[mapguide-commits] r7665 - in trunk/MgDev/UnitTest/WebTier/DotNet: MgTestRunner TestCommon TestMapGuideApi
svn_mapguide at osgeo.org
Sat Jul 6 10:52:51 PDT 2013
Author: jng
Date: 2013-07-06 10:52:51 -0700 (Sat, 06 Jul 2013)
New Revision: 7665
trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonUtility.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
#2307: We are now down to 3 failures. These are all strictly issues relating to our binary comparison and/or pre-processing.
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2013-07-06 16:46:47 UTC (rev 7664)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2013-07-06 17:52:51 UTC (rev 7665)
@@ -74,6 +74,7 @@
//"validate" is currently the only test execution mode supported
exec.Initialize("validate", dumpFile);
ret += exec.Execute(ref testsRun, logger, isEnterprise);
+ exec.Cleanup();
return ret;
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonUtility.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonUtility.cs 2013-07-06 16:46:47 UTC (rev 7664)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonUtility.cs 2013-07-06 17:52:51 UTC (rev 7665)
@@ -5,6 +5,7 @@
using System.Globalization;
using System.IO;
using System.Linq;
+using System.Reflection;
using System.Text;
using System.Threading.Tasks;
using System.Xml;
@@ -161,9 +162,17 @@
public static string GetPath(string dbPath)
- return dbPath.Replace("\\", "/");
+ if (Path.IsPathRooted(dbPath))
+ return dbPath.Replace("\\", "/");
+ else
+ return Path.Combine(GetAssemblyPath(), dbPath).Replace("\\", "/");
+ private static string GetAssemblyPath()
+ return Path.GetDirectoryName(new Uri(Assembly.GetExecutingAssembly().CodeBase).LocalPath);
public static MgStringCollection StringToMgStringCollection(string str)
try
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2013-07-06 16:46:47 UTC (rev 7664)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2013-07-06 17:52:51 UTC (rev 7665)
@@ -461,7 +461,11 @@
public override void Cleanup()
+ foreach (var exec in _executors.Values)
+ exec.Dispose();
+ _executors.Clear();
public override string ApiType
More information about the mapguide-commits
