[mapguide-commits] r7576 - branches/2.4/MgDev/Desktop/MapViewer
svn_mapguide at osgeo.org
Fri Jun 7 02:04:00 PDT 2013
Author: jng
Date: 2013-06-07 02:04:00 -0700 (Fri, 07 Jun 2013)
New Revision: 7576
branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
#2248: The mg-desktop legend will still infinite loop on a background thread if we have groups not set to display in the legend. This submission handles this particular case.
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-06-07 09:00:51 UTC (rev 7575)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgLegendControlPresenter.cs 2013-06-07 09:04:00 UTC (rev 7576)
@@ -383,27 +383,27 @@
output.Add(node);
nodesById.Add(group.GetObjectId(), node);
- while (remainingNodes.Count > 0)
+ while (remainingNodes.Count > 0)
+ List<MgLayerGroup> toRemove = new List<MgLayerGroup>();
+ for (int j = 0; j < remainingNodes.Count; j++)
- List<MgLayerGroup> toRemove = new List<MgLayerGroup>();
- for (int j = 0; j < remainingNodes.Count; j++)
+ var parentId = remainingNodes[j].Group.GetObjectId();
+ if (nodesById.ContainsKey(parentId))
- var parentId = remainingNodes[j].Group.GetObjectId();
- if (nodesById.ContainsKey(parentId))
- var node = CreateGroupNode(remainingNodes[j]);
- nodesById[parentId].Nodes.Add(node);
- toRemove.Add(remainingNodes[j]);
+ var node = CreateGroupNode(remainingNodes[j]);
+ nodesById[parentId].Nodes.Add(node);
+ toRemove.Add(remainingNodes[j]);
- //Whittle down this list
- if (toRemove.Count > 0)
+ //Whittle down this list
+ if (toRemove.Count > 0)
+ foreach (var g in toRemove)
- foreach (var g in toRemove)
- remainingNodes.Remove(g);
+ remainingNodes.Remove(g);
@@ -499,34 +499,40 @@
node.Expand();
- while (remainingLayers.Count > 0)
+ while (remainingLayers.Count > 0)
+ List<MgLayerBase> toRemove = new List<MgLayerBase>();
+ for (int j = 0; j < remainingLayers.Count; j++)
- List<MgLayerBase> toRemove = new List<MgLayerBase>();
- for (int j = 0; j < remainingLayers.Count; j++)
+ var parentGroup = remainingLayers[j].Group;
+ var parentId = parentGroup.GetObjectId();
- var parentId = remainingLayers[j].Group.GetObjectId();
+ var node = CreateLayerNode(remainingLayers[j]);
+ if (node != null)
- var node = CreateLayerNode(remainingLayers[j]);
- if (node != null)
- if (remainingLayers[j].ExpandInLegend)
- node.Expand();
- toRemove.Add(remainingLayers[j]);
+ if (remainingLayers[j].ExpandInLegend)
+ node.Expand();
+ toRemove.Add(remainingLayers[j]);
+ else //Check parent group visibility. Could explain it
- remainingLayers.Remove(g);
+ if (!parentGroup.GetDisplayInLegend())
+ remainingLayers.Remove(g);
//Now expand any relevant groups
More information about the mapguide-commits
