResourceReferenceList EnumerateResourceReferences(string resourceid);
+        ObjCommon.ResourceReferenceList EnumerateResourceReferences(string resourceID);
         /// <summary>
         /// Copies the specified resource to the specified path
         /// </summary>
-        /// <param name="oldpath"></param>
-        /// <param name="newpath"></param>
+        /// <param name="oldResourceID"></param>
+        /// <param name="newResourceID"></param>
         /// <param name="overwrite"></param>
-        void CopyResource(string oldpath, string newpath, bool overwrite);
+        void CopyResource(string oldResourceID, string newResourceID, bool overwrite);
         /// <summary>
         /// Moves the specified resources to the specified path
         /// </summary>
-        void MoveResource(string oldpath, string newpath, bool overwrite);
+        void MoveResource(string oldResourceID, string newResourceID, bool overwrite);
         /// <summary>
         /// Moves the specified resources to the specified path. Any resources referencing this resource
         /// are updated to reference the resource's new location
         /// </summary>
         /// <param name="progress"></param>
-        bool MoveResourceWithReferences(string oldpath, string newpath, LengthyOperationCallBack callback, LengthyOperationProgressCallBack progress);
+        bool MoveResourceWithReferences(string oldResourceID, string newResourceID, LengthyOperationCallBack callback, LengthyOperationProgressCallBack progress);
         /// <summary>
         /// Copies the specified folder to the specified path. Any resources referencing this folder
         /// are updated to reference the resources's new location
         /// </summary>
-        bool CopyFolderWithReferences(string oldpath, string newpath, LengthyOperationCallBack callback, LengthyOperationProgressCallBack progress);
+        bool CopyFolderWithReferences(string oldResourceID, string newResourceID, LengthyOperationCallBack callback, LengthyOperationProgressCallBack progress);
         /// <summary>
         /// Gets whether the specified resource id exists
         /// </summary>
-        bool ResourceExists(string resourceid);
+        bool ResourceExists(string resourceID);
         /// <summary>
         /// Saves an object into the repository
@@ -296,29 +296,29 @@
         /// Saves an object into the repository using the specified resource id.
         /// </summary>
         /// <remarks>
-        /// The <paramref name="resourceid"/> parameter only instructs this method where to save the resource to. It does
+        /// The <paramref name="resourceID"/> parameter only instructs this method where to save the resource to. It does
         /// not modify the <see cref="P:IResource.ResourceID"/> property of the input resource does not get
         /// updated as a result of this operation.
         /// </remarks>
         /// <param name="resource">The object to save</param>
-        /// <param name="resourceid">The resourceId to save the object as</param>
-        void SaveResourceAs(IResource resource, string resourceid);
+        /// <param name="resourceID">The resourceId to save the object as</param>
+        void SaveResourceAs(IResource resource, string resourceID);
         /// <summary>
         /// Enumerates all unmanaged folders, meaning alias'ed folders
         /// </summary>
-        /// <param name="type">The type of data to return</param>
+        /// <param name="startpath">The path to retrieve the data from</param>
         /// <param name="filter">A filter applied to the items</param>
         /// <param name="recursive">True if the list should contains recursive results</param>
-        /// <param name="startpath">The path to retrieve the data from</param>
+        /// <param name="type">The type of data to return</param>
         /// <returns>A list of unmanaged data</returns>
         ObjCommon.UnmanagedDataList EnumerateUnmanagedData(string startpath, string filter, bool recursive, UnmanagedDataTypes type);
         /// <summary>
         /// Upload a MapGuide Package file to the server
         /// </summary>
-        /// <param name="filename">Name of the file to upload</param>
+        /// <param name="fileName">Name of the file to upload</param>
         /// <param name="callback">A callback argument used to display progress. May be null.</param>
-        void UploadPackage(string filename, Utility.StreamCopyProgressDelegate callback);
+        void UploadPackage(string fileName, Utility.StreamCopyProgressDelegate callback);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/ITileService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/ITileService.cs	2013-07-04 15:23:22 UTC (rev 7663)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/ITileService.cs	2013-07-06 16:46:47 UTC (rev 7664)
@@ -42,13 +42,13 @@
         /// <summary>
         /// Reads a tile from MapGuide
         /// </summary>
-        /// <param name="mapdefinition">A map with baselayergroups</param>
-        /// <param name="baselayergroup">The name of a baselayergroup</param>
-        /// <param name="col">The column index of the tile</param>
+        /// <param name="mapDefinition">A map with baselayergroups</param>
+        /// <param name="baseLayerGroup">The name of a baselayergroup</param>
+        /// <param name="column">The column index of the tile</param>
         /// <param name="row">The row index of the tile</param>
-        /// <param name="scaleindex">The scale index for the tile set</param>
+        /// <param name="scaleIndex">The scale index for the tile set</param>
         /// <param name="format">The format to return the tile in, either JPG, GIF, PNG or PNG8</param>
         /// <returns>An image stream</returns>
-        System.IO.Stream GetTile(string mapdefinition, string baselayergroup, int col, int row, int scaleindex, string format);
+        System.IO.Stream GetTile(string mapDefinition, string baseLayerGroup, int column, int row, int scaleIndex, string format);
More information about the mapguide-commits mailing list
